    4. Zigbee cc2538 und Philips Hue Bewegungsmelder
    • Asgothian
      Asgothian Developer @peterfido last edited by
      @peterfido
      Es scheint so zu sein das sich der Bewegungsmelder aktiv abmeldet, und dann beim anmelden nicht konfiguriert werden kann.
      Die Abfrage selber kann keinen Effekt haben, da sie nur den Datenpunkt selber abfragt, nicht den Sensor.
      A.
        peterfido @Asgothian last edited by
        @Asgothian
        Ja, das dachte ich mir auch. Aber wieso lief es die ganze Zeit durch, wenn jede Minute ein Skript den Datenpunkt abfragt?
        Auffällig im Log finde ich, dass der Bewegungsmelder regelmäßig seine Attribute sendet:
        2020-10-01 09:20:16.392  - debug: zigbee.0 (10503) Publish {"battery":100,"voltage":3015}
        2020-10-01 09:20:16.392  - debug: zigbee.0 (10503) Publish {"contact":false}
        2020-10-01 09:20:24.237  - debug: zigbee.0 (10503) Failed to ping 0x7cb03eaa0a014714 Plug 01
        2020-10-01 09:21:01.260  - debug: zigbee.0 (10503) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1830}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601536861260},"endpoint":"[Circular]","data":{"batteryPercentageRemaining":200},"linkquality":78,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":39,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
        2020-10-01 09:21:01.260  - debug: zigbee.0 (10503) Received Zigbee message from '0x0017880104b71362', type 'attributeReport', cluster 'genPowerCfg', data '{"batteryPercentageRemaining":200}' from endpoint 2 with groupID 0
        2020-10-01 09:21:01.261  - debug: zigbee.0 (10503) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1830}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601536861260},"mapped":{"zigbeeModel":["SML001"],"model":"9290012607","vendor":"Philips","description":"Hue motion sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x0017880104b71362"} incoming event: {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1830}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601536861260},"endpoint":"[Circular]","data":{"batteryPercentageRemaining":200},"linkquality":78,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":39,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
        2020-10-01 09:21:01.262  - debug: zigbee.0 (10503) Publish {"battery":100}
        2020-10-01 09:21:17.882  - debug: zigbee.0 (10503) Non-pingable device 0x0017880104b71362 SML001 was last seen '16.622' seconds ago.
        Ich habe den BWM neu angelernt und die minütliche Abfrage wieder eingeschaltet. Mal sehen, ob er jetzt erhalten bleibt.
        • Asgothian
          @peterfido das regelmäßige senden ist normal. Das er nicht auf einen Ping antwortet auch. Kannst du mal im log vom Fehler nachgehen wie lange es dauert zwischen der letzten Statusmeldungen und dem Abmelden des Sensors ?
          A.
            peterfido @Asgothian last edited by peterfido
            @Asgothian
            So wie ich das sehe, etwa 24 Sekunden.
            Ich habe den Log der letzten zwei Tage, wo der BWM vorkommt, mal angehängt.Hue BWM Zigbee Protokoll.zip
            Also den Tag der Abmeldung des BWM sowie den davor.
            Edit:
            Um 15:27:55 Uhr ging es wohl los. Da kamen die ersten "neuen" Meldungen.
