    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Thomas Braun Most Active @Glasfaser last edited by
      @Glasfaser
      iobroker rebuild mbus
      Glasfaser H 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @Thomas Braun last edited by
        @Thomas-Braun
        ...ja ... eigentlich wird es auch selbst behoben ..
        . wollte aber sicher gehen und alles nochmal per "npm rebuild" durchführen lassen .
          Habedere @Glasfaser last edited by
          @Glasfaser sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
          @Habedere sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
          Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
          cd /opt/iobroker
          npm rebuild
          /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in d        efinition of macro ‘V8_DEPRECATED’
             declarator __attribute__((deprecated(message)))
          ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
             data->callback.Call(2, argv);
          In file included from ../src/./serialport.h:6:0,
                           from ../src/serialport.cpp:1:
          ../../nan/nan.h:1674:3: note: declared here
             Call(int argc, v8::Local<v8::Value> argv[]) const {
          ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
          ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
             data->callback.Call(1, argv);
          ../src/serialport.cpp: At global scope:
          ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
             void init(v8::Handle<v8::Object> target) {
          ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
          ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ toke        n
          ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
          In file included from ../../nan/nan.h:53:0,
                           from ../src/./serialport.h:6,
          ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
           NODE_MODULE(serialport, init);
          /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in defi        nition of macro ‘NODE_MODULE_X’
                 (node::addon_register_func) (regfunc),                          \
          ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
          serialport.target.mk:112: recipe for target 'Release/obj.target/serialport/src/s        erialport.o' failed
          make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
          make: Leaving directory '/opt/iobroker/node_modules/iobroker.discovery/node_modu        les/serialport/build'
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module        s/node-gyp/lib/build.js:194:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces        s.js:275:12)
          gyp ERR! System Linux 4.19.13-sunxi
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialpo        rt
          gyp ERR! node -v v12.18.4
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the serialport@6.2.2 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
          npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_31_30_970Z-debug.log
          • Glasfaser
            Glasfaser @Habedere last edited by
            @Habedere
            installiere ihn neu :
              Habedere @Thomas Braun last edited by
              @Thomas-Braun sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
              @Glasfaser
              root@orangepizero:/opt/iobroker# iobroker rebuild mbus
              npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
              In file included from ../../nan/nan_converters.h:67:0,
                               from ../../nan/nan.h:221,
              ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
              ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
                     val->To ## TYPE(isolate->GetCurrentContext())                            \
              ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
               X(Boolean)
              In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
                               from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
                               from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
                               from ../../nan/nan.h:52,
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
                               V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
              ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
              ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
                 return val->NAME ## Value(isolate->GetCurrentContext());                     \
              ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
               X(bool, Boolean)
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
                               V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
              In file included from ../../nan/nan_new.h:189:0,
                               from ../../nan/nan.h:222,
              ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
              ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
                                         , obj));
              In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
                 static MaybeLocal<Function> New(
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
              ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
              ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
                               Local<String> ToString(Isolate* isolate) const);
              ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
              ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
                               bool Set(Local<Value> key, Local<Value> value));
              ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
              ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   New(persistentHandle)->Set(key, value);
              ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
              ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   New(persistentHandle)->Set(index, value);
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
                               bool Set(uint32_t index, Local<Value> value));
              ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
              ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       New(persistentHandle)->Get(New(key).ToLocalChecked()));
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
                 V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
              ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
              ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   return scope.Escape(New(persistentHandle)->Get(key));
              ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
              ../../nan/nan.h:1884:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   return scope.Escape(New(persistentHandle)->Get(index));
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3557:51: note: declared here
                 V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));
              In file included from /usr/include/c++/6/cassert:44:0,
                               from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node_object_wrap.h:26,
                               from ../../nan/nan.h:54,
              ../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
              ../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
                   assert(persistent().IsNearDeath());
              In file included from ../../nan/nan.h:2698:0,
              ../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
              ../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
                   persistent().MarkIndependent();
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:570:22: note: declared here
                     V8_INLINE void MarkIndependent());
              ../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
              ../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
                   assert(wrap->handle_.IsNearDeath());
              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
                 v8::String::Utf8Value path(info[0]->ToString());
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
                 V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
              ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
                 v8::Local<v8::Object> options = info[1]->ToObject();
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
                 V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                               Local<Object> ToObject(Isolate* isolate) const);
