    5. Telegram sendet mehrfach
      Semmy @Homoran last edited by Homoran
      @Homoran So sieht es im log aus:
      telegram.0	2020-10-13 15:49:03.543	debug	(1259) system.adapter.admin.0: logging true
      telegram.0	2020-10-13 15:48:53.877	debug	(1259) system.adapter.admin.0: logging false
      telegram.0	2020-10-13 15:48:50.464	debug	(1259) Message sent
      telegram.0	2020-10-13 15:48:50.463	debug	(1259) Request: {"message_id":2140,"from":{"id":1016259540,"is_bot":true,"first_name":"Semmy","username":"Robbi110_bot"},"chat":{"id":1221955920,"first_name":"Dirk","type":"private"},"date":160259693
      telegram.0	2020-10-13 15:48:50.447	debug	(1259) Message sent
      telegram.0	2020-10-13 15:48:50.445	debug	(1259) Request: {"message_id":2139,"from":{"id":1016259540,"is_bot":true,"first_name":"Semmy","username":"Robbi110_bot"},"chat":{"id":1221955920,"first_name":"Dirk","type":"private"},"date":160259693
      telegram.0	2020-10-13 15:48:50.385	debug	(1259) Message sent
      telegram.0	2020-10-13 15:48:50.384	debug	(1259) Request: {"message_id":2138,"from":{"id":1016259540,"is_bot":true,"first_name":"Semmy","username":"Robbi110_bot"},"chat":{"id":1221955920,"first_name":"Dirk","type":"private"},"date":160259693
      telegram.0	2020-10-13 15:48:50.328	debug	(1259) Message sent
      telegram.0	2020-10-13 15:48:50.327	debug	(1259) Request: {"message_id":2137,"from":{"id":1016259540,"is_bot":true,"first_name":"Semmy","username":"Robbi110_bot"},"chat":{"id":1221955920,"first_name":"Dirk","type":"private"},"date":160259693
      telegram.0	2020-10-13 15:48:50.302	debug	(1259) Message sent
      telegram.0	2020-10-13 15:48:50.301	debug	(1259) Request: {"message_id":2136,"from":{"id":1016259540,"is_bot":true,"first_name":"Semmy","username":"Robbi110_bot"},"chat":{"id":1221955920,"first_name":"Dirk","type":"private"},"date":160259693
      telegram.0	2020-10-13 15:48:50.178	debug	Mähe gerade Zone 2.
      telegram.0	2020-10-13 15:48:50.178	debug	(1259) Send message to "Dirk": Info Robbi:
      telegram.0	2020-10-13 15:48:50.177	debug	(1259) Received command "send": {"text":"Info Robbi:\n\nMähe gerade Zone 2.","user":"Dirk"}
      telegram.0	2020-10-13 15:48:50.149	debug	Mähe gerade Zone 2.
      telegram.0	2020-10-13 15:48:50.149	debug	(1259) Send message to "Dirk": Info Robbi:
      telegram.0	2020-10-13 15:48:50.148	debug	(1259) Received command "send": {"text":"Info Robbi:\n\nMähe gerade Zone 2.","user":"Dirk"}
      telegram.0	2020-10-13 15:48:50.145	debug	Mähe gerade Zone 2.
      telegram.0	2020-10-13 15:48:50.145	debug	(1259) Send message to "Dirk": Info Robbi:
      telegram.0	2020-10-13 15:48:50.144	debug	(1259) Received command "send": {"text":"Info Robbi:\n\nMähe gerade Zone 2.","user":"Dirk"}
      telegram.0	2020-10-13 15:48:50.142	debug	Mähe gerade Zone 2.
      telegram.0	2020-10-13 15:48:50.142	debug	(1259) Send message to "Dirk": Info Robbi:
      telegram.0	2020-10-13 15:48:50.134	debug	(1259) Received command "send": {"text":"Info Robbi:\n\nMähe gerade Zone 2.","user":"Dirk"}
      telegram.0	2020-10-13 15:48:50.129	debug	(1259) Send message to "Dirk": Mähe gerade Zone 1.
      telegram.0	2020-10-13 15:48:50.128	debug	(1259) Received command "send": {"text":"Mähe gerade Zone 1.","user":"Dirk"}
      javascript.0	2020-10-13 15:48:50.124	info	(7333) script.js.Robbi-Mähzyklus: Telegram gesendet
      MOD-Edit: Code in code-tags gesetzt!
        Homoran Global Moderator Administrators @Semmy last edited by
        @Semmy sagte in Telegram sendet mehrfach:
        und (unmittelbar) vor dem Eintrag javascript.0 2020-10-13 15:48:50.124 info
        keine weiteren Javascript einträge mit gleichem Inhalt?
          @Homoran Nein, das ist der Anfang.
            @Semmy das stammt aber nicht aus dem gezeigten Skript!
            Mähe gerade Zone 2.
            ist ein anderer Text!
            Also wahrscheinlich genau das was @MCU schon lange vermutet hat.
              @Homoran Das stimmt, aber ich habe die anderen Blöcke, in denen der Text steht, alle deaktiviert. Dann sollte der Text doch auch nicht erscheinen, oder?
                @Semmy Da spuckt dir ein anderes Skript noch in die Suppe.
                deswegen solltest du ja nach einem typischen Wort daraus suchen, jetzt z.B. "Zone 2"
                dein Skript sollte die Meldung mit Zone 1 ausliefern, was auch nur EINMALIG nach deinem debug kommt
                  @Homoran Und genau diese Suchfunktion funktioniert nicht.
                    Homoran Global Moderator Administrators @Semmy last edited by Homoran
                    was @MCU und ich ja in der 4.8.4 nicht bestätigen können.
                    dann musst du die gute alte manuelle Suche starten, oder ALLE anderen Skripte deaktivieren und schubweise wieder aktivieren, bis du den Verursacher findest
                      @Homoran Ich habe auch die Version 4.8.4 und nur ein Script installiert.
                        @Semmy geh mal in Objekte, filter dort die erste Spalte nach scripten klappe alles auf und poste den Screenshot
                            @Semmy warum schneidest du den Rest ab, warum bist du im Expertenmodeus, und warum filterst du zusätzlich nach state. Das hatte ich nicht geschrieben.
                              @Homoran So, jetzt aber.
                                @Semmy das ist schon seltsam.
                                Dein Expertenmodus hat uns aber weitergebracht 😉
                                Demnach hast du 2 Skripte
                                • wo ist das hin?
                                  @Homoran Habe nur mal was kurz getestet, script ist gelöscht.
                                    @Semmy
                                    und kaum schickst du mal Informationen, findet man noch mehr
                                    deine Admin-Version ist ebenfalls noch beta.
                                    mach mal ein downgrade auf die stable-Version (4.0.10)
                                      lass dir doch nicht immer alles aus der Nase ziehen!
                                      Ist es jetzt gelöscht oder was meinst du?
                                        Thomas Braun Most Active @Semmy last edited by
                                        @Semmy
                                        Umlaute in Skriptnamen würde ich auch vermeiden.
                                          @Homoran Es ist jetzt nur ein sript installiert und 4.0.10 wird gerade aktualisiert.
                                            der Screenshot sagte aber zwei, nachdem du schriebst:
                                            Was stimmt denn jetzt?
                                            4284
