    4. [neuer Adapter] smartgarden adapter for Gardena smart system
    • jpgorganizer
      jpgorganizer @michihorn last edited by
      @michihorn
      Was steht im Log? LogLevel auf 3
      VG jpgorganizer
        michihorn @jpgorganizer last edited by
        @jpgorganizer ```
        smartgarden.0 2020-09-25 20:12:44.180 info (6060) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:44.180 info (6060) 3/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0 2020-09-25 20:12:44.178 error (6060) Error: getlocations: no data
        smartgarden.0 2020-09-25 20:12:44.019 info (6060) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:44.019 info (6060) 3/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0 2020-09-25 20:12:44.018 info (6060) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:44.018 info (6060) 3/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0 2020-09-25 20:12:44.014 info (6060) 3/ get_locations ...
        smartgarden.0 2020-09-25 20:12:44.014 info (6060) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0 2020-09-25 20:12:44.013 info (6060) 3/ sgSetState: info.connection value=true ack=true
        smartgarden.0 2020-09-25 20:12:44.013 info (6060) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0 2020-09-25 20:12:43.665 info (6060) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:43.665 info (6060) 3/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
        smartgarden.0 2020-09-25 20:12:43.664 info (6060) 3/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0 2020-09-25 20:12:43.639 info (6060) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0 2020-09-25 20:12:43.639 info (6060) 3/ sgSetState: info.revision value=Main: 2160 / API: 2250 ack=true
        smartgarden.0 2020-09-25 20:12:43.632 info (6060) starting. Version 1.0.2 in C:/iobroker/SmartHome/node_modules/iobroker.smartgarden, node: v12.18.3, js-controller: 3.1.6
        smartgarden.0 2020-09-25 20:12:39.817 info (3796) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartgarden.0 2020-09-25 20:12:39.817 info (3796) terminating
        smartgarden.0 2020-09-25 20:12:39.816 info (3796) 3/ cleaned everything up...
        smartgarden.0 2020-09-25 20:12:39.816 info (3796) Got terminate signal TERMINATE_YOURSELF
        smartgarden.0 2020-09-25 20:12:35.624 info (3796) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:35.623 info (3796) 3/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0 2020-09-25 20:12:35.621 error (3796) Error: getlocations: no data
        smartgarden.0 2020-09-25 20:12:35.486 info (3796) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:35.486 info (3796) 3/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0 2020-09-25 20:12:35.485 info (3796) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:35.485 info (3796) 3/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0 2020-09-25 20:12:35.479 info (3796) 3/ get_locations ...
        smartgarden.0 2020-09-25 20:12:35.479 info (3796) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0 2020-09-25 20:12:35.479 info (3796) 3/ sgSetState: info.connection value=true ack=true
        smartgarden.0 2020-09-25 20:12:35.478 info (3796) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0 2020-09-25 20:12:34.783 info (3796) 3/ ---> State change by device
        smartgarden.0 2020-09-25 20:12:34.783 info (3796) 3/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
        smartgarden.0 2020-09-25 20:12:34.782 info (3796) 3/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0 2020-09-25 20:12:34.761 info (3796) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0 2020-09-25 20:12:34.760 info (3796) 3/ sgSetState: info.revision value=Main: 2160 / API: 2250 ack=true
        smartgarden.0 2020-09-25 20:12:34.754 info (3796) starting. Version 1.0.2 in C:/iobroker/SmartHome/node_modules/iobroker.smartgarden, node: v12.18.3, js-controller: 3.1.6
        smartgarden.0 2020-09-25 20:12:30.943 info (12304) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartgarden.0 2020-09-25 20:12:30.942 info (12304) terminating
        smartgarden.0 2020-09-25 20:12:30.942 info (12304) Got terminate signal TERMINATE_YOURSELF
        smartgarden.0 2020-09-25 20:12:26.756 error (12304) Error: getlocations: no data
        smartgarden.0 2020-09-25 20:12:26.260 info (12304) starting. Version 1.0.2 in C:/iobroker/SmartHome/node_modules/iobroker.smartgarden, node: v12.18.3, js-controller: 3.1.6
        smartgarden.0 2020-09-25 20:12:22.453 info (8344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartgarden.0 2020-09-25 20:12:22.453 info (8344) terminating
        smartgarden.0 2020-09-25 20:12:22.452 info (8344) Got terminate signal TERMINATE_YOURSELF
        • jpgorganizer
          jpgorganizer @jpgorganizer last edited by jpgorganizer
          Es kommen keine Daten von Gardena.
          get_locations : no data
          Warum auch immer. Es gab im Mai mal Probleme mit der API von Gardena. Wurde aber seitens Gardena gefixed. Seitdem ist Ruhe in der Sache, aber bei dir ??????
