    3. Entwicklung
    4. ZigBee neue/unbekannte Geräte - ab 1.3.0
      stewe @arteck last edited by
      @arteck Hallo arteck,
      nach update auf 1.3.0 hier noch einmal die Bitte, den LED Stripe Controller DC5-24V (Lonsonho Tuya Zigbee Smart RGB Led Controller) einzubinden.
      https://de.aliexpress.com/item/1005001315938878.html?spm=a2g0s.9042311.0.0.1cda4c4dhphTWS
      Vielen Dank für die bisher geleistete Arbeit!
        arteck Developer Most Active @Holger Etzel last edited by arteck
        @Holger-Etzel das Bild wird nicht immer passen da tuya unterschiedlichen Geräten gleiche Modelnamen vergibt..
        stell den adapter auf Debug.. drücke ein knopp nach dem anderen und poste das LOG
        Holger Etzel 1 Reply Last reply Reply Quote 0
        • Holger Etzel
          Holger Etzel @arteck last edited by
          @arteck
          hier das log
          zigbee.1	2020-10-09 15:56:41.798	debug	(12346) Publish {"action":"right_single"}
          zigbee.1	2020-10-09 15:56:41.795	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:41.793	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,119,253,0]}' from endpoint 1 with groupID 0
          zigbee.1	2020-10-09 15:56:41.792	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:38.471	debug	(12346) Publish {"action":"middle_hold"}
          zigbee.1	2020-10-09 15:56:38.464	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:38.463	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,118,253,2]}' from endpoint 2 with groupID 0
          zigbee.1	2020-10-09 15:56:38.461	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:35.070	debug	(12346) Publish {"action":"left_hold"}
          zigbee.1	2020-10-09 15:56:35.066	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:35.065	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,117,253,2]}' from endpoint 3 with groupID 0
          zigbee.1	2020-10-09 15:56:35.064	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:31.648	debug	(12346) Publish {"action":"right_double"}
          zigbee.1	2020-10-09 15:56:31.609	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:31.608	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,116,253,1]}' from endpoint 1 with groupID 0
          zigbee.1	2020-10-09 15:56:31.606	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:30.292	debug	(12346) Publish {"action":"middle_double"}
          zigbee.1	2020-10-09 15:56:30.288	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:30.287	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,115,253,1]}' from endpoint 2 with groupID 0
          zigbee.1	2020-10-09 15:56:30.285	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:28.823	debug	(12346) Publish {"action":"left_double"}
          zigbee.1	2020-10-09 15:56:28.815	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:28.814	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,114,253,1]}' from endpoint 3 with groupID 0
          zigbee.1	2020-10-09 15:56:28.813	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:27.032	debug	(12346) Publish {"action":"right_single"}
          zigbee.1	2020-10-09 15:56:27.011	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:27.010	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,113,253,0]}' from endpoint 1 with groupID 0
          zigbee.1	2020-10-09 15:56:27.010	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          javascript.0	2020-10-09 15:56:26.644	info	(31849) script.js.common.BattUeberwachung: Reaching MakeTable
          javascript.0	2020-10-09 15:56:26.643	info	(31849) script.js.common.BattUeberwachung: Reaching CheckDeadBatt()
          zigbee.1	2020-10-09 15:56:25.978	debug	(12346) Publish {"action":"middle_single"}
          zigbee.1	2020-10-09 15:56:25.974	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:25.973	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,112,253,0]}' from endpoint 2 with groupID 0
          zigbee.1	2020-10-09 15:56:25.971	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
          zigbee.1	2020-10-09 15:56:24.686	debug	(12346) Publish {"action":"left_single"}
          zigbee.1	2020-10-09 15:56:24.682	debug	(12346) Type raw device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"dev
          zigbee.1	2020-10-09 15:56:24.680	debug	(12346) Received Zigbee message from '0xec1bbdfffe76d92a', type 'raw', cluster 'genOnOff', data '{"type":"Buffer","data":[17,111,253,0]}' from endpoint 3 with groupID 0
          zigbee.1	2020-10-09 15:56:24.679	debug	(12346) handleMessage. {"type":"raw","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe76d92a","_networkAddress":18300,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceI
            @Holger-Etzel ok fehler erkannt.. muss im converter korrigiert werden.. musst dich gedulden
            Holger Etzel 3 Replies Last reply Reply Quote 0
              sting last edited by
              Servus!