            2020-10-02 15:27:53.957  - debug: zigbee.0 (10503) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645273955},"mapped":{"zigbeeModel":["SML001"],"model":"9290012607","vendor":"Philips","description":"Hue motion sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x0017880104b71362"} incoming event: {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645273955},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":84,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":248,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2020-10-02 15:27:55.750  - debug: zigbee.0 (10503) handleDeviceAnnounce. {"device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645275750}}
            2020-10-02 15:27:55.750  - debug: zigbee.0 (10503) Device '0x0017880104b71362' announced itself
            2020-10-02 15:27:55.750  - debug: zigbee.0 (10503) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645275750},"mapped":{"zigbeeModel":["SML001"],"model":"9290012607","vendor":"Philips","description":"Hue motion sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x0017880104b71362"}
            2020-10-02 15:27:55.765  - debug: zigbee.0 (10503) handleDeviceAnnounce. {"device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645275765}}
            2020-10-02 15:27:55.766  - debug: zigbee.0 (10503) Device '0x0017880104b71362' announced itself
            2020-10-02 15:27:55.766  - debug: zigbee.0 (10503) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645275765},"mapped":{"zigbeeModel":["SML001"],"model":"9290012607","vendor":"Philips","description":"Hue motion sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x0017880104b71362"}
            2020-10-02 15:27:56.751  - debug: zigbee.0 (10503) Publish available for 0x0017880104b71362 = true
            2020-10-02 15:27:56.767  - debug: zigbee.0 (10503) Publish available for 0x0017880104b71362 = true
            2020-10-02 15:28:04.005  - debug: zigbee.0 (10503) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645284005},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":251,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2020-10-02 15:28:04.006  - debug: zigbee.0 (10503) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645284006},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":251,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2020-10-02 15:28:04.006  - debug: zigbee.0 (10503) Received Zigbee message from '0x0017880104b71362', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 2 with groupID 0
            2020-10-02 15:28:04.007  - debug: zigbee.0 (10503) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645284006},"mapped":{"zigbeeModel":["SML001"],"model":"9290012607","vendor":"Philips","description":"Hue motion sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x0017880104b71362"} incoming event: {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x0017880104b71362","_networkAddress":31156,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genBasic":{"attributes":{"modelId":"SML001","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20190219","swBuildId":"6.1.1.27575"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":31156,"deviceIeeeAddress":"0x0017880104b71362","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1929}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":5864}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML001","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20190219","_softwareBuildID":"6.1.1.27575","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1601645284006},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":251,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
            2020-10-02 15:28:04.007  - debug: zigbee.0 (10503) Received Zigbee message from '0x0017880104b71362', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 2 with groupID 0
              kaifu last edited by
              ich möchte mich hier auch dranhängen. Habe nun den zweiten cc2538-Stick getestet. Leider gibt es auch bei diesem wieder Probleme mit dem SML002 (9290019758).
              Er wird zwar erkannt und unter den Objekten als state "available --- true" angezeigt. Auch unter Netzwerkkarte im Adapter hat er ne grüne Verbindung zum Coordinator.
              Aber es kommen keine Daten rein. Das heißt occupancy, temperature, illuminance bleiben alle unverändert... Zigbee Adapter (1.2.1) bzw. Pi neu starten bringt nichts. Mit dem cc2531 ging es bei identischer Konfiguration problemlos (der hat aber an anderer Stelle rumgezickt, daher der Wechsel.)
              model: 9290019758
              description:Hue motion outdoor sensor
              supports:occupancy, temperature, illuminance
              model:SML002
              type:EndDevice
              nwk:34266
              manuf id:4107
              manufacturer:Philips
              power:Battery
              app version:2
              hard version:1
              zcl version:1
              stack version:1
              date code:20180828
              build:6.1.0.25261
              interviewed:true
              configured:true
                peterfido @kaifu last edited by
                @kaifu
                Einen Outdoor BWM von Philips hatte ich noch im Schrank. Eben mal ausgepackt und unter Version 1.2.1 gepairt.
                Heißt 9290019758 und meldet Temperatur, Helligkeit, Batteriestatus und Bewegung.
                model:9290019758
                model:SML002
                type:EndDevice
                nwk:57028
                manuf id:4107
                power:Battery
                app version:2
                hard version:1
                zcl version:1
                stack version:1
                date code:20180828
                build:6.1.0.25261
                interviewed:true
                configured:true
                Die Netzwerkkarte zeigt bei mir auch teilweise Murks an. Eine Osram Steckdose ist schon seit Monaten im Schrank, wird jedoch noch grün angezeigt, obwohl der Status "available" = false ist.
                  kaifu @peterfido last edited by
                  @peterfido
                  Danke, guter Hinweis mit der Netzwerkkarte. Habe nun den BWM noch einmal gelöscht und neu gepairt. Dann hat er auch Daten gemeldet. Allerdings schaltet sich nach rund einer Stunde History wieder aus und der BWM ist wieder weg:
                  2020-10-11 18:03:59.899 - info: zigbee.0 (4130) Zigbee: allowing new devices to join.
