    3. Off Topic
    4. Grafana
    5. [GELÖST] Grafana und iobroker? Firefox blockiert Ansicht
    • UncleSam
      UncleSam Developer @Beowolf last edited by
      @Beowolf es hilft :). xx und xx.xx.xx.xx sind dieselbe IP Adresse?
      • Feuersturm
        Feuersturm @Beowolf last edited by
        @Beowolf Hi, hast du Grafana wie folgt konfiguriert?
          Beowolf @UncleSam last edited by
          @UncleSam jepp
            Beowolf @Feuersturm last edited by
            @Feuersturm
            Jepp
            • Feuersturm
              Feuersturm @Beowolf last edited by Feuersturm
              @Beowolf Zeigt sich das gleiche Verhalten auch in einem anderen Browser? Kannst du deine grafana.ini hier mal reinstellen?
                Beowolf @Feuersturm last edited by Beowolf
                ##################### Grafana Configuration Example #####################
                # Everything has defaults so you only need to uncomment things you want to
                # change
                # possible values : production, development
                ;app_mode = production
                # instance name, defaults to HOSTNAME environment variable value or hostname if HOSTNAME var is empty
                ;instance_name = ${HOSTNAME}
                #################################### Paths ####################################
                [paths]
                # Path to where grafana can store temp files, sessions, and the sqlite3 db (if that is used)
                ;data = /var/lib/grafana
                # Temporary files in `data` directory older than given duration will be removed
                ;temp_data_lifetime = 24h
                # Directory where grafana can store logs
                ;logs = /var/log/grafana
                # Directory where grafana will automatically scan and look for plugins
                ;plugins = /var/lib/grafana/plugins
                # folder that contains provisioning config files that grafana will apply on startup and while running.
                ;provisioning = conf/provisioning
                #################################### Server ####################################
                [server]
                # Protocol (http, https, h2, socket)
                ;protocol = http
                # The ip address to bind to, empty will bind to all interfaces
                ;http_addr =
                # The http port  to use
                ;http_port = 3000
                # The public facing domain name used to access grafana from a browser
                ;domain = localhost
                # Redirect to correct domain if host header does not match domain
                # Prevents DNS rebinding attacks
                ;enforce_domain = false
                # The full public facing url you use in browser, used for redirects and emails
                # If you use reverse proxy and sub path specify full url (with sub path)
                ;root_url = %(protocol)s://%(domain)s:%(http_port)s/
                # Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
                ;serve_from_sub_path = false
                # Log web requests
                ;router_logging = false
                # the path relative working path
                ;static_root_path = public
                # enable gzip
                ;enable_gzip = false
                # https certs & key file
                ;cert_file =
                ;cert_key =
                # Unix socket path
                ;socket =
                #################################### Database ####################################
                [database]
                # You can configure the database connection by specifying type, host, name, user and password
                # as separate properties or as on string using the url properties.
                # Either "mysql", "postgres" or "sqlite3", it's your choice
                ;type = sqlite3
                ;host = 127.0.0.1:3306
                ;name = grafana
                ;user = root
                # If the password contains # or ; you have to wrap it with triple quotes. Ex """#password;"""
                ;password =
                # Use either URL or the previous fields to configure the database
                # Example: mysql://user:secret@host:port/database
                ;url =
                # For "postgres" only, either "disable", "require" or "verify-full"
                ;ssl_mode = disable
                ;ca_cert_path =
                ;client_key_path =
                ;client_cert_path =
                ;server_cert_name =
                # For "sqlite3" only, path relative to data_path setting
                ;path = grafana.db
                # Max idle conn setting default is 2
                ;max_idle_conn = 2
                # Max conn setting default is 0 (mean not set)
                ;max_open_conn =
                # Connection Max Lifetime default is 14400 (means 14400 seconds or 4 hours)
                ;conn_max_lifetime = 14400
                # Set to true to log the sql calls and execution times.
                ;log_queries =
                # For "sqlite3" only. cache mode setting used for connecting to the database. (private, shared)
                ;cache_mode = private
                #################################### Cache server #############################
                [remote_cache]
                # Either "redis", "memcached" or "database" default is "database"
                ;type = database
                # cache connectionstring options
                # database: will use Grafana primary database.
                # redis: config like redis server e.g. `addr=127.0.0.1:6379,pool_size=100,db=0,ssl=false`. Only addr is required. ssl may be 'true', 'false', or 'insecure'.
