    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
      KleinesA @Adnim last edited by KleinesA
      @Adnim
      Hallo, ich habe jetzt umgestellt auf Energy (was den gesamten Verbrauch des Gerätes abbildet). Da wird aber der Energy Wert bei jedem Adapter Neustart auf die Messungen in SA addiert.
        Adnim @KleinesA last edited by
        @KleinesA
        Das hört sich irgendwie falsch an, ja...ein bug?
        • Dutchman
          Dutchman Developer Most Active Administrators @Adnim last edited by
          @Adnim sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
          @KleinesA
          Waehre neu
          @KleinesA sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
          Wird bei jedem Neustart vom Adapter der Wert von Energy addiert.
          zeig mal bitte die raw-daten des Objektes welches du loggen möchtest
            KleinesA @Dutchman last edited by
            @Dutchman
            hier die RAW Daten
              "from": "system.adapter.sourceanalytix.0",
              "user": "system.user.admin",
              "ts": 1601417928907,
              "common": {
                "name": "Energy",
                "type": "number",
                "role": "value.power",
                "unit": "Wh",
                "desc": "Created by linkeddevices",
                "def": 0,
                "read": true,
                "write": false,
                "custom": {
                  "linkeddevices.0": {
                    "enabled": true,
                    "parentId": "shelly.0.SHPLG-S#BBBB#1.Relay0.Energy",
                    "parentType": "number",
                    "isLinked": true,
                    "linkedId": "",
                    "name": "",
                    "role": "",
                    "mergeSettingsOnRestart": false,
                    "expertSettings": false,
                    "number_convertTo": "",
                    "number_unit": "",
                    "number_maxDecimal": "",
                    "number_min": "",
                    "number_max": "",
                    "number_calculation": "",
                    "number_calculation_readOnly": "",
                    "number_to_boolean_condition": "",
                    "number_to_boolean_value_true": "",
                    "number_to_boolean_value_false": "",
                    "number_to_string_condition": "",
                    "number_to_duration_convert_seconds": "",
                    "number_to_duration_format": "",
                    "number_to_datetime_convert_seconds": "",
                    "number_to_datetime_format": "",
                    "number_to_multi_condition": "",
                    "boolean_convertTo": "",
                    "boolean_to_string_value_true": "",
                    "boolean_to_string_value_false": "",
                    "string_convertTo": "",
                    "string_prefix": "",
                    "string_suffix": "",
                    "string_to_boolean_value_true": "",
                    "string_to_boolean_value_false": "",
                    "string_to_number_unit": "",
                    "string_to_number_maxDecimal": "",
                    "string_to_number_calculation": "",
                    "string_to_number_calculation_readOnly": "",
                    "string_to_duration_format": "",
                    "string_to_datetime_parser": "",
                    "string_to_datetime_format": ""
                  "sourceanalytix.0": {
                    "enabled": true,
                    "alias": "",
                    "selectedPrice": "Strom",
                    "selectedUnit": "automatisch",
                    "costs": true,
                    "consumption": false,
                    "meter_values": true,
                    "start_day": 0,
                    "start_week": 0,
                    "start_month": 0,
                    "start_quarter": 0,
                    "start_year": 0,
                    "valueAtDeviceReset": 0.144
                "icon": "linkeddevices_small.png"
              "native": {},
              "acl": {
                "object": 1636,
                "owner": "system.user.admin",
                "state": 1636
              "_id": "linkeddevices.0.Grundstueck.Haus.Esszimmer.Lampe.Energy",
              "type": "state"
            • Dutchman
              Dutchman Developer Most Active Administrators @KleinesA last edited by
              hier die RAW Daten
              stoppe mal bitte den adapter und schmeiße diesen Eintrag raus
              inclusief dem comma auf der Zeile davor und probiere 🙂
                @Dutchman
                Hab ich gemacht.
                Vor dem Start
                Nach dem Start
                Die Lampe ist gerade aus. Verbraucht keinen Strom.
                Und der Eintrag ist wieder drinnen mit einem anderen Wert. (0.432)
                  lolax last edited by
                  Unter Koste mit oder ohne Grundgebühr bleibt es immer bei ohne Grundgebühr. Ein Speichern mit Grundgebühr ist nicht möglich.
                  K Dutchman 2 Replies Last reply Reply Quote 0
                    Kueppert @lolax last edited by Kueppert
                    @lolax wurde hier schon mal erwähnt, ist m.E. noch nicht implementiert.