                  2020-10-11 18:04:43.226 - info: zigbee.0 (4130) Starting interview of '0x001788010647b6f7'
                  2020-10-11 18:05:01.129 - info: zigbee.0 (4130) Zigbee: stop joining
                  2020-10-11 18:05:04.783 - info: zigbee.0 (4130) Successfully interviewed '0x001788010647b6f7', device has succesfully been paired
                  2020-10-11 18:05:04.784 - info: zigbee.0 (4130) Device '0x001788010647b6f7' is supported, identified as: Philips Hue motion outdoor sensor (9290019758)
                  2020-10-11 18:05:04.787 - info: zigbee.0 (4130) Configuring 0x001788010647b6f7 SML002
                  2020-10-11 18:05:08.856 - info: zigbee.0 (4130) DeviceConfigure successful 0x001788010647b6f7 SML002
                  2020-10-11 18:09:14.106 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.temperature_calibration, Alias=false
                  2020-10-11 18:09:14.229 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.temperature, Alias=false
                  2020-10-11 18:09:14.292 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.occupancy_timeout, Alias=false
                  2020-10-11 18:09:14.358 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.occupancy, Alias=false
                  2020-10-11 18:09:14.418 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.motion_sensitivity, Alias=false
                  2020-10-11 18:09:14.485 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.link_quality, Alias=false
                  2020-10-11 18:09:14.543 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.illuminance_calibration, Alias=false
                  2020-10-11 18:09:14.604 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.illuminance, Alias=false
                  2020-10-11 18:09:14.667 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.battery, Alias=false
                  2020-10-11 18:09:14.724 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.available, Alias=false
                  2020-10-11 18:14:05.121 - info: info.0 (779) Popup news was read...
                  2020-10-11 18:44:05.149 - info: info.0 (779) Popup news was read...
                  2020-10-11 19:14:05.120 - info: info.0 (779) Popup news was read...
                  2020-10-11 19:19:13.522 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.link_quality
                  2020-10-11 19:19:13.532 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.battery
                  2020-10-11 19:19:13.546 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.occupancy
                  2020-10-11 19:19:13.548 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.occupancy_timeout
                  2020-10-11 19:19:13.555 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.temperature
                  2020-10-11 19:19:13.557 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.illuminance
                  2020-10-11 19:19:13.560 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.motion_sensitivity
                  2020-10-11 19:19:13.563 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.temperature_calibration
                  2020-10-11 19:19:13.565 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.illuminance_calibration
                  Danach noch einmal das gleiche Spiel. Gepairt, History eingeschaltet, nach rund einer Stunde wieder weg:
                  2020-10-11 19:25:24.286 - info: zigbee.0 (6495) Zigbee: allowing new devices to join.
                  2020-10-11 19:25:59.013 - info: zigbee.0 (6495) Starting interview of '0x001788010647b6f7'
                  2020-10-11 19:26:06.706 - info: zigbee.0 (6495) Successfully interviewed '0x001788010647b6f7', device has succesfully been paired
                  2020-10-11 19:26:06.706 - info: zigbee.0 (6495) Device '0x001788010647b6f7' is supported, identified as: Philips Hue motion outdoor sensor (9290019758)
                  2020-10-11 19:26:06.710 - info: zigbee.0 (6495) Configuring 0x001788010647b6f7 SML002
                  2020-10-11 19:26:10.862 - info: zigbee.0 (6495) DeviceConfigure successful 0x001788010647b6f7 SML002
                  2020-10-11 19:26:25.559 - info: zigbee.0 (6495) Zigbee: stop joining
                  2020-10-11 19:27:06.594 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.temperature_calibration, Alias=false
                  2020-10-11 19:27:06.663 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.temperature, Alias=false
                  2020-10-11 19:27:06.731 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.occupancy_timeout, Alias=false
                  2020-10-11 19:27:06.810 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.occupancy, Alias=false
                  2020-10-11 19:27:06.877 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.motion_sensitivity, Alias=false
                  2020-10-11 19:27:06.970 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.link_quality, Alias=false
                  2020-10-11 19:27:07.059 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.illuminance_calibration, Alias=false
                  2020-10-11 19:27:07.124 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.illuminance, Alias=false
                  2020-10-11 19:27:07.222 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.battery, Alias=false
                  2020-10-11 19:27:07.377 - info: history.0 (748) enabled logging of zigbee.0.001788010647b6f7.available, Alias=false
                  2020-10-11 19:44:05.128 - info: info.0 (779) Popup news was read...
                  2020-10-11 20:00:07.528 - info: admin.0 (727) Request actual repository...
                  2020-10-11 20:00:07.564 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                  2020-10-11 20:00:08.840 - info: admin.0 (727) Repository received successfully.
                  2020-10-11 20:14:05.126 - info: info.0 (779) Popup news was read...
