    • simatec
      simatec Developer Most Active @JB_Sullivan last edited by
      @JB_Sullivan
      Mache mal folgendes...
      • In den Instanzen löschen
      • In Adapter löschen
      • backitup.0 in den Objekten löschen
      • iobroker neustarten
      • backitup über den weiter oben geposteten Github-Link installieren
      • backitup manuell einrichten (kein Restore der settings)
      • simatec
        Ab sofort steht die Version 1.6.9 auf Github und in Kürze auch im latest zum testen bereit.
        Changelog
        1.6.9 (30.09.2020)
        • (simatec) Timeout fix for backup process
        • JB_Sullivan
          JB_Sullivan @simatec last edited by JB_Sullivan
          @simatec
          "Holzhammer" Methode der Neuinstallation war leider auch nicht von Erfolg gekrönt. Habe jetzt schon die 1.6.9 aus dem GIT drauf und habe es so gemacht wie von dir beschrieben.
          Trotzdem noch: error: 30. September 2020 um 10:57 Uhr
          Output:
          [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"30. September 2020 um 10:57 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
          Im übrigen braucht man nach dem löschen der Instanz, die Objekte nicht mehr separat löschen. Die werden einfach gleich mit gelöscht wenn man die Instanz entfernt.
          Hat das ggf. etwas mit der Fehlermeldung während der Deinstallation zu tun?
          2020-09-30 10:45:13.749 - info: host.GLT(GLT) iobroker del backitup
          2020-09-30 10:45:15.322 - info: daswetter.0 (12624) Terminated (NO_ERROR): Without reason
          2020-09-30 10:45:15.866 - info: host.GLT(GLT) instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2020-09-30 10:45:16.652 - info: host.GLT(GLT) iobroker Delete adapter "backitup"
          2020-09-30 10:45:16.722 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 meta of backitup
          2020-09-30 10:45:16.731 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 adapter for backitup
          2020-09-30 10:45:16.817 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 states of system.adapter.backitup
          2020-09-30 10:45:19.307 - info: host.GLT(GLT) iobroker host.GLT(GLT) file backitup.admin deleted
          2020-09-30 10:45:19.316 - info: host.GLT(GLT) iobroker host.GLT(GLT) object backitup deleted
          2020-09-30 10:45:19.321 - info: host.GLT(GLT) iobroker host.GLT(GLT) object backitup.admin deleted
          2020-09-30 10:45:19.322 - info: host.GLT(GLT) iobroker host.GLT(GLT) Deleting 3 object(s).
          2020-09-30 10:45:19.391 - info: host.GLT(GLT) iobroker npm uninstall iobroker.backitup --error (System call)
          2020-09-30 10:45:20.298 - error: host.GLT(GLT) Cannot write files: C:\iobroker\GLT\iobroker-data\files\backitup.admin\_data.json: ENOENT: no such file or directory, open 'C:\iobroker\GLT\iobroker-data\files\backitup.admin\_data.json'
          2020-09-30 10:45:57.045 - info: host.GLT(GLT) iobroker npm
          2020-09-30 10:45:57.046 - info: host.GLT(GLT) iobroker WARN jscs-loader@0.3.0 requires a peer of jscs@^3.0.3 but none is installed. You must install peer dependencies yourself.
          2020-09-30 10:45:57.050 - info: host.GLT(GLT) iobroker npm
          2020-09-30 10:45:57.051 - info: host.GLT(GLT) iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules\fsevents):
          2020-09-30 10:45:57.054 - info: host.GLT(GLT) iobroker npm
          2020-09-30 10:45:57.056 - info: host.GLT(GLT) iobroker
          2020-09-30 10:45:57.057 - info: host.GLT(GLT) iobroker WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
          2020-09-30 10:45:57.060 - info: host.GLT(GLT) iobroker npm
          2020-09-30 10:45:57.063 - info: host.GLT(GLT) iobroker
          2020-09-30 10:45:57.064 - info: host.GLT(GLT) iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules\osx-temperature-sensor):
          2020-09-30 10:45:57.066 - info: host.GLT(GLT) iobroker npm
          2020-09-30 10:45:57.067 - info: host.GLT(GLT) iobroker
          2020-09-30 10:45:57.069 - info: host.GLT(GLT) iobroker WARN
          2020-09-30 10:45:57.070 - info: host.GLT(GLT) iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
          2020-09-30 10:45:57.071 - info: host.GLT(GLT) iobroker
          2020-09-30 10:45:58.183 - info: host.GLT(GLT) iobroker exit 0
          • simatec
            @JB_Sullivan
            In der Theorie sollten die Objekte gelöscht sein ...
