    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Разные ошибки
    Разные ошибки
    • Bluefox
      Bluefox last edited by
      ` > Из замечаний - некорректно работает поиск.
      Нашло 8 устройств - реально 15. `
      Как выглядит папка /mnt/1wire ? Или где там у тебя замонтировано.
        Haus last edited by
        @Bluefox:
        На гите:
        0.3.3 (2016-08-25)
        • (bluefox) custom poll interval for every sensor
        • (bluefox) fix list of sensors over ethernet more than 5 `
          Без чебокса, мастер подключен к серверу.
        ! inMem 2016-08-25 23:05:32.311 debug message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472155532267, q=0, from=system.adapter.admin.0, lc=1472155532267
        ! inMem 2016-08-25 23:05:32.293 debug message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472155532267, q=0, from=system.adapter.admin.0, lc=1472155532267
        ! owfs-0 2016-08-25 23:05:27.269 debug sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
        ! owfs-0 2016-08-25 23:05:27.268 error Cannot read dir: Invalid response for list [empty answer]
        ! owfs-0 2016-08-25 23:05:27.267 warn Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0
        ! owfs-0 2016-08-25 23:05:23.806 debug Connect to 192.168.1.11:4304
        ! inMem 2016-08-25 23:05:23.799 debug message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=192.168.1.11, port=4304, from=system.adapter.admin.0, ip=192.168.1.11, port=4304, id=13, ack=false, time
        ! megaesp-0 2016-08-25 23:05:16.788 debug Response for 192.168.1.20[all]: 117;123;255;temp:19.50/hum:80.70;temp:19.00;OFF;RGB;NC;NC;31
        ! megaesp-0 2016-08-25 23:05:16.769 debug getPortState http://192.168.1.20/sec/?cmd=all
        ! owfs-0 2016-08-25 23:05:04.845 debug sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
        ! owfs-0 2016-08-25 23:05:04.842 error Cannot read dir: Invalid response for list [empty answer]
        ! owfs-0 2016-08-25 23:05:04.839 warn Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0
        ! owfs-0 2016-08-25 23:05:01.310 debug Connect to 127.0.0.1:4304
        ! inMem 2016-08-25 23:05:01.304 debug message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=12, ack=false, time=14721
        ! inMem 2016-08-25 23:04:56.504 debug message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472155496459, q=0, from=system.adapter.admin.0, lc=1472155496459
        ! inMem 2016-08-25 23:04:56.495 debug message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472155496459, q=0, from=system.adapter.admin.0, lc=1472155496459
        ! owfs-0 2016-08-25 23:04:53.929 info starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.owfs
        ! owfs-0 2016-08-25 23:04:53.837 debug statesDB connected
        ! owfs-0 2016-08-25 23:04:53.817 debug objectDB connected
        ! host-Server1 2016-08-25 23:04:52.702 info instance system.adapter.owfs.0 started with pid 30470
        ! host-Server1 2016-08-25 23:04:50.741 info instance system.adapter.owfs.0 terminated with code 0 (OK)
        ! owfs-0 2016-08-25 23:04:50.720 info terminating
        ! host-Server1 2016-08-25 23:04:50.182 info stopInstance system.adapter.owfs.0 killing pid 29564
        ! host-Server1 2016-08-25 23:04:50.181 info stopInstance system.adapter.owfs.0
        ! host-Server1 2016-08-25 23:04:50.177 info object change system.adapter.owfs.0
        –force --logs
        root@Server1:/opt/iobroker# iobroker stop owfs
        Adapter "owfs.0 stopped.