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
              ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
              ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../../nan/nan.h:1655:3: note: declared here
              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
              ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
              ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
              ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
              ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
              ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
              ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
              ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
              ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
              ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
              ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
              ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
              ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
              ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
              In file included from ../../nan/nan.h:52:0,
              /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/iobroker.mbus/node_modules/serialport
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR!     /home/iobroker/.npm/_logs/2020-10-06T19_36_22_957Z-debug.log
              Rebuild mbus done
              root@orangepizero:/opt/iobroker# root@orangepizero:/opt/iobroker# iobroker rebuild mbus
              -bash: root@orangepizero:/opt/iobroker#: No such file or directory
               X(Boolean)
              root@orangepizero:/opt/iobroker# npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.mbus"
              -bash: syntax error near unexpected token `('
               X(bool, Boolean)
              root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_converters.h:67:0,
              Could not find the database of available applications, run update-command-not-found as root to fix this
              In: command not found
              root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:221,
              root@orangepizero:/opt/iobroker#                  from ../src/./serialport.h:6,
              from: can't read /var/mail/../src/./serialport.h:6,
              root@orangepizero:/opt/iobroker#                  from ../src/serialport.cpp:1:
              from: can't read /var/mail/../src/serialport.cpp:1:
              root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:18:51: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#        val->To ## TYPE(isolate->GetCurrentContext())                            \
                                         , obj));
              ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8val-: command not found
              root@orangepizero:/opt/iobroker#                                                    ^
              ^: command not found
              root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
              -bash: ../../nan/nan_converters_43_inl.h:22:1:: No such file or directory
              root@orangepizero:/opt/iobroker#  X(Boolean)
              -bash: syntax error near unexpected token `Boolean'
              root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
              root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
              from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
              root@orangepizero:/opt/iobroker#                  from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
              from: can't read /var/mail//home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
              root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:52,
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59: note: declared here
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2664:59:: No such file or directory
              root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3:: No such file or directory
              root@orangepizero:/opt/iobroker#    declarator __attribute__((deprecated(message)))
              root@orangepizero:/opt/iobroker#    ^~~~~~~~~~
              ^~~~~~~~~~: command not found
              root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#    return val->NAME ## Value(isolate->GetCurrentContext());                     \
              -bash: return: val-: numeric argument required
              -bash: return: can only `return' from a function or sourced script
              root@orangepizero:/opt/iobroker# ../../nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
              -bash: ../../nan/nan_converters_43_inl.h:40:1:: No such file or directory
              root@orangepizero:/opt/iobroker#  X(bool, Boolean)
              -bash: syntax error near unexpected token `bool,'
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51: note: declared here
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2702:51:: No such file or directory
              root@orangepizero:/opt/iobroker#                  V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(
              root@orangepizero:/opt/iobroker# In file included from ../../nan/nan_new.h:189:0,
              root@orangepizero:/opt/iobroker#                  from ../../nan/nan.h:222,
              root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’
              root@orangepizero:/opt/iobroker#                            , obj));
              -bash: syntax error near unexpected token `)'
              root@orangepizero:/opt/iobroker# In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note: candidate: static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)
              root@orangepizero:/opt/iobroker#    static MaybeLocal<Function> New(
              ^~~: command not found
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
              -bash: v8::Context: No such file or directory
              root@orangepizero:/opt/iobroker# In file included from ../src/./serialport.h:6:0,
              root@orangepizero:/opt/iobroker# ../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan.h:1064:78: warning: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#        v8::Local<v8::String> string = from->ToString(v8::Isolate::GetCurrent());
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: declared here
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31:: No such file or directory
              root@orangepizero:/opt/iobroker#                  Local<String> ToString(Isolate* isolate) const);
              root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan.h:1855:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
              -bash: syntax error near unexpected token `persistentHandle'
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22:: No such file or directory
              root@orangepizero:/opt/iobroker#                  bool Set(Local<Value> key, Local<Value> value));
              root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan.h:1861:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(key, value);
              root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
              root@orangepizero:/opt/iobroker# ../../nan/nan.h:1867:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#      New(persistentHandle)->Set(index, value);
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22: note: declared here
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3508:22:: No such file or directory
              root@orangepizero:/opt/iobroker#                  bool Set(uint32_t index, Local<Value> value));
              root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
              root@orangepizero:/opt/iobroker# ../../nan/nan.h:1873:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#          New(persistentHandle)->Get(New(key).ToLocalChecked()));
              root@orangepizero:/opt/iobroker# /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51: note: declared here
              -bash: /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3553:51:: No such file or directory
              root@orangepizero:/opt/iobroker#    V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
              -bash: syntax error near unexpected token `"Use maybe version",'
              root@orangepizero:/opt/iobroker# ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
              root@orangepizero:/opt/iobroker# ../../nan/nan.h:1879:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              root@orangepizero:/opt/iobroker#      return scope.Escape(New(persistentHandle)->Get(key));
              selbes spiel in grün...
