    4. Time Out Instancen Installation
    UNSOLVED Time Out Instancen Installation
      Cedrik1 @Cedrik1 last edited by
      Die Log spuckt momentan diese Meldungen aus
      host.raspberrypi	2020-10-06 18:01:54.980	info	instance system.adapter.ping.0 started with pid 4703
      host.raspberrypi	2020-10-06 18:01:38.725	info	Restart adapter system.adapter.info.0 because enabled
      host.raspberrypi	2020-10-06 18:01:38.724	error	instance system.adapter.info.0 terminated with code 0 (OK)
      host.raspberrypi	2020-10-06 18:01:38.724	error	Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.raspberrypi	2020-10-06 18:01:38.724	error	Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      host.raspberrypi	2020-10-06 18:01:38.724	error	Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      host.raspberrypi	2020-10-06 18:01:38.724	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
      host.raspberrypi	2020-10-06 18:01:38.723	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.info/main.js:92:26
      host.raspberrypi	2020-10-06 18:01:38.723	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi	2020-10-06 18:01:38.723	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.info/main.js:103:57
      host.raspberrypi	2020-10-06 18:01:38.723	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.info/main.js:124:49
      host.raspberrypi	2020-10-06 18:01:38.722	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
      host.raspberrypi	2020-10-06 18:01:38.721	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      info.0	2020-10-06 18:01:38.674	info	cleaned everything up...
      info.0	2020-10-06 18:01:38.674	error	TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23) at /opt/iobroker/node_modules/iobroker.info/main.js:124:49 at
      info.0	2020-10-06 18:01:38.671	error	uncaught exception: Cannot read property 'split' of undefined
      info.0	2020-10-06 18:01:38.535	info	Popup-News readed...
      info.0	2020-10-06 18:01:38.183	info	Reading process data every 8 seconds.
      info.0	2020-10-06 18:01:38.183	info	Reading CPU temp data every 3 seconds.
      info.0	2020-10-06 18:01:38.182	info	Reading battery data every 8 seconds.
      info.0	2020-10-06 18:01:38.182	info	Reading user data every 8 seconds.
      info.0	2020-10-06 18:01:38.182	info	Reading memory data every 3 seconds.
      info.0	2020-10-06 18:01:38.181	info	Reading disk data every 8 seconds.
      info.0	2020-10-06 18:01:38.025	info	Reading CPU data every 3 seconds.
      info.0	2020-10-06 18:01:38.024	info	Reading CPU current speed every 3 seconds.
      info.0	2020-10-06 18:01:38.022	info	starting. Version 1.3.7 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.4
        Ein Screenshot von meinen Instanzen
        • Glasfaser
          Glasfaser @Glasfaser last edited by
          @Glasfaser sagte in Time Out Instancen Installation:
          @Cedrik1 sagte in Time Out Instancen Installation:
          Beim ersten Start vom Io Broker mussten die Instancen ping.0 und web.0 installiert werden. Diese wurde nicht erfolgreich durchgeführt
          Zeige mal deine JS-Controller Version
          iobroker version
            Thomas Braun Most Active @Cedrik1 last edited by
            @Cedrik1
            Versuch mal den info-Adapter nochmal in das System zu bügeln.
              Cedrik1 @Glasfaser last edited by
              @Glasfaser said in Time Out Instancen Installation:
              iobroker version
              1.5.11
              • Glasfaser
                Glasfaser @Cedrik1 last edited by Glasfaser
                1.5.11
                ist die wirklich 1.xx.xx ???
                Dann hast du aber ein sehr altes System , damit läuft auch nicht der aktuelle Ping Adapter
                C 2 Replies Last reply Reply Quote 0
                  @Glasfaser Ja wie gesagt, ich habe mir ein aktuelles Image von der ioBroker Seite heruntergeladen
                    Cedrik1 @Thomas Braun last edited by
                    @Thomas-Braun Ich habe jetzt den Info Adapter und vorsichtshalber den discovery adapter gelöscht. Wie installiere ich die neu ins System?