          Versuch mal das hier
          https://github.com/jpgorganizer/test4smartgarden/tree/master/apitestscript
          Wenn du dort den gleichen Fehler bekommst, dann können wir Gardena mal fragen, wenn das geht, dann muss das im Adapter auch gehen.
          Grüße jpgorganizer
            @jpgorganizer es läuft nun wieder, offenbar war das Connected To strubellig
            Michael und Thanks for support
              stevie77 @michihorn last edited by
              @michihorn sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
              Was soll das heißen? Temporärer Fehler bei Husquarna/Gardena? Ich hab den Fehler auch seit heute, Adapter bleibt gelb. Meine Skripte konnten seit gestern zwar noch fehlerfrei die Befehle/States an den Adapter setzen, aber gestern gab es keine Bewässerung durch die Gartenpumpe und heute wollte der Mäher seine Arbeit bei Regen nicht unterbrechen. Suchte den Fehler erst im Skript, aber dann sah ich, dass der Adapter gelb ist...
              Hat sich das von allein gelöst?
              @jpgorganizer Oder hat Gardena die URL geändert? Hier steht für die GARDENA smart system API wäre die URL https://api.smart.gardena.dev/v1; im Adapter steht Standard https://api.smart.gardena.dev. Was ist nun richtig? Könnte es daran liegen oder sind beide URLs okay?
              S jpgorganizer 2 Replies Last reply Reply Quote 0
                stevie77 @stevie77 last edited by
                Ah, sehe gerade, dass das /v1 wohl überall angehängt wird, u.a. in dem Test-Skript.
                r = requests.get(f'{SMART_HOST}/v1/locations', headers=headers)
                Da hat sich nun auch gezeigt, dass ich scheinbar über dem Rate Limit liege.
                ### get locations ###
                Traceback (most recent call last):
                  File "ws_test.py", line 80, in <module>
                    assert r.status_code == 200, format(r)
                AssertionError: https://api.smart.gardena.dev/v1/locations
                429
                Content-Type: application/json
                Content-Length: 28
                Connection: keep-alive
                Date: Sat, 10 Oct 2020 19:18:21 GMT
                x-amzn-RequestId: 4aff2328-7ad8-418a-9036-b41a5faa6e54
                x-amzn-ErrorType: LimitExceededException
                x-amz-apigw-id: UNZXlEDPjoEF8xg=
                X-Cache: Error from cloudfront
                Wenn ich das Adapter-Logfile ansehe, weiß ich nun auch warum. Ich hab fahrlässig für einen Eisfreihalter (Heizstab) für den Teich alle 5 min einen Befehl mit einschalten oder ausschalten abgeschickt. Da bin ich dann schnell über den 3.000, das Skript läuft schon ne Weile.
                Die Frage ist jetzt nur, entsperrt sich das von alleine und wenn ja wie schnell? Oder soll ich gleich nen neuen Key erstellen?
                  @stevie77 Hat sich erledigt, mit neuem Key läuft es nun wieder und ich muss nun meine Skripte nochmals auf Sparsamkeit der Aufrufe durchforsten. 😉
                  • jpgorganizer
                    jpgorganizer @stevie77 last edited by
                    @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                    Sieht so aus .... das /v1 hatte die Tage schon mal ein Nutzer des Adapters genutzt. Da war ich noch der Meinung, dass das falsch ist. Jetzt sieht es so aus, als ob Gardena da was ändert. Aber zumindest bei mir funktioniert alles mit der bisherigen URL (ohne /v1) immer noch. Wir werden sehen was dabei rauskommt. Ich hatte mich eh schon gewundert, dass Gardena keine solche Versionierung in der URL drin hat. Dies erleichert die Weiterentwicklung und den parallelen Support von "Alt"-Applikationen ungemein. Ich erwarte, dass Gardena in nächster Zeit eine neue Version der API veröffentlicht (wann immer das sein mag .... Frühjahr vielleicht? ... das wäre die Zeit, wo Gardena Geräte die größte Verwendung finden ???) Ob da dann neue Features implementiert sein werden? Bin gespannt.
                    neuer Key hilft sofort. Ansonsten wird dein Key wieder freigeschaltet, einfach abwarten. Aber du musst natürlich aufpassen, dass du nicht gleich wieder über dem Limit bist. Du solltest dein Script überarbeiten!