              • Glasfaser
                @Habedere
                siehe über dein Beitrag !
                  @Habedere
                  alles klar - ich probiers...
                    Thomas Braun Most Active @Habedere last edited by
                    @Habedere
                    root@orangepizero
                    Bitte nicht als root anmelden. Da läuft doch bestimmt das debian-artiges?
                      @Habedere
                      root@orangepizero
                      Welcome to ARMBIAN 5.69 stable Debian GNU/Linux 9 (stretch) 4.19.13-sunxi
                      System load: 1.46 0.55 0.20 Up time: 1 min
                      Memory usage: 39 % of 493MB IP: 192.168.178.4
                      CPU temp: 54°C
                      Usage of /: 8% of 29G
                      Hmm auf dem Orange bin ich so selten drauf - der ist nur für den Mbus da.
                      PS: Der Mbus Adapter läuft wieder 🙂 THX @all
                      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        sehr schön .... 😉
                          @Habedere Auch selten meldet man sich nicht als root an. NIE ist die Devise.
                            Du siehst - es fehlt an Grundlagen 😉 Ich google mich von einer Anleitung zum nächsten Thread im Forum 🙂
                            Das muss ich also mal als nächstes angehen 👍
                              cop2810 last edited by
                              Hallo Community , ich habe in Problem. Bin nu im raspberry Geschäft und habe nach der Anleitung oben gearbeitet bis ich folgenden Fehler bekam.
                              Was muss ich machen um das wieder glatt zu ziehen?
                              VG
                              Stephan
                                Thomas Braun Most Active @cop2810 last edited by Thomas Braun
                                @cop2810
                                Bitte keine Screenshots sondern Text auch als Text (in CodeTags) ins Forum.
                                Und bitte einen eigenen Thread eröffnen.
                                  cop2810 @Thomas Braun last edited by Negalein
                                  @Thomas-Braun Sorry, wusste nicht, dass das so geht.
                                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                  permitted by applicable law.
                                  Last login: Wed Oct 28 09:14:06 2020 from 192.168.178.70
                                  pi@raspberrypi:~ $ iobroker stop
                                  pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                                  pi@raspberrypi:~ $ apt update
                                  N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird        ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                                  E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13:        Keine Berechtigung)
                                  E: Das Verzeichnis /vDebian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                  E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
                                  W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - Remov        eCaches (13: Keine Berechtigung)
                                  W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - Re        moveCaches (13: Keine Berechtigung)
                                    @cop2810 Bitte einen neuen Thread eröffnen.
                                    Und da bitte CodeTags </> verwenden.
                                      @Habedere
                                      root@orangepizero
                                      So jetzt ist es mal wieder soweit... der Orange ist abgestürzt und kommt nicht mehr in die Pötte 😞
                                      Wie kann ich mich denn mit einem non-Root Benutzer anmelden?
                                      FInde da nirgends was passendes 😞
                                        @Habedere Bitte einen eigenen Thread eröffnen. Das hat mit node nichts zu tun.
                                        • O
                                          Oli @Thomas Braun last edited by
                                          @Thomas-Braun
                                          super Anleitung, vielen Dank dafür, aber jetzt meine Frage, kann ich Nodejs auch auf einer Dockerinstallation updaten?
                                          Mein ioBroker läuft als Docker auf einer Qnap und bis jetzt sind alles Versuche kläglich gescheitert, mit der Meldung, dass die aktuellste Version schon installiert sei.
                                          Thomas Braun Negalein 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Oli last edited by
                                            @Oli
                                            Von Docker hab ich keine Ahnung. Die Meinungen gehen da wohl auseinander wie das da zu aktualisieren sei.
                                            Bitte aber einen eigenen Thread dazu eröffnen.
                                            nodejs
                                            91
                                            844
                                            222978
