    4. Alias mit Channel umsetzten wie ?
      Flopsi last edited by Flopsi
      Hallo zusammen wie kann ich bei den Alias die Channelfunktion umsetzten ?
      So sehen meine Aliasdatenpunkte aus.....
      Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
      				Changelog
      Version 1.1.3
        - use callbacks in alias-path
      Version 1.1.2
        - fix log message 'Created Alias-Path '
      Version 1.1.1
        - Bugfixing, clean functions
      Version 1.1.0
        - added function for cleaning enums
      Version 1.0.6
        - use callback functions for safety call
      Version 1.0.5
        - decrease timeout assing enum
      Version 1.0.4
        - Bugfixing array id lenght
      Version 1.0.3
        - Githublink
      Version 1.0.2
        - existsObject for Alias in the timeout
        - remove lowerCase enum
        - improved logs
      Version 1.0.1
        - Rooms and functions casesensitive
      Version 1.0
      		Flags /
      		Variablen
      // typeAlias = 'boolean'; // oder 'number'
      // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
      // write = "val ? 'Ein' : 'Aus'";
      // nameAlias = 'Licht Haustür';
      // role = 'switch';
      // desc = 'per Script erstellt';
      // min = 0; // nur Zahlen
      // max = 100; // nur Zahlen
      // unit = '%'; // nur für Zahlen
      // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
      let bCreateAliasPath = false;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
      Requirements: bCreateAliasPath == true
      If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
      let bConvertExistingPath = false;
      	Don't change anything from here /
      	Ab hier nichts verändern
      let arEnum = [];
      let arId = [];
      let timeoutAssignEnum;
      function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
        if(!idDst.includes('alias.0.'))
            idDst = 'alias.0.' + idDst;
        if(!existsObject(idSrc))
            log('Source-Id ' + idSrc +' does not exists.','warn');
            return;
        // Create the object Path for alias id,
        // so you can assign rooms and function to the parents
        var createAliasPath = (id) => {
             if(bCreateAliasPath){
                  let lisMergedIds = [];
                  let mergedId = 'alias.0';
                  id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                  let split = id.split('.');
                  for(let i=0;i<split.length-1;i++){
                      mergedId += '.' + split[i];
                      lisMergedIds.push(mergedId);
                  function path(){
                      if(lisMergedIds.length == 0) {// Zu Ende erstellt
                          alias();
                          return;
                      let tmpId = lisMergedIds[0];
                      lisMergedIds.splice(0,1); // entferne element
                      if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                          let obj;
                          if(existsObject(tmpId))
                              obj = getObject(tmpId);
                          else
                              obj = {};
                          if(obj.type == undefined || obj.type != 'meta')
                              obj.type = 'meta';
                          if(obj.common == undefined || obj.common != {})
                              obj.common = {};
                          if(obj.common.type == undefined || obj.common.type != 'meta.folder')
                              obj.common.type = 'meta.folder';
                          if(obj.common.desc == undefined || obj.common.desc != 'createAliasPath')
                              obj.common.desc = 'createAliasPath';
                          if(obj.common.def == undefined || obj.common.def != false)
                              obj.common.def = false;
                          if(obj.native == undefined || obj.native != {})
                              obj.native = {};
                          setObject(tmpId, obj, (err) =>{
                              if(!err){
                                  log('Created Alias-Path ' + tmpId);
                                  path();
                              else
                                  log('Error creating alias-path','error');
                  path();
             else
               alias();
          //   createAliasPath(idDst);
        function alias(){
            // Create alias object
              if(!existsObject(idDst)){
                  let obj = {};
                  obj.type = 'state';
                  obj.common = getObject(idSrc).common;
                  obj.common.alias = {};
                  obj.common.alias.id = idSrc;
                  if(typeAlias !== undefined)
                      obj.common.type = typeAlias;
                  if(obj.common.read !== undefined)
                      obj.common.alias.read = read;
                  if(obj.common.write !== undefined)
                      obj.common.alias.write = write;
                  if(nameAlias !== undefined)
                      obj.common.name = nameAlias;
                  if(role !== undefined)
                      obj.common.role = role;
                  if(desc !== undefined)
                      obj.common.desc = desc;
                  if(min !== undefined)