              Bitte den Plug ZHS-15 von Schwaiger einbinden.
              Danke!
              • V
                vikk88 last edited by
                @arteck
                ist es möglich bei dem Thermostat die Batterieanzeige einzufügen?
                Habe gerade gemerkt dass das echt nützlich ist nachdem ich im Wohnzimmer 24 Grad hatte weil die Batterien leer waren und das Ventil sich geöffnet hat.😁
                • Holger Etzel
                  @arteck
                  Bin ja froh das was gefunden wurde und das du dich so intensiv darum kümmerst. Danke schön mal vorab
                    memoire last edited by
                    @arteck
                    könntest du bitte folgenden Adapter aufnehmen?
                    Zigbee ID: "ZG2833K8_EU05"
                    Wall Remote 8V
                    Model ROB_200-007-0 manufactured by ROBB eg. YPHIX (Product Code: 50208691)
                    Vielen Dank für deine tolle Arbeit bisher.
                    M M 2 Replies Last reply Reply Quote 0
                      hansjuri last edited by
                      @arteck
                      Habe mir eine neue Zigbee Lampe gekauft und leider
                      Device 0xf0d1b8000013ab26 "Tibea TW Z3" not described in statesMapping
                      hier die Daten:
                      ieee:0xf0d1b8000013ab26
                      nwk:16470 (0x4056)
                      model:Tibea TW Z3
                      model:Tibea TW Z3
                      type:Router
                      nwk:16470
                      manuf id:4489
                      manufacturer:LEDVANCE
                      power:Mains (single phase)
                      app version:1
                      hard version:1
                      zcl version:2
                      stack version:2
                      date code:Nov 26 2018
                      build:00103101
                      interviewed:true
                      configured:false
                      endpoint:1
                      profile:260
                      input clusters:genBasic (0)
                      genIdentify (3)
                      genGroups (4)
                      genScenes (5)
                      genOnOff (6)
                      genLevelCtrl (8)
                      lightingColorCtrl (768)
                      haDiagnostic (2821)
                      touchlink (4096)
                      manuSpecificOsram (64527)
                      output clusters:genOta (25)
                      endpoint:242
                      profile:41440
                      output clusters:greenPower (33)
                      Danke schon mal im Voraus
                      Z Asgothian 2 Replies Last reply Reply Quote 0
                      • Thorsten B.
                        Thorsten B. last edited by
                        @arteck
                        wäre es möglich die FLAIR Viyu Smarte LED Kerze E14 von Hornbach aufzuhnemen?
                        Gruß und Danke
                        • Z
                          zgadgeter @hansjuri last edited by
                          @hansjuri Hallo, hattest Du die Lampe integriert bekommen? danke.
                          • Asgothian
                            Asgothian Developer @hansjuri last edited by Asgothian
                            @hansjuri sagte in ZigBee neue/unbekannte Geräte - ab 1.3.0:
                            Tibea TW Z3
                            @zgadgeter sagte in ZigBee neue/unbekannte Geräte - ab 1.3.0:
                            @Thorsten-B sagte in ZigBee neue/unbekannte Geräte - ab 1.3.0:
                            Bisher ist die Lampe nicht bei zigbee2mqtt.io als supported gelistet. Es kann also etwas dauern bis sie geht.
                            A.
