    4. Netatmo?
    Netatmo?
      Smokey last edited by
      Hallo, kann mir vielleicht jemand helfen? Ich bekomme die Instanz nicht gestartet und erhalte folgende Fehlermeldung im Log:
      TypeError: 2016-07-24 01:29:46.004 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError: 2016-07-24 01:29:46.004 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError: 2016-07-24 01:29:46.004 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError: 2016-07-24 01:29:46.004 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError: 2016-07-24 01:29:46.004 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:389:29)
      TypeError: 2016-07-24 01:29:46.004 error at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2963:14)
      TypeError: 2016-07-24 01:29:46.004 error at Adapter.emit (events.js:104:17)
      TypeError: 2016-07-24 01:29:46.004 error at Adapter. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:66:15)
      TypeError: 2016-07-24 01:29:46.004 error at new netatmo (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:15:10)
      TypeError: 2016-07-24 01:29:46.004 error at netatmo.authenticate (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:125:12)
      TypeError: 2016-07-24 01:29:46.004 error undefined is not a function
      uncaught 2016-07-24 01:29:45.975 error exception: undefined is not a function
        steinwedel last edited by
        habe einen kleinen Fehler gefunden. Bei dem Device-Type Wind wird immer UNKNOWN DEVICE TYPE ausgegeben. Die Ursache ist, dass in netatmoStation.js nach Zeile 81 ein````
        break;
        Ansonsten wäre ich immer noch dankbar, wie man auf die Bilder und Videos von der Netatmo Welcome abrufen kann.
        Gerhard
          wep4you2 last edited by
          Hallo @steinwedel
          sorry war längere Zeit nicht im Forum Online, daher erst jetzt meine Antwort.
          Video Stream funktioniert nicht, dazu benötigt man extra Berechtigungen bei Netatmo, die man gesondert dort anfordern muss, daher habe ich das bisher noch nicht ausprobiert, bzw. implementiert.
          Die Bilder des Events bzw. der Person lade ich als Bildobjekt herunter, auf diese kannst du dann in VIS zugreifen. Die Url ist im jeweiligen JPG Object im Reiter Native gespeichert, hier ist nur der Host und Port zu ersetzen und kann in einem Bild Widget eingegeben werden:
          Beispiel:
          http://<vis-url>:<vis-port>/state/netatmo.0.WELCOME_HOME_NAME.Persons.Known.NAME_PERSON.jpg</vis-port></vis-url>
          Der String ist so gespeichert nur die beiden Einträge für vis-url und vis-port sind zu ersetzen.
          Hoffe das war halbwegs verständlich. Nachdem die Listensicht in Vis in der Struktur nicht funktioniert, arbeite ich noch an einer Möglichkeit das so abzuspeichern das es einfach in VIS zu verwenden ist, ev. mit einem eigenen JSON Object.
            ganz herzlichen Dank. Auch ich habe es jetzt verstanden. Vielleicht ergänzt Du die readme entsprechend. Eine dumme Frage: Könnte man nicht gleich die URL um Servernamen und Port ergänzen?
            Wäre schön, wenn Du den Fehler mit dem break; in der nächsten Version korrigieren könntest. Tolle Arbeit.
            Gruß Gerhard
              Noch eine Kleinigkeit:
              Woher kommt eigentlich der Ort der Cam? Bei mir wird der Nachbarort angegeben. Wenn ich auf der Webseite von Netatmo den Ort kontrolliere ist alles richtig.
              Gruß Gerhard
                @steinwedel:
                Vielleicht ergänzt Du die readme entsprechend. Eine dumme Frage: Könnte man nicht gleich die URL um Servernamen und Port ergänzen? `
                Nachdem ich ev. die Struktur noch ändern muss, erweitere ich das Realem, wenn alles wirklich fix so bleibt, ist mir noch etwas zu umständlich zum Handhaben.
                Ob ich den Servername und Port von der jeweiligen VIS Installation auslesen kann muss ich mal prüfen, ev. kann ich das dann ja noch einbauen.