                      @Glasfaser Im ioBroker steht aber oben rechts was anderes
                      ioBroker.admin 3.6.2
                      • Glasfaser
                        .... kann ich mir nicht vorstellen , das du bei der Ausgabe von
                        iobroker version
                        1.x.x. als JS-Version hast
                        wo hast du das Image her .
                          @Glasfaser Von der ioBroker Seite https://www.iobroker.net/#de/download
                          • Glasfaser
                            @Cedrik1
                            Zeige mal als Ausgabe . in CodeTags </> .. nicht als Text von dir als Aussage
                            iobroker version
                            nach deimem Link ist die Version "mit dem js-controller v2.1.1 nach Stand vom 27.11.2019."
                              @Glasfaser war eben schon als code tag, aber gerne nochmal neu:
                              pi@raspberrypi:~ $ iobroker version
                              1.5.11
                              • Glasfaser
                                @Cedrik1
                                Zeige mal die Ausgabe von :
                                iobroker update
                                aber im Spoiler setzen !!!
                                  @Cedrik1
                                  iobroker update
                                  im Spoiler setzen?
                                    Hat sich nichts geändert
                                    pi@raspberrypi:~ $ iobroker update
                                    Used repository: default
                                    update done
                                    Adapter    "admin"         : 4.0.10   , installed 3.6.2 [Updateable]
                                    Adapter    "alarm"         : 1.2.4
                                    Adapter    "alexa2"        : 3.3.1
                                    Adapter    "alpha2"        : 1.0.0
                                    Adapter    "amazon-dash"   : 1.1.0
                                    Adapter    "artnet"        : 1.2.2
                                    Adapter    "asterisk"      : 1.0.6
                                    Adapter    "asuswrt"       : 1.0.1
                                    Adapter    "b-control-em"  : 0.2.1
                                    Adapter    "backitup"      : 1.6.7
                                    Adapter    "beckhoff"      : 1.2.2
                                    Adapter    "benq"          : 0.2.0
                                    Adapter    "binance"       : 1.1.3
                                    Adapter    "ble"           : 0.11.8
                                    Adapter    "bmw"           : 1.3.3
                                    Adapter    "bosesoundtouch": 0.2.4
                                    Adapter    "botvac"        : 1.0.0
                                    Adapter    "bring"         : 1.7.2
                                    Adapter    "broadlink2"    : 2.0.3
                                    Adapter    "bsblan"        : 0.1.5
                                    Adapter    "bshb"          : 0.1.10
                                    Adapter    "chromecast"    : 2.3.1
                                    Adapter    "cloud"         : 3.0.4
                                    Adapter    "comfoair"      : 0.3.2
                                    Adapter    "contactid"     : 1.0.1
                                    Adapter    "coronavirus-statistics": 0.6.1
                                    Adapter    "countdown"     : 1.1.0
                                    Adapter    "cul"           : 1.2.1
                                    Adapter    "daikin"        : 1.0.5
                                    Adapter    "daswetter"     : 3.0.1
                                    Adapter    "deconz"        : 1.3.10
                                    Adapter    "denon"         : 1.7.7
                                    Adapter    "devices"       : 0.3.6
                                    Adapter    "digitalstrom"  : 0.5.5
                                    Adapter    "discovergy"    : 0.5.0
                                    Adapter    "discovery"     : 2.3.7
                                    Adapter    "doorio"        : 1.0.10
                                    Adapter    "ds18b20"       : 1.1.4
                                    Adapter    "dwd"           : 2.4.10
                                    Adapter    "ebus"          : 2.1.1
                                    Adapter    "ecovacs-deebot": 1.0.3
                                    Adapter    "egigeozone"    : 0.1.2
                                    Adapter    "ekey"          : 1.1.0
                                    Adapter    "email"         : 1.0.7
                                    Adapter    "emby"          : 1.0.2
                                    Adapter    "energymanager" : 1.2.3
                                    Adapter    "enet"          : 1.0.1
