    4. fb-checkpresence Timeout-Fehler und falscher Username
    UNSOLVED fb-checkpresence Timeout-Fehler und falscher Username
      Elektroman @afuerhoff last edited by
      @afuerhoff
      Sorry so sauber ist der Log doch nicht, habe gerade die FB neu gestartet
      fb-checkpresence.0	2020-10-17 19:59:01.274	debug	(2731299) checkPresence first run
      fb-checkpresence.0	2020-10-17 19:59:01.269	debug	(2731299) getActive [{"Name":"Tobias","Active":"false","Kommt":"2020.10.10 00:39:24","Geht":"2020.10.09 18:18:24"},{"Name":"Imke","Active":"false","Kommt":"2020.10.10 15:00:24","Geht":"2020.10.10 10:2
      fb-checkpresence.0	2020-10-17 19:59:01.222	warn	(2731299) ipaddress 192.168.168.170 from member Imke: invalid action
      fb-checkpresence.0	2020-10-17 19:59:01.185	debug	(2731299) getActive [{"Name":"Tobias","Active":"false","Kommt":"2020.10.10 00:39:24","Geht":"2020.10.09 18:18:24"},
      fb-checkpresence.0	2020-10-17 19:59:01.097	warn	(2731299) ipaddress 192.168.168.171 from member Tobias: invalid action
      fb-checkpresence.0	2020-10-17 19:59:01.057	warn	(2731299) can not read external ip address
      fb-checkpresence.0	2020-10-17 19:59:01.056	debug	(2731299) {"status":500,"data":null,"result":false,"resultData":null,"errNo":4,"errorMsg":{"$":{"xmlns":"urn:dslforum-org:control-1-0"},"errorCode":"401","errorDescription":"invalid action"}}
      fb-checkpresence.0	2020-10-17 19:59:01.035	debug	(2731299) {"status":500,"data":null,"result":false,"resultData":null,"errNo":4,"errorMsg":{"$":{"xmlns":"urn:dslforum-org:control-1-0"},"errorCode":"401","errorDescription":"invalid action"}}
      fb-checkpresence.0	2020-10-17 19:59:01.012	error	(2731299) soapAction GetInfo status=500 errNo=4 401 invalid action
      fb-checkpresence.0	2020-10-17 19:59:01.001	error	(2731299) soapAction X_AVM-DE_GetHostListPath status=500 errNo=4 401 invalid action
      fb-checkpresence.0	2020-10-17 19:59:00.998	info	(2731299) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fb-checkpresence.0	2020-10-17 19:59:00.997	info	(2731299) terminating
      fb-checkpresence.0	2020-10-17 19:59:00.997	info	(2731299) cleaned everything up...
      fb-checkpresence.0	2020-10-17 19:59:00.995	info	(2731299) Got terminate signal TERMINATE_YOURSELF
      fb-checkpresence.0	2020-10-17 19:59:00.991	info	(2731299) History function disabled
      fb-checkpresence.0	2020-10-17 19:59:00.987	debug	(2731299) createMemberObjects Imke
      fb-checkpresence.0	2020-10-17 19:59:00.986	info	(2731299) History function disabled
      fb-checkpresence.0	2020-10-17 19:59:00.986	debug	(2731299) createMemberObjects Tobias
      fb-checkpresence.0	2020-10-17 19:59:00.884	error	(2731299) createFbDeviceObjects -> can't read devices from fritzbox!
      fb-checkpresence.0	2020-10-17 19:59:00.883	error	(2731299) soapAction X_AVM-DE_GetHostListPath status=500 errNo=4 401 invalid action
      fb-checkpresence.0	2020-10-17 19:59:00.872	debug	(2731299) function fb-devices true
      fb-checkpresence.0	2020-10-17 19:59:00.871	debug	(2731299) createGlobalObjects
      fb-checkpresence.0	2020-10-17 19:59:00.869	debug	(2731299) sslPort 49443
      fb-checkpresence.0	2020-10-17 19:59:00.860	debug	(2731299) response: 0 "<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecur
      fb-checkpresence.0	2020-10-17 19:59:00.847	info	(2731299) service GetInfo is supported
      fb-checkpresence.0	2020-10-17 19:59:00.811	info	2
      fb-checkpresence.0	2020-10-17 19:59:00.811	info	(2731299) service GetSpecificHostEntry is supported
      fb-checkpresence.0	2020-10-17 19:59:00.784	info	(2731299) service X_AVM-DE_GetHostListPath is supported
      fb-checkpresence.0	2020-10-17 19:59:00.755	debug	(2731299) configuration familymembers: [{"familymember":"Tobias","macaddress":"0C:2F:B0:CA:89:AC","ipaddress":"192.168.168.171","useip":true,"comment":"Tobias privates Handy","enabled":true},{"family
      fb-checkpresence.0	2020-10-17 19:59:00.755	debug	(2731299) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
      fb-checkpresence.0	2020-10-17 19:59:00.754	debug	(2731299) configuration history: <>
      fb-checkpresence.0	2020-10-17 19:59:00.753	debug	(2731299) configuration user: <admin>
      fb-checkpresence.0	2020-10-17 19:59:00.752	info	(2731299) start fb-checkpresence: ip-address: 192.168.168.99 polling interval: 3 Min.