                  2020-10-11 20:36:01.175 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.link_quality
                  2020-10-11 20:36:01.193 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.battery
                  2020-10-11 20:36:01.198 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.occupancy
                  2020-10-11 20:36:01.200 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.occupancy_timeout
                  2020-10-11 20:36:01.202 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.temperature
                  2020-10-11 20:36:01.203 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.illuminance
                  2020-10-11 20:36:01.205 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.motion_sensitivity
                  2020-10-11 20:36:01.207 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.temperature_calibration
                  2020-10-11 20:36:01.208 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.illuminance_calibration
                  2020-10-11 20:36:01.210 - info: history.0 (748) disabled logging of zigbee.0.001788010647b6f7.available
                  Könntest du deinen BWM bitte mal durchlaufen lassen um es zu testen?
                  Bei mir muss es am 2538 liegen. Wenn ich den alten 2531 wieder anstöpsel funktioniert es...
                    arteck Developer Most Active @kaifu last edited by arteck
                    @kaifu welche Firmware version ist auf dem 2538?
                      kaifu @arteck last edited by
                      @arteck Soll laut Verkäufer die neueste sein. Könntest du mir sagen, wo ich die Info sonst finde? Danke.
                        @kaifu zeigmal das log nach start des adapter
                          @arteck
                          2020-10-12 11:33:25.280 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                          2020-10-12 11:33:25.307 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 889
                          2020-10-12 11:33:27.184 - info: zigbee.0 (889) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.22.0, js-controller: 3.1.6
                          2020-10-12 11:33:27.223 - info: zigbee.0 (889) Starting Zigbee...
                          2020-10-12 11:33:29.147 - info: zigbee.0 (889) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                          2020-10-12 11:33:29.156 - info: zigbee.0 (889) --> transmitPower : normal
                          2020-10-12 11:33:29.171 - info: zigbee.0 (889) Currently 5 devices are joined:
                          2020-10-12 11:33:29.182 - info: zigbee.0 (889) 0x00158d0004094af0 (addr 26820): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                          2020-10-12 11:33:29.189 - info: zigbee.0 (889) 0xd0cf5efffe1194fb (addr 36701): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                          2020-10-12 11:33:29.192 - info: zigbee.0 (889) 0x680ae2fffe9178f4 (addr 28525): ICPSHC24-10EU-IL-1 - IKEA TRADFRI driver for wireless control (10 watt) (Router)
                          2020-10-12 11:33:29.194 - info: zigbee.0 (889) 0x04cf8cdf3c7759af (addr 65466): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                          2020-10-12 11:33:29.197 - info: zigbee.0 (889) 0x00158d00027d7fb3 (addr 27291): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                          2020-10-12 11:33:29.199 - info: zigbee.0 (889) Zigbee started
                            @kaifu sagte in Zigbee cc2538 und Philips Hue Bewegungsmelder:
                            ergo alles gut
                            aber da du schon router hast... fang nochmal an und verbinde zuerst die Router mit dem Coordinator...
                            danach einmal adapter neu starten... dann den rest
                              @arteck said in Zigbee cc2538 und Philips Hue Bewegungsmelder:
                              fang nochmal an
                              Ok. Reicht es, die Geräte zu löschen, oder soll ich den Zigbee-Adapter deinstallieren?
                                @kaifu unter einstellung gibts ein Hard-Reset knopp nutze diesen.. adapter oder geräte müssen aus den Objekten nicht raus
                                K 2 Replies Last reply Reply Quote 0
                                  @arteck 👍 Vielen Dank! Meld mich dann wieder, wenn ich alles wieder eingerichtet habe...
                                    @arteck Mmh, das klappt mit dem Hard-Reset irgendwie nicht, am Ende sind alle Geräte wieder da.
                                    2020-10-12 11:56:22.655 - error: zigbee.0 (1592) Adapter disconnected, stopping
                                    2020-10-12 11:56:22.660 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:56:32.659 - info: zigbee.0 (1592) Try to reconnect. 5 attempts left
                                    2020-10-12 11:56:32.661 - info: zigbee.0 (1592) Starting Zigbee...
                                    2020-10-12 11:56:32.854 - error: zigbee.0 (1592) Failed to start Zigbee
                                    2020-10-12 11:56:32.857 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:56:32.855 - error: zigbee.0 (1592) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00'
                                    at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                    at Generator.next ()
                                    at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                    at new Promise ()
                                    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                    at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                    at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                                    at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
                                    2020-10-12 11:56:32.860 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:56:42.857 - info: zigbee.0 (1592) Try to reconnect. 4 attempts left
                                    2020-10-12 11:56:42.859 - info: zigbee.0 (1592) Starting Zigbee...