        root@Server1:/opt/iobroker# node node_modules/iobroker.owfs/main.js --force --logs
        2016-08-25 23:53:59.435  - info: owfs.0 starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.owfs
        2016-08-25 23:54:24.315  - debug: inMem message  *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472158464267, q=0, from=system.adapter.admin.0, lc=1472158464267
        2016-08-25 23:54:26.874  - debug: inMem message  messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=16, ack=false, time=1472158466861, _id=36007437
        2016-08-25 23:54:26.880  - debug: owfs.0 Connect to 127.0.0.1:4304
        Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}]
        2016-08-25 23:54:30.349  - warn: owfs.0 Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}]
        2016-08-25 23:54:30.351  - error: owfs.0 Cannot read dir: Invalid response for list [empty answer]
        2016-08-25 23:54:30.354  - debug: owfs.0 sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
        2016-08-25 23:54:34.435  - debug: inMem message  *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1472158474389, q=0, from=system.adapter.admin.0, lc=1472158474389
        С чебоксом "локальный OWFS"
        • Bluefox
          Haus ну ты же стрелянный воробей. Там owserver почему-то шлёт странные ответы. Можешь посмотреть что там приходит в ответ:
          Line 277
          client.list = function (path, callback) {
                  this.send(path, null, OW_DIRALL).then(function (messages) {
                      var ret;
                      var str;
                      adapter.log.debug('Got ' + messages.length + ' packets'); // <================================= Check output
                      for (var m = 0; m < messages.length; m++) {
                          ret = messages[m].header ? messages[m].header.ret : -100;
                          adapter.log.debug(JSON.stringify(messages[m])); // <================================= Check output
                          if (messages[m].header && messages[m].header.payload > 0 && messages[m].header.ret >= 0) {
                              str = messages[m].payload;
                              break;
                      if (ret < 0) {
                          adapter.log.warn('Invalid response for list: ' + ret);
                          callback('Invalid response');
                          return;
                      if (!str) {
                          adapter.log.warn('Invalid response for list [empty answer]: ' + JSON.stringify(messages));
                          callback('Invalid response for list [empty answer]');
                          return;
                      str = str.substring(0, str.length - 1); // remove zero-char from end
                      callback(null, str.split(','));
                  }, function (error) {
                      callback(error);
          И подправить. 😉
            Haus last edited by
            @Bluefox:
            Line 277
                        var ret;
                        var str;
                                break;
                        if (ret < 0) {
                            return;
                        if (!str) {
                            return;
                        callback(error);
            И подправить. 😉 `
            root@Server1:/opt/iobroker# iobroker upload owfs
            got /opt/iobroker/node_modules/iobroker.owfs/admin
            upload [1] owfs.admin /opt/iobroker/node_modules/iobroker.owfs/admin/owfs.png owfs.png image/png
            upload [0] owfs.admin /opt/iobroker/node_modules/iobroker.owfs/admin/index.html index.html text/html
            root@Server1:/opt/iobroker# iobroker restart owfs
            Adapter "owfs.0 restarted.
            2016-08-26 01:16:47.660 - info: owfs.0 starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.owfs
            2016-08-26 01:17:16.807 - debug: inMem message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1472163436761, q=0, from=system.adapter.admin.0, lc=1472163436761
            2016-08-26 01:17:27.910 - debug: inMem message messagebox.system.adapter.owfs.0 messagebox.system.adapter.owfs.0 command=readdir, ip=127.0.0.1, port=4304, from=system.adapter.admin.0, ip=127.0.0.1, port=4304, id=19, ack=false, time=1472163447900, _id=36007443
            2016-08-26 01:17:27.916 - debug: owfs.0 Connect to 127.0.0.1:4304
            Got 4 packets
            2016-08-26 01:17:31.390 - debug: owfs.0 Got 4 packets
            2016-08-26 01:17:31.392 - debug: owfs.0 {"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload" :""}
            2016-08-26 01:17:31.393 - debug: owfs.0 {"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload" :""}
            2016-08-26 01:17:31.395 - debug: owfs.0 {"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload" :""}
            {"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD0400 00,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF7603 4B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}
            2016-08-26 01:17:31.396 - debug: owfs.0 {"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775}," payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28 .FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000 ,/3A.DB481E000000\u0000"}
            Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payloa d":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"paylo ad":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"s ize":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E07640 40000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483 B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}]
            2016-08-26 01:17:31.397 - warn: owfs.0 Invalid response for list [empty answer]: [{"header":{"version":0,"payload":-1,"ret":0,"cont rolflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"pa yload":""},{"header":{"version":0,"payload":-1,"ret":0,"controlflags":0,"size":0,"offset":0},"payload":""},{"header":{"version":0,"p ayload":272,"ret":0,"controlflags":32,"size":271,"offset":32775},"payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3 C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28.FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/ 28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000,/3A.DB481E000000\u0000"}]
            2016-08-26 01:17:31.399 - error: owfs.0 Cannot read dir: Invalid response for list [empty answer]
            2016-08-26 01:17:31.402 - debug: owfs.0 sendTo "readdir" to system.adapter.admin.0 from system.adapter.owfs.0
              jeorgep last edited by
              @Bluefox:
              Нашло 8 устройств - реально 15. Как выглядит папка /mnt/1wire ? Или где там у тебя замонтировано.