                                    Adapter    "epson_stylus_px830": 0.2.1
                                    Adapter    "exchangerates" : 0.0.13
                                    Adapter    "fakeroku"      : 0.2.1
                                    Adapter    "fb-checkpresence": 1.0.4
                                    Adapter    "feiertage"     : 1.0.17
                                    Adapter    "fhem"          : 1.5.3
                                    Adapter    "find-my-iphone": 0.2.15
                                    Adapter    "firetv"        : 0.0.27
                                    Adapter    "flot"          : 1.9.2
                                    Adapter    "foobar2000"    : 2.0.3
                                    Adapter    "fritzbox"      : 0.2.1
                                    Adapter    "fritzdect"     : 0.2.4
                                    Adapter    "fronius"       : 1.0.5
                                    Adapter    "fullcalendar"  : 1.1.0
                                    Adapter    "fullybrowser"  : 2.0.1
                                    Adapter    "g-homa"        : 0.5.3
                                    Adapter    "geofency"      : 0.3.2
                                    Adapter    "gruenbeck"     : 0.0.18
                                    Adapter    "habpanel"      : 0.4.3
                                    Adapter    "haier"         : 1.0.2
                                    Adapter    "ham"           : 1.1.2
                                    Adapter    "ham-wemo"      : 1.0.1
                                    Adapter    "harmony"       : 1.2.2
                                    Adapter    "heatingcontrol": 0.5.7
                                    Adapter    "heytech"       : 1.0.0
                                    Adapter    "hid"           : 0.1.17
                                    Adapter    "history"       : 1.9.10   , installed 1.9.10
                                    Adapter    "hm-rega"       : 2.6.21
                                    Adapter    "hm-rpc"        : 1.14.23
                                    Adapter    "hmip"          : 1.3.1
                                    Adapter    "homeconnect"   : 0.0.30
                                    Adapter    "homee"         : 1.0.7
                                    Adapter    "homepilot"     : 1.0.3
                                    Adapter    "hp-ilo"        : 1.0.6
                                    Adapter    "hs100"         : 2.0.1
                                    Adapter    "hue"           : 3.3.5
                                    Adapter    "hue-extended"  : 2.0.0
                                    Adapter    "ical"          : 1.7.4
                                    Adapter    "icons-addictive-flavour-png": 0.1.0
                                    Adapter    "icons-fatcow-hosting": 0.1.0
                                    Adapter    "icons-icons8"  : 0.0.1
                                    Adapter    "icons-material-png": 0.1.0
                                    Adapter    "icons-material-svg": 0.1.0
                                    Adapter    "icons-mfd-png" : 1.0.2
                                    Adapter    "icons-mfd-svg" : 1.0.2
                                    Adapter    "icons-open-icon-library-png": 0.1.2
                                    Adapter    "icons-ultimate-png": 1.0.1
                                    Adapter    "influxdb"      : 1.9.1
                                    Adapter    "info"          : 1.7.2
                                    Adapter    "innogy-smarthome": 0.3.6
                                    Adapter    "iogo"          : 0.5.10
                                    Adapter    "iot"           : 1.5.3
                                    Adapter    "iqontrol"      : 1.2.4
                                    Adapter    "jarvis"        : 1.0.6
                                    Adapter    "javascript"    : 4.6.17   , installed 4.6.17
                                    Adapter    "jeelink"       : 0.1.0
                                    Controller "js-controller" : 3.1.6    , installed 1.5.11 [Updateable]
                                    Adapter    "kecontact"     : 0.1.0
                                    Adapter    "klf200"        : 1.0.1
                                    Adapter    "km200"         : 1.1.6
                                    Adapter    "knmi-weather"  : 1.0.0
                                    Adapter    "knx"           : 1.0.39
                                    Adapter    "kodi"          : 2.0.4
                                    Adapter    "kostal-piko-ba": 1.0.2
                                    Adapter    "kress"         : 2.5.5
                                    Adapter    "lametric"      : 0.0.9
                                    Adapter    "landroid"      : 1.0.3
                                    Adapter    "lcn"           : 0.3.2
                                    Adapter    "letrika_comgw" : 0.0.5
                                    Adapter    "lgtv"          : 1.1.10
