    4. Test Adapter Shelly v4.0.3 (latest)
      Lokverführer @harrym last edited by
      @harrym @Stuebi
      Ping und CoAP-Test waren ja erfolgreich:
      (von mir wurde die ID durch XXX ersetzt)
      martin@NUCi3:/opt/iobroker/node_modules/iobroker.shelly$ node coaptest.js
      UDP Server listening on 0.0.0.0:5683
      2020-09-19T10:20:19.316Z - 10.0.0.88:5683 - PH13citsm
                                                           SHEM-3#XXX#2R{"G":[[0,9103,0],[0,1101,0],[0,4105,-409.74],[0,4106,20122.7],[0,4107,30416.7],[0,4108,234.57],[0,4109,1.99],[0,4110,-0.88],[0,4205,457.29],[0,4206,58448.8],[0,4207,0.0],[0,4208,234.55],[0,4209,2.22],[0,4210,0.88],[0,4305,15.79],[0,4306,22764.1],[0,4307,0.0],[0,4308,234.57],[0,4309,0.30],[0,4310,0.22],[0,6102,0]]}
      2020-09-19T10:20:34.318Z - 10.0.0.88:5683 - PH23citsm
                                                           SHEM-3#XXX#2R{"G":[[0,9103,0],[0,1101,0],[0,4105,-409.82],[0,4106,20122.7],[0,4107,30416.7],[0,4108,234.81],[0,4109,1.99],[0,4110,-0.88],[0,4205,442.22],[0,4206,58448.8],[0,4207,0.0],[0,4208,234.78],[0,4209,2.15],[0,4210,0.87],[0,4305,16.06],[0,4306,22764.1],[0,4307,0.0],[0,4308,234.83],[0,4309,0.31],[0,4310,0.22],[0,6102,0]]}
      2020-09-19T10:20:49.328Z - 10.0.0.88:5683 - PH33citsm
                                                           SHEM-3#XXX#2R{"G":[[0,9103,0],[0,1101,0],[0,4105,-409.08],[0,4106,20122.7],[0,4107,30416.7],[0,4108,234.74],[0,4109,1.99],[0,4110,-0.88],[0,4205,438.21],[0,4206,58448.8],[0,4207,0.0],[0,4208,234.83],[0,4209,2.14],[0,4210,0.87],[0,4305,15.70],[0,4306,22764.1],[0,4307,0.0],[0,4308,234.82],[0,4309,0.31],[0,4310,0.22],[0,6102,0]]}
      2020-09-19T10:21:04.343Z - 10.0.0.88:5683 - PH43citsm
                                                           SHEM-3#XXX#2R{"G":[[0,9103,0],[0,1101,0],[0,4105,-408.93],[0,4106,20122.7],[0,4107,30423.5],[0,4108,234.93],[0,4109,1.99],[0,4110,-0.88],[0,4205,451.49],[0,4206,58456.2],[0,4207,0.0],[0,4208,234.88],[0,4209,2.19],[0,4210,0.88],[0,4305,16.38],[0,4306,22764.5],[0,4307,0.0],[0,4308,234.99],[0,4309,0.31],[0,4310,0.23],[0,6102,0]]}
      2020-09-19T10:21:18.242Z - 10.0.0.88:5683 - PH53citsm
                                                           SHEM-3#XXX#2R{"G":[[0,9103,0],[0,1101,0],[0,4105,-409.29],[0,4106,20122.7],[0,4107,30423.5],[0,4108,235.08],[0,4109,1.99],[0,4110,-0.88],[0,4205,452.94],[0,4206,58456.2],[0,4207,0.0],[0,4208,234.99],[0,4209,2.19],[0,4210,0.88],[0,4305,16.62],[0,4306,22764.5],[0,4307,0.0],[0,4308,235.06],[0,4309,0.31],[0,4310,0.23],[0,6102,0]]}
      harrym 1 Reply Last reply Reply Quote 0
      • harrym
        harrym @Lokverführer last edited by harrym
        @Lokverführer bring den EM3 mal auf die letzte FW 1.8.4 .... http://repo.shelly.cloud/firmware/SHEM-3.zip
        Ausserdem stell mal das adapter log auf debug und poste dann die zeilen mit dem EM3.
          @harrym
          Ich habe das Update auf 1.8.4 gemacht und hier ein paar Zyklen aus dem Log:
          • da_Woody
            da_Woody @Lokverführer last edited by
            @Lokverführer du hast irgendwo rumgefummelt. bei der shelly id muss #1 und nicht #2 stehn... ich nehm mal an, das du beim adapterupdaten nicht gestoppt hast.
            harrym 1 Reply Last reply Reply Quote -1
            • harrym
              harrym @da_Woody last edited by
              @da_Woody nö g dat passt schon so ... die #2 im log zeigt ja nur an, dass ne FW >= 1.8 am Shelly läuft ^^
                klausiob @harrym last edited by klausiob
                Ich hänge mich mal hier rein, da ich keinen anderen Thread gefunden habe. Habe einen Shelly 2.5 (FW 1.8.3) in Betrieb genommen mit jeweils 3 LED-Spots an jedem Relay. Funktioniert mit Schalter, vom Handy, mit Alexa jeweils einzeln. Jetzt wollte ich alle Spots gleichzeitig ein und ausschalten. Habe in der Handy-App eine Gruppe erstellt und kann alle gleichzeitig ein und ausschalten. Nun wollte ich das gerne auch über Alexa schalten. Bereits bevor ich die Gruppe in der App erstellt habe, gab es eine Gruppe in iot. Diese hat alle Datenpunkte bis auf den Datenpunkt switch der beiden Relays. Unter alexa2.1 gibt es auch die Gruppe mit merkwürdigen Datenpunkten.