              ! root@art4:/opt/iobroker# ls -l /mnt/1wire drwxrwxrwx 1 root root 4096 сер 26 06:33 261DE49101000070 drwxrwxrwx 1 root root 4096 сер 26 06:33 268725A401000028 drwxrwxrwx 1 root root 4096 сер 26 06:33 26A9CA91010000F1 drwxrwxrwx 1 root root 4096 сер 26 06:33 26ECEA9101000097 drwxrwxrwx 1 root root 4096 сер 26 06:33 26F1EA9101000086 drwxrwxrwx 1 root root 4096 сер 26 06:33 280D1C2A05000057 drwxrwxrwx 1 root root 4096 сер 26 06:33 2834C84804000051 drwxrwxrwx 1 root root 4096 сер 26 06:33 283B42D805000049 drwxrwxrwx 1 root root 4096 сер 26 06:33 28799F74040000F0 drwxrwxrwx 1 root root 4096 сер 26 06:33 28864975040000EB drwxrwxrwx 1 root root 4096 сер 26 06:33 28B0A92A05000087 drwxrwxrwx 1 root root 4096 сер 26 06:33 28E5BC2A050000EC drwxrwxrwx 1 root root 4096 сер 26 06:33 29191D160000004F drwxrwxrwx 1 root root 4096 сер 26 06:33 29276E0C000000B1 drwxrwxrwx 1 root root 4096 сер 26 06:33 2945B70C000000B1 drwxr-xr-x 1 root root 4096 сер 22 08:12 alarm drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.1 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.2 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.3 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.4 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.5 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.6 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.7 drwxr-xr-x 1 root root 4096 сер 22 08:12 bus.8 drwxr-xr-x 1 root root 4096 сер 22 08:12 settings drwxrwxrwx 1 root root 4096 сер 26 06:33 simultaneous drwxr-xr-x 1 root root 4096 сер 22 08:12 statistics drwxr-xr-x 1 root root 4096 сер 22 08:12 structure drwxr-xr-x 1 root root 4096 сер 22 08:12 system drwxr-xr-x 1 root root 4096 сер 22 08:12 uncached !
              "version": "0.3.3"
              Found 8 sensors
              У меня восьмиканальный мастер DS2482-800
              Похоже оно посчитало каналы
              Внутри канальной папки:
              root@art4:/opt/iobroker# ls -l /mnt/1wire/bus.5
              drwxrwxrwx 1 root root 4096 сер 26 06:38 2834C84804000051
              drwxrwxrwx 1 root root 4096 сер 26 06:38 28B0A92A05000087
              drwxrwxrwx 1 root root 4096 сер 26 06:38 28E5BC2A050000EC
              drwxr-xr-x 1 root root 4096 сер 22 08:12 interface
              drwxrwxrwx 1 root root 4096 сер 26 06:38 simultaneous
              Наверное есть смысл считать лишь файлы, которые начинаются с двойки.
              Типа:
              ! root@art4:/opt/iobroker# ls /mnt/1wire | grep '^2' 261DE49101000070 268725A401000028 26A9CA91010000F1 26ECEA9101000097 26F1EA9101000086 280D1C2A05000057 2834C84804000051 283B42D805000049 28799F74040000F0 28864975040000EB 28B0A92A05000087 28E5BC2A050000EC 29191D160000004F 29276E0C000000B1 2945B70C000000B1 !
              • Bluefox
                @jeorgep:
                @Bluefox:
                "version": "0.3.3"
                Found 8 sensors
                Типа:
                ! root@art4:/opt/iobroker# ls /mnt/1wire | grep '^2' 261DE49101000070 268725A401000028 26A9CA91010000F1 26ECEA9101000097 26F1EA9101000086 280D1C2A05000057 2834C84804000051 283B42D805000049 28799F74040000F0 28864975040000EB 28B0A92A05000087 28E5BC2A050000EC 29191D160000004F 29276E0C000000B1 2945B70C000000B1 ! `
                А у меня например все начинаются с 02, а ещё есть "-" или "." в имени. Вот я и отфильтровал все сенсоры с точкой.
