    4. ioBroker soll Raspberry PI System Befehl ausführen
      Accu @Homoran last edited by
      @Homoran habe den iobroker fix laufen lassen und im custom_iobroker folgdende Zeile: iobroker ALL=(ALL) NOPASSWD: ALL
      (und alle möglichen Kombinationen) probiert. Leider kein Erfolg. Der EXEC Befehl im Blockly Script schaltet den pihole nicht 😞
        Accu @liv-in-sky last edited by
        @liv-in-sky ja der Raspi ist zugleich iobroker und pihole server. Der pihole adapter lässt sich irgendwie nicht installieren bei mir:
        gyp ERR! build error
        gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
        • iobroker.pi-hole@1.3.1updated 2 packages in 100.16s
          24 packages are looking for funding run npm fund for details
          upload [5] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
          upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/tsconfig.json tsconfig.json application/json
          upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
          upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
          upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
          upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
          process exited with code 0
        liv-in-sky AlCalzone Thomas Braun 3 Replies Last reply Reply Quote 0
          liv-in-sky @Accu last edited by liv-in-sky
          @Accu bei diesen fehlern bin ich nicht der richtige für die antworten
          wie hast du versucht, den adapter zu installieren - über admin oder console ?
            Homoran Global Moderator Administrators @Accu last edited by
            @Accu sagte in ioBroker soll Raspberry PI System Befehl ausführen:
            wie kommst du denn auf so etwas???
            • AlCalzone
              AlCalzone Developer @Accu last edited by AlCalzone
              + iobroker.pi-hole@1.3.1
              Das sieht doch aus als hätte es funktioniert! Der Wust an gyp-Errors kommt von einer optionalen Dependency, eines anderen Adapters. npm versucht es nur jedes Mal aufs Neue das zu installieren.
                Thomas Braun Most Active @Accu last edited by
                /usr/local/bin/node
                Riecht mal wieder stark nach versemmelter Node-Installation.
                Schau hier wie man das wieder gerade rückt:
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                Homoran A 2 Replies Last reply Reply Quote 0
                  @Thomas-Braun sagte in ioBroker soll Raspberry PI System Befehl ausführen:
                  oder einer ebenso versemmelten uralt-Installation
                  Thomas Braun A 2 Replies Last reply Reply Quote 0
                    @Homoran
                    Beides sollte man sich anschauen.
                      @liv-in-sky ja ich hatte den GitHub link in der Adminkonsole gepasted und habs von da aus zu installieren.
                        @Homoran ich hatte rumgelesen und diverse sachen probiert. Das war die "lockerste" Einstellung, die auch nix bringt.
                          @Homoran wie kommst du darauf? Die PI installation ist in der Tat schon älter. Ich hatte damals den ioBroker unter Jessi aufgesetzt und habe dann zu Jessi geupgraded. Ich wollte das aber alles nicht von komplett neu aufsetzen, da diverse Haussteuerungssachen auf dem PI laufen. Blöderweise klappt es irgendwie auch nicht dessen Speicherkarte zu klonen als Backup - aber das ist ein anderes Thema.
                            Accu @Thomas Braun last edited by
                            @Thomas-Braun said in ioBroker soll Raspberry PI System Befehl ausführen:
                            Hier mal die ein paar Versionsnummern von meiner Node installation:
                            v8.17.0
                            /usr/local/bin/node
                            v12.18.3
                            /usr/local/bin/npm
                            6.14.6
                            nodejs:
                            Installiert: 8.17.0-1nodesource1
                            Installationskandidat: 8.17.0-1nodesource1
                            Versionstabelle:
                            *** 8.17.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_8.x stretch/main armhf Packages
                            100 /var/lib/dpkg/status
                            8.11.1~dfsg-2~bpo9+1 500
                            500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                            4.8.2~dfsg-1 500
                            500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                              Thomas Braun Most Active @Accu last edited by Thomas Braun
                              @Accu
                              Ich würde da auf node12 gehen.
                              Und schauen, dass nodejs und node die gleiche Versionsnummer haben. Anleitung habe ich ja oben gepostet.
                              Im Moment ist da etwas Chaos bei dir drin.
                                v8.17.0
                                v8 wird nicht mehr unterstützt!
                                v12.18.3
                                noch eine zweite node-Installation??
                                  @Homoran sagte in ioBroker soll Raspberry PI System Befehl ausführen:
                                  Klar. Die 8er über den Paketmanager, die 12er von Hand in das System gedübelt.
                                    @Thomas-Braun sorry ich muss jetzt doch noch mal nachfragen. Bin leider nicht der Linux Profi.
                                    Ich hatte lange Zeit Jessi mit der ioBroker Installation und anderen Sachen (z.B. PiHole) auf dem Raspi laufen. Irgendwann bin ich von Jessi auf Stretch gegangen.
                                    Es schien alles noch zu funzen.
                                    Aus der Fix Anleitung werde ich leider nicht so ganz schlau draus.
                                    Hier nochmal meine Ausgangssituation:
                                    Pi:
                                    Linux Raspi 5.4.51-v7+ #1327 SMP Thu Jul 23 10:58:46 BST 2020 armv7l GNU/Linux
                                    Distribution:
                                    No LSB modules are available.
                                    Distributor ID: Raspbian
                                    Description: Raspbian GNU/Linux 9.13 (stretch)
                                    Release: 9.13
                                    Codename: stretch
                                    Meine Fragen:
                                    was ist der Unterschied zw. Node und Node.js?
                                    Was den Fix angeht sieht es ja so aus, als würden hier eher die Installationsorte: Node.js =/usr/bin vs. Node = /usr/local/bin angemahnt, statt die Versionsnumern selber.
                                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                    /usr/bin/nodejs
                                    v8.17.0
                                    /usr/local/bin/node
                                    v12.18.3
                                    /usr/local/bin/npm
                                    6.14.6
                                    nodejs:
                                    Versionstabelle:
                                    4.8.2~dfsg-1 500
                                    Muss ich eine Node Installation deinstallieren?
                                      Jein. Du solltest die Installation aus /usr/local/bin kratzen und dann den Paketmanager apt sauber aufsetzen und node/nodeJS dann daraus installieren.
                                      Wie man das macht? Siehe oben.
                                      Wenn nicht verstanden, konkret fragen.
                                      Die Versionsnummern von node / nodejs müssen am Ende gleich sein und in /usr/bin liegen.
                                      Und bitte Konsolenausgaben als Text in CodeTags c1ede93e-8e03-4b3f-97d0-e75e9edbe73b-image.png setzen. Liest sich besser.
                                        @Thomas-Braun hi Thomas, ich habe jetzt einmal nodejs (node) nach Anleitung hier aus dem Forum komplett deinstalliert und den Pi rebootet.
                                        (seltsamerweise lief ioBroker dann immer noch und auch der Script Adapter)
                                        Dann nach der Anleitung neu installiert.
                                        Das ganze schaut jetzt so aus:
                                        /usr/bin/nodejs
                                        v12.18.4
                                        /usr/local/bin/node
                                        v12.18.3
                                        /usr/local/bin/npm
                                        6.14.6
                                        nodejs:
                                          Installiert:           12.18.4-1nodesource1
                                          Installationskandidat: 12.18.4-1nodesource1
                                          Versionstabelle:
                                         *** 12.18.4-1nodesource1 500
                                                500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                                             4.8.2~dfsg-1 500
                                          klar!
                                          weil du die schief installierte Version nicht gelöscht hast
                                            @Accu Ist noch krumm.
                                            Der Kram aus /usr/local/bin muss gelöscht werden.
                                            blockly
                                            1500