                    Oder einfach hier im Thread nach "Grundgebühr" suchen:
                    https://forum.iobroker.net/topic/31932/major-update-sourceanalytix-v0-4-7-beta-0-released/484
                    • Dutchman
                      Dutchman Developer Most Active Administrators @lolax last edited by
                      @lolax sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                      ist
                      @Kueppert sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                      • ostseereiter
                        ostseereiter @Dutchman last edited by
                        @Dutchman naja verpasst würde ich nicht sagen habe jetzt auch schon die Beta installiert hat sich aber nichts gebessert. ZB habe ich ein Datenpunkt erstellt wo ich täglich mein Stromverbrauch von der Wohnung eintrage. Screenshot (4).png
                        hier die RAW Daten
                          "ts": 1601046077309,
                          "common": {
                            "name": "Zähler_neu",
                            "role": "",
                            "type": "number",
                            "desc": "Manuell erzeugt",
                            "unit": "kWh",
                            "min": 0,
                            "max": 100000,
                            "def": 0,
                            "read": true,
                            "write": true,
                            "custom": {
                                "enabled": true,
                                "alias": "",
                                "state_type": "kWh_consumption",
                                "state_unit": "automatically",
                                "costs": true,
                                "consumption": true,
                                "meter_values": false,
                                "start_day": 13581,
                                "start_week": 1328,
                                "start_month": 1015,
                                "start_quarter": 0,
                                "start_year": 1358,
                                "valueAtDeviceReset": 135813591388,
                                "selectedPrice": "Wählen",
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636
                          "_id": "Meine_Geräte.0.Zähler_neu",
                          "type": "state"
                        die ausgabe zeigt dann diese Daten
                        dieses Daten zeigt dann der Adapter
                        also dann habe ich nochmal versucht einen neuen DATENPUNKT.
                        anzulegen da sieht es dann so aus.
                        dazu die RAW
                          "ts": 1600992079978,
                          "common": {
                            "name": "z1",
                            "role": "",
                            "type": "number",
                            "desc": "Manually created",
                            "unit": "kWh",
                            "min": 0,
                            "max": 10000,
                            "def": 0,
                            "read": true,
                            "write": true,
                            "custom": {
                                "enabled": true,
                                "alias": "",
                                "costs": true,
                                "start_day": 0,
                                "start_week": 0,
                                "start_month": 0,
                                "start_quarter": 0,
                                "start_year": 0
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636
                          "_id": "Meine_Geräte.0.z1",
                          "type": "state"
                        Ich weiß auch nicht weiter. Muss wohl wieder ein Blockly basteln für die Berechnung:
                        also 1418 * 0,28 = 397,04 dieses Ergebnis taucht nirgendswo auf.
                          KleinesA @KleinesA last edited by
                          @Dutchman eine Idee?
                            Michi_Pi last edited by
                            @Dutchman hatte auch das Problem wie @KleinesA. Mit dem "," hat es dann auch funktioniert, allerdings passen die Monate nicht.
                            Für den Oktober hat er auch nicht auf 0 zurückgesetzt. 😕
                            Glaub ich muss auch erst mal warten bis eine vernünftige Version erscheint.
                              Kueppert @Michi_Pi last edited by
                              @Michi_Pi sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                              Hi, ich würde an der Stelle empfehlen, den letzten Satz zu editieren. Auch wenns nicht so gemeint ist von dir, kommts bei Entwickler, der viel Freizeit in den Adapter investiert, mit Sicherheit nicht gut an und schmälert den tollen Einsatz den er zeigt 😉
                              Dutchman M 2 Replies Last reply Reply Quote 1
                              • Dutchman
                                Dutchman Developer Most Active Administrators @Kueppert last edited by Dutchman
                                Die ist da, aber genau wie n auto kannst dir fuer 1ne mille einen super Sportwagen kaufen man muss aber den Tankdeckel und Gaspedal richtig verwenden 😉
                                @Kueppert
                                danke
                                @Michi_Pi @ostseereiter
                                Es wuerde helfen das Thema und git zu lesen und zu verstehen was man falsch macht !......
                                    "def": 0,
                                https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/191
                                Mehr sage ich dazu jetzt mal nicht.... hat nix mit adapter sonder euren Datenpunkten zu tun 🙂
                                @KleinesA
                                Auch bei dir !!!!
                                    "def": 0,
                                zusätzlich musst du (sorry habe ich nicht erwähnt !) den jetzigen kumulierten wert auf 0 setzen nach der aenderung sonst sieht er das als letzten wert und zählt darauf weiter (genau das verhalten was du beschrieben hast)
                                • SA aus
                                • Bei objecten experten modus an
                                • Current_Reading auf 0 setzen
                                • wieder den previous raus
                                • und diese dev : 0 weck bitte !!!
