    5. Bewegungsmelder
    Bewegungsmelder
      Dragon last edited by
        <variables>
          <variable id=":fiQ@Ot,b8r$.QwlWq(U">Count</variable>
          <variable type="interval" id="Intervall">Intervall</variable>
          <variable type="interval" id="Intervall2">Intervall2</variable>
        </variables>
        <block type="on_ext" id="0)xVnkW`7Ij8iSU4CiE;" x="-937" y="-687">
          <value name="OID0">
            <shadow type="field_oid" id="yod!wxpP`@b@#;3xf}`D">
              <field name="oid">sonoff.0.Badezimmer-Deckenlampe.POWER</field>
            <block type="controls_if" id="C2fZ56U1t)4V-(67H4fA">
                <block type="logic_compare" id="rgpE?}H,a,v!,cXhPhi_">
                  <field name="OP">EQ</field>
                    <block type="on_source" id="pAyf:(p._Yk2jY6LHMWr">
                    <block type="logic_boolean" id="5#{AfXpijg8,KHV(.TCq">
                <block type="variables_set" id="-oJ[G^t[,oQ4,Uo{rC,@">
                  <field name="VAR" id=":fiQ@Ot,b8r$.QwlWq(U">Count</field>
                    <block type="math_number" id="q%]O:=o]9h?]3-X~Iys_">
                      <field name="NUM">70</field>
                    <block type="timeouts_setinterval" id="w6pphAidF-m9tm,zM*GB">
                      <field name="NAME">Intervall</field>
                      <field name="INTERVAL">1</field>
                        <block type="math_change" id="5`Yp[(OXfH55CeQ[),,a">
                          <value name="DELTA">
                            <shadow type="math_number" id="WR}+IMw~|~vx5gBXG|9}">
                              <field name="NUM">-1</field>
                            <block type="math_number" id="JxQ),rY0UmMWM209HN+B">
                            <block type="controls_if" id="kj.l}DPTOyP96]!RtlyG">
                                <block type="logic_compare" id="q71_W[JQIhFs(^4lROcl">
                                    <block type="variables_get" id="xUYRbail*|LD^7Ql?9ry">
                                    <block type="math_number" id="9%|m}[WI0KV]jgS$l003">
                                      <field name="NUM">0</field>
                                <block type="control" id=":f|t92|DfJQjE_:o.r0)">
                                  <field name="OID">sonoff.0.Badezimmer-Deckenlampe.POWER</field>
                                    <block type="logic_boolean" id="d=cQmU`3f{zipj9yO6~.">
                                    <block type="timeouts_clearinterval" id="YJO6!A:{w?8J6?dVJp=P">
              <statement name="ELSE">
                <block type="timeouts_clearinterval" id="0Gtuh%ZmYST2.c{%B48V">
                    <block type="variables_set" id="ymUIcHr|,Rzj)/Y#+..a">
                        <block type="math_number" id=";1aqLi(SVrdBqS~?eL;H">
            <block type="on_ext" id="TbYfSlx/shYS^;;0^Kho">
              <value name="OID0">
                <shadow type="field_oid" id="4R+S/r,{35HGk#0OM=o@">
                  <field name="oid">zigbee.0.00158d0005228fc3.occupancy</field>
                <block type="controls_if" id="=)uK}]z^3PY$*qw^u)s}">
                    <block type="logic_compare" id="gdT_O~{8p{R1TMEEa$_{">
                        <block type="on_source" id="tY;F0F{`a9a6P?84qQ~q">
                        <block type="logic_boolean" id="!I/}]hD]SKyvTxuCSFRb">
                    <block type="timeouts_clearinterval" id="0WY9+PPk{6T5rMkKT{]U">
                        <block type="timeouts_clearinterval" id="NXss`9;`#fanB=em,~jR">
                          <field name="NAME">Intervall2</field>
                            <block type="variables_set" id="2T/aE]zz}B{:.|ykAa/n">
                                <block type="math_number" id="WjQy9!7:p9EQWq=))2!J">
                    <block type="variables_set" id="/-)V9X9KI97p4+h:jpp*">
                        <block type="math_number" id="n]S((OmsW81I]X{tf)sx">
                        <block type="timeouts_setinterval" id="D!qQ(sJH_4wt9kxq.~kE">
                            <block type="math_change" id="hpT3j9:kk*94/Vp.4(#J">
                                <shadow type="math_number">
                                <block type="math_number" id="u9?:2giyzs5z~l^jT:jM">
                                <block type="controls_if" id="pX44N^w8HoWf0KSk0/Z9">
                                    <block type="logic_compare" id="7VR9_*RPB_4=9-0KN9/F">
                                        <block type="variables_get" id="+e*(fTJ6{jn670tV2D}L">
                                        <block type="math_number" id="q%UW:q#j+iW,jpJ37Mh%">
                                    <block type="control" id="G@uEF-8b_+v:F~(VCd^?">
                                        <block type="logic_boolean" id="Y:O$%hlTJm/y5!t.@{e%">
                                        <block type="timeouts_clearinterval" id="Xh*o+*3F(qRqGu*-yI@|">
        ASMM @Dragon last edited by
        @David-Froebus
        RESPEKT !!!!