                # memcache: 127.0.0.1:11211
                ;connstr =
                #################################### Data proxy ###########################
                [dataproxy]
                # This enables data proxy logging, default is false
                ;logging = false
                # How long the data proxy should wait before timing out default is 30 (seconds)
                ;timeout = 30
                # If enabled and user is not anonymous, data proxy will add X-Grafana-User header with username into the request, default is false.
                ;send_user_header = false
                #################################### Analytics ####################################
                [analytics]
                # Server reporting, sends usage counters to stats.grafana.org every 24 hours.
                # No ip addresses are being tracked, only simple counters to track
                # running instances, dashboard and error counts. It is very helpful to us.
                # Change this option to false to disable reporting.
                ;reporting_enabled = true
                # Set to false to disable all checks to https://grafana.net
                # for new vesions (grafana itself and plugins), check is used
                # in some UI views to notify that grafana or plugin update exists
                # This option does not cause any auto updates, nor send any information
                # only a GET request to http://grafana.com to get latest versions
                ;check_for_updates = true
                # Google Analytics universal tracking code, only enabled if you specify an id here
                ;google_analytics_ua_id =
                # Google Tag Manager ID, only enabled if you specify an id here
                ;google_tag_manager_id =
                #################################### Security ####################################
                [security]
                # disable creation of admin user on first start of grafana
                ;disable_initial_admin_creation = false
                # default admin user, created on startup
                ;admin_user = admin
                # default admin password, can be changed before first start of grafana,  or in profile settings
                ;admin_password = admin
                # used for signing
                ;secret_key = SW2YcwTIb9zpOOhoPsMm
                # disable gravatar profile images
                ;disable_gravatar = false
                # data source proxy whitelist (ip_or_domain:port separated by spaces)
                ;data_source_proxy_whitelist =
                # disable protection against brute force login attempts
                ;disable_brute_force_login_protection = false
                # set to true if you host Grafana behind HTTPS. default is false.
                ;cookie_secure = false
                # set cookie SameSite attribute. defaults to `lax`. can be set to "lax", "strict", "none" and "disabled"
                ;cookie_samesite = lax
                # set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
                allow_embedding = true
                # Set to true if you want to enable http strict transport security (HSTS) response header.
                # This is only sent when HTTPS is enabled in this configuration.
                # HSTS tells browsers that the site should only be accessed using HTTPS.
                # The default version will change to true in the next minor release, 6.3.
                ;strict_transport_security = false
                # Sets how long a browser should cache HSTS. Only applied if strict_transport_security is enabled.
                ;strict_transport_security_max_age_seconds = 86400
                # Set to true if to enable HSTS preloading option. Only applied if strict_transport_security is enabled.
                ;strict_transport_security_preload = false
                # Set to true if to enable the HSTS includeSubDomains option. Only applied if strict_transport_security is enabled.
                ;strict_transport_security_subdomains = false
                # Set to true to enable the X-Content-Type-Options response header.
                # The X-Content-Type-Options response HTTP header is a marker used by the server to indicate that the MIME types advertised
                # in the Content-Type headers should not be changed and be followed. The default will change to true in the next minor release, 6.3.
                ;x_content_type_options = false
                # Set to true to enable the X-XSS-Protection header, which tells browsers to stop pages from loading
                # when they detect reflected cross-site scripting (XSS) attacks. The default will change to true in the next minor release, 6.3.