                                    Adapter    "lgtv-rs"       : 0.1.0
                                    Adapter    "lgtv11"        : 1.0.5
                                    Adapter    "lifx"          : 0.1.0
                                    Adapter    "lightify"      : 0.2.16
                                    Adapter    "link"          : 0.5.9
                                    Adapter    "linkeddevices" : 1.2.2
                                    Adapter    "linux-control" : 1.0.0
                                    Adapter    "logparser"     : 1.0.4
                                    Adapter    "lovelace"      : 1.0.16
                                    Adapter    "loxone"        : 1.1.0
                                    Adapter    "luftdaten"     : 0.0.17
                                    Adapter    "lupusec"       : 1.2.6
                                    Adapter    "luxtronik1"    : 0.2.2
                                    Adapter    "material"      : 0.13.9
                                    Adapter    "maxcube"       : 0.1.2
                                    Adapter    "maxcul"        : 1.3.0
                                    Adapter    "mbus"          : 2.2.2
                                    Adapter    "mclighting"    : 0.1.1
                                    Adapter    "megad"         : 1.2.1
                                    Adapter    "megadd"        : 0.2.0
                                    Adapter    "megaesp"       : 0.1.0
                                    Adapter    "melcloud"      : 1.0.6
                                    Adapter    "mercedesme"    : 0.0.21
                                    Adapter    "mercury"       : 0.1.1
                                    Adapter    "meross"        : 1.5.0
                                    Adapter    "meteoalarm"    : 1.0.9
                                    Adapter    "midea"         : 0.0.6
                                    Adapter    "miele"         : 0.1.5
                                    Adapter    "mielecloudservice": 2.0.0
                                    Adapter    "mihome"        : 1.3.0
                                    Adapter    "mihome-lamp"   : 1.1.0
                                    Adapter    "mihome-plug"   : 0.2.0
                                    Adapter    "mihome-vacuum" : 2.0.7
                                    Adapter    "mikrotik"      : 1.0.11
                                    Adapter    "milight"       : 0.3.6
                                    Adapter    "milight-smart-light": 0.2.7
                                    Adapter    "mobile"        : 1.0.1
                                    Adapter    "modbus"        : 3.1.6
                                    Adapter    "moma"          : 1.2.6
                                    Adapter    "mpd"           : 1.0.5
                                    Adapter    "mqtt"          : 2.1.4
                                    Adapter    "mqtt-client"   : 1.3.1
                                    Adapter    "musiccast"     : 0.1.3
                                    Adapter    "mysensors"     : 2.0.1
                                    Adapter    "nanoleaf-lightpanels": 0.8.1
                                    Adapter    "nello"         : 2.0.6
                                    Adapter    "netatmo"       : 1.3.1
                                    Adapter    "nibeuplink"    : 0.3.0
                                    Adapter    "nina"          : 0.0.22
                                    Adapter    "node-red"      : 1.17.2
                                    Adapter    "nuki"          : 1.3.1
                                    Adapter    "nuki-extended" : 2.3.0
                                    Adapter    "nut"           : 1.1.3
                                    Adapter    "odl"           : 1.0.5
                                    Adapter    "oilfox"        : 0.0.5
                                    Adapter    "onkyo"         : 2.0.3
                                    Adapter    "onvif"         : 0.4.4
                                    Adapter    "openhab"       : 1.1.0
                                    Adapter    "openligadb"    : 1.1.0
                                    Adapter    "openweathermap": 0.1.0
                                    Adapter    "opi"           : 0.1.1
                                    Adapter    "oppoplayer"    : 0.2.1
                                    Adapter    "owfs"          : 0.6.4
                                    Adapter    "owntracks"     : 0.6.3
                                    Adapter    "panasonic-viera": 1.0.2
                                    Adapter    "parser"        : 1.0.7
                                    Adapter    "paw"           : 0.0.7
                                    Adapter    "phantomjs"     : 1.0.1
                                    Adapter    "pi-hole"       : 1.3.1
                                    Adapter    "piface"        : 1.0.0
                                    Adapter    "pimatic"       : 0.3.0
