    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    • Dutchman
      Dutchman Developer Most Active Administrators @Palm_Maniac last edited by
      @Palm_Maniac sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
      Ich hab mal bei mir nachgeschaut, wie es bei meinen DPs ausschaut, die ich per LinkedDevices erzeugt habe und per SA auswerte. Dort gibt es augenscheinlich kein def:0 Problem, zumindest habe ich in keinem DP von LD diesen def:0 Eintrag gefunden. LD scheint also mit SA zu funktionieren.
      danke, damit koennen wir das fuer linked devices ausschliessen
      JB_Sullivan B 2 Replies Last reply Reply Quote 0
      • JB_Sullivan
        JB_Sullivan @Dutchman last edited by
        @Dutchman
        Nur ein kleiner Hinweis, da ich mir vorhin die 0.4.8 - alpha gezogen hatte.
        Heute Nacht wurde das hier protolliert.
        2020-10-06 00:00:02.902 - info: sourceanalytix.0 (5100) Executing reset for : fritzdect.0.DECT200_087610236923.energy
        2020-10-06 00:00:02.902 - info: sourceanalytix.0 (5100) Memory values for fritzdect.0.DECT200_087610236923.energy before reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"fritzdect__0__DECT200_087610236923__energy","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Switch total energy","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"kWh"},"calcValues":{"currentValue":230.728,"start_day":230.036,"start_week":230.036,"start_month":226.99200000000002,"start_quarter":226.99200000000002,"start_year":"","valueAtDeviceReset":0},"prices":{"basicPrice":"7.74","unitPrice":"0.2707"}}
        2020-10-06 00:00:02.903 - info: sourceanalytix.0 (5100) Current known state values : {"currentValue":230.728,"start_day":230.036,"start_week":230.036,"start_month":226.99200000000002,"start_quarter":226.99200000000002,"start_year":"","valueAtDeviceReset":0}
        2020-10-06 00:00:02.908 - info: sourceanalytix.0 (5100) Memory values for fritzdect.0.DECT200_087610236923.energy after reset : {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"fritzdect__0__DECT200_087610236923__energy","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Switch total energy","stateType":"ElectricityDay","stateUnit":"Wh","useUnit":"kWh"},"calcValues":{"currentValue":230.728,"start_day":230.728,"start_week":230.036,"start_month":226.99200000000002,"start_quarter":226.99200000000002,"start_year":"","valueAtDeviceReset":0},"prices":{"basicPrice":"7.74","unitPrice":"0.2707"}}
        Jetzt bekomme ich diese Fehlermeldung - OK ich weiß es ist eine Alpha - aber hat das was zu bedeuten und warum kommt die Meldung erst jetzt?
        2020-10-06 14:45:20.633 - error: sourceanalytix.0 (10540) [calculationHandler fritzdect.0.DECT200_087610236923.energy] error: calculationRounded is not defined, stack: ReferenceError: calculationRounded is not defined
        at Sourceanalytix.calculationHandler (C:\iobroker\GLT\node_modules\iobroker.sourceanalytix\main.js:919:99)
        at process._tickCallback (internal/process/next_tick.js:68:7)
          babl @Dutchman last edited by
          @Dutchman so habe sämtliche Datenpunkte angesehen, in meinen eigens erstellten Datenpunkten habe ich ja gestern den def wert gelöscht hier findet sich auch keiner mehr, in den sourceanalytics datenpunkten ist überall ein def wert mit 0 zu finden.
          Das errechnete stimmt ebenfalls nicht.
          • Dutchman
            Dutchman Developer Most Active Administrators @babl last edited by
            @babl sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
            nicht böse gemeint, aber ich glaube bereits 10 mal erklärt zu haben das der def wert in den SA Datenpunkten komplett egal ist !
            bitt bereits genannten troubleshoot befolgen in die raw daten anschauen ob da previous werte drin sind und die startwerte richtig gesetzt wurden
            • Dutchman
              Dutchman Developer Most Active Administrators @JB_Sullivan last edited by
              @JB_Sullivan sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
              0.4.8 war noch nicht zum testen bereit, jetzt ja ich mache dazu gleich eine Ankündigung.