                Надо найти правило, как можно распознать сенсоры. А пока я просто уберу любые фильтры.
                  Haus last edited by
                  @Bluefox:
                  @jeorgep:
                  @Bluefox:
                  Надо найти правило, как можно распознать сенсоры. А пока я просто уберу любые фильтры. `
                  ls -l /mnt/1wire
                  ! root@Server1:~# ls -l /mnt/1wire
                  ! итого 0
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 10.DB1979020800
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.1C8D2D050000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.3C3B63040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.3E0764040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.6659CE040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.ECB1CD040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FF1C154A0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FF3E484E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FF76034B0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FF7B414E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FFC1674E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FFE6574E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 28.FFF2054A0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 3A.483B1E000000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 3A.DB481E000000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 3A.E6331E000000
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 alarm
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 bus.1
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 settings
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:05 simultaneous
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 statistics
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 structure
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 system
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 uncached
                  ! root@Server1:~#
                  ls -l /mnt/1wire/bus.1
                  ! root@Server1:~# ls -l /mnt/1wire/bus.1
                  ! итого 0
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 10.DB1979020800
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.1C8D2D050000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.3C3B63040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.3E0764040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.6659CE040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.ECB1CD040000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FF1C154A0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FF3E484E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FF76034B0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FF7B414E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FFC1674E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FFE6574E0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 28.FFF2054A0400
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 3A.483B1E000000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 3A.DB481E000000
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 3A.E6331E000000
                  ! drwxr-xr-x 1 root root 4096 авг 26 02:10 interface
                  ! drwxrwxrwx 1 root root 4096 авг 26 09:09 simultaneous
                    @Haus:
                    @Bluefox:
                    @jeorgep: `
                    ls -l /mnt/1wire
                    ! итого 0
                    ! root@Server1:~#
                    ! итого 0
                    ! drwxrwxrwx 1 root root 4096 авг 26 09:09 simultaneous `
                    Можна, например, так:
                    (здесь мои и Haus'a находятся. Тире не ставил, ибо не знаю в каком месте оно может быть)
                    • Bluefox
                      @Haus:
                      Got 4 packets
                      2016-08-26 01:17:31.396 - debug: owfs.0 {"header":{"version":0,"payload":272,"ret":0,"controlflags":32,"size":271,"offset":32775}," payload":"/10.DB1979020800,/28.ECB1CD040000,/28.1C8D2D050000,/28.3C3B63040000,/28.6659CE040000,/28.3E0764040000,/28.FF1C154A0400,/28 .FFF2054A0400,/28.FFE6574E0400,/28.FF76034B0400,/28.FF3E484E0400,/28.FFC1674E0400,/28.FF7B414E0400,/3A.483B1E000000,/3A.E6331E000000 ,/3A.DB481E000000\u0000"} `
                      У тебя точно такой код? Примерно строка 283
                                          break;
                      Ну не может там такой ответ получатся.
                      • Bluefox
                        @jeorgep:
                        @Haus:
                        @Bluefox:
                        ls -l /mnt/1wire
                        ! итого 0
                        ! root@Server1:~#
                        ! итого 0
                        (здесь мои и Haus'a находятся. Тире не ставил, ибо не знаю в каком месте оно может быть) `
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 ./
                        drwxr-xr-x 4 root root 4096 Aug 23 15:49 ../
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 05.3158A35A255D/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 05.4AEC29CDBAAB/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 05.765A2E63339F/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 05.C99A66320DB7/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 10.051758E95ED4/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 10.213DDC8770E9/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 10.54110E827441/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 10.67C6697351FF/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 10.ABB2CDC69BB4/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 3A.F2FBE3467CC2/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 alarm/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 bus.0/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 ED.54F81BE8E78D/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 settings/