                      obj.common.min = min;
                  if(max !== undefined)
                      obj.common.max = max;
                  if(unit !== undefined)
                      obj.common.unit = unit;
                  if(states !== undefined)
                      obj.common.states = states;
                  obj.native = {};
                  obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                  log('Created Alias-State ' + idDst);
                  setObject(idDst, obj,(err) =>{
                      if(!err)
                          startAttach();
                      else
                          log('Error creating-alias','error');
              else
                  startAttach();
        // Save ID and Enum (room or function)
        var attach = (id, enu,value) => {
            if(id.length == 0){
                log('ID has lenght 0, can not attach to enum','warn');
                return;
            if(value.length == 0){
                log('Value has lenght 0','warn');
                return;
            let sEnuId = 'enum.' + enu + '.' + value;
            if(enu.length > 0 && existsObject(sEnuId))
                let obj = getObject(sEnuId)
                let members = obj.common.members;
                if(!members.includes(id)){
                    arEnum.push(sEnuId);
                    arId.push(id);
            else
         	      log('Can not find enum ' + sEnuId,'warn');
       function startAttach(){
          let bRoom = raum !== undefined && raum.length > 0;
          let bGewerk = gewerk !== undefined && gewerk.length > 0;
          if(bRoom)
              attach(idDst,'rooms',raum);
          if(bGewerk)
              attach(idDst,'functions',gewerk);
          if(bRoom || bGewerk){
                  if(timeoutAssignEnum){
                      clearTimeout(timeoutAssignEnum);
                      timeoutAssignEnum = null;
                  timeoutAssignEnum = setTimeout(finishScript,100);
      function finishScript(){
      	assignEnums();
      // Add the saved IDs to the rooms/functions
      function assignEnums(){
       if(arEnum.length == 0 || arId.length == 0){
            return;
       if(arEnum.length != arId.length){
            log('Arrays have different size','error');
            return;
       let mapEnumId = new Map();
       for(let i=0;i < arEnum.length; i++){
           let enu = arEnum[i];
           let id = arId[i];
           if(existsObject(id)){
          	 let obj = getObject(enu)
          	 let members;
          	 if(!mapEnumId.has(enu)){
          		 mapEnumId.set(enu,members);
          	 else
          		 members = mapEnumId.get(enu);
          		  log("Adding " + id + " to " + enu);
          		  members.push(id);
           else
               log('Can not find Alias ' + id,'error');
        function setMembers(members,enu,map){
            let obj = getObject(enu);
            obj.common.members = members;
            setObject(enu,obj);
        mapEnumId.forEach(setMembers);
      		END /
      		ENDE
      Beispiel Datenpunkt bei mir:
      createAlias('zwave2.0.Node_013.Multilevel_Switch.targetValue','Buero.Rollladen.Fenster.targetValue');
        paul53 @Flopsi last edited by
        @Flopsi sagte:
        Was verstehst Du unter "Channelfunktion" ? Was möchtest Du erreichen ?
        @Flopsi sagte in Alias mit Channel umsetzten wie ?:
        Weshalb hast Du "Current value" und "Target value" nicht zu einem Datenpunkt zusammengeführt ?
          @ Paul
          Aus unwissenheit würde ich mal sagen bin froh das ich das so hinbekommen habe 🙂
          Was bringt es wenn die beiden Punkte zusammengeführt werden wie stellt sich das da ?
          Deswegen will ich das so umsetzten.
          https://forum.iobroker.net/topic/30668/jarvis-just-another-remarkable-vis/612
            paul53 @Flopsi last edited by paul53
            @Flopsi sagte:
            In der Visualisierung ist es nur ein Datenpunkt, der den Status anzeigt und mit dem geschaltet werden kann.
            Im Tab "Objekte" kann man aus einem Ordner leicht ein Channel-Objekt machen: "+" (Tochterobjekt hinzufügen).
            Man muss den identischen Namen des Ordners eingeben.
              Zu Punkt 1 wie baue ich mein Aliasskript so um das die Punkte zusammengeführt werden ?
              Zu Punkt 2 ich habe das so versucht wie ich verstanden habe bekomme folgende Fehlermeldung:
              Kann man das Aliasskript nicht so umbauen das Automatisch diese Channelfunktion mit gemacht wird ?
                @Flopsi sagte:
                Wenn parent "alias0.Ankleide.Beleuchtung" ist, muss der Channel-Name "Schrankbeleuchtung" oder "Steckdose_2" sein.
                Siehe hier, unterster Spoiler.
                  Ich merke gerade mal wieder das ich keine Ahnung habe was ich da mache LOL.
                  Für euch mag das alles einleuchtend und selbstversändlich sein aber für mich ist das ein graus und absolut nicht ziehlführend sitze hier mehr und teste rum um am ende festzustellen das ich keinen Schritt weiter bin :).
                  Hier das versuchte umsetzten in Bildern leider kein Erfolg 😞
                    @Flopsi sagte:
                    leider kein Erfolg
                    Dann muss "alias.0.Ankleide.Beleuchtung.Schrankbeleuchtung" bereits ein Objekt sein !?