                              hansjuri @Asgothian last edited by
                              @zgadgeter noch nicht, siehst ja was Asgothian schreibt, habe aber kein Zeitproblem, wenn es irgendwann geht freu ich mich, Dank an Asgothian
                              • Jens Bräunel
                                Jens Bräunel last edited by
                                @arteck
                                leider bekomme ich immer noch kein Status für das click und double_click Event bei den Schaltern (Aqara WXKG06LM)
                                anbei noch das Log
                                zigbee.0	2020-10-18 10:51:53.164	debug	(23249) Publish {"action":"double"}
                                zigbee.0	2020-10-18 10:51:53.144	debug	(23249) Type attributeReport device {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
                                zigbee.0	2020-10-18 10:51:53.140	debug	(23249) Received Zigbee message from '0x00158d000521d44b', type 'attributeReport', cluster 'genMultistateInput', data '{"presentValue":2}' from endpoint 1 with groupID 0
                                zigbee.0	2020-10-18 10:51:53.138	debug	(23249) handleMessage. {"type":"attributeReport","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
                                zigbee.0	2020-10-18 10:51:47.154	debug	(23249) Publish {"action":"single"}
                                zigbee.0	2020-10-18 10:51:47.125	debug	(23249) Type attributeReport device {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
                                zigbee.0	2020-10-18 10:51:47.120	debug	(23249) Received Zigbee message from '0x00158d000521d44b', type 'attributeReport', cluster 'genMultistateInput', data '{"presentValue":1}' from endpoint 1 with groupID 0
                                zigbee.0	2020-10-18 10:51:47.114	debug	(23249) handleMessage. {"type":"attributeReport","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
                                zigbee.0	2020-10-18 10:49:15.932	debug	(23249) Publish {"action":"single"}
                                zigbee.0	2020-10-18 10:49:15.849	debug	(23249) Type attributeReport device {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
                                zigbee.0	2020-10-18 10:49:15.834	debug	(23249) Received Zigbee message from '0x00158d000521d44b', type 'attributeReport', cluster 'genMultistateInput', data '{"presentValue":1}' from endpoint 1 with groupID 0
                                zigbee.0	2020-10-18 10:49:15.824	debug	(23249) handleMessage. {"type":"attributeReport","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
                                zigbee.0	2020-10-18 10:49:09.486	debug	(23249) Publish available for 0x00158d000521d44b = true
                                zigbee.0	2020-10-18 10:49:09.454	debug	(23249) Publish available for 0x00158d0004652cf7 = true
                                zigbee.0	2020-10-18 10:49:08.498	info	(23249) Zigbee started
                                zigbee.0	2020-10-18 10:49:08.497	info	(23249) 0x00158d000521d44b (addr 37267): WXKG06LM - Xiaomi Aqara D1 single key wireless wall switch (EndDevice)
                                zigbee.0	2020-10-18 10:49:08.486	debug	(23249) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000521d44b","_networkAddress":37267,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"d
                                zigbee.0	2020-10-18 10:49:08.472	info	(23249) 0x00158d0004652cf7 (addr 12940): WXKG06LM - Xiaomi Aqara D1 single key wireless wall switch (EndDevice)
                                zigbee.0	2020-10-18 10:49:08.470	debug	(23249) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0004652cf7","_networkAddress":12940,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"d
                                zigbee.0	2020-10-18 10:49:08.452	debug	(23249) DeviceConfigure 0x00158d000521d44b lumi.remote.b186acn02 not needed
                                zigbee.0	2020-10-18 10:49:08.440	debug	(23249) DeviceConfigure 0x00158d0004652cf7 lumi.remote.b186acn02 not needed
                                zigbee.0	2020-10-18 10:49:08.439	debug	(23249) Publish available for 0x00158d000521d44b = true
                                zigbee.0	2020-10-18 10:49:08.433	debug	(23249) Publish available for 0x00158d0004652cf7 = true
                                zigbee.0	2020-10-18 10:49:08.428	info	(23249) Currently 2 devices are joined:
                                zigbee.0	2020-10-18 10:49:08.387	info	(23249) --> transmitPower : high
                                zigbee.0	2020-10-18 10:49:08.365	debug	(23249) Zigbee network parameters: {"panID":1305,"extendedPanID":"0xddddddddddddddda","channel":11}
                                zigbee.0	2020-10-18 10:49:08.346	info	(23249) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                                zigbee.0	2020-10-18 10:49:08.340	debug	(23249) zigbee-herdsman started
                                zigbee.0	2020-10-18 10:49:05.300	debug	(23249) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_18-10_49_04.tar.gz success
                                zigbee.0	2020-10-18 10:49:04.672	debug	(23249) Starting zigbee-herdsman...
                                zigbee.0	2020-10-18 10:49:04.670	info	(23249) Starting Zigbee...
                                zigbee.0	2020-10-18 10:49:04.543	debug	(23249) Using zigbee-herdsman with settings: {"network":{"panID":1305,"extendedPanID":[218,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,10]},"databa
                                zigbee.0	2020-10-18 10:49:04.470	info	(23249) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                Vielen Dank für deine Unterstützung.