                        drwxrwxrwx 1 root root 4096 Aug 24 11:36 simultaneous/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 statistics/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 structure/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 system/
                        drwxr-xr-x 1 root root 4096 Aug 24 11:36 uncached/
                          @Bluefox:
                          @jeorgep:
                          @Haus:
                          ls -l /mnt/1wire
                          ! итого 0
                          ! root@Server1:~#
                          ! итого 0
                          эти тоже находятся верно правилом: ([\dA-F]){2,}[.\dA-F]{1,}([\dA-F]){12,}
                            Haus last edited by
                            @Bluefox:
                            Line 277
                                        var ret;
                                        var str;
                                                break;
                                        if (ret < 0) {
                                            return;
                                        if (!str) {
                                            return;
                                        callback(error);
                            И подправить. 😉 `
                            Я не понял, пере залил сегодня с гита с убранным фильтром и работает поиск без чебокса 😮
                            Но при этом запустился ещё один owsf.0
                            root@Server1:/opt/iobroker# ps ax | grep owfs
                              482 ?        Ssl    0:14 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/run/owfs/owserver.pid
                              499 ?        Ss     0:00 /usr/bin/owhttpd -c /etc/owfs.conf --pid-file /var/run/owfs/owhttpd.pid
                              501 ?        Ssl    0:00 /usr/bin/owftpd -c /etc/owfs.conf --pid-file /var/run/owfs/owftpd.pid
                              519 ?        Ssl    0:00 /usr/lib/owfs/owfs -c /etc/owfs.conf
                             5649 ?        Rl     0:56 io.owfs.0
                             6424 pts/0    S+     0:00 grep owfs
                              482 ?        Ss     1:25 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/run/owfs/owserver.pid
                             4724 ?        Sl     0:02 io.owfs.0
                             4831 pts/0    S+     0:00 grep owfs
                             5649 ?        Rl   193:55 io.owfs.0
                              482 ?        Ssl    1:27 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/run/owfs/owserver.pid
                             4853 ?        Rl     0:23 io.owfs.0
                             5325 pts/0    S+     0:00 grep owfs
                             5649 ?        Rl   195:10 io.owfs.0
                              482 ?        Ssl    1:28 /usr/bin/owserver -c /etc/owfs.conf --pid-file /var/run/owfs/owserver.pid
                             4853 ?        Rl     1:08 io.owfs.0
                             5649 ?        Rl   195:55 io.owfs.0
                             5890 pts/0    S+     0:00 grep owfs
                              Haus last edited by
                              @Bluefox:
                              @jeorgep:
                              @Bluefox:
                              Вот у конкурентов в коде, я так понимаю папки которые всегда присутствуют отбрасывают. Я у себя вернул фильтр и драйвер находит на один больше, это оказывается папка /simultaneous.
                              function scanDevices() {
                              if (!defined('ONEWIRE_SERVER')) {
                              return 0;
                              $ow=new OWNet(ONEWIRE_SERVER);
                              $tmp=$ow->get("/",OWNET_MSG_DIR,false);
                              if (!$tmp) {
                              return 0;
                              $devices=explode(',', $tmp);
                              $total=count($devices);
                              for($i=0;$i<$total;$i++) {
                              ! if (
                              $devices[$i]=='/alarm' ||
                              $devices[$i]=='/structure' ||
                              $devices[$i]=='/system' ||
                              $devices[$i]=='/settings' ||
                              $devices[$i]=='/uncached' ||
                              $devices[$i]=='/simultaneous' ||
                              $devices[$i]=='/statistics' ||
                              preg_match('/bus.\d+$/', $devices[$i]) ||
                              0
                              continue;
                              $udid=preg_replace('/^//', '', $devices[$i]);
                              $rec=SQLSelectOne("SELECT * FROM owdevices WHERE UDID='".$udid."'");
                              if (!$rec['ID']) {
                              $rec['UDID']=$udid;
                              $rec['TITLE']=$rec['UDID'];
                              $rec['STATUS']=1;
                              $rec['ONLINE_INTERVAL']=60*60;
                              $rec['LOG']=date('Y-m-d H:i:s').' Added';
                              $rec['ID']=SQLInsert('owdevices', $rec);
                              $this->updateDevice($rec['ID']);
                              if ($parse_php_type && $get_type!=OWNET_MSG_DIR_ALL){
        $tmp            =explode('/',$path);$c=count($tmp)-1;
        if ($c>0){              // must be something like '/dir/file'   array('dir', 'file'), count()-1 = 1 > 0
        $variavel       =$tmp[$c];              // get last two uri args