            Was sagt dein Debug Log?
            Wie viele History-Einträge hast du in deine Config drin?
            Hast du mal ein iobroker fix laufen lassen?
            Wie sieht dein Softwarestand aus? node, nodejs, js-controller?
            • JB_Sullivan
              @simatec
              Es ist eine Windows Installation - also nix fix.
              History (DB) sind 5 - Historie Eintragungen sind 10
              Debug Log:
              Gestartet...
              [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
              [DEBUG] [iobroker] - host.GLT(GLT) 15691 states saved
              [DEBUG] [iobroker] - host.GLT(GLT) 17574 objects saved
              [DEBUG] [iobroker] - Backup created: C:\iobroker\GLT\backups\iobroker_2020_09_30-12_22_00_backupiobroker.tar.gz
              [DEBUG] [iobroker] - done
              [DEBUG] [historyDB] - Packed 2MB so far...
              [DEBUG] [historyDB] - Packed 11MB so far...
              [DEBUG] [historyDB] - Packed 20MB so far...
              [DEBUG] [historyDB] - Packed 28MB so far...
              [DEBUG] [historyDB] - Packed 38MB so far...
              [DEBUG] [historyDB] - Packed 50MB so far...
              [DEBUG] [historyDB] - Packed 62MB so far...
              [DEBUG] [historyDB] - done
              [DEBUG] [googledrive] - Google Drive: Copy iobroker_2020_09_30-12_22_00_backupiobroker.tar.gz...
              [DEBUG] [googledrive] start with {"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal","deleteBackupAfter":0}
              [DEBUG] [googledrive] - Google Drive: Copy historyDB_2020_09_30-12_22_17_backupiobroker.tar.gz...
              [DEBUG] [googledrive] - done
              [DEBUG] [clean] - done
              [DEBUG] [history] - backitup.0.history.html
              [DEBUG] [history] - backitup.0.history.json
              [EXIT] 0
              [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de","time":"30. September 2020 um 12:24 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
              Software Stände sind Admin, js-controller = latest
              simatec 2 Replies Last reply Reply Quote 0
              • simatec
                @JB_Sullivan
                Zeig mal bitte deine Config von backitup als json
                • JB_Sullivan
                  @simatec sagte in Test Adapter Backitup v1.6.x:
                  @JB_Sullivan
                  die finde ich wo? - iobroker-data\files\backitup.admin?
                    Kueppert @JB_Sullivan last edited by
                    @JB_Sullivan sagte in Test Adapter Backitup v1.6.x:
                    @JB_Sullivan
                    • JB_Sullivan
                      JB_Sullivan @Kueppert last edited by JB_Sullivan
                      @Kueppert
                      Vielen Dank - habe ich noch nie benutzt (benutzen müssen) 😉
                      system.adapter.backitup.0.json
                      F simatec 2 Replies Last reply Reply Quote 0
                        Frank_y @JB_Sullivan last edited by
                        @simatec
                        heute Nacht erneut fehlerlos mit 1.6.8 durchgelaufen.
                        Vielen Dank für intensive Unterstützung.
                        • simatec
                          @JB_Sullivan
                          Schalte mal in der Adapter Config Debug aus.
                          In den Instanzen aber bitte anlassen
                          • simatec
                            simatec Developer Most Active @JB_Sullivan last edited by simatec
                            @JB_Sullivan
                            Hast du auch wirklich die Reihenfolge eingehalten? Instanz löschen, Adapter löschen, prüfen ob alles aus den Objekten gelöscht ist, iobroker bzw. System neustarten und im Anschluss Backitup neu installieren und manuell konfigurieren.