                                    2020-10-12 11:56:44.989 - info: zigbee.0 (1592) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                                    2020-10-12 11:56:44.996 - info: zigbee.0 (1592) --> transmitPower : normal
                                    2020-10-12 11:56:45.000 - info: zigbee.0 (1592) Currently 5 devices are joined:
                                    2020-10-12 11:56:45.006 - info: zigbee.0 (1592) 0x00158d0004094af0 (addr 26820): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                                    2020-10-12 11:56:45.008 - info: zigbee.0 (1592) 0xd0cf5efffe1194fb (addr 36701): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                                    2020-10-12 11:56:45.010 - info: zigbee.0 (1592) 0x680ae2fffe9178f4 (addr 28525): ICPSHC24-10EU-IL-1 - IKEA TRADFRI driver for wireless control (10 watt) (Router)
                                    2020-10-12 11:56:45.011 - info: zigbee.0 (1592) 0x04cf8cdf3c7759af (addr 65466): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    2020-10-12 11:56:45.013 - info: zigbee.0 (1592) 0x00158d00027d7fb3 (addr 27291): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                    2020-10-12 11:56:45.013 - info: zigbee.0 (1592) Zigbee started
                                    2020-10-12 11:56:52.253 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2020-10-12 11:56:52.254 - error: zigbee.0 (1592) unhandled promise rejection: AREQ - SYS - resetInd after 30000ms
                                    2020-10-12 11:56:52.255 - error: zigbee.0 (1592) Error: AREQ - SYS - resetInd after 30000ms
                                    at Timeout.waiter.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
                                    at ontimeout (timers.js:436:11)
                                    at tryOnTimeout (timers.js:300:5)
                                    at listOnTimeout (timers.js:263:5)
                                    at Timer.processTimers (timers.js:223:10)
                                    2020-10-12 11:56:52.257 - info: zigbee.0 (1592) cleaned everything up...
                                    2020-10-12 11:56:52.260 - info: zigbee.0 (1592) Zigbee: disabling joining new devices.
                                    2020-10-12 11:56:55.453 - warn: zigbee.0 (1592) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2020-10-12 11:56:55.467 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:56:55.471 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:56:55.474 - info: zigbee.0 (1592) terminating
                                    2020-10-12 11:56:55.477 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:56:55.972 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2020-10-12 11:56:55.973 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                                    2020-10-12 11:56:55.975 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                                    2020-10-12 11:57:25.997 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1701
                                    2020-10-12 11:57:27.859 - info: zigbee.0 (1701) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.22.0, js-controller: 3.1.6
                                    2020-10-12 11:57:27.900 - info: zigbee.0 (1701) Starting Zigbee...
                                    2020-10-12 11:57:29.800 - info: zigbee.0 (1701) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                                    2020-10-12 11:57:29.806 - info: zigbee.0 (1701) --> transmitPower : normal
                                    2020-10-12 11:57:29.815 - info: zigbee.0 (1701) Currently 5 devices are joined:
                                    2020-10-12 11:57:29.821 - info: zigbee.0 (1701) 0x00158d0004094af0 (addr 26820): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                                    2020-10-12 11:57:29.825 - info: zigbee.0 (1701) 0xd0cf5efffe1194fb (addr 36701): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                                    2020-10-12 11:57:29.826 - info: zigbee.0 (1701) 0x680ae2fffe9178f4 (addr 28525): ICPSHC24-10EU-IL-1 - IKEA TRADFRI driver for wireless control (10 watt) (Router)
                                    2020-10-12 11:57:29.828 - info: zigbee.0 (1701) 0x04cf8cdf3c7759af (addr 65466): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                                    2020-10-12 11:57:29.829 - info: zigbee.0 (1701) 0x00158d00027d7fb3 (addr 27291): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                    2020-10-12 11:57:29.830 - info: zigbee.0 (1701) Zigbee started
                                      @kaifu ja die werden auch alle da sein.ist ja auch der sinn des ganzen.. sonst müstest du alles ändern. sollte aber nicht mehr funktionieren...
                                      zeigmal die Einstellugen ?
                                        kaifu @arteck last edited by kaifu
                                        @arteck Nee, die Geräte funktionieren alle noch! Kann ich ganz normal über die Objekte ansteuern.
                                        Hier die Einstellungen:
                                          @kaifu
                                          Wenn er sich immer noch regelmäßig verabschiedet, probier Mal wie ich den Datenpunkt minütlich auszulesen.
                                          Wenn ich heute Abend zu komme, packe ich den neuen BWM in die Küche und logge mit, was der so treibt.
                                            Der zweite läuft und wird mitgeloggt.
                                            zigbee hue bewegungsmelder
                                            6292