                Was mache ich falsch? Geht das überhaupt?
                • da_Woody
                  da_Woody @klausiob last edited by
                  @klausiob alexa legt das hirnrissig an.
                  erstell am handy in der alexa-app eine gruppe "Licht Essdiele" und da hackst du die beiden relais an.
                    klausiob @da_Woody last edited by
                    @da_Woody Danke. So funktioniert es zumindest. Aber eigentlich sollte man doch alles im iot-Adapter anlegen. Hier und unter Alexa sieht man im iobroker die im Handy angelegte Gruppe nicht. Das ist doch dann etwas inhomogen oder unterstützt das iobroker nicht so richtig.
                    • da_Woody
                      @klausiob naja, da ich teilweise die shelly-app (WAF) noch verwende, hab ich nur einige shelly im iot. z.b. die rolläden von der werkstatt. wenn du alles im iot anlegst, brauchst du die shelly-cloud/adapter nicht mehr.
                      aber eigentlich müsstest du auch die beiden relais im iot anlegen können.
                      bevor du da aber rumkünstelst, solltest du nachdenken ob nicht vorher alles im alias angelegt werden sollte. wenn ein shelly kaputt wird, brauchst du nur dort die ID zu ändern, alles andere greifst du nicht mehr an.
                      und so nebebei hab ich das terrassenlicht in der app und im iot und der alexa. (da ist der echo auch mit drinnen, drum 4)
                        Th3RockYeah @Stuebi last edited by Th3RockYeah
                        @Stuebi
                        Ich möchte gern longpush mit CoAP nutzen. Ich nutze die Version 4.0.3
                        Bei meinen Tests bin ich auf folgendes Phänomen gestoßen und kann nicht verifizieren, ob das so gewollt ist.
                        Wenn ich Longpush geschaltet habe und danach einen einfachen Schaltungsvorgang (Short) ausführe, wird zusätzlich noch mal Longpush gefeuert. Ist das normal?
                        on({id: "shelly.0.SHSW-PM#F27119#1.Relay0.longpush", change: "ne"}, function (obj) {
                          log('longpush geschaltet');
                        on({id: "shelly.0.SHSW-PM#F27119#1.Relay0.Switch", change: "ne"}, function (obj) {
                        log('Switch geschaltet');
                        LogFile:
                        javascript.0	2020-10-03 15:32:52.155	info	(24372) script.js.common.Shellys: longpush geschaltet ---> wird zusätzlich geschaltet
                        javascript.0	2020-10-03 15:32:52.149	info	(24372) script.js.common.Shellys: Switch geschaltet ---> Short geschaltet
                        javascript.0	2020-10-03 15:32:47.610	info	(24372) script.js.common.Shellys: longpush geschaltet --> Longpush gedrückt
                        javascript.0	2020-10-03 15:32:47.168	info	(24372) script.js.common.Shellys: Switch geschaltet ---> Short Ausschalten
                        javascript.0	2020-10-03 15:32:45.200	info	(24372) script.js.common.Shellys: Switch geschaltet --> Short Einschalten
                        Button-Type: Momentary,
                        Szenario
                        Ich steuere einen Raum per Bewegungsmelder und möchte aber bei bestimmten Tätigkeiten das Licht Dauerhaft einschalten, dafür wollte ich den Longpush nutzen und wundere mich gerade darüber, dass das Licht immer wieder erneut eingeschaltet wird, nachdem ich es eigentlich ausstellen wollen würde.
                        Bei meiner Recherche konnte ich nicht herausfinden, ob das Event-Handling so von Shelly gewollt ist oder ob das ein Bug ist.
                        • da_Woody
                          da_Woody @Th3RockYeah last edited by
                          @Th3RockYeah kann das eventuell damit zusammen hängen?
                            Th3RockYeah @da_Woody last edited by
                            @da_Woody Nein, das hat keine Auswirkungen auf das Verhalten. Ich habe es eben noch mal durchgespielt und bei beiden Szenarien passiert obiges Verhalten. Longpush wird nochmal nach dem ShortPush gefeuert.
                            • da_Woody
                              @Th3RockYeah sorry, war nur so eine idea... näxte: longpushtime ändern? kann man ja einstellen. ich setz bis jetzt longpush nicht ein, aber vllt erkennt der den short zusätzlich, weil die longpush zu klein ist...
                                @da_Woody Kein Ding, ich freue mich über Vorschläge 🙂
                                Ne daran liegt es leider auch nicht. Nutze die standard 800ms. Ich habe ein wenig damit rumgespielt, leider ohne Erfolg.