                    Doku von AWS für solches limithandling: Die AWS-Dokumentation: https://docs.aws.amazon.com/apigateway/latest/developerguide/api-gateway-request-throttling.html
                    VG jpgorganizer
                      stevie77 @jpgorganizer last edited by
                      @jpgorganizer Danke für deine Antwort. Wie schon weiter unten geschrieben, hängt Gardena das /v1 wohl selbstständig an, zumindest sieht es in dem Testskript so aus. Und auch bei mir funktioniert es wieder mit der Standard-URL wie vom Adapter vorgeschlagen. Habe zwei meiner Skripte identifiziert, wo ich nun das unnötige spammen abfange. Und schon hat sich der Rasenmäher heute schön ins Häuschen zurückgezogen, als der Regenmesser Regen funkte... 🙂
                        dazilla last edited by
                        ich habe den Key gelöscht und einen neuen angelegt, leider funktioniert es trotzdem nicht und der Adapter bleibt gelb.
                        Liegt es vielleicht daran, dass ich die Application gelöscht habe statt einfach den Key zu renewen? Hab ich noch etwas vergessen? Den neuen Key habe ich in iobroker eingetragen.
                        jpgorganizer D 2 Replies Last reply Reply Quote 0
                        • jpgorganizer
                          jpgorganizer @dazilla last edited by
                          @dazilla sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          und wie bitte soll man dir helfen?
                            dazilla @dazilla last edited by dazilla
                            Hat sich erledigt. Ich hatte einen API connect vergessen nach dem Erzeugen eines neuen Keys.
                            • jpgorganizer
                              @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                              oje, irgendwie war ich wohl nicht ganz auf der Höhe, als ich die o.a. Antwort geschrieben habe. Vergesst einfach was ich dort geschrieben habe. Ist komplett falsch.
                              Ich korrigiere hiermit meine Antwort: die richtige URL ist https://api.smart.gardena.dev. Kein /v1 hintendran, das hängt der Adapter selbstständig an. Das macht auch Sinn, denn der Adapter weiß, welche Version der Schnittstelle er unterstützt. Also alles so, wie im Readme beschrieben.
                              Man sollte seiner eigenen Doku ab und an trauen.
                              Sorry, das hatte ich nicht mehr auf dem Schirm. Somit gab es da auch keine Änderung seitens Gardena.
                              VG jpgorganizer
                              • chucky666
                                chucky666 last edited by
                                Hallo
                                Ich habe seit heute den Fehler error 429 . Adapter bleibt gelb
                                Woran könnte es liegen ?
                                • jpgorganizer
                                  jpgorganizer @chucky666 last edited by
                                  @chucky666
                                  Fehler 429 heißt meiner Ansicht nach, dass du die Limits gerissen hast. Warum auch immer?
                                  Ansonsten mal das Testscript ausprobieren oder einfach mal ein bisschen warten. Wenn es die Limits sind, dann gibt sich das wieder, wobei das Grundproblem dann trotz allem weiterbesteht.
                                  @All
                                  seit heute Mittag bekomme ich selbst immer den Error 401 Unauthorized. D.h. ich kann mich selbst nicht mehr einloggen. Sieht für mich nicht nach einem Problem des Adapter aus, denn mit dem Testscript kommt der gleiche Fehler. Ich habe mich schon mal an Gardena gewandt.
                                  Bekommt sonst noch jemand einen Fehler?
                                  VG jpgorganizer
                                  chucky666 JohGre 2 Replies Last reply Reply Quote 0
                                  • chucky666
                                    chucky666 @jpgorganizer last edited by
                                    Danke dir
                                    Ich warte mal ab . Shaun ist eh im Winterschlaf
                                    @chucky666
                                    @All
                                    VG jpgorganizer
                                    • JohGre
                                      JohGre @jpgorganizer last edited by
                                      Ich komme weiter ohne Probleme rein, Adapter ist Grün und liefert Werte
                                        stevie77 @JohGre last edited by
                                        @JohGre sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                        Bei mir läuft auch alles normal, Werte kommen an.
                                        jpgorganizer 1 Reply Last reply Reply Quote 0
                                        • jpgorganizer
                                          Gardena hat den Fehler 401 bestätigt --- Sie sind dran.
                                          VG jpgorganizer
                                          • JohGre
                                            Habe seit heute folgende Fehlermeldungen im Log. Hängt das mit dem 401-er Problem zusammen?