              Die log Einträge sind um den tegesreset zu überwachen, alles OK
              das war ein typo von mir, fixed in 0.4.8-alpha.0
              https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/commit/0bcbac91231fd2c234531ac3db00a4300e4ffa18#diff-7a9076d6d94e62c13d641aa71f19ae8eR919
              0 DutchmanNL committed to iobroker-community-adapters/ioBroker.sourceanalytix
              fix typo in rounding function
              • Dutchman
                Dutchman Developer Most Active Administrators @Dutchman last edited by Dutchman
                ** !!! Version 0.4.8-alpha.0 Major Breaking change !!!**
                0.4.8-alpha.0 (2020-10-06)
                • (Dutchman) Breaking!!! Move current values to currentYear
                • (Dutchman) Add back "currentYear"
                • (Dutchman) Code cleanup
                • (Dutchman) Optimized error reporting (Sentry)
                • (Dutchman) implemented weekly reset of weekdays
                • (Dutchman) implemented calculation for all states
                • (Dutchman) Removed unneeded settings in configuration
                • (Dutchman) Implemented new configuration for "currentYear"
                Beachte also bitte das alle xx_current_xx sich jetzt nicht mehr unter dem Jahr sondern curentYear befinden !
                Nach jetzigen stand, git issues und Erwartungen ist dies das letzte mal das an der Struktur geschraubt wird.
                Happy testing, ab heute nacht / morgen im admin verfügbar (nur als latest!) oder bereits jetzt per npm :
                cd /opt/iobroker
                npm i iobroker.sourceanalytix@latest
                Bei NPM installation NICHT "sudo" verwenden !
                In den neuen structuren findet ihr jetzt auch wieder die Woche zurueck und man hat werte fur gestern, vorige Woche etc...
                MichMein F 2 Replies Last reply Reply Quote 0
                • MichMein
                  MichMein @Dutchman last edited by
                  @Dutchman hi dutchman,
                  ich hatte mir versehentlich die 0.4.8 Version schon vor längerer Zeit installiert und hatte sie drauf gelassen weil es keine Probleme gab. Jetzt habe ich mir das 0.4.8 er Release installiert und habe viele Datenpunkte die scheinbar aus der nicht offiziellen 0.4.8 er sind.
                  Funktioniert es ohne Datenverlust wenn ich den Adapter stoppe, dann ALLE datenpunkte löschen und wieder starten? Werden dann die korrekten datenpunkte vom Adapter erstellt und sind dann auch werte darin?
                    fastsonic @Dutchman last edited by fastsonic
                    @Dutchman
                    Danke Danke Danke !
                    Daumen hoch. Ich bin auch dafür das du jetzt nichts mehr an der Struktur veränderst 😄
                    Ich sehe zwar noch keine Werte für last Day und Weeks, aber ich gehe mal davon aus das die ersten erst morgen erstellt werden.
                    • Dutchman
                      Dutchman Developer Most Active Administrators @MichMein last edited by
                      @MichMein sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                      leider nein, den wen du alles löscht sind auch die werte unter currentYear weck.
                      Hab aber ne loesung : mach mir bitte ein git issue auf dazu.... meine idee :
                      • Beim start ermittle ich welche Datenpunkte alle existieren
                      • Machen eine Tabelle welche nicht mehr zur neuen version gehoeren
                      • Stelle einen button zur verfuegung in der configuration welche diese "alten" Datenpunkte aufräumt.
                      Waehre ne loesung oder ?
                      MichMein 1 Reply Last reply Reply Quote 1
                      • MichMein
                        @Dutchman
                        Das klingt nach nem tollen Vorschlag und Lösungsansatz. Issue auf Github erstelle ich gleich.
