    4. Test Adapter todoist2 v0.9 Latest/GitHub
      Burg_Io @Glasfaser last edited by
      @Glasfaser
      sorry, hier der Code. ich hoffe d. es so okay ist?
      host.iobroker	2020-10-08 18:03:55.804	error	Caught by controller[1]: (node:15272) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proce
      host.iobroker	2020-10-08 18:03:55.804	error	Caught by controller[1]: (node:15272) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by r
      host.iobroker	2020-10-08 18:03:55.804	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:724:14)
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:879:32)
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1035:10)
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1015:30)
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.todoist2/main.js:2737:5)
      host.iobroker	2020-10-08 18:03:55.803	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.todoist2/main.js:54:15)
      host.iobroker	2020-10-08 18:03:55.802	error	Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:393:32)
      host.iobroker	2020-10-08 18:03:55.802	error	Caught by controller[0]: at JSON.parse (<anonymous>)
      host.iobroker	2020-10-08 18:03:55.802	error	Caught by controller[0]: (node:15272) UnhandledPromiseRejectionWarning: SyntaxError: Unexpected token , in JSON at position 9244
      • Glasfaser
        Glasfaser @Glasfaser last edited by
        @Glasfaser sagte in Test Adapter todoist2 v0.7.1 GitHub:
        den Adapter über Git nochmal neu drüberinstallieren !?
        mal mal das und dann ein reboot.
          @Glasfaser danke wird probiert und ich melde mich
            jukus100 @Burg_Io last edited by
            Ich krieg direkt diese Fehlermeldung beim installieren
            • Glasfaser
              @jukus100
              @Burg_Io
              ein Screenshot bringt nicht viel .
              Die Ausgabe in Code-Tags </> reinsetzen .
                jukus100 @Glasfaser last edited by
                @Glasfaser said in Test Adapter todoist2 v0.7.1 GitHub:
                @jukus100
                @Burg_Io
                mea culpa
                $ ./iobroker url "https://github.com/rde-master/ioBroker.todoist2" --debug
                install https://github.com/rde-master/ioBroker.todoist2/tarball/81b03243a253db5e18f2eb3a4aac39a2e443f830
                NPM version: 6.14.6
                npm install https://github.com/rde-master/ioBroker.todoist2/tarball/81b03243a253db5e18f2eb3a4aac39a2e443f830 --loglevel error --prefix "/opt/iobroker" (System call)
                + iobroker.todoist2@0.7.2updated 1 package in 32.899s
                23 packages are looking for funding  run `npm fund` for details
                ERROR: internal/modules/cjs/loader.js:1238    throw err;    ^SyntaxError: /opt/iobroker/node_modules/iobroker.todoist2/io-package.json: Unexpected token , in JSON at position 9244    at parse (<anonymous>)    at Object.Module._extensions..json (internal/modules/cjs/loader.js:1235:22)    at Module.load (internal/modules/cjs/loader.js:1050:32)    at Function.Module._load (internal/modules/cjs/loader.js:938:14)    at Module.require (internal/modules/cjs/loader.js:1090:19)    at require (internal/modules/cjs/helpers.js:75:18)    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:481:19)    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:1781:24    at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:478:47)    at ChildProcess.emit (events.js:314:20)
                ERROR: process exited with code 1
                Fertig mit Fehler: internal/modules/cjs/loader.js:1238 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.todoist2/io-package.json: Unexpected token , in JSON at position 9244 at parse () at Object.Module._extensions..json (internal/modules/cjs/loader.js:1235:22) at Module.load (internal/modules/cjs/loader.js:1050:32) at Function.Module._load (internal/modules/cjs/loader.js:938:14) at Module.require (internal/modules/cjs/loader.js:1090:19) at require (internal/modules/cjs/helpers.js:75:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:481:19) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:1781:24 at ChildProcess. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:478:47) at ChildProcess.emit (events.js:314:20)
                • Glasfaser
                  Glasfaser @jukus100 last edited by
                  @jukus100
                  Da ist ein Fehler in der Version 0.7.2.
                  Habe es eben selber getetest , gleicher Fehler.
                  Melde ist auf GitHub.
                    rde-master Developer last edited by rde-master
                    @Glasfaser @jukus100
                    feher gefunden...
                    da hat sich eine } versteckt...
                    Jetzt sollte alles wieder gehen... Verison 0.7.3 ist auf GitHub.
                      jukus100 @rde-master last edited by
                      @rde-master said in Test Adapter todoist2 v0.7.3 GitHub:
                      feher gefunden...
                      Hat geklappt 😉
                      Allerdings habe ich wahrscheinlich irgendwie nicht verstanden, wie man diesen Adapter richtig konfiguriert. Bei mir wird nichts ausgelesen; ich erhalte nur die Objekte Control Close New mit einer Hand voll Unterpunkten...
                        rde-master Developer @jukus100 last edited by
                        @jukus100
                        Super,..
                        Zum Einrichten brauchst du deinen API Token von Todoist...
                        Der link dafür ist in der Adapter konfiguartion bei dem Token hinterlegt.
                        Einfach einfügen,... neu starten und dann kommen nach ein paar Sekunden die Daten.
                        Über die Hacken darunter stellst du ein wie du deine Todo's haben willst.
                        1. Willst du deine Projekte, Sektionen, Todo's oder Labels haben
                        2. Willst du es als HTML Tabelle, JSON Tabelle, oder als reinen Text.
                        Erst wenn du da die Hacken setzt, tauchen auch die Objekte auf...
                          jukus100 @rde-master last edited by jukus100
                          Hmm ich habe jetzt mal alles angeklickt in der Hoffnung, dass irgendwo etwas kommt, aber Pustekuchen.