                                DutchmanNL created this issue in iobroker-community-adapters/ioBroker.sourceanalytix
                                closed SourceState is set to default value at daily value reset #191
                                ostseereiter 1 Reply Last reply Reply Quote 0
                                • ostseereiter
                                  @Dutchman Habe den Link gelesen mit google-Übersetzer.Habe nichts gefunden was man falsch machen könnte wenn man einen Datenpunkt anlegt. Bin dazu halt zu doof.
                                    Kueppert @ostseereiter last edited by
                                    @ostseereiter schau mal in deinem Datenpunkt diesen Eintrag hier:
                                    Bedeutet, bei nem Reset fängt der mit dieser Zahl an zu zählen (mein Verständnis). Das muss auf "0".
                                      Michi_Pi @Kueppert last edited by
                                      @Kueppert @Dutchman natürlich war das nicht so gemeint! 🙂 Ich bin ja froh dass hier sich Leute die Zeit nehmen und daran entwickeln. Dafür ein großes Lob von mir.
                                      Zu dem Thema, ich hab den Issue gelesen und auch das "def" entfernt. Leider funktioniert es bei mir trotzdem nicht. Also die Tagesübergabe funktioniert, aber der Monatswechsel (gestern auf heute) hat nicht funktioniert. Hier wird kumuliert. Vielleicht haben ja mehr das Problem?
                                      Hier noch der Code: (und das verhalten ist bei allen das gleiche)
                                        "from": "system.adapter.shelly.0",
                                        "ts": 1601525063160,
                                        "common": {
                                          "name": "Energy",
                                          "type": "number",
                                          "unit": "Wh",
                                          "read": true,
                                          "write": false,
                                          "custom": {
                                              "enabled": true,
                                              "alias": "Büro_Zähler",
                                              "selectedPrice": "ElectricityDay",
                                              "selectedUnit": "Wh",
                                              "costs": true,
                                              "start_day": 16.837979999999998,
                                              "start_week": 0,
                                              "start_month": 0,
                                              "start_quarter": 0,
                                              "start_year": 0,
                                              "currentValue": 16.837979999999998,
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636
                                        "_id": "shelly.0.SHPLG-S#8042E0#1.Relay0.Energy",
                                        "type": "state"
                                      • Dutchman
                                        Dutchman Developer Most Active Administrators @ostseereiter last edited by Dutchman
                                        @ostseereiter sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                                        das steht doch eindeutig das der wert dev: 0 (also ein default wert) dafür sorgt das er jede nacht auf diesen default geschrieben wird ?
                                        Wie in allen Beispielen hier genannt, default wert rausschmeissen und das problem ist gelöst ......
                                        bei mir kumuliert da nix, sind deine startwerte richtig eingetragen ?
                                        Wen du heute nacht den dev nicht rausgenommen hattest, waren es um 0 Uhr 0 und dan kam dein wert also wird gefühlt kumuliert
                                        K M 2 Replies Last reply Reply Quote 0
                                          @Dutchman Erst einmal Danke für den Adapter und Deine Unterstützung.
                                          Ich SA gestoppt.
                                          Den Eintrag dev:0, habe ich entfernt.
                                          Dann SA für den mit linkeddevice erstellten DP deaktiviert.
                                          SA für den linkeddevice DP wieder aktiviert.
                                          Kontrolle ob dev:0 wieder da. War nicht da.
                                          Also SA gestartet.
                                          Dann SA gestoppt und wieder gestartet.
                                          Wieder sind alle Werte gedoppelt.
                                            "type": "state",
                                            "common": {
                                              "name": "Energy",
                                              "type": "number",
                                              "read": true,
                                              "write": false,
                                              "unit": "Wh",
                                              "custom": {
                                                  "enabled": true,
                                                  "parentId": "shelly.0.SHPLG-S#B86FCB#1.Relay0.Energy",
                                                  "isLinked": true,
                                                  "linkedId": "",
                                                  "name": "",
                                                  "role": "",
                                                  "number_unit": "",
                                                  "number_min": "",
                                                  "number_max": "",
                                                  "enabled": true,
                                                  "alias": "",
                                                  "costs": true,
                                                  "start_day": 0,
                                                  "start_week": 0,
                                                  "start_month": 0,
                                                  "start_quarter": 0,
                                                  "start_year": 0,
                                                  "valueAtDeviceReset": 0.082
                                              "icon": "linkeddevices_small.png",
                                            "native": {},
                                            "ts": 1601556237424,
                                            "_id": "linkeddevices.0.Grundstueck.Haus.Esszimmer.Spirallampe.Energy",
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                            Michi_Pi @Dutchman last edited by
                                            @Dutchman
                                            Ich hatte bei 0 angefangen, habe keine Startwerte eingetragen.
                                            Aktuell steht hier 0 bei Monatsbeginn, sollte eigentlich dann passen?
                                            Kann ich den Wert unter "Oktober" noch manuell anpassen?
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            356280