                ;x_xss_protection = false
                #################################### Snapshots ###########################
                [snapshots]
                # snapshot sharing options
                ;external_enabled = true
                ;external_snapshot_url = https://snapshots-origin.raintank.io
                ;external_snapshot_name = Publish to snapshot.raintank.io
                # Set to true to enable this Grafana instance act as an external snapshot server and allow unauthenticated requests for
                # creating and deleting snapshots.
                ;public_mode = false
                # remove expired snapshot
                ;snapshot_remove_expired = true
                #################################### Dashboards History ##################
                [dashboards]
                # Number dashboard versions to keep (per dashboard). Default: 20, Minimum: 1
                ;versions_to_keep = 20
                #################################### Users ###############################
                [users]
                # disable user signup / registration
                ;allow_sign_up = true
                # Allow non admin users to create organizations
                ;allow_org_create = true
                # Set to true to automatically assign new users to the default organization (id 1)
                ;auto_assign_org = true
                # Set this value to automatically add new users to the provided organization (if auto_assign_org above is set to true)
                ;auto_assign_org_id = 1
                # Default role new users will be automatically assigned (if disabled above is set to true)
                ;auto_assign_org_role = Viewer
                # Require email validation before sign up completes
                ;verify_email_enabled = false
                # Background text for the user field on the login page
                ;login_hint = email or username
                ;password_hint = password
                # Default UI theme ("dark" or "light")
                ;default_theme = dark
                # External user management, these options affect the organization users view
                ;external_manage_link_url =
                ;external_manage_link_name =
                ;external_manage_info =
                # Viewers can edit/inspect dashboard settings in the browser. But not save the dashboard.
                ;viewers_can_edit = false
                # Editors can administrate dashboard, folders and teams they create
                ;editors_can_admin = false
                [auth]
                # Login cookie name
                ;login_cookie_name = grafana_session
                # The lifetime (days) an authenticated user can be inactive before being required to login at next visit. Default is 7 days,
                ;login_maximum_inactive_lifetime_days = 7
                # The maximum lifetime (days) an authenticated user can be logged in since login time before being required to login. Default is 30 days.
                ;login_maximum_lifetime_days = 30
                # How often should auth tokens be rotated for authenticated users when being active. The default is each 10 minutes.
                ;token_rotation_interval_minutes = 10
                # Set to true to disable (hide) the login form, useful if you use OAuth, defaults to false
                ;disable_login_form = false
                # Set to true to disable the signout link in the side menu. useful if you use auth.proxy, defaults to false
                ;disable_signout_menu = false
                # URL to redirect the user to after sign out
                ;signout_redirect_url =
                # Set to true to attempt login with OAuth automatically, skipping the login screen.
                # This setting is ignored if multiple OAuth providers are configured.
                ;oauth_auto_login = false
                # limit of api_key seconds to live before expiration
                ;api_key_max_seconds_to_live = -1
                #################################### Anonymous Auth ######################
                [auth.anonymous]
                # enable anonymous access
                enabled = true
                # specify organization name that should be used for unauthenticated users
                ;org_name = Main Org.