                            Die Probleme hatten andere auch ab und an in der Vergangenheit.
                            Ich vermute es liegt an Fehlern bei irgendwelchen Updates im System ... aber kann es nicht lokalisieren.
                            Aber der Fehler war bei der von mir beschriebenen Reihenfolge im Anschluss weg.
                            https://forum.iobroker.net/post/392401
                            Auch ein Update von node und npm wäre ratsam
                            • JB_Sullivan
                              @simatec
                              Ist ja der Knaller - ich habe es eben noch einmal EXAKT so gemacht wie heute Mittag und wie von dir vorgegeben - nun ist der Error weg und im Output steht nur noch [Exit] 0.
                              Ist schon der Knaller - Ist die Error Meldung eigentlich nur ein textlicher Schönheitsfehler? In der historie json, stand ja trotz des Error - "Fehler - None".
                              Die Backup Dateien sind ja auch 1A erzeugt und gesichert worden.
                              • simatec
                                @JB_Sullivan
                                Nein es ist kein Schönheitsfehler.
                                Der Prozess bleibt beim erstellen des Historyeintrags hängen.
                                Warum das so ist, kann ich aktuell nicht erklären, da ich den Fehler nicht nachstellen kann.
                                Aber es muss irgendwas mit beschädigten Paketen/Abhängigkeiten zu tun haben.
                                Durch die komplette Neuinstallation werden die Pakete/Abhängigkeiten auch neu installiert und damit der Fehler behoben
                                • simatec
                                  Ab sofort ist auf Github und in kürze auch im latest die Version 1.7.0 verfügbar ...
                                  Changelog
                                  1.7.0 (26.10.2020)
                                  • (simatec) small Bugfix for umount on cifs/nfs mount
                                  • (simatec) Dev-Dependencies updated
                                  • (simatec) Dependencies updated
                                    eMd last edited by
                                    Sorry, jetzt hatte ich schon in einem anderen Thema gefragt.
                                    Beim zurückspielen meiner zigbee.tar bekomme ich folgende Fehlermeldung :
                                    Mache ich was falsch?
                                    MfG
                                    eMd
                                      eMd last edited by
                                      So, Problem gelöst. Habe die Sicherung per Hand nach /opt/iobroker/backup kopiert, danach ließ sie sich einwandfrei einspielen...
                                      MfG
                                      eMd
                                        Bibo*13 last edited by
                                        ich bin noch auf 1.6.9
                                        Seit einiger Zeit so etwa 2 Wochen werden die Daten im json DP immer als undefined angezeigt.
                                        Das Backup File wurde aber auf dem NAS(Fritz:NAS) geschrieben.
                                        Was könnte das sein? Bin für jeden Tipp dankbar!!
                                        [{"date":"31. Oktober 2020 um 10:34 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"31. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"30. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"29. Oktober 2020 um 10:10 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"29. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"28. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 12:53 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 09:02 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 07:11 Uhr","name":"iobroker_2020_10_27-07_11_24_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"7MB","error":"none"},{"date":"27. Oktober 2020 um 02:04 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 22:43 Uhr","name":"iobroker_2020_10_26-22_43_13_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"7MB","error":"none"},{"date":"26. Oktober 2020 um 22:32 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 22:20 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 16:20 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"25. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"24. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_24-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"23. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_23-02_00_22_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"22. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_22-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"21. Oktober 2020 um 13:43 Uhr","name":"iobroker_2020_10_21-13_43_19_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"21. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"20. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"19. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_19-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"18. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_18-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"17. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_17-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"}]
                                        • Meister Mopper
                                          Meister Mopper @Bibo*13 last edited by
                                          @Bibo-13 Obacht! Nach Update auf 1.7.0 musste ich im Adapter bei CCU-Backup das Kennwort neu eingeben, sonst lief das Backup nicht. Das ioBroker-Backup lief problemlos durch.
                                          B simatec H 3 Replies Last reply Reply Quote 0
                                            Bibo*13 @Meister Mopper last edited by
                                            @Meister-Mopper Danke sehr, aber bei mir ist es der IOBROKER Backup
                                            170
                                            2780
                                            2343748
