    4. Zigbee cc2538 und Philips Hue Bewegungsmelder
      kaifu @arteck last edited by
      @arteck Soll laut Verkäufer die neueste sein. Könntest du mir sagen, wo ich die Info sonst finde? Danke.
        arteck Developer Most Active @kaifu last edited by
        @kaifu zeigmal das log nach start des adapter
          @arteck
          2020-10-12 11:33:25.280 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
          2020-10-12 11:33:25.307 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 889
          2020-10-12 11:33:27.184 - info: zigbee.0 (889) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.22.0, js-controller: 3.1.6
          2020-10-12 11:33:27.223 - info: zigbee.0 (889) Starting Zigbee...
          2020-10-12 11:33:29.147 - info: zigbee.0 (889) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
          2020-10-12 11:33:29.156 - info: zigbee.0 (889) --> transmitPower : normal
          2020-10-12 11:33:29.171 - info: zigbee.0 (889) Currently 5 devices are joined:
          2020-10-12 11:33:29.182 - info: zigbee.0 (889) 0x00158d0004094af0 (addr 26820): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
          2020-10-12 11:33:29.189 - info: zigbee.0 (889) 0xd0cf5efffe1194fb (addr 36701): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
          2020-10-12 11:33:29.192 - info: zigbee.0 (889) 0x680ae2fffe9178f4 (addr 28525): ICPSHC24-10EU-IL-1 - IKEA TRADFRI driver for wireless control (10 watt) (Router)
          2020-10-12 11:33:29.194 - info: zigbee.0 (889) 0x04cf8cdf3c7759af (addr 65466): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
          2020-10-12 11:33:29.197 - info: zigbee.0 (889) 0x00158d00027d7fb3 (addr 27291): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
          2020-10-12 11:33:29.199 - info: zigbee.0 (889) Zigbee started
            arteck Developer Most Active @kaifu last edited by arteck
            @kaifu sagte in Zigbee cc2538 und Philips Hue Bewegungsmelder:
            ergo alles gut
            aber da du schon router hast... fang nochmal an und verbinde zuerst die Router mit dem Coordinator...
            danach einmal adapter neu starten... dann den rest
              @arteck said in Zigbee cc2538 und Philips Hue Bewegungsmelder:
              fang nochmal an
              Ok. Reicht es, die Geräte zu löschen, oder soll ich den Zigbee-Adapter deinstallieren?
                @kaifu unter einstellung gibts ein Hard-Reset knopp nutze diesen.. adapter oder geräte müssen aus den Objekten nicht raus
                K 2 Replies Last reply Reply Quote 0
                  @arteck 👍 Vielen Dank! Meld mich dann wieder, wenn ich alles wieder eingerichtet habe...
                    @arteck Mmh, das klappt mit dem Hard-Reset irgendwie nicht, am Ende sind alle Geräte wieder da.
                    2020-10-12 11:56:22.655 - error: zigbee.0 (1592) Adapter disconnected, stopping
                    2020-10-12 11:56:22.660 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:56:32.659 - info: zigbee.0 (1592) Try to reconnect. 5 attempts left
                    2020-10-12 11:56:32.661 - info: zigbee.0 (1592) Starting Zigbee...
                    2020-10-12 11:56:32.854 - error: zigbee.0 (1592) Failed to start Zigbee
                    2020-10-12 11:56:32.857 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:56:32.855 - error: zigbee.0 (1592) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00'
                    at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                    at Generator.next ()
                    at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                    at new Promise ()
                    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                    at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                    at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                    at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
                    2020-10-12 11:56:32.860 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:56:42.857 - info: zigbee.0 (1592) Try to reconnect. 4 attempts left
                    2020-10-12 11:56:42.859 - info: zigbee.0 (1592) Starting Zigbee...