                # specify role for unauthenticated users
                ;org_role = Viewer
                #################################### Github Auth ##########################
                [auth.github]
                ;enabled = false
                ;client_id = some_id
                ;client_secret = some_secret
                ;scopes = user:email,read:org
                ;auth_url = https://github.com/login/oauth/authorize
                ;token_url = https://github.com/login/oauth/access_token
                ;api_url = https://api.github.com/user
                ;allowed_domains =
                ;team_ids =
                ;allowed_organizations =
                #################################### GitLab Auth #########################
                [auth.gitlab]
                ;enabled = false
                ;scopes = api
                ;auth_url = https://gitlab.com/oauth/authorize
                ;token_url = https://gitlab.com/oauth/token
                ;api_url = https://gitlab.com/api/v4
                ;allowed_domains =
                ;allowed_groups =
                #################################### Google Auth ##########################
                [auth.google]
                ;enabled = false
                ;client_id = some_client_id
                ;client_secret = some_client_secret
                ;scopes = https://www.googleapis.com/auth/userinfo.profile https://www.googleapis.com/auth/userinfo.email
                ;auth_url = https://accounts.google.com/o/oauth2/auth
                ;token_url = https://accounts.google.com/o/oauth2/token
                ;api_url = https://www.googleapis.com/oauth2/v1/userinfo
                ;allowed_domains =
                ;hosted_domain =
                #################################### Grafana.com Auth ####################
                [auth.grafana_com]
                ;enabled = false
                #################################### Generic OAuth ##########################
                [auth.generic_oauth]
                ;enabled = false
                ;name = OAuth
                ;email_attribute_name = email:primary
                ;email_attribute_path =
                ;auth_url = https://foo.bar/login/oauth/authorize
                ;token_url = https://foo.bar/login/oauth/access_token
                ;api_url = https://foo.bar/user
                ;allowed_domains =
                ;team_ids =
                ;role_attribute_path =
                ;tls_skip_verify_insecure = false
                ;tls_client_cert =
                ;tls_client_key =
                ;tls_client_ca =
                #################################### SAML Auth ###########################
                [auth.saml] # Enterprise only
                # Defaults to false. If true, the feature is enabled.
                ;enabled = false
                # Base64-encoded public X.509 certificate. Used to sign requests to the IdP
                ;certificate =
                # Path to the public X.509 certificate. Used to sign requests to the IdP
                ;certificate_path =
                # Base64-encoded private key. Used to decrypt assertions from the IdP
                ;private_key =
                ;# Path to the private key. Used to decrypt assertions from the IdP
                ;private_key_path =
                # Base64-encoded IdP SAML metadata XML. Used to verify and obtain binding locations from the IdP
                ;idp_metadata =
                # Path to the SAML metadata XML. Used to verify and obtain binding locations from the IdP
                ;idp_metadata_path =
                # URL to fetch SAML IdP metadata. Used to verify and obtain binding locations from the IdP
                ;idp_metadata_url =
                # Duration, since the IdP issued a response and the SP is allowed to process it. Defaults to 90 seconds.
                ;max_issue_delay = 90s
                # Duration, for how long the SP's metadata should be valid. Defaults to 48 hours.
                ;metadata_valid_duration = 48h
                # Friendly name or name of the attribute within the SAML assertion to use as the user's name
                ;assertion_attribute_name = displayName
                # Friendly name or name of the attribute within the SAML assertion to use as the user's login handle
                ;assertion_attribute_login = mail
                # Friendly name or name of the attribute within the SAML assertion to use as the user's email
                ;assertion_attribute_email = mail
                #################################### Basic Auth ##########################
                [auth.basic]
                ;enabled = true
                #################################### Auth Proxy ##########################
                [auth.proxy]
                ;enabled = false
                ;header_name = X-WEBAUTH-USER
                ;header_property = username
                ;auto_sign_up = true
                ;sync_ttl = 60
                ;whitelist = 192.168.1.1, 192.168.2.1
                ;headers = Email:X-User-Email, Name:X-User-Name
                # Read the auth proxy docs for details on what the setting below enables
                ;enable_login_token = false
                #################################### Auth LDAP ##########################
                [auth.ldap]
                ;enabled = false
                ;config_file = /etc/grafana/ldap.toml
                # LDAP backround sync (Enterprise only)
                # At 1 am every day
                ;sync_cron = "0 0 1 * * *"
                ;active_sync_enabled = true
                #################################### SMTP / Emailing ##########################
                [smtp]
                ;enabled = false