                                Die Frage für mich wäre, ist das ein Shelly Problem oder ein Adapter oder IoBroker Phänomen? Also wo sollte ich anfangen tiefer zu graben?
                                • da_Woody
                                  @Th3RockYeah hmm, adapter kann ich mir nicht vorstellen, hätten sicher mehrere, somit kann ich mir auch den IOB ned vorstellen.
                                  falls du frazenbuch hast, Shelly support group (English Version) eventull Dimitar direkt anschreiben. in der deutschen treiben sich die selben vögel wie im Offizielles Shelly Support Forum rum...
                                  IoBroker SmartHome und IoT
                                  https://shelly.cloud/support/ ein ticket erstellen. dazu sollter der shelly allerdings in der cloud sein. die können dann per ID sich das problem anlinsen. genaue fehlerbeschreibung, eventuell LOGs
                                    Th3RockYeah @da_Woody last edited by Th3RockYeah
                                    @da_Woody Besten Dank! Dann schaue ich mal in den anderen Foren herum.
                                    Eine weitere Frage hätte ich noch: Mir ist in den letzten Tagen aufgefallen, dass die Shellys ab und zu den Kontakt zum Shelly Adapter verlieren. Ich bekomme beim Testen keine Logs mehr im IoBroker angezeigt. Erst wenn ich einen Neustart beim Shelly Adapter mache, geht es wieder. Vielleicht haben das noch andere beobachtet?
                                    Update: Nach einer Neuinstallation des Adapters 4.0.4 und einlesen von allen Shellys, scheint das Verhalten mit den Aussetzern erledigt zu sein. Das Longpush Verhalten bleibt bestehen.
                                    Update 2: Ich habe leider noch keine Antwort vom Shelly Support bekommen. Das Ticket ist im Development angekommen, wenn ich das richtig interpretiere. fyi: Dimitar hat auf meine FB Message nicht reagiert. Was aber fair ist 🙂 Der bekomme bestimmt einige Messages.
                                    Sobald ich ein Update habe, melde ich mich.
                                    • harrym
                                      ein paar worte .....
                                      nachdem uns vorgeworfen wurde, dass wir auf "fehler" sehr träge reagieren:
                                      a) der Adapter selbst ist fehlerfrei.
                                      b) falls ECHTE fehler auftreten haben wir die innerhalb kürzester Zeit behoben .... ersichtlich in Git (https://github.com/schmupu/ioBroker.shelly/issues)
                                      c) Sonderwünsche oder Erweiterungen werden berücksichtigt und auch realisiert ... soweit es machbar ist ud auch sinn ergibt.
                                      @Stuebi und ich hatten bei der Umstellung auf die neue Firmmware 1.8 seitens Allterco genug Zeit investiert um euch einen funktionierenden Adapter zu bieten. Ja ... IoBroker war das erste System, dass FEHLERFREI mit der neuen FW umgehen konnte. Leider können viele von euch nicht lesen oder auch die Forensuche verwenden ... Stichwort CoAP und Shelly nicht erreichbar.
                                      Das waren jetzt meine paar Worte. Viel Spaß weiterhin mit dem Adapter für die ganzen Shelly Produkte.
                                      W -cs- 2 Replies Last reply Reply Quote 4
                                        watcherkb @harrym last edited by
                                        @harrym von mir hast du/ihr einen riesen Daumen hoch verdient. Auf Fehler habt ihr schnell reagiert. Man darf nicht vergessen dass ihr das in eurer Freizeit macht. Wer hier meint alles geschenkt zu bekommen und alles fehlerfrei sein sollte der hat keine Ahnung von Softwareentwicklung.
                                        da_Woody 1 Reply Last reply Reply Quote 2
                                        • harrym
                                          harrym last edited by harrym
                                          Zur Info für Alle ...
                                          Wir arbeiten an der Adapter Version 5.x
                                          Was wird sich ändern?
                                          Der Adapter wird zu 100% an die Shelly API angepasst. Das betrifft alle Datenpunkte und "Schaltpunkte".
                                          Wir weisen euch jetzt schon auf die Aliasfunktion von ioBroker hin ... richtet euch jetzt schon die jeweiligen Datenpunkte als Alias ein ... erspart euch ne menge Arbeit in der Zukunft,
                                          Latzi E 2 Replies Last reply Reply Quote 3
                                          • da_Woody
                                            da_Woody @watcherkb last edited by
                                            @watcherkb ich war ja live dabei! der adapter war 2 tage vor rollout des updates fertig, also lange bevor irgend jemand anderes reagiert hat.
                                            meinereiner durfte ja neben @harrym das versuchskarnickel spielen. meine ca 70 shelly's mussten als erste dran glauben. 😄
                                            die paar kleinen peanuts waren eigentlich kleine tappfühler, die halt mal passieren in der hitze der nacht. 😉
                                            , oder ; is halt was anderes...
                                            harrym 1 Reply Last reply Reply Quote 1
                                            31.7k
                                            79.9k
                                            latest shelly shelly adapter
                                            28
                                            163
                                            19363