                          API Token scheint richtig zu sein, es wird nämlich "grün" angezeigt und bei Copy+Paste sollte jetzt nicht allzu viel schief gehen.
                          EDIT: Ok, jetzt bekomme ich die Tasks alle angezeigt und oben eine Liste über sämtliche Projekte; nur die Projekte mit Tasks kriege ich irgendwie noch nicht gefüllt als ein "Element" ausgegeben
                          EDIT2:
                          todoist2.0	2020-10-09 17:35:14.940	error	at processImmediate (internal/timers.js:458:21)
                          todoist2.0	2020-10-09 17:35:14.940	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
                          todoist2.0	2020-10-09 17:35:14.940	error	at Adapter.emit (events.js:314:20)
                          todoist2.0	2020-10-09 17:35:14.940	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.todoist2/main.js:181:13)
                          todoist2.0	2020-10-09 17:35:14.940	error	at state_task_delete (/opt/iobroker/node_modules/iobroker.todoist2/main.js:200:10)
                          todoist2.0	2020-10-09 17:35:14.940	error	(26929) TypeError: Cannot read property 'val' of null
                          todoist2.0	2020-10-09 17:35:14.933	error	(26929) unhandled promise rejection: Cannot read property 'val' of null
                          Unhandled	2020-10-09 17:35:14.931	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          EDIT3: Nach mehrfachen neuinstallieren scheint das Problem nun behoben.
                            Habe gerade die letzten Beiträge gelesen und erfolgreich auf v0.7.3 geupdatet. Adapter wird auch wieder grün.
                            Danke und ein angenehmes Wochenende
                              @jukus100
                              Der Edit2 Fehler ist schon interesant..
                              Ich werde mal in meinen Code eine zusätzliche Sicherung einbauen, der den Fehler abfängt.
                              Aber wenn es jetzt klappt dann passt es ja 🙂
                              • jackblackson
                                jackblackson last edited by jackblackson
                                Ich bins mal wieder, mit einem Wunsch/Frage. Ich bin grad dran mein VIS etwas umzubauen, und würde die Tabelle gerne nur dann anzeigen, wenn mindestens ein ToDo drinnen ist. Nun frage ich mich grad, wie ich es in der Sichtbarkeit einstellen kann - würde es vielleicht Sinn machen, eine Möglichkeit anzubieten, dass die Tabelle leer ist, wenn kein ToDo verfügbar ist? Oder hast du eine Idee, wie ich das im VIS am besten machen kann?
                                Und cool wäre noch, das, wenn man keine Übersetzung für "Aufgabe" verwaltet, er keine leere Zeile in der Tabelle erzeugt - was meinst du dazu?
                                • jackblackson
                                  Hab grad noch die 0.7.3 installiert - sehr cool, das man den Namen nun ändern kann vom Button. Wie fändest du die Option, das man hier auch den Pfad für ein Icon verwalten kann - so einen Haken oder so?
                                  Weiter ist mir noch das "enge" Aufgaben aufgefallen - soll das so?
                                    rde-master Developer @jackblackson last edited by
                                    @jackblackson
                                    Klar ich kann eine Option einbauen, dass dann die HTML Tabelle nicht angezeigt wird.
                                    Dann ist die Tabelle aber ganz weg, auch keine Überschriften da....
                                    Das hab ich leider nicht verstanden 😞
                                    Wann und wo hättest du gerne das Icon anzeigen? Für was soll das Icon da sein?
                                    Das "enge" ist ein Übersetzungsfehler....werd ich korregieren.
                                    jackblackson 1 Reply Last reply Reply Quote 0
                                    • jackblackson
                                      jackblackson @rde-master last edited by
                                      @rde-master Ja, zumindest aus meiner Sicht würde es so am meisten Sinn machen, das dann alles weg ist. Aber vielleicht wirklich als Option, vielleicht freuen sich auch Leute, wenn sie eine Liste haben, wo steht "alles erledigt" 🙂
                                      Wegen der "Leeren Zeile": Ich hätte für meine VIS gerne keine Überschrift, nur rein die Aufgaben + Button. Hab den Inhalt im Feld "Name für das Aufgabenfeld" leer gemacht, aber dann erzeugt er trotzdem einen Header: f47830d7-f786-49e2-b3bf-542fd12c3ca7-grafik.png
                                      Und wegen dem Icon: statt OK hätte ich mir vorgestellt, ein Icon zu verwenden, im Button.
                                        @jackblackson
                                        Alles klar,.. ich schau mal was sich machen lässt 🙂
                                        • jackblackson
                                          @rde-master Ich bins mal wieder. Nutzt du die Funktion, Aufgaben über den Button abzuhaken, bei dir? Kann ich es irgendwie einstellen, dass eine Aufgabe, wenn ich sie abhake, gleich in der VIS verschwindet? Aktuell verschwindet sie ja glaub ich erst, wenn der Sync läuft.
                                            @jackblackson
                                            Ja, dafür suche ich auch schon eine Lösung.
                                            Das Problem aktuell dabei ist, dass der Button nicht weis, welche Tabelle es ist. Und somit eigenltich alle aktualisiert werden müssten, und da wird es schwirig.
                                            Und einen neuen API Call will ich nicht machen, hier versuche ich die Anzahl so gering wie möglich, pro Minute zu halten, da diese auf 50 Begrenzt sind.
                                            Ich baue gerade ein bisschen mehr um, und auch die anderen Punkte ein.
                                            Evtl. fällt mir dazu noch was ein,... ist aber auch mein Wunsch.... 🙂
                                            31.7k
                                            79.8k
                                            tester todoist
                                            18
                                            141
                                            11835