                                    Adapter    "ping"          : 1.4.8    , installed 1.4.8
                                    Adapter    "places"        : 1.0.0
                                    Adapter    "plex"          : 0.8.11
                                    Adapter    "plexconnect"   : 0.0.7
                                    Adapter    "pollenflug"    : 1.0.6
                                    Adapter    "proxmox"       : 1.0.1
                                    Adapter    "proxy"         : 1.1.1
                                    Adapter    "pushbullet"    : 0.0.11
                                    Adapter    "pushover"      : 2.0.2
                                    Adapter    "pushsafer"     : 0.1.8
                                    Adapter    "radar2"        : 1.0.9
                                    Adapter    "radiohead"     : 1.0.7
                                    Adapter    "rflink"        : 2.0.0
                                    Adapter    "rickshaw"      : 1.0.0
                                    Adapter    "ring"          : 1.1.3
                                    Adapter    "robonect"      : 0.1.3
                                    Adapter    "roomba"        : 1.1.1
                                    Adapter    "rpi2"          : 1.2.0
                                    Adapter    "s7"            : 1.1.8
                                    Adapter    "samsung"       : 0.2.9
                                    Adapter    "sayit"         : 1.9.8
                                    Adapter    "sbfspot"       : 4.0.0
                                    Adapter    "scenes"        : 1.1.0
                                    Adapter    "schoolfree"    : 0.6.3
                                    Adapter    "schwoerer-ventcube": 1.3.0
                                    Adapter    "shelly"        : 4.0.2
                                    Adapter    "shuttercontrol": 0.8.6
                                    Adapter    "sia"           : 1.0.4
                                    Adapter    "siegenia"      : 1.0.0
                                    Adapter    "simple-api"    : 2.4.6    , installed 2.4.8
                                    Adapter    "smappee"       : 0.2.2
                                    Adapter    "smartgarden"   : 1.0.1
                                    Adapter    "smartmeter"    : 3.1.5
                                    Adapter    "snips"         : 1.5.1
                                    Adapter    "snmp"          : 0.5.0
                                    Adapter    "socketio"      : 3.0.13   , installed 3.0.13
                                    Adapter    "solarlog"      : 2.0.0
                                    Adapter    "solarviewdatareader": 0.2.1
                                    Adapter    "solarwetter"   : 1.0.0
                                    Adapter    "sonnen"        : 1.6.0
                                    Adapter    "sonoff"        : 2.3.3
                                    Adapter    "sonos"         : 2.1.0
                                    Adapter    "sony-bravia"   : 1.0.1
                                    Adapter    "spotify-premium": 1.0.0
                                    Adapter    "sql"           : 1.15.2
                                    Adapter    "squeezebox"    : 1.0.0
                                    Adapter    "squeezeboxrpc" : 1.0.0
                                    Adapter    "starline"      : 1.0.0
                                    Adapter    "statistics"    : 0.2.2
                                    Adapter    "stiebel-isg"   : 1.5.1
                                    Adapter    "sunnyportal"   : 0.1.5
                                    Adapter    "swiss-weather-api": 0.3.2
                                    Adapter    "synology"      : 0.1.18
                                    Adapter    "systeminfo"    : 0.3.1
                                    Adapter    "tahoma"        : 0.3.2
                                    Adapter    "tankerkoenig"  : 2.0.5
                                    Adapter    "telegram"      : 1.5.9
                                    Adapter    "terminal"      : 0.1.2
                                    Adapter    "tesla-motors"  : 0.2.3
                                    Adapter    "text2command"  : 1.3.0
                                    Adapter    "tinker"        : 1.1.0
                                    Adapter    "tr-064"        : 4.0.9
                                    Adapter    "tradfri"       : 2.6.3
                                    Adapter    "trashschedule" : 0.0.11
                                    Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                    Adapter    "tuya"          : 3.3.12
                                    Adapter    "tvspielfilm"   : 1.0.4
                                    Adapter    "unifi"         : 0.5.8
                                    Adapter    "upnp"          : 1.0.16
                                    Adapter    "vaillant"      : 0.0.10
                                    Adapter    "valloxmv"      : 1.1.1