                        DANKE
                        • Dutchman
                          Dutchman Developer Most Active Administrators @fastsonic last edited by
                          @fastsonic sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                          previous day usw sollte da sein wen du in der Instanz vorige aktiviert hast (nur in version 0.4.8-alpha.0 oder hoeher !):
                          Arg und jetzt sehe ich das ich die previous vergessen habe fuer Tages reset, fixe ich heute Abend und es gibt ne alpha.1 sorry guys 😕
                            @Dutchman
                            Ja das habe ich nur übersehen weil ich noch die komplette history an Dateistrukturen habe.
                            Eigentlich sollten ja jetzt unter den entsprechenden Geräten 2 Ordner sein. einmal die Jahreszahl und einmal current Year.
                            Hab heute einige Updates gemacht und irgendwie hat es mir ein paar Werte zerschossen.
                            Muss erstmal die Ordnerstruktur von den alten Werten mal säubern.
                            • Dutchman
                              Correct und die current sind vom Jahr nach current gewandert
                                guergen @Dutchman last edited by
                                @Dutchman Es scheint in der alpha alle korrekt zu laufen!
                                Klasse gemacht!
                                Danke!
                                Dutchman 1 Reply Last reply Reply Quote 1
                                • Dutchman
                                  Dutchman Developer Most Active Administrators @guergen last edited by Dutchman
                                  update der alpha version, bitte morgen prüfen ob damit die "previous" richtig gesetzt werden (also previousDay)
                                  0.4.8-alpha.2 sollte ab mittag (nach 15Uhr) per admin zu installieren sein (wen auf latest eingestellt!)
                                  Changelog
                                  0.4.8-alpha.2 (2020-10-08)
                                  (Dutchman) Bugfix : Cannot read property 'stateDetails' of null
                                  0.4.8-alpha.1 (2020-10-08)
                                  (Dutchman) Fix calculations for "previous" values
                                  MichMein 1 Reply Last reply Reply Quote 0
                                  • MichMein
                                    MichMein @Dutchman last edited by MichMein
                                    @Dutchman sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                                    Hi Dutchman,
                                    das klingt sehr gut.
                                    Hast Du in dem alpha.2 auch schon das prüfen und entfernen der alten Datenpunkte eingebaut?
                                      Kueppert last edited by Kueppert
                                      ich bin gerade etwas ratlos...ich habe bei curent year und 2020 Differenzen im Ausweis der Daten. Entweder wurde das hier schon erwähnt und ich habe es nicht verstanden - oder ein Problem?
                                      Ich logge aktuell nur meine Sonoff-Datenpunkte in kWh (Gesamtverbraucht). HMIP mache ich wieder wenn dort nicht immer der "def: xyz" auftaucht (nach dem nächsten JS-Release):
                                      PS: Hatte erst 0.4.8 alpha0 und jetzt alpha2 drauf. Sah bei alpha0 schon genau so aus - und die Differenzen/Abweichungen werden immer größer.
                                      • Dutchman
                                        noch nicht da muss ich nochmal ganz genau durch den code durch kommt aber schnell
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @Kueppert last edited by
                                          @Kueppert sagte in [Major Update] SourceAnalytix v0.4.7-beta.0 released !:
                                          die Datenpunkte unter dem jähr 2020 gehören dort nicht mehr hin siehe changelog von 0.4.8-xxx.x 🙂
                                          Wie im vorigen Kommentar erwähnt werde ich eine function bereit stellen um alte Sachen auf zu räumen
                                            @Dutchman moin, was wäre jetzt besser die alte Version 0.47 runterlöschen und mit der sauberen 0.48.2 starten oder nur updaten oder noch ganz warten. Daten die bisher gespeichert worden sind sind mir egal da ich sowieso noch in der findungsfase und im Aufbau bin.
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            356813