        $ow             =$tmp[$c-1];
        unset($tmp);
        if (preg_match('/([0-9A-F]{2})[\.]{0,1}[0-9A-F]{12}/',$ow,$tmp)){       // check if ow is an OW id ("XX.ZZZZZZZZZZZZ $
        $tmp=$tmp[1];
        if (!isset($OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel])){ // check if we have structure information
        $tmp_v=@$this->get("/structure/$tmp/$variavel",OWNET_MSG_READ,false,false);     // get estrutucture i$
        if ($tmp_v!==NULL){
        $tmp_v=explode(',',$tmp_v);                                             // ok :D we will get $
        $OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel]=$tmp_v;
        $type=$tmp_v;
        }else
        $type=$OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel];
        unset($tmp,$tmp_v,$variavel,$ow,$c);
                                @Haus:
                                @Bluefox:
                                @jeorgep: `
                                ! function scanDevices() {
                                ! if (!defined('ONEWIRE_SERVER')) {
                                ! return 0;
                                ! $ow=new OWNet(ONEWIRE_SERVER);
                                ! $tmp=$ow->get("/",OWNET_MSG_DIR,false);
                                ! if (!$tmp) {
                                ! return 0;
                                ! $devices=explode(',', $tmp);
                                ! $total=count($devices);
                                ! for($i=0;$i<$total;$i++) {
                                ! if (
                                ! $devices[$i]=='/alarm' ||
                                ! $devices[$i]=='/structure' ||
                                ! $devices[$i]=='/system' ||
                                ! $devices[$i]=='/settings' ||
                                ! $devices[$i]=='/uncached' ||
                                ! $devices[$i]=='/simultaneous' ||
                                ! $devices[$i]=='/statistics' ||
                                ! preg_match('/bus.\d+$/', $devices[$i]) ||
                                ! 0
                                ! continue;
                                ! $udid=preg_replace('/^//', '', $devices[$i]);
                                ! $rec=SQLSelectOne("SELECT * FROM owdevices WHERE UDID='".$udid."'");
                                ! if (!$rec['ID']) {
                                ! $rec['UDID']=$udid;
                                ! $rec['TITLE']=$rec['UDID'];
                                ! $rec['STATUS']=1;
                                ! $rec['ONLINE_INTERVAL']=60*60;
                                ! $rec['LOG']=date('Y-m-d H:i:s').' Added';
                                ! $rec['ID']=SQLInsert('owdevices', $rec);
                                ! $this->updateDevice($rec['ID']);
                                ! if ($parse_php_type && $get_type!=OWNET_MSG_DIR_ALL){
                                ! $tmp =explode('/',$path);$c=count($tmp)-1;
                                ! if ($c>0){ // must be something like '/dir/file' array('dir', 'file'), count()-1 = 1 > 0
                                ! $variavel =$tmp[$c]; // get last two uri args
                                ! $ow =$tmp[$c-1];
                                ! unset($tmp);
                                ! if (preg_match('/([0-9A-F]{2})[.]{0,1}[0-9A-F]{12}/',$ow,$tmp)){ // check if ow is an OW id ("XX.ZZZZZZZZZZZZ $
                                ! $tmp=$tmp[1];
                                ! if (!isset($OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel])){ // check if we have structure information
                                ! $tmp_v=@$this->get("/structure/$tmp/$variavel",OWNET_MSG_READ,false,false); // get estrutucture i$
                                ! if ($tmp_v!==NULL){
                                ! $tmp_v=explode(',',$tmp_v); // ok 😄 we will get $
                                ! $OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel]=$tmp_v;
                                ! $type=$tmp_v;
                                ! }else
                                ! $type=$OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel];
                                ! unset($tmp,$tmp_v,$variavel,$ow,$c);
                                строка:
                                Не будет находить моих датчиков.
                                Необходимо как я писал выше:
                                if (preg_match('/([0-9A-F]{2})[.\dA-F]{0,1}[0-9A-F]{12}/',$ow,$tmp)){
                                Странно, она не совпадает с данным регулярным выражением
                                  Haus last edited by
                                  @jeorgep:
                                  @Haus:
                                  @Bluefox:
                                  ! return 0;
                                  ! if (!$tmp) {
                                  ! return 0;
                                  ! if (
                                  ! 0
                                  ! continue;
                                  ! $rec['STATUS']=1;
                                  ! $ow =$tmp[$c-1];
                                  ! unset($tmp);
                                  ! $tmp=$tmp[1];
                                  ! $type=$tmp_v;
                                  ! }else
                                  строка:
                                  Странно, она не совпадает с данным регулярным выражением `
                                  Я её увидел, когда не было фильтра драйвер написал что нашел 24(на самом деле 16) датчика. Я ему Ок, ан мне показывает мои 16 и 1 simultaneous temperature, вот я и подумал что когда фильтр есть он пишет 17 а показывает нормально 16.
