    4. ioBroker soll Raspberry PI System Befehl ausführen
      Thomas Braun Most Active @Accu last edited by
      @Accu Starte die Kiste mal neu.
        Accu @Thomas Braun last edited by
        @Thomas-Braun
         which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v12.18.4
        /usr/bin/node
        v12.18.4
        /usr/bin/npm
        6.14.6
        nodejs:
          Installiert:           12.18.4-1nodesource1
          Installationskandidat: 12.18.4-1nodesource1
          Versionstabelle:
         *** 12.18.4-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                100 /var/lib/dpkg/status
             8.11.1~dfsg-2~bpo9+1 500
                500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
             4.8.2~dfsg-1 500
                500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
          @Accu
          Jetzt passt es.
            @Thomas-Braun Yipeeeee.
            Jetzt zu meinem eigentlichen Anliegen. Kann ich einfach den GitHub PiHole Adapter aus ioBroker raus installieren?
              @Accu
              Der ist doch drin:
              process exited with code 0
                @Thomas-Braun war verwirrt weil der Gyp ERR noch im Log steht.
                $ ./iobroker url "https://github.com/unltdnetworx/ioBroker.pi-hole/tarball/master" pi-hole
                install https://github.com/unltdnetworx/ioBroker.pi-hole/tarball/master
                NPM version: 6.14.6
                npm install https://github.com/unltdnetworx/ioBroker.pi-hole/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                ERR!
                 sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1info sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^
                compilation terminated.
                make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
                gyp ERR! build error gyp ERR!
                 stack Error: `make` failed with exit code: 2gyp
                 ERR!
                stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.18.4gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                upload [5] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
                upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/tsconfig.json tsconfig.json application/json
                upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
                upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
                upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
                upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                  Thomas Braun Most Active @Accu last edited by Thomas Braun
                  @Accu sagte in ioBroker soll Raspberry PI System Befehl ausführen:
                  sharp
                  Das musst du sharp selber bauen.
                  Installier mal
                  sudo apt install libvips42 libvips-dev
                  Warum installierst du eigentlich pi-hole aus git?
                    @Thomas-Braun gute Frage. Gehts auch anders? Hatte das irgendwo gesehen.
                    Habe jetzt blöderweise ein anderes Problem: hatten den Pihole adapter installiert und jetzt wieder über das Terminal gedisabled. Aber irgendwie lagged der Pi jetzt total. Die ioBroker Maske wird nicht mehr vollständig geladen und zeigt nur noch den Ladekreis. Shutdown und reboot hat nix gebracht.
                    Irgendwelche ideen? (...never change a running system)
                      @Accu pi-hole ist doch ganz normal in der Adapter-Liste?
                      iobroker status
                      iobroker list adapters
                      iobroker list instances
                      hier eher: Never install alpha versions.
                      oder auch:
                      Never install software the wrong way.
                        @Thomas-Braun glaube ich habe meine Installation jetzt geschrottet 🤨
                        pi@Raspi:/opt/iobroker $ iobroker start
                        pi@Raspi:/opt/iobroker $ iobroker status
                        iobroker is not running on this host.
                        No iobroker host is running.
                          @Accu
                          Was hast du denn da getrieben?
                          iobroker fix
                            Accu @Thomas Braun last edited by Accu
                            @Thomas-Braun es war eigentlich alles gut. Dann hatte ich den pihole adapter noch mal über die GitHub URL aus ioBroker installiert und die Pihole Instanz hinzugefügt. Dann darin die IP vom pihole der auch auf dem Raspi läuft eingegeben. Dann hat das system super gelagged. --> Shutdown -> Reboot --> dann im Terminal den pihole adapter deaktiviert und noch mal ioBroker fix gemacht.
                            Und das Deinsallieren übers Terminal dauert eeeeewig:
                            pi@Raspi:/opt/iobroker $ iobroker del pi-hole
                            Delete adapter "pi-hole"
                            host.Raspi Counted 1 instances of pi-hole
                            host.Raspi Counted 1 adapter for pi-hole
                            host.Raspi Counted 11 channels of pi-hole
                            host.Raspi Counted 44443 states of pi-hole
                            host.Raspi Counted 14 states of system.adapter.pi-hole
                            host.Raspi object pi-hole.admin deleted
                            host.Raspi Deleting 44470 object(s). Be patient...
                            host.Raspi: Only 44400 objects left to be deleted.
                            host.Raspi: Only 44200 objects left to be deleted.
                            host.Raspi: Only 44000 objects left to be deleted.
                            host.Raspi: Only 43800 objects left to be deleted.
                            host.Raspi: Only 43600 objects left to be deleted.
                            host.Raspi: Only 43400 objects left to be deleted.
                            host.Raspi: Only 43200 objects left to be deleted.
                            host.Raspi: Only 43000 objects left to be deleted.
                            host.Raspi: Only 42800 objects left to be deleted.
                            host.Raspi: Only 42600 objects left to be deleted.
                              Accu @Accu last edited by
                              kurzes Update: der Pi läuft wieder. Es liegt def. am Pi-hole adapter. Sobald ich den Adapter installiere, reagiert mein Pi kaum noch.
                              blockly
                              1501