                      Ja sehe ich jetzt auch 🙂
                      Das steht Channel.
                      Wie auch immer ich das geschaft habe....
                      OK jetzt nochmal ne Frage
                      Kann ich nicht bei createalias sofort schon sagen das die Ordner "channel" sind und den verschiedenen Datenpunkte sagen was sie sind z.B. state etc...... ?
                        @Flopsi sagte:
                        Da es mehrere Ordner in einem Pfad gibt, must Du erst definieren, welcher Ordner ein Channel sein soll. Der letzte vor dem Datenpunkt ?
                        Das von Dir verwendete Script ist nicht von mir. Frage besser den Ersteller des Scripts.
                          Ja wenn du so fragst habe ich glaube meine Aliasstruktur falsch ....
                          Folgendes:
                          Ich nutze Fibaro Module.....
                          Das Modul nenn wir es Modul1(switch) kann zwei sachen schalten....
                          Schrankbeleuchtung
                          und
                          Steckdose_2
                          Der Ordner Beleuchtung ist nur ein Platzhalter.....
                          Um mir eine bessere Übericht zu verschaffen habe ich das Modul im Alias aufgeteilt...
                          Deswegen wäre meiner Meinung nach
                          Schrankbeleuchtung = Channel
                          und
                          Steckdose_2 = Channel
                          Der Ordner Multisensor ist wieder nur ein Platzhalter.....
                          Motion_Auge wäre dann wieder =Channel
                          Ich weis nur nicht warum bei Beleuchtung state steht und bei Mulitsenor nix....
                          //Ankleide//////////////////////////////////////////////////////////////////////////////////////////
                          //Motion_Fibaro//
                          createAlias('zwave2.0.Node_030.Multilevel_Sensor.illuminance','Ankleide.Multisensor.Motion_Auge.Lux');
                          createAlias('zwave2.0.Node_030.Multilevel_Sensor.airTemperature','Ankleide.Multisensor.Motion_Auge.Temp');
                          createAlias('zwave2.0.Node_030.Binary_Sensor.any','Ankleide.Multisensor.Motion_Auge.Bewegung');
                          createAlias('zwave2.0.Node_030.Battery.isLow','Ankleide.Multisensor.Motion_Auge.Battery_Status');
                          createAlias('zwave2.0.Node_030.Battery.level','Ankleide.Multisensor.Motion_Auge.Battery_Level');
                          //Beleuchtung//
                          createAlias('zwave2.0.Node_031.Binary_Switch.targetValue_001','Ankleide.Beleuchtung.Schrankbeleuchtung.target');
                          createAlias('zwave2.0.Node_031.Binary_Switch.currentValue_001','Ankleide.Beleuchtung.Schrankbeleuchtung.state');
                          createAlias('zwave2.0.Node_031.Binary_Switch.targetValue_002','Ankleide.Beleuchtung.Steckdose_2.target');
                          createAlias('zwave2.0.Node_031.Binary_Switch.currentValue_002','Ankleide.Beleuchtung.Steckdose_2.state');
                          So sieht die Alias-Erstellung dazu aus ...
                          Vielen Dank schon mal das du dir so eine Mühe gibst 🙂
                          Hast du ein besseres Skript kenn mich da nicht aus ich kann dir noch nicht mal sagen wo ich das her habe Copy/Paste.....
                          Ich bin eh noch am anfang und teste aus Smarthome = Hobby 🙂
                          crunchip paul53 2 Replies Last reply Reply Quote 0
                            crunchip Forum Testing Most Active @Flopsi last edited by crunchip
                            Guck 5 antworten weiter oben, da steht der link zum script
                            Dort findest du auch den link zu deinem bisherigen verwendeten script https://forum.iobroker.net/post/378743
                              @Flopsi sagte:
                              Ist vermutlich entstanden, als Du versucht hast, einen Channel unter "Beleuchtung" zu erstellen.
                                @crunchip
                                Danke ist schon länger her das ich dann dein Skript genommen habe ....
                                Mir ist ja egal welches ich nutze Hauptsache ich bekomme das mit der Channelfunktion gedängelt.
                                Kann man das überhaupt mit createAlias so erstellen das die Informationen so zugewiesen werden wie ich mir das vorstelle ?
                                Ich denke mal das ich an den bestehenden Skript eh nix ändern kann mangels fachwissen.
                                //Motion_Fibaro//
                                //Beleuchtung//
                                Schrankbeleuchtung und Steckdose_2 und Motion_Auge sollen Typ Channel bekommen.
                                Wie kann ich das im alias Skrip umsetzten ......
                                javascript
                                685