        Wahnsinn. Es funktioniert. Tausend Dank dafür schonmal. I hätte es niemals geschafft.
        Den Ersten Block macht er PERFEKT. Also wenn Lampe eingeschaltet wird und keine Bewegung ferstgestellt wird geht sie wieder aus. TOP !!!
        Beim zweiten Block folgt eine Bewegung nach dem einschalten des Lichts und es dauert aber 2-3 Minuten nach der letzten Bewegung, bis das Licht wieder aus geht. Das ist jetzt nur zur Info. Für meine Zwecke absolut in Ordnung.
        Jetzt habe ich noch eine Herausforderung für Dich 😀
        Folgende Szene:
        Ich komme in den Raum, der BWM geht auf "true", ich stelle fest, es ist mir doch zu dunkel und schalte jetzt das Licht ein und bewege mich in dem Raum.
        Jetzt sollte das Licht weiter an bleiben, tut es leider nicht. Es geht nach 70 Sek. aus. Meinst du, das könntest du noch hinkriegen ????
        D 2 Replies Last reply Reply Quote 1
        • Asgothian
          Asgothian Developer @Dragon last edited by
          @David-Froebus
          @ASMM
          Funktional, aber kompliziert. Das gleiche macht:
          ohne die ganzen Zähler und so weiter.
          So sollte es im Übrigen auch schon die "Herausforderung" lösen, denn im Original wird beim Einschalten der Lampe das "intervall2" welches nach aktivieren des BWM die Lampe abschaltet nicht gelöscht, so das auf jeden F all 70 sekunden nach BWM ein die Lampe aus geht.
          A.
          A 2 Replies Last reply Reply Quote 0
            ASMM @Asgothian last edited by
            @Asgothian
            Vielen Dank.
            Ich werde es frühestens heute Abend mal testen und berichten.
            • Peoples
              Peoples last edited by
              Hatte für Bewegungsmelder und Licht Mal ein kleines Script geschrieben, vielleicht hilft das ja irgendwie weiter
              https://forum.iobroker.net/topic/21226/vorlage-automatisches-licht
                Dragon @ASMM last edited by
                @ASMM klar, mom mache mir Gedanken.
                  Dragon @ASMM last edited by Dragon
                  @ASMM sagte in Bewegungsmelder:
                  @David-Froebus
                  RESPEKT !!!!
                  Folgende Szene:
                  Beim zweiten Block, das liegt an dem zu langen Aktualisierungsintervall vom BWM ohne den HW Hack.
                  Habe ich die neue Aufgabe richtig verstanden, dass wenn du in den Raum gehst, das Licht doch anschaltest über den Schalter soll kein Zeitintervall sein sondern das Licht einfach an sein?
                    <variables>
                    </variables>
                      <value name="OID0">
                          <mutation elseif="1" else="1"></mutation>
                            <block type="logic_operation" id="QipXGIVgI1%x$3@2@aK:" inline="false">
                              <field name="OP">AND</field>
                                <block type="logic_compare" id="(#oFrbq_~Qz]oFmEn+s,">
                                    <block type="get_value" id="GpIrWM.t5PX.9S[a:=NU">
                                      <field name="OID">zigbee.0.00158d0005228fc3.occupancy</field>
                                    <block type="logic_boolean" id="IL.4v+A@n9epTZU%@npJ">
                          <value name="IF1">
                            <block type="logic_operation" id="Tk3/orljB,%A+XsRTZ|T" inline="false">
                                <block type="logic_compare" id="9v*RYmqc@v2CKsX@]wPn">
                                    <block type="on_source" id="Sm8`$HM#7!9:cdFus5_0">
                                    <block type="logic_boolean" id="1pQHCv#0l[wuuV8*_Jp6">
                                <block type="logic_compare" id="Iy0ZE19SsY-x()~9$3d2">
                                    <block type="get_value" id="u|F=,nF[kk-kGv@N+okg">
                                    <block type="logic_boolean" id="yl?%mWqme{`yGL3qQcW`">
                          <statement name="DO1">
                            <block type="control" id="sN_XHf#l6rJ+IQT~1Ko;">
                                <block type="logic_boolean" id="^}}ggYmSyGv%$$R,H=nB">
                          <value name="OID0">
                    paul53 @ASMM last edited by paul53
                    @ASMM sagte:
                    Das Licht soll nur über einen Taster eingeschaltet werden... Nachdem keine Bewegung mehr erkannt wird, z.B. 2 Minuten und das Licht nicht per Taster ausgeschaltet wurde, soll das Licht automatisch ausgehen.