                ;host = localhost:25
                ;user =
                ;password =
                ;cert_file =
                ;key_file =
                ;skip_verify = false
                ;from_address = admin@grafana.localhost
                ;from_name = Grafana
                # EHLO identity in SMTP dialog (defaults to instance_name)
                ;ehlo_identity = dashboard.example.com
                [emails]
                ;welcome_email_on_sign_up = false
                ;templates_pattern = emails/*.html
                #################################### Logging ##########################
                [log]
                # Either "console", "file", "syslog". Default is console and  file
                # Use space to separate multiple modes, e.g. "console file"
                ;mode = console file
                # Either "debug", "info", "warn", "error", "critical", default is "info"
                ;level = info
                # optional settings to set different levels for specific loggers. Ex filters = sqlstore:debug
                ;filters =
                # For "console" mode only
                [log.console]
                ;level =
                # log line format, valid options are text, console and json
                ;format = console
                # For "file" mode only
                [log.file]
                ;level =
                ;format = text
                # This enables automated log rotate(switch of following options), default is true
                ;log_rotate = true
                # Max line number of single file, default is 1000000
                ;max_lines = 1000000
                # Max size shift of single file, default is 28 means 1 << 28, 256MB
                ;max_size_shift = 28
                # Segment log daily, default is true
                ;daily_rotate = true
                # Expired days of log file(delete after max days), default is 7
                ;max_days = 7
                [log.syslog]
                ;level =
                ;format = text
                # Syslog network type and address. This can be udp, tcp, or unix. If left blank, the default unix endpoints will be used.
                ;network =
                ;address =
                # Syslog facility. user, daemon and local0 through local7 are valid.
                ;facility =
                # Syslog tag. By default, the process' argv[0] is used.
                ;tag =
                #################################### Usage Quotas ########################
                [quota]
                ; enabled = false
                #### set quotas to -1 to make unlimited. ####
                # limit number of users per Org.
                ; org_user = 10
                # limit number of dashboards per Org.
                ; org_dashboard = 100
                # limit number of data_sources per Org.
                ; org_data_source = 10
                # limit number of api_keys per Org.
                ; org_api_key = 10
                # limit number of orgs a user can create.
                ; user_org = 10
                # Global limit of users.
                ; global_user = -1
                # global limit of orgs.
                ; global_org = -1
                # global limit of dashboards
                ; global_dashboard = -1
                # global limit of api_keys
                ; global_api_key = -1
                # global limit on number of logged in users.
                ; global_session = -1
                #################################### Alerting ############################
                [alerting]
                # Disable alerting engine & UI features
                ;enabled = true
                # Makes it possible to turn off alert rule execution but alerting UI is visible
                ;execute_alerts = true
                # Default setting for new alert rules. Defaults to categorize error and timeouts as alerting. (alerting, keep_state)
                ;error_or_timeout = alerting
                # Default setting for how Grafana handles nodata or null values in alerting. (alerting, no_data, keep_state, ok)
                ;nodata_or_nullvalues = no_data
                # Alert notifications can include images, but rendering many images at the same time can overload the server
                # This limit will protect the server from render overloading and make sure notifications are sent out quickly
                ;concurrent_render_limit = 5
                # Default setting for alert calculation timeout. Default value is 30
                ;evaluation_timeout_seconds = 30
                # Default setting for alert notification timeout. Default value is 30
                ;notification_timeout_seconds = 30
                # Default setting for max attempts to sending alert notifications. Default value is 3
                ;max_attempts = 3
                # Makes it possible to enforce a minimal interval between evaluations, to reduce load on the backend
                ;min_interval_seconds = 1
                #################################### Explore #############################
                [explore]
                # Enable the Explore section
                ;enabled = true
                #################################### Internal Grafana Metrics ##########################
                # Metrics available at HTTP API Url /metrics
                [metrics]
                # Disable / Enable internal metrics
                ;enabled           = true
                # Graphite Publish interval
                ;interval_seconds  = 10
                # Disable total stats (stat_totals_*) metrics to be generated
                ;disable_total_stats = false
                #If both are set, basic auth will be required for the metrics endpoint.