                    2020-10-12 11:56:44.989 - info: zigbee.0 (1592) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                    2020-10-12 11:56:44.996 - info: zigbee.0 (1592) --> transmitPower : normal
                    2020-10-12 11:56:45.000 - info: zigbee.0 (1592) Currently 5 devices are joined:
                    2020-10-12 11:56:45.006 - info: zigbee.0 (1592) 0x00158d0004094af0 (addr 26820): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                    2020-10-12 11:56:45.008 - info: zigbee.0 (1592) 0xd0cf5efffe1194fb (addr 36701): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                    2020-10-12 11:56:45.010 - info: zigbee.0 (1592) 0x680ae2fffe9178f4 (addr 28525): ICPSHC24-10EU-IL-1 - IKEA TRADFRI driver for wireless control (10 watt) (Router)
                    2020-10-12 11:56:45.011 - info: zigbee.0 (1592) 0x04cf8cdf3c7759af (addr 65466): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                    2020-10-12 11:56:45.013 - info: zigbee.0 (1592) 0x00158d00027d7fb3 (addr 27291): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                    2020-10-12 11:56:45.013 - info: zigbee.0 (1592) Zigbee started
                    2020-10-12 11:56:52.253 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2020-10-12 11:56:52.254 - error: zigbee.0 (1592) unhandled promise rejection: AREQ - SYS - resetInd after 30000ms
                    2020-10-12 11:56:52.255 - error: zigbee.0 (1592) Error: AREQ - SYS - resetInd after 30000ms
                    at Timeout.waiter.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
                    at ontimeout (timers.js:436:11)
                    at tryOnTimeout (timers.js:300:5)
                    at listOnTimeout (timers.js:263:5)
                    at Timer.processTimers (timers.js:223:10)
                    2020-10-12 11:56:52.257 - info: zigbee.0 (1592) cleaned everything up...
                    2020-10-12 11:56:52.260 - info: zigbee.0 (1592) Zigbee: disabling joining new devices.
                    2020-10-12 11:56:55.453 - warn: zigbee.0 (1592) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2020-10-12 11:56:55.467 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:56:55.471 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:56:55.474 - info: zigbee.0 (1592) terminating
                    2020-10-12 11:56:55.477 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:56:55.972 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2020-10-12 11:56:55.973 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                    2020-10-12 11:56:55.975 - info: javascript.0 (860) script.js.Eigene_Skripte.##on_log_-_Überwachung_und_telegram: ERROR an telegram gesendet
                    2020-10-12 11:57:25.997 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1701
                    2020-10-12 11:57:27.859 - info: zigbee.0 (1701) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.22.0, js-controller: 3.1.6
                    2020-10-12 11:57:27.900 - info: zigbee.0 (1701) Starting Zigbee...
                    2020-10-12 11:57:29.800 - info: zigbee.0 (1701) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                    2020-10-12 11:57:29.806 - info: zigbee.0 (1701) --> transmitPower : normal
                    2020-10-12 11:57:29.815 - info: zigbee.0 (1701) Currently 5 devices are joined:
                    2020-10-12 11:57:29.821 - info: zigbee.0 (1701) 0x00158d0004094af0 (addr 26820): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
                    2020-10-12 11:57:29.825 - info: zigbee.0 (1701) 0xd0cf5efffe1194fb (addr 36701): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                    2020-10-12 11:57:29.826 - info: zigbee.0 (1701) 0x680ae2fffe9178f4 (addr 28525): ICPSHC24-10EU-IL-1 - IKEA TRADFRI driver for wireless control (10 watt) (Router)
                    2020-10-12 11:57:29.828 - info: zigbee.0 (1701) 0x04cf8cdf3c7759af (addr 65466): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                    2020-10-12 11:57:29.829 - info: zigbee.0 (1701) 0x00158d00027d7fb3 (addr 27291): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                    2020-10-12 11:57:29.830 - info: zigbee.0 (1701) Zigbee started
                      @kaifu ja die werden auch alle da sein.ist ja auch der sinn des ganzen.. sonst müstest du alles ändern. sollte aber nicht mehr funktionieren...
                      zeigmal die Einstellugen ?
                        kaifu @arteck last edited by kaifu
                        @arteck Nee, die Geräte funktionieren alle noch! Kann ich ganz normal über die Objekte ansteuern.
                        Hier die Einstellungen:
                          peterfido @kaifu last edited by
                          @kaifu
                          Wenn er sich immer noch regelmäßig verabschiedet, probier Mal wie ich den Datenpunkt minütlich auszulesen.