                    Wenn der Taster betätigt wird und keine Bewegung innerhalb von z.B. 70 Sek. festgetsellt wird, dann soll das Licht ebenfalls ausgehen.
                    Vorschlag:
                      Dragon @paul53 last edited by
                      @paul53 genau, aber genau das hat er ja in der neuen Aufgabe wieder verneint...
                      Zitat:
                      Folgende Szene:
                        paul53 @Dragon last edited by paul53
                        @David-Froebus sagte:
                        Bei Bewegung wird der 70-s-Timer (timeout2) gestoppt.
                          ASMM last edited by
                          Ich bin leider noch nicht dazu gekommne Eure Scripts zu testen. Ich werde mich auf jeden Fall melden und berichten.
                          @David-Froebus sagte in Bewegungsmelder:
                          Grundsätzlich:
                          1.) Das Licht darf ausschließlich NUR durch den Taster eingeschaltet werden.
                          2.) Das Licht soll IMMER automatisch ausgehen, nachdem der BWM 2 Min. keine Bewegung mehr meldet.
                          Dein erster Script ist nahezu perfekt, bis auf eine einzige Szene.
                          Ich komme in den Raum, dann gehe ich direkt zurück zum Schalter, um das Licht anzumachen. Dann bleibe ich 10 Minuten im Raum und so lange sollte auch das Licht anbleiben. Wenn ich wieder den Raum verlasse und keine Bewegung mehr stattfindet, dann soll das Licht wieder ausgehen.
                            ASMM @Dragon last edited by ASMM
                            @David-Froebus
                            Dein neuer Script läuft 100% so, wie ich es mir vorstelle !!!
                            Herzlichen Dank, ist ne Kiste Bier Wert 👍
                              @Asgothian
                              Deinen Script habe ich auch getestet und es sieht wie folgt aus:
                              1.) Der erste Block funktioniert einwandfrei 👍
                              2.) Beim zweiten Block geht die Lampe stur nach 70 Sek. Die Bewegung im Raum wird ignoriert.
                              Trotzdem Danke für deine Bemühungen.
                              • Asgothian
                                Asgothian Developer @ASMM last edited by
                                @ASMM
                                Log doch mal bitte wie schnell der bwm ein Signal sendet wenn du dich Im Raum bewegst. Es kann sein das du im 2. Teil die 70 Sekunden auf 120 Sekunden erhöhen musst damit das Sauber geht.
                                A.
                                  ASMM @ASMM last edited by
                                  Zur Info: Der Xiaomi BWM hat unter anderem "Time from last motion", das nach 60 Sek. alle 10 Sek. aktualisiert wird bis 1810 Sekunden.
                                  Der Wert "Occupancy" meldet nach 60 Sek. zum ersten mal wieder ein Signal, wenn keine Bewegung stattfindet.
                                    @ASMM Das freut mich!!!! Dann hat es sich gelohnt...
                                      @David-Froebus
                                      Fazit nach einigen Tagen Praxis-Test:
                                      Nachdem ich den Script frisch aktiviere läuft alles reibungslos.
                                      Aber nach einem Tag schon verändert sich die Sache wie folgt:
                                      Ich drücke den Taster, gehe nicht ins Zimmer und das Licht geht bereits nach 3 Sek. aus.
                                      D.h. die erste eingestellte Zeit wird völlig ignoriert, oder aber es hat sich verändert.
                                      Der zweite Block funktioniert nach wie vor super.
                                      Pausiere ich den Script und lasse ihn sofort wieder laufen, dann funzt alles perfekt.
                                      Hast du vielleicht eine Idee, was da im Hintergrung schief läuft ?????? 😢
                                      1875