                ; basic_auth_username =
                ; basic_auth_password =
                # Send internal metrics to Graphite
                [metrics.graphite]
                # Enable by setting the address setting (ex localhost:2003)
                ;address =
                ;prefix = prod.grafana.%(instance_name)s.
                #################################### Grafana.com integration  ##########################
                # Url used to import dashboards directly from Grafana.com
                [grafana_com]
                ;url = https://grafana.com
                #################################### Distributed tracing ############
                [tracing.jaeger]
                # Enable by setting the address sending traces to jaeger (ex localhost:6831)
                ;address = localhost:6831
                # Tag that will always be included in when creating new spans. ex (tag1:value1,tag2:value2)
                ;always_included_tag = tag1:value1
                # Type specifies the type of the sampler: const, probabilistic, rateLimiting, or remote
                ;sampler_type = const
                # jaeger samplerconfig param
                # for "const" sampler, 0 or 1 for always false/true respectively
                # for "probabilistic" sampler, a probability between 0 and 1
                # for "rateLimiting" sampler, the number of spans per second
                # for "remote" sampler, param is the same as for "probabilistic"
                # and indicates the initial sampling rate before the actual one
                # is received from the mothership
                ;sampler_param = 1
                # Whether or not to use Zipkin propagation (x-b3- HTTP headers).
                ;zipkin_propagation = false
                # Setting this to true disables shared RPC spans.
                # Not disabling is the most common setting when using Zipkin elsewhere in your infrastructure.
                ;disable_shared_zipkin_spans = false
                #################################### External image storage ##########################
                [external_image_storage]
                # Used for uploading images to public servers so they can be included in slack/email messages.
                # you can choose between (s3, webdav, gcs, azure_blob, local)
                ;provider =
                [external_image_storage.s3]
                ;endpoint =
                ;path_style_access =
                ;bucket =
                ;region =
                ;path =
                ;access_key =
                ;secret_key =
                [external_image_storage.webdav]
                ;url =
                ;public_url =
                ;username =
                ;password =
                [external_image_storage.gcs]
                ;key_file =
                ;bucket =
                ;path =
                [external_image_storage.azure_blob]
                ;account_name =
                ;account_key =
                ;container_name =
                [external_image_storage.local]
                # does not require any configuration
                [rendering]
                # Options to configure a remote HTTP image rendering service, e.g. using https://github.com/grafana/grafana-image-renderer.
                # URL to a remote HTTP image renderer service, e.g. http://localhost:8081/render, will enable Grafana to render panels and dashboards to PNG-images using HTTP requests to an external service.
                ;server_url =
                # If the remote HTTP image renderer service runs on a different server than the Grafana server you may have to configure this to a URL where Grafana is reachable, e.g. http://grafana.domain/.
                ;callback_url =
                [panels]
                # If set to true Grafana will allow script tags in text panels. Not recommended as it enable XSS vulnerabilities.
                ;disable_sanitize_html = false
                [plugins]
                ;enable_alpha = false
                ;app_tls_skip_verify_insecure = false
                [enterprise]
                # Path to a valid Grafana Enterprise license.jwt file
                ;license_path =
                [feature_toggles]
                # enable features, separated by spaces
                ;enable =
                  @Feuersturm sagte in Grafana und iobroker? Firefox blockiert Ansicht:
                  Anderer Browser? Jepp, habe Edge probiert. Dort wird es auch nicht angezeigt.
                  • UncleSam
                    @Beowolf sagte in Grafana und iobroker? Firefox blockiert Ansicht:
                    Adresse von vis:
                    xx:8082/vis/index.html#Bodentemperatur
                    Die Adresse ist auch http://, richtig?