                @steinwedel:
                Wäre schön, wenn Du den Fehler mit dem break; in der nächsten Version korrigieren könntest. Tolle Arbeit. `
                Den Netatmo Teil hat @PArt implementiert, ich submatte meine Änderungen vom Welcome Teil und schick sie ihm, er erstellt dann das Gesamtpaket, wenn ich meine Erweiterung durch hab, kann ich das mitnehmen, schneller gehts wenn das gleich er einbaut, kannst auf Git-Hub ja einen Issue aufmachen: https://github.com/PArns/ioBroker.netatmo
                @steinwedel:
                Woher kommt eigentlich der Ort der Cam? Bei mir wird der Nachbarort angegeben. Wenn ich auf der Webseite von Netatmo den Ort kontrolliere ist alles richtig. `
                Da werden die Werte ausgelesen die konfiguriert wurden und auf Netatmo gespeichert sind, sollte also genau das drinnen stehen, das du konfiguriert hast.
                  Leider konnte mir vor einiger Zeit schon niemand helfen… auch mit der neuesten Version des adapters habe ich noch folgende Fehlermeldung im Log. Wirklich niemand, der auch nur einen kleinen Hinweis hat?
                  TypeError: 2016-08-31 20:10:18.800 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                  TypeError: 2016-08-31 20:10:18.800 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  TypeError: 2016-08-31 20:10:18.800 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                  TypeError: 2016-08-31 20:10:18.800 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                  TypeError: 2016-08-31 20:10:18.800 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:392:29)
                  TypeError: 2016-08-31 20:10:18.800 error at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2998:14)
                  TypeError: 2016-08-31 20:10:18.800 error at Adapter.emit (events.js:104:17)
                  TypeError: 2016-08-31 20:10:18.800 error at Adapter. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:69:15)
                  TypeError: 2016-08-31 20:10:18.800 error at new netatmo (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:15:10)
                  TypeError: 2016-08-31 20:10:18.800 error at netatmo.authenticate (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:125:12)
                  TypeError: 2016-08-31 20:10:18.800 error undefined is not a function
                  uncaught 2016-08-31 20:10:18.772 error exception: undefined is not a function
                  netatmo-0 2016-08-31 20:10:18.718 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.netatmo
                  host-raspberrypi 2016-08-31 20:10:14.286 info instance system.adapter.netatmo.0 started with pid 14581
                  host-raspberrypi 2016-08-31 20:10:08.311 info Restart adapter system.adapter.netatmo.0 because enabled
                    bei mir läuft der netatmo-Adapter. Das ist natürlich kein Trost für Dich, aber damit weißt Du, dass der Adapter grundsätzlich funktioniert.
                    Ich würde den Adapter mal ganz deinstallieren (also nicht nur Instanzen) und dann direkt von Github neu installieren. Mache dies am Besten von der Konsole, damit wirklich alles ersetzt werden kann.
                    Gruß Gerhard
                      Hallo Gerhard,
                      hab ich jetzt gemacht. Ändert leider nichts an der Fehlermeldung. Trotzdem Danke für den Tipp!
                      Markus
                        Hallo wep4you2,
                        sagt dir vielleicht der Auszug aus dem Log irgendwas, was mir einen Hinweis auf den Fehler geben könnte? Wäre ganz klasse. Ich hab meine Netatmo zwar schon in iobroker verbunden, aber eben über den aufwändigen Weg und der Adapter wäre ne coole Sache.
                        Danke schon mal
                        Markus
                          MattiHamburg last edited by
                          Hallo erst mal aus dem schönen Norden.
                          Ich bin auch eine begeisterter ccuio und jetzt ioBroker Nutzer. Ich taste mich da von Adapter zu Adapter heran.
                          Mein System läuft auf einer Cubox sehr stabil. Alles gerade platt gemacht und auf den neusten Stand.
                          Meine CCU umfasst bis jetzt 54 Komponenten und wächst stetig
                          Meine neueste Errungenschaft ist die Netatmo Wetterstation komplett mit Wind und Regensensor.