                                            2020-10-24 10:27:00.087 - debug: smartgarden.0 (3910) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                            2020-10-24 10:27:00.105 - debug: smartgarden.0 (3910) Objects client ready ... initialize now
                                            2020-10-24 10:27:00.107 - debug: smartgarden.0 (3910) Objects create System PubSub Client
                                            2020-10-24 10:27:00.108 - debug: smartgarden.0 (3910) Objects create User PubSub Client
                                            2020-10-24 10:27:00.109 - debug: smartgarden.0 (3910) Objects client initialize lua scripts
                                            2020-10-24 10:27:00.122 - debug: smartgarden.0 (3910) Objects connected to redis: 0.0.0.0:9001
                                            2020-10-24 10:27:00.125 - debug: smartgarden.0 (3910) objectDB connected
                                            2020-10-24 10:27:00.126 - debug: smartgarden.0 (3910) Redis States: Use Redis connection: 0.0.0.0:9000
                                            2020-10-24 10:27:00.131 - debug: smartgarden.0 (3910) States create User PubSub Client
                                            2020-10-24 10:27:00.132 - debug: smartgarden.0 (3910) States create System PubSub Client
                                            2020-10-24 10:27:00.140 - debug: smartgarden.0 (3910) States connected to redis: 0.0.0.0:9000
                                            2020-10-24 10:27:00.141 - debug: smartgarden.0 (3910) statesDB connected
                                            2020-10-24 10:27:00.871 - info: smartgarden.0 (3910) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.19.0, js-controller: 3.1.6
                                            2020-10-24 10:27:00.898 - info: smartgarden.0 (3910) 3/ sgSetState: info.revision value=Main: 2160 / API: 2250 ack=true
                                            2020-10-24 10:27:00.899 - info: smartgarden.0 (3910) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                                            2020-10-24 10:27:00.951 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.connection changed: false (ack = true)
                                            2020-10-24 10:27:00.951 - info: smartgarden.0 (3910) 3/ ---> State change by device
                                            2020-10-24 10:27:00.952 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
                                            2020-10-24 10:27:00.952 - info: smartgarden.0 (3910) 3/ ---> State change by device
                                            2020-10-24 10:27:00.965 - info: smartgarden.0 (3910) 3/ state smartgarden.0.testVariable changed: true (ack = false)
                                            2020-10-24 10:27:00.965 - info: smartgarden.0 (3910) 3/ ---> Command should be sent to device
                                            2020-10-24 10:27:01.239 - info: smartgarden.0 (3910) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
                                            2020-10-24 10:27:01.240 - info: smartgarden.0 (3910) 3/ sgSetState: info.connection value=true ack=true
                                            2020-10-24 10:27:01.241 - info: smartgarden.0 (3910) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXX-XXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XX-XXXXXXXXXXXXXXXXXXXXXXXXXXXX-X
                                            2020-10-24 10:27:01.242 - info: smartgarden.0 (3910) 3/ get_locations ...
                                            2020-10-24 10:27:01.253 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.connection changed: true (ack = true)
                                            2020-10-24 10:27:01.256 - info: smartgarden.0 (3910) 3/ ---> State change by device
                                            2020-10-24 10:27:01.261 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.connection changed: true (ack = true)
                                            2020-10-24 10:27:01.262 - info: smartgarden.0 (3910) 3/ ---> State change by device
                                            2020-10-24 10:27:01.556 - error: smartgarden.0 (3910) uncaught exception: Unexpected end of JSON input
                                            2020-10-24 10:27:01.557 - error: smartgarden.0 (3910) SyntaxError: Unexpected end of JSON input
                                            at JSON.parse ()
                                            at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29)
                                            at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                            at Request.emit (events.js:314:20)
                                            at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
                                            at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
                                            at Object.onceWrapper (events.js:420:28)
                                            at IncomingMessage.emit (events.js:326:22)
                                            at endReadableNT (_stream_readable.js:1223:12)
                                            2020-10-24 10:27:01.558 - info: smartgarden.0 (3910) 3/ cleaned everything up...
                                            2020-10-24 10:27:01.602 - info: smartgarden.0 (3910) terminating
                                            2020-10-24 10:27:01.603 - info: smartgarden.0 (3910) Terminated (NO_ERROR): Without reason
                                            2020-10-24 10:27:02.123 - info: host.vm-iobroker instance system.adapter.smartgarden.0 terminated with code 0 (NO_ERROR)
                                            2020-10-24 10:27:02.123 - info: host.vm-iobroker Restart adapter system.adapter.smartgarden.0 because enabled
                                            2020-10-24 10:27:12.727 - info: host.vm-iobroker "system.adapter.smartgarden.0" disabled
                                            2020-10-24 10:27:33.317 - error: smartgarden.0 (4056) adapter disabled
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            287685