                                    Adapter    "vcard"         : 0.0.9
                                    Adapter    "velux"         : 0.0.5
                                    Adapter    "viessmann"     : 1.3.0
                                    Adapter    "virtualpowermeter": 1.2.1
                                    Adapter    "vis"           : 1.2.12
                                    Adapter    "vis-bars"      : 0.1.4
                                    Adapter    "vis-canvas-gauges": 0.1.5
                                    Adapter    "vis-colorpicker": 1.1.1
                                    Adapter    "vis-fancyswitch": 1.1.0
                                    Adapter    "vis-google-fonts": 0.1.0
                                    Adapter    "vis-history"   : 1.0.0
                                    Adapter    "vis-hqwidgets" : 1.1.4
                                    Adapter    "vis-icontwo"   : 0.24.0
                                    Adapter    "vis-inventwo"  : 1.3.8
                                    Adapter    "vis-jqui-mfd"  : 1.0.12
                                    Adapter    "vis-justgage"  : 1.0.2
                                    Adapter    "vis-keyboard"  : 0.0.2
                                    Adapter    "vis-lcars"     : 1.0.4
                                    Adapter    "vis-map"       : 1.0.4
                                    Adapter    "vis-metro"     : 1.1.2
                                    Adapter    "vis-players"   : 0.1.6
                                    Adapter    "vis-plumb"     : 1.0.2
                                    Adapter    "vis-rgraph"    : 0.0.2
                                    Adapter    "vis-timeandweather": 1.1.7
                                    Adapter    "vis-weather"   : 2.5.2
                                    Adapter    "vr200"         : 1.0.0
                                    Adapter    "vw-connect"    : 0.0.15
                                    Adapter    "weatherunderground": 3.2.1
                                    Adapter    "web"           : 3.0.12   , installed 3.0.12
                                    Adapter    "weishaupt-wem" : 0.0.8
                                    Adapter    "wiffi-wz"      : 2.2.0
                                    Adapter    "wifilight"     : 1.1.0
                                    Adapter    "windows-control": 0.1.5
                                    Adapter    "wled"          : 0.5.2
                                    Adapter    "wm-bus"        : 0.1.12
                                    Adapter    "wolf"          : 0.9.2
                                    Adapter    "worx"          : 1.2.3
                                    Adapter    "xbox"          : 0.6.8
                                    Adapter    "xs1"           : 1.0.2
                                    Adapter    "yahka"         : 0.11.0
                                    Adapter    "yamaha"        : 0.3.19
                                    Adapter    "yeelight-2"    : 1.0.3
                                    Adapter    "youtube"       : 0.0.11
                                    Adapter    "yr"            : 2.0.3
                                    Adapter    "zigbee"        : 1.2.1
                                    Adapter    "zont"          : 0.5.3
                                    Adapter    "zwave"         : 2.0.1
                                    Adapter    "zwave2"        : 1.5.0
                                    1.5.11
                                    pi@raspberrypi:~ $
                                    • Glasfaser
                                      Hast du dort mal was geupdate ... igendwelche Code´s aus dem I-Net genutzt ?
                                      @Thomas-Braun @Homoran
                                      Wie geht denn das in einem fertigen Image !?
                                      Habt ihr eine Idee .
                                      C Homoran 2 Replies Last reply Reply Quote 0
                                        @Glasfaser Das image habe ich vorgestern erst runtergeladen und da kamen schon die Fehler im ioBroker. An updates etc. habe ich nur das gemacht was hier im Thread von euch vorgeschlagen wurde.
                                        Vor ungefähr einem Jahr habe ich das selbe image auf den selben PI installiert und klappte alles Problemlos.
                                        • Glasfaser
                                          Dann ist alles gut ....
                                          ...... nur ist die JS-Version komplett falsch ...warum auch immer !
                                          • Glasfaser
                                            Man (könnte) es gerade biegen ... da bin ich gerade Vorsichtig damit ... das ist ein riesen Sprung ... und da könnte noch mehr hinterhängen .
                                            Wäre es nicht von dir möglich , es einfach neu aufzusetzten !?
                                            raspberry
                                            3181