                      Beowolf @UncleSam last edited by Beowolf
                      @UncleSam
                      http://192.168.xx.xx:3000/d/p14aCLRRk/new-dashboard-copy?orgId=1&from=1602668338364&to=1602670138364&panelId=2&fullscreen
                      K B 2 Replies Last reply Reply Quote 0
                        Knoddel @Beowolf last edited by
                        @Beowolf
                        Um Grafiken in Iobroker VIS einbinden zu können müss in der grafana.ini
                        noch Einstellungen geändert werden, die wie folgt aussehen.
                        sudo nano /etc/grafana/grafana.ini
                        dort die Einträge von false auf true ändern
                        [auth.anonymous]
                        enable anonymous
                        ;enabled = false
                        enabled = true
                        [security]
                        ;allow_embedding = false
                          Beowolf @Beowolf last edited by
                          @Beowolf
                          Ich habe doch die ini oben eingestellt. Dort sind die Einträge so wie sie sollen.
                            So, ich habe gerade einmal ALLES runter gefahren, abgeschaltet und dann alles neu gestartet. Rechner, Pi3 und die Kaffeemaschine.
                            Warum auch immer - es läuft jetzt. 👍 👍 👍 😀 😀
                            Trotzdem danke für die tolle Unterstützung. 👍
                            Manfred
                            Feuersturm da_Woody 2 Replies Last reply Reply Quote 1
                            • Feuersturm
                              @Beowolf Dann koch dir mal einen Kaffee und viel Spaß mit Grafana und VIS 😁
                              • da_Woody
                                da_Woody @Beowolf last edited by
                                @Beowolf reboot macht meistens gut... 😉 ab und an auch mal ein shift+reload...
                                dieses ganze browser gesocks wird immer zickiger.
                                  Beowolf last edited by Beowolf
                                  Ist schon ein wenig her, aber als früher mal DOS und Windows 3.1 nicht mehr so richtig wollten, habe ich aus Frust schon mal ein "fdisk" gemacht. Das tat auch immer gut. 😀
                                  Für die denen das nichts sagt - fdisk kommt aus der Zeit, als 20MB-Festplatten noch 3kg wogen. 😳
                                  Manfred
                                  PS:
                                  Habe gerade herausgefunden, das man die Grafik auch ohne alles drumherum anzeigen lassen kann. Ich glaube, ich werde hier in Grafana noch vieles entdecken. 😀 😀
                                  • da_Woody
                                    da_Woody @Beowolf last edited by da_Woody
                                    @Beowolf du meinst wohl fdisk -mbr muss ja nicht gleich alles gelöscht werden... 😄
                                    mit 20MB warst du ja schon gottgleich!
                                    • Meister Mopper
                                      Meister Mopper @da_Woody last edited by
                                      @da_Woody sagte in [GELÖST] Grafana und iobroker? Firefox blockiert Ansicht:
                                      Un alle haben behauptet: "Die kriegst Du niemals voll!" 😊
                                      • N
                                        nukia last edited by
                                        Hab seltsamerweise genau das gleiche Probleme. Die Einträge in der ini sind angepasst, Rasperry und der Garfana Server wurden neu gestartet...
                                        Fehlermeldung:
                                        Firefox darf diese eingebettete Seite nicht öffnen
                                        Zu Ihrem Schutz erlaubt 192.xxx.xxx.xxx es Firefox nicht, diese Seite anzuzeigen, wenn sie in eine andere Seite eingebettet ist. Zur Anzeige der Seite muss diese in einem neuen Tab geöffnet werden.
                                        • N
                                          nukia @nukia last edited by
                                          @nukia Fehler gefunden, man muss in der oben beschriebenen ini Änderung auch den ";" entfernen
                                          da_Woody K 2 Replies Last reply Reply Quote 0
                                          • da_Woody
                                            da_Woody @nukia last edited by
                                            @nukia na steht ja auch dort! 😉
                                            vis
                                            5461