      fb-checkpresence.0	2020-10-17 19:59:00.663	info	(2731299) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.18.3, js-controller: 3.1.6
      fb-checkpresence.0	2020-10-17 19:58:59.750	debug	(2731299) statesDB connected
      fb-checkpresence.0	2020-10-17 19:58:59.749	debug	(2731299) States connected to redis: 0.0.0.0:9000
      fb-checkpresence.0	2020-10-17 19:58:59.667	debug	(2731299) States create System PubSub Client
      fb-checkpresence.0	2020-10-17 19:58:59.652	debug	(2731299) States create User PubSub Client
      fb-checkpresence.0	2020-10-17 19:58:59.621	debug	(2731299) Redis States: Use Redis connection: 0.0.0.0:9000
      fb-checkpresence.0	2020-10-17 19:58:59.619	debug	(2731299) objectDB connected
      fb-checkpresence.0	2020-10-17 19:58:59.611	debug	(2731299) Objects connected to redis: 0.0.0.0:9001
      fb-checkpresence.0	2020-10-17 19:58:59.564	debug	(2731299) Objects client initialize lua scripts
      fb-checkpresence.0	2020-10-17 19:58:59.564	debug	(2731299) Objects create User PubSub Client
      fb-checkpresence.0	2020-10-17 19:58:59.560	debug	(2731299) Objects create System PubSub Client
      fb-checkpresence.0	2020-10-17 19:58:59.536	debug	(2731299) Objects client ready ... initialize now
      fb-checkpresence.0	2020-10-17 19:58:59.471	debug	(2731299) Redis Objects: Use Redis connection: 0.0.0.0:9001
      fb-checkpresence.0	2020-10-17 19:59:00.831	info	(2731299) service GetSecurityPort is supported
      fb-checkpresence.0	2020-10-17 19:59:00.818	info	(2731299) service X_AVM-DE_GetSpecificHostEntryByIP is supported
      fb-checkpresence.0	2020-10-17 19:59:00.755	debug	(2731299) configuration familymembers: [{"familymember":"Tobias","macaddress":"0C:2F:B0:CA:89:AC","ipaddress":"192.168.168.171","useip":true,"comment":"Tobias privates Handy","enabled":true},{"familym
      E afuerhoff 2 Replies Last reply Reply Quote 0
        Elektroman @Elektroman last edited by
        Adapter ist jetzt schon wieder aus
          fastfoot @Elektroman last edited by
          @Elektroman in den oberen LOGS ird die 192.168.178.1 als ip gezeigt, später ist es dann 192.168.168.1, check das mal
            Elektroman @fastfoot last edited by
            @fastfoot sagte in fb-checkpresence Timeout-Fehler und falscher Username:
            Bin ich blind
            192.168.178.1 habe ic nicht gefunfen
              @Elektroman sagte in fb-checkpresence Timeout-Fehler und falscher Username:
              Bin ich blind
              Beiträge 6,8,15...
                @fastfoot
                6 fb-checkpresence.0 2020-10-17 19:59:01.057 warn (2731299) can not read external ip address
                8 fb-checkpresence.0 2020-10-17 19:59:01.035 debug (2731299) {"status":500,"data":null,"result":false,"resultData":null,"errNo":4,"errorMsg":{"$":{"xmlns":"urn:dslforum-org:control-1-0"},"errorCode":"401","errorDescription":"invalid action"}}
                15 fb-checkpresence.0 2020-10-17 19:59:00.991 info (2731299) History function disabled
                F afuerhoff 2 Replies Last reply Reply Quote 0
                  @fastfoot
                  Da sind auch noch mehr Zeilen zum Durchsehen! Auch wenn du sie nicht findest, check deine Settings und warum da Unterschiede sind. Die 192.168.168.x wie zuletzt gezeigt ist zumindest ungewöhnlich
                  fb-checkpresence.0 2020-08-19 21:07:18.189 debug (21128) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
                  fb-checkpresence.0 2020-08-19 21:07:18.189 debug (21128) configuration history: <>
                  fb-checkpresence.0 2020-08-19 21:07:18.188 debug (21128) configuration user: <iobroker>
                  fb-checkpresence.0 2020-08-19 21:07:18.187 info (21128) start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 1 Min.
                  fb-checkpresence.0 2020-08-19 21:07:18.137 info (21128) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.20.1, js-controller: 3.1.6
                    fastfoot @fastfoot last edited by
                    Sorry, die waren gar nicht von Dir!
                    • afuerhoff
                      afuerhoff Developer @Elektroman last edited by
                      @Elektroman
                      Es ist auch kein History Adapter in der Konfiguration ausgewählt.
                      • afuerhoff
                        @Elektroman
                        Sind die IP-Adressen bei den Family-Membern korrekt? Du könntest ja auch die Mac-Adresse benutzen. Funktioniert im Konfigurationsdialog der Button "Familienmitglied hinzufügen"?
                          @afuerhoff
                          ok 😊
                          habe schon gedacht ich bekomme nichts mehr hin
                          habe MAC und ip eingetragen!
                          Aber auch wenn ich da was falsches eingebe, der Adapter sollte sich doch nicht ganz abschalten, oder ?
                          von grün auf gelb ok , aber abschalten ?
                          afuerhoff 1 Reply Last reply Reply Quote 0
                          • afuerhoff
                            @Elektroman
                            Hallo, ich glaube, dass da noch irgendetwas in der Konfiguration nicht korrekt ist.
                            Der aktualisiert dann entsprechend die Mac- und IP-Adresse der Familienmitgliedern.
                            Warum hast du keinen History Adapter ausgewählt?
                            Bitte alles nochmal prüfen. Auch User und Passwort.
                            Es könnte auch sein, dass sich bei einer falschen Einstellung die Fritzbox schon wieder aufgehängt hat. Der Adapter läuft bei dir nicht sauber durch.
                              @afuerhoff
                              ich habe jetzt noch mal alles neu eingegeben
                              Jetzt funktioniert wieder alles. Fragt sich nur wie lange!
                              Aber erst mal vielen Dank für die Hilfe!!!!!!
                              @au
                              2423