                                • luesec
                                  luesec @arteck last edited by luesec
                                  @arteck
                                  Hallo habe eine Außenlampe von Paulmann die noch nicht erkannt wird.
                                  Wäre super wenn diese kurzfristig bekannt gemacht werden könnte.
                                  f58ff473-3697-4cde-adaa-9f1ce2ca1d36-grafik.png https://de.paulmann.com/aussenleuchten/gartenbeleuchtung-system/leuchten/plug-und-shine-lichtobjekt-globe-rgbw-smart-home-zigbee-2-8w-24v/94269
                                  Vielen Dank für eure Mühe
                                  Gruß luesec
                                  PS: Hab ich erst bestellt und daher noch keine näheren Daten. Denke aber der Paulmann Zigbee Outdoorcontroller fehlt auch noch:
                                  https://de.paulmann.com/aussenleuchten/gartenbeleuchtung-system/steuerung/plug-und-shine-smart-home-zigbee-controller-ip68-24v-dc-max-75w-schwarz/93999
                                  Werde die Daten dann noch mal posten wenn er da ist und ihr proaktiv noch nichts machen könnt 😉 -> EDIT 22.10. der Outdoorcontroller ist gekommen und wird erkannt. Scheint der gleiche zu sein wie indoor nur anderes gehäuse 😉 . Fehlt nur noch die Lampe.
                                    stefan.cloer @arteck last edited by
                                    @arteck leider ist auch der optische Rauchmelder AV2010/24A von bitron noch nicht eingebunden:
                                    https://manuals.smabit.eu/lde/av2010_24a.html
                                    Vielen Dank im Voraus und für die bisher geleistete Arbeit
                                    K S 2 Replies Last reply Reply Quote 0
                                      kamikazemimmi @stefan.cloer last edited by
                                      bei uns werden 2 Philips Hue Lampen nicht richtig erkannt.
                                      Erst mal unsere Zigbee Version / Revision:
                                      zigbee.0	2020-10-21 14:49:48.818	info	(12165) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                                      zigbee.0	2020-10-21 14:49:46.458	info	(12165) Starting Zigbee...
                                      zigbee.0	2020-10-21 14:49:46.244	info	(12165) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                      hier die Infos der Hue Fuzo Wall Lantern Outdoor
                                      ![alt text](hue-fuzo-1.png image url)
                                      Link:
                                      https://www.philips-hue.com/de-de/p/hue-white-fuzo-wandleuchte/1744530P7
                                      Und die Hue Discover:
                                      Link:
                                      https://www.coolshop.de/produkt/philips-hue-discover-black-outdoor-weiss-farbe-ambiance/AH7EN9/
                                      Ich hoffe, ich habe nichts vergessen🤗
                                      LG
                                        lu1043201 last edited by lu1043201
                                        Re: ZigBee neue/unbekannte Geräte - ab 1.3.0
                                        mein Sunricher Schaltaktor (sr-zg9101sac-hp-switch) wird nicht richtig erkannt.
                                        Zigbee Version/Revision: 20190608
                                        link zum Produkt
                                        Bei zigbee2mqtt unter supported devices ist Produkt dabei.
                                        Wäre super, wenn dies eingebunden werden kann.
                                        Danke schon im voraus.
                                        @Asgothian
                                        Habe eben erst jetzt gesehen, dass "sein Bruder" (ZG9101SAC-HP) welcher dimmbar bereits verfügbar ist. Vielleicht macht es die Sache etwas einfacher. Danke bereits!
                                        @arteck
                                        Vielen Dank fürs Aufnehmen. Kriege noch ein "not described in states mapping... undefined" nach dem neu-pairen (nach reset des Aktors).
                                        Danke für die Bemühungen!
                                        Xsev 1 Reply Last reply Reply Quote 0
                                        • Xsev
                                          Xsev @lu1043201 last edited by
                                          Könnte bitte folgendes Gerät ebenfalls aufgenommen werden.
                                          • Asgothian
                                            Asgothian Developer @Xsev last edited by Asgothian
                                            @Xsev hast Du mal ein Bild was Du da gerne haben willst ?
                                            Nachtrag - der ist noch nicht im Herdsman-converters drin, daher wird er noch nicht erkannt.
                                            A.
                                            converter herdsman neuer adapter zigbee
                                            50
                                            231
                                            35996