                          Nun habe ich diverse Versuche unternommen euren Adapter zum laufen zu bringen.
                          Wie schon gesagt gesamte System neu aufgesetzt. Alles hat nicht geholfen.
                          Sonst konnte ich mir immer selber weiter helfen indem ich in eure Beiträge gelesen hab
                          Folgen Fehler erscheinen im Log
                          host-cubox-i	2016-10-16 14:18:15.530	info	Restart adapter system.adapter.netatmo.0 because enabled
                          host-cubox-i	2016-10-16 14:18:15.530	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
                          netatmo-0	2016-10-16 14:18:15.484	info	terminating
                          TypeError:	2016-10-16 14:18:14.959	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                          TypeError:	2016-10-16 14:18:14.959	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          TypeError:	2016-10-16 14:18:14.959	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                          TypeError:	2016-10-16 14:18:14.959	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                          TypeError:	2016-10-16 14:18:14.959	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:394:29)
                          TypeError:	2016-10-16 14:18:14.959	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3004:14)
                          TypeError:	2016-10-16 14:18:14.959	error	at Adapter.emit (events.js:104:17)
                          TypeError:	2016-10-16 14:18:14.959	error	at Adapter. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:69:15)
                          TypeError:	2016-10-16 14:18:14.959	error	at new netatmo (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:15:10)
                          TypeError:	2016-10-16 14:18:14.959	error	at netatmo.authenticate (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:125:12)
                          TypeError:	2016-10-16 14:18:14.959	error	undefined is not a function
                          uncaught	2016-10-16 14:18:14.937	error	exception: undefined is not a function
                          netatmo-0	2016-10-16 14:18:14.901	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.netatmo
                          Habt ihr eine Ahnung was ich falsch mache
                          Danke für die Hilfe
                          Geändert Homoran Code in codetags
                            tgirard last edited by
                            Guten Morgen
                            Der Adapter sieht vielversprechend aus. Wenn ich ihn starte, dann beendet er leider gleich wieder mit:
                            host-bananapi	2016-12-09 06:51:37.844	error	instance system.adapter.netatmo.0 terminated with code 6 (uncaught exception)
                            TypeError:	2016-12-09 06:51:36.686	error	at Request.emit (events.js:172:7)
                            TypeError:	2016-12-09 06:51:36.686	error	at emitTwo (events.js:87:13)
                            TypeError:	2016-12-09 06:51:36.686	error	at Request.self.callback (/root/node_modules/iobroker.netatmo/node_modules/netatmo-homey/node_modules/request/request.js:186:22)
                            TypeError:	2016-12-09 06:51:36.686	error	at null. (/root/node_modules/iobroker.netatmo/node_modules/netatmo-homey/netatmo.js:388:14)
                            TypeError:	2016-12-09 06:51:36.686	error	at /root/node_modules/iobroker.netatmo/netatmoStation.js:14:26
                            TypeError:	2016-12-09 06:51:36.686	error	at Array.forEach (native)
                            TypeError:	2016-12-09 06:51:36.686	error	at /root/node_modules/iobroker.netatmo/netatmoStation.js:15:25
                            TypeError:	2016-12-09 06:51:36.686	error	at handleDevice (/root/node_modules/iobroker.netatmo/netatmoStation.js:32:13)
                            TypeError:	2016-12-09 06:51:36.686	error	at handleDevice (/root/node_modules/iobroker.netatmo/netatmoStation.js:34:30)
                            TypeError:	2016-12-09 06:51:36.686	error	at getDeviceName (/root/node_modules/iobroker.netatmo/netatmoStation.js:25:27)
                            TypeError:	2016-12-09 06:51:36.686	error	Cannot read property 'replaceAll' of undefined
                            uncaught	2016-12-09 06:51:36.665	error	exception: Cannot read property 'replaceAll' of undefined
                            netatmo-0	2016-12-09 06:51:33.674	info	starting. Version 0.4.1 in /root/node_modules/iobroker.netatmo
                            kann mir hier jemand helfen?