                                    За формат отвечает ключ -f
                                    Из man owfs
                                       -f --format="f[.]i[[.]c]"
                                           Display format for the 1-wire devices. Each device has a 8byte address, consisting of:
                                           f      family code, 1 byte
                                           i      ID number, 6 bytes
                                           c      CRC checksum, 1 byte
                                           Possible formats are f.i (default, 01.A1B2C3D4E5F6), fi fic f.ic f.i.c and fi.c
                                           All formats are accepted as input, but the output will be in the specified format.
                                           The address elements can be retrieved from a device entry in owfs by the family, id and crc8 properties, and as a  whole  with
                                           address.  The reversed id and address can be retrieved as r_id and r_address.
                                    По умолчанию - формат f.i
                                    Я когда-то, для экспериментов установил format = fic
                                    Сейчас для меня некритично и я вернул format = f.i чтоб было как у всех 🙂
                                    ! root@art4:~# ls -l /mnt/1wire/
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 26.1DE491010000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 26.8725A4010000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 26.A9CA91010000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 26.ECEA91010000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 26.F1EA91010000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.0D1C2A050000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.34C848040000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.3B42D8050000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.799F74040000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.864975040000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.B0A92A050000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 28.E5BC2A050000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 29.191D16000000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 29.276E0C000000
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 29.45B70C000000
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 alarm
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.1
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.2
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.3
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.4
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.5
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.6
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.7
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 bus.8
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 settings
                                    ! drwxrwxrwx 1 root root 4096 сер 28 08:39 simultaneous
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 statistics
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 structure
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 system
                                    ! drwxr-xr-x 1 root root 4096 сер 28 08:38 uncached
                                      @Haus:
                                      Но при этом запустился ещё один owsf.0 `
                                      временно, как workaround, я установил на слейве скрипт, который отслеживает и при появлении дубликатов драйверов, запущенных мастером перезапускает iobroker на слейве:
                                      root@art1:~# cat /usr/local/bin/iobroker_duplicate_checker.sh
                                      #!/bin/bash
                                      count=`ps ax | grep 'io[.b]' | grep -v bash | awk -F" " '{print $5}' | uniq -d | wc -l`
                                      if [ "$count" -gt "0" ]
                                        then
                                        systemctl restart iobroker
                                      fi
                                      exit 0
                                      И добавил в /etc/crontab
                                      # Check Duplicate instances of iobroker and restart iobroker on a slave
                                      *  *    * * *   root    /usr/local/bin/iobroker_duplicate_checker.sh
                                        Haus last edited by
                                        @jeorgep:
                                        @Haus:
                                        #!/bin/bash
                                          then
                                        fi
                                        exit 0
                                        После чистой установки owfs сколько не менял настройки драйвера появление дубликатов замечено не было
                                          Haus last edited by
                                          @jeorgep:
                                          Из man owfs
                                          ! drwxr-xr-x 1 root root 4096 сер 28 08:38 uncached `
                                          Тогда получается фильтр Bluefox'a правильный 🙂 , только лишний в ответе датчик?
                                          P.S. Bluefox уже всё сделал 0.3.4 🙂
                                            @Haus:
                                            После чистой установки owfs сколько не менял настройки драйвера появление дубликатов замечено не было `
                                            у меня были проблемы только на слейве - при перезапуске iobroker на мастере или рестарта мастер сервера.
                                            А так, как у меня там свой экземпляр javascript адаптера - при дубликате его - он перестает работать.
                                            ! Необходимость в двух серверах в том, что другой установлен на входной двери
                                            ! и обрабатывает информацию от датчиков тока возле щитка, ИК освещении перед дверью,
                                            ! герконов в двери и замке, RFID ключа, камеры в глазке и т.п.
                                            ! Делать связь через WiFi не стал - так как вор бы включил глушилку на частоте WiFi и открывай дверь,
                                            ! никакой сигнализации не будет. Поэтому протянул к слейву витую пару и завел все через нее.
                                            192
                                            56009