                          Wenn ich heute Abend zu komme, packe ich den neuen BWM in die Küche und logge mit, was der so treibt.
                            peterfido last edited by
                            Der zweite läuft und wird mitgeloggt.
                              Hat nicht lange ausgehalten, bis er das Netzwerk verlassen hat:
                              2020-10-14 20:15:50.875  - debug: zigbee.0 (1894) handleDeviceLeave. {"ieeeAddr":"0x001788010647b3a5"}
                              2020-10-14 20:15:50.875  - debug: zigbee.0 (1894) Device '0x001788010647b3a5' left the network
                              2020-10-14 20:15:50.875  - debug: zigbee.0 (1894) Leave device event: 0x001788010647b3a5
                              2020-10-14 20:15:50.875  - debug: zigbee.0 (1894) Delete device 001788010647b3a5 from iobroker.
                              2020-10-14 20:15:50.938  - info: history.0 (1141) disabled logging of zigbee.0.001788010647b3a5.link_quality
                              2020-10-14 20:15:50.953  - info: history.0 (1141) disabled logging of zigbee.0.001788010647b3a5.occupancy
                                Die letzten Einträge, Teil 1:
                                2020-10-14 20:14:34.282 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699274282},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":28,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":150,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:14:34.282 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                2020-10-14 20:14:34.283 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699274282},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699274282},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":28,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":150,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:14:42.187 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699282186},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":31,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":151,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:14:42.187 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                2020-10-14 20:14:42.187 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699282186},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699282186},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":31,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":151,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:03.500 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699303500},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":28,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":152,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:03.500 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:03.501 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699303500},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699303500},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":28,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":152,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:04.782 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699304782},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":39,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":153,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:04.782 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:04.783 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699304782},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699304782},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":39,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":153,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:04.846 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699304845},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":39,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":154,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:04.846 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:04.846 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699304845},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699304845},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":39,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":154,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:14.794 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699314794},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":28,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":155,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:14.795 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:14.795 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699314794},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699314794},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":28,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":155,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:25.753 - zigbee.0 (1894) handleDeviceAnnounce. {"device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699325753}}
                                2020-10-14 20:15:25.753 - zigbee.0 (1894) Device '0x001788010647b3a5' announced itself
                                2020-10-14 20:15:25.754 - zigbee.0 (1894) New device event: {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699325753},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"}
                                2020-10-14 20:15:25.877 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699325877},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":156,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:25.877 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:25.877 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699325877},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699325877},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":156,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:26.754 - zigbee.0 (1894) Publish available for 0x001788010647b3a5 = true
                                2020-10-14 20:15:27.406 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327406},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.406 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:27.407 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327406},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327406},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.407 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327407},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.408 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:27.408 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327407},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327407},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.409 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327409},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.410 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.410 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:27.411 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.411 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:27.420 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.421 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18155}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:27.421 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327410},"endpoint":"[Circular]","data":{"measuredValue":18155},"linkquality":21,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":157,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                2020-10-14 20:15:27.885 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327885},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":158,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                2020-10-14 20:15:27.885 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 2 with groupID 0
                                2020-10-14 20:15:27.885 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327885},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":0}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699327885},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":158,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                  peterfido last edited by
                                  Teil 2:
                                  2020-10-14 20:15:28.481 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699328481},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":159,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                  2020-10-14 20:15:28.482 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:28.482 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699328481},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699328481},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":159,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                  2020-10-14 20:15:30.096 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330096},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.096 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:30.097 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330096},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330096},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.098 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330098},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.099 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.100 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.100 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:30.100 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.101 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:30.101 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:30.102 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:30.102 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18155}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699330099},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":21,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:37.256 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699337256},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":28,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":161,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                  2020-10-14 20:15:37.256 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:37.257 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699337256},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699337256},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":28,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":161,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                                  2020-10-14 20:15:38.845 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338845},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.846 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:38.846 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338845},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338845},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.847 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338847},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.848 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338848},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.849 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338849},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.850 - zigbee.0 (1894) handleMessage. {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.850 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:38.850 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.851 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:38.851 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.852 - zigbee.0 (1894) Type attributeReport device {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"mapped":{"zigbeeModel":["SML002"],"model":"9290019758","vendor":"Philips","description":"Hue motion outdoor sensor","supports":"occupancy, temperature, illuminance","fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["occupancy_timeout"]},{"key":["motion_sensitivity"]}],"meta":{"configureKey":1},"ota":{}},"name":"0x001788010647b3a5"} incoming event: {"type":"attributeReport","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x001788010647b3a5","_networkAddress":57028,"_manufacturerID":4107,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2128,"inputClusters":[0],"outputClusters":[0,3,4,6,8,768,5],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genBasic":{"attributes":{"modelId":"SML002","manufacturerName":"Philips","powerSource":3,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20180828","swBuildId":"6.1.0.25261"}}},"_binds":[]},{"ID":2,"profileID":260,"deviceID":263,"inputClusters":[0,1,3,1030,1024,1026],"outputClusters":[25],"deviceNetworkAddress":57028,"deviceIeeeAddress":"0x001788010647b3a5","clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}},"msOccupancySensing":{"attributes":{"occupancy":1}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1775}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":18085}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1},{"cluster":1030,"type":"endpoint","deviceIeeeAddress":"0x00124b00061058b2","endpointID":1}]}],"_manufacturerName":"Philips","_powerSource":"Battery","_modelID":"SML002","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20180828","_softwareBuildID":"6.1.0.25261","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1602699338850},"endpoint":"[Circular]","data":{"measuredValue":18085},"linkquality":23,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":162,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2020-10-14 20:15:38.852 - zigbee.0 (1894) Received Zigbee message from '0x001788010647b3a5', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":18085}' from endpoint 2 with groupID 0
                                  2020-10-14 20:15:50.875 - zigbee.0 (1894) handleDeviceLeave. {"ieeeAddr":"0x001788010647b3a5"}
                                  2020-10-14 20:15:50.875 - zigbee.0 (1894) Device '0x001788010647b3a5' left the network
                                  2020-10-14 20:15:50.875 - zigbee.0 (1894) Leave device event: 0x001788010647b3a5
                                  2020-10-14 20:15:50.875 - zigbee.0 (1894) Delete device 001788010647b3a5 from iobroker.
                                    kaifu @peterfido last edited by
                                    @peterfido
                                    Vielen Dank für deine Mühe 👍 ! Wenn ich das richtig verstehe, hat sich deiner genau wie meiner nach etwas mehr als einer Stunde verabschiedet?!?
                                      @kaifu keine Ahnung.. hab den nicht.. fehler gefunden
                                      https://github.com/Koenkk/zigbee2mqtt/issues/2693
                                      die haben es auch
                                      ccorderod created this issue in Koenkk/zigbee2mqtt
                                      closed Philips Hue Motion sensors disconnect from the network #2693
                                      Xsev K 2 Replies Last reply Reply Quote 0
                                      • Xsev
                                        Xsev @arteck last edited by
                                        Das Problem hatte ich schon vor gut einem Jahr mit den Senosern, damals CC2531...
                                        Mein damaliges "Provisorium" mit Hue Adapter läuft bis heute... 🤦
                                        siehe: hier
                                        An einer Lösung wäre ich aber ebenfalls sehr interessiert, da hue nur via polling geht, was bei Bewegungssensoren (die schnell reagieren sollen) nicht so prickelnd ist 👎
                                          kaifu @arteck last edited by
                                          @arteck
                                          Ah, Mist. Aber vielen Dank, dass du es versucht hast!
                                            kaifu @Xsev last edited by
                                            @Xsev Funktioniert deine Version nur mit der Hue Bridge?
                                            Werde sonst mal versuchen 2 Zigbee-Instanzen zu nehmen. Bei mir laufen die Sensoren mit dem CC2531 stabil. Für den Rest dann CC2538. Mal schauen... 👷
                                            Xsev 1 Reply Last reply Reply Quote 0
                                            zigbee hue bewegungsmelder
                                            6283