                            vielen Dank!
                            Thierry
                              PArt last edited by
                              Nach langem Warten gibt es noch einmal ein Update für den Adapter.
                              Beachtet bitte, das ihr eine aktuelle Node-Version verwendet (>= 4)!
                              Neu ist, das die Welcome & Presence jetzt realtime updates versenden…
                              Wenn ihr Probleme habt, so gebt mir bitte kurz bescheid. An meine 2 Vorredner: Checkt bitte einmal eure Node-Version! Ich habe das original Repo des homey-netatmo Projekt aber gerade geforkt und hier bereits einige Fehler behoben....
                                gst666 last edited by
                                Version 1.0.0 des netatmo Adapters hat bei mir Probleme mit der Welcome Kamera. Anscheinend kann sich der Treiber nicht authentisieren. Nutze ich nur die Wetterstation, ist alles OK.
                                Nutze node 4.7.2
                                Hier das Fehlerlog
                                Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                                automation	2017-01-29 09:49:34.198	info	host.automation Restart adapter system.adapter.netatmo.0 because enabled
                                automation	2017-01-29 09:49:34.197	error	host.automation instance system.adapter.netatmo.0 terminated with code 0 (OK)
                                netatmo.0	2017-01-29 09:49:33.684	info	netatmo.0 Registering realtime events with https://iobroker.herokuapp.com/netatmo/
                                netatmo.0	2017-01-29 09:49:33.684	info	netatmo.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
                                host.automation	2017-01-29 09:49:33.101	info	instance system.adapter.netatmo.0 started with pid 20122
                                host.automation	2017-01-29 09:49:29.528	info	Restart adapter system.adapter.netatmo.0 because enabled
                                host.automation	2017-01-29 09:49:29.528	error	instance system.adapter.netatmo.0 terminated with code 0 (OK)
                                netatmo.0	2017-01-29 09:49:29.511	info	terminating
                                netatmo.0	2017-01-29 09:49:29.508	info	cleaned everything up...
                                netatmo.0	2017-01-29 09:49:29.507	info	Unregistering realtime events
                                netatmo.0	2017-01-29 09:49:29.506	error	at IncomingMessage.g (events.js:260:16)
                                netatmo.0	2017-01-29 09:49:29.506	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:1001:12)
                                netatmo.0	2017-01-29 09:49:29.506	error	at Request.emit (events.js:169:7)
                                netatmo.0	2017-01-29 09:49:29.506	error	at emitOne (events.js:77:13)
                                netatmo.0	2017-01-29 09:49:29.506	error	at Request. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:1081:10)
                                netatmo.0	2017-01-29 09:49:29.506	error	at Request.emit (events.js:172:7)
                                netatmo.0	2017-01-29 09:49:29.506	error	at emitTwo (events.js:87:13)
                                netatmo.0	2017-01-29 09:49:29.506	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/node_modules/request/request.js:186:22)
                                netatmo.0	2017-01-29 09:49:29.506	error	at null. (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/netatmo.js:156:25)
                                netatmo.0	2017-01-29 09:49:29.506	error	at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/node_modules/netatmo/netatmo.js:46:17)
                                netatmo.0	2017-01-29 09:49:29.506	error	Error: Authenticate error: invalid_request
                                netatmo.0	2017-01-29 09:49:29.504	error	uncaught exception: Authenticate error: invalid_request
                                netatmo.0	2017-01-29 09:49:29.311	info	Registering realtime events with https://iobroker.herokuapp.com/netatmo/
                                netatmo.0	2017-01-29 09:49:29.235	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v4.7.2
                                host.	2017-01-29 09:49:29.221	info	States connected to redis 127.0.0.1:6379
                                host.automation	2017-01-29 09:49:28.743	info	instance system.adapter.netatmo.0 started with pid 20112
                                  PArt last edited by
                                  Ok, mist, habe das Problem gefunden … Netatmo erlaubt den Zugriff auf diese Daten nur aus einem speziellen Scope, der NUR für den eigenen Account funktioniert 😞 Ich werde gleich einen Workaround veröffentlichen
                                  Danke für die Meldung
                                    PArt last edited by
                                    Habe direkt bei Netatmo einen Request gestellt, das der Scope mit der aktuellen AppID abgerufen werden darf … Warte noch auf Antwort
                                      Danke für Dein Update. Mit dem eigenen App-Key scheint es jetzt auch mit der Welcome-Kamera zu gehen. Jetzt habe ich aber leider doch noch eine Frage: Wie kann ich den Live-Stream mir in iobroker anzeigen lassen. Die URL für das Bild funktioniert. Bei dem Live-Stream bekomme ich eine m3u8-Datei. Soweit schön. In dieser sind dann Streams mit verschiedenen Auflösungen enthalten. Wie kann ich diesen mit den Widgets von iobroker verwenden?
                                      Wie sähe die URL aus? Muss ich erst mit einer Javascript-App eine passende erzeugen?
                                        PArt last edited by
                                        Die m3u8 Datei ist der Stream, normalerweise sollte diese von jedem Mediaplayer/Browser wiedergegeben werden können. Wie man diese in VIS anbindet, da bin ich leider etwas überfragt, da können dir hier die VIS-Profis sicherlich besser helfen …
                                        Du kannst die m3u8 aber auch in einem Texteditor öffnen. Diese beinhaltet die URLs für die einzelnen Auflösungen und Qualitäten (m3u Files)
                                          Bradock last edited by
                                          Habe heute die erste Presence montiert.
                                          Werde sie in Verbindung mit dem neuen Adapter testen.
                                          An dieser Stelle großen Dank an PArt
                                          Hoffe für die Stream-Einbindung in VIS findet sich auch noch ein Weg 😉
                                          Gruß Sascha
                                            Dinosky last edited by
                                            bisher lief dein Adapter perfekt bis zur Version 0.41, ab da ließ er sich nicht mehr Updaten.
                                            Habe Testhalber auf einer Synology iobroker installiert mit node.js 4.4.2
                                            Selbst auf der neu installation bekomme ich deinen Adapter nicht mehr zum laufen.
                                            Anbei der Log vielleicht kannst du mir einen Tip geben.
                                            Gruß Dinosky
                                            Log:
                                            $ ./iobroker add netatmo
                                            npm install iobroker.netatmo –production --prefix "/volume1/homes/admin/opt/iobroker" (System call)
                                            npm
                                            WARN
                                            addRemoteGit Error: not found: gitnpm
                                            WARN addRemoteGit at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)npm
                                            WARN addRemoteGit at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
                                            npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                                            npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                                            npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
                                            npm
                                            WARN addRemoteGit git+https://github.com/PArns/netatmo.git resetting remote /var/services/homes/admin/.npm/_git-remotes/https-github-com-PArns-netatmo-git-64c84a8d because of error: { [Error: not found: git] code: 'ENOGIT' }
                                            npm
                                            ERR! git clone –template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/PArns/netatmo.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-PArns-netatmo-git-64c84a8d: undefinednpm ERR! git clone --template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/PArns/netatmo.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-PArns-netatmo-git-64c84a8d:
                                            undefined
                                            npm
                                            ERR!
                                            Linux 3.10.77npm ERR!
                                            argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.netatmo" "--production" "--prefix" "/volume1/homes/admin/opt/iobroker"npm ERR! node v4.4.2
                                            npm ERR! npm
                                            v2.15.0npm
                                            ERR! code ENOGIT
                                            npm ERR!
                                            not found: gitnpm ERR!
                                            npm ERR! Failed using git.
                                            npm ERR! This is most likely not a problem with npm itself.
                                            npm ERR!
                                            Please check if you have git installed and in your PATH.
                                            npm ERR! Please include the following file with any support request:npm ERR!
                                            /volume1/homes/admin/opt/npm-debug.log
                                            ERROR: host.DiskStation Cannot install iobroker.netatmo: 1
                                            ERROR: process exited with code 25
                                            140
                                            35511
