    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      mumurik last edited by
      Hallo @andre
      ich habe das Problem, dass ich kein Telegram-Adapter im Docker (buanet-Image im macvlan-Modus) zum laufen bekomme. Adapter lässt sich ohne Probleme installieren, jedoch bekomme ich den Adapter nicht gestartet -> mit folgender Fehlermeldung:
      host.iobroker-docker	2020-10-19 20:33:16.326	error	instance system.adapter.telegram.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: }
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: ]
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.telegram/main.js'
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js',
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: requireStack: [
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: code: 'MODULE_NOT_FOUND',
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at internal/main/run_main_module.js:17:47 {
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at Module.load (internal/modules/cjs/loader.js:985:32)
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
      host.iobroker-docker	2020-10-19 20:33:16.326	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:23:15)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at require (internal/modules/cjs/helpers.js:72:18)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Module.require (internal/modules/cjs/loader.js:1025:19)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Module.load (internal/modules/cjs/loader.js:985:32)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js:13:41)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Array.forEach (<anonymous>)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js:14:43
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: Require stack:
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/auth/@eaDir'
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: ^
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: throw err;
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[1]: internal/modules/cjs/loader.js:968
      host.iobroker-docker	2020-10-19 20:33:16.325	error	Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:1137:30
      host.iobroker-docker	2020-10-19 20:33:16.324	error	Caught by controller[0]: In the future, you will have to enable it yourself.
      host.iobroker-docker	2020-10-19 20:33:16.324	error	Caught by controller[0]: Mon, 19 Oct 2020 18:33:16 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
      Eine Idee dazu?
      Danke im voraus!
      mania25 created this issue in yagop/node-telegram-bot-api
      closed Error: cannot enable cancellation after promises are in use #319
      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @mumurik last edited by
        @mumurik sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
        Eine Idee dazu?
        Hat aber nichts mit ..... Docker ...... zu tun !
        Da stimmt etwas mit dem Adapter nicht .
        Deinstalliere ihn und über die Katze (git) neu .
          Thomas Braun Most Active @mumurik last edited by
          @mumurik Versionsnummern? Das verlinkte Issue
          sollte in aktuellen Versionen ja längstens erledigt sein.
            mumurik @Thomas Braun last edited by
            @Thomas-Braun
            Die Version is aktuell 1.5.9
              mumurik @Glasfaser last edited by
              @Glasfaser
              auf dem Raspberry läuft's seit Jahren ohne Probleme...
              • Glasfaser
                Glasfaser @mumurik last edited by Glasfaser
                und was möchtest du mir damit sagen ... !???
                Du hast es doch jetzt im Docker , das sind doch zwei verschiedene Systeme !
                  @Glasfaser
                  nicht falsch verstehen, ich wollte nur damit sagen, dass die gleiche Adapter-Version auf dem Pi bereits erfolgreich läuft und im Docker auch ohne Probleme sich installiert hat. Deswegen ging meine Vermutung in Richtung Docker und nicht in Richtung des Adapters selbst
                  dslraser Thomas Braun 3 Replies Last reply Reply Quote 0
                  • dslraser
                    dslraser Forum Testing Most Active @mumurik last edited by dslraser
                    @mumurik
                    ich habe Telegram im ioBroker Docker (auch mac vlan) gefühlt schon ewig laufen. Daran liegt es nicht. Es muß also eine andere Ursache bei Deinem System sein.
                    Und die Fehlermeldung in Deinem log verweist, wie oben schon erwähnt, auf ein Uraltes Issue..
                      @mumurik Irgendwie wird da wohl das Modul socksv5 nicht gefunden. Keine Ahnung ob das von telegram abhängig mit installiert werden müsste.
                      Auf meinem System ist es jedenfalls nicht drauf (Habe aber auch telegram nicht drauf):
                      pi@raspberrypi:~ $ cd /opt/iobroker/
                      pi@raspberrypi:/opt/iobroker $ npm list socksv5
                      iobroker.inst@2.0.3 /opt/iobroker
                      └── (empty)
                      • Glasfaser
                        Glasfaser @Thomas Braun last edited by
                        So sieht es im Docker aus :
                        root@iobroker:/opt/iobroker# npm list socksv5
                        └─┬ iobroker.telegram@1.5.9
                          └── socksv5@0.0.6
                          @mumurik Ich würde wohl telegram nochmal drüberbügeln. Schau in's log.
                            @Thomas-Braun
                            habe eben mal downgegraded auf die Version 1.4.3 und dann wieder hoch auf die 1.5.9. Bekomme bei der Installation des Adapters nun folgende Fehlermeldung:
                            $ ./iobroker upgrade telegram
                            Update telegram from @1.4.3 to @1.5.9
                            NPM version: 6.14.6
                            npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (System call)
                            npm
                             ERR! code EINVALIDPACKAGENAME
                            npm ERR! Invalid package name "@eaDir/.bin@SynoResource": name can only contain URL-friendly characters
                            npm ERR! A complete log of this run can be found in:npm ERR!
                            • Glasfaser
                              Gehört nicht zu ioBroker ... da ist aber ganz schön was schief.
                              cd /opt/iobroker
                              pkill -u iobroker
                              npm cache clean --force
                              iobroker del telegram
                              iobroker start
                              poste mal die Ausgabe von :
                              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                @Glasfaser sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
                                #which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                /usr/bin/nodejs
                                v12.18.3
                                /usr/bin/node
                                v12.18.3
                                /usr/bin/npm
                                6.14.6
                                nodejs:
                                  Installiert:           12.18.3-1nodesource1
                                  Installationskandidat: 12.18.3-1nodesource1
                                  Versionstabelle:
                                 *** 12.18.3-1nodesource1 500
                                        500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                     10.21.0~dfsg-1~deb10u1 500
                                        500 http://deb.debian.org/debian buster/main amd64 Packages
                                        500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                  @mumurik
                                  Das könntest du schon mal aktualisieren.
                                  sudo apt update
                                  sudo apt upgrade
                                    @Thomas-Braun sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
                                    sudo apt upgrade
                                    apt upgrade durchgeführt
                                    ejs
                                    /usr/bin/nodejs
                                    v12.19.0
                                    /usr/bin/node
                                    v12.19.0
                                    /usr/bin/npm
                                    6.14.8
                                    nodejs:
                                      Installiert:           12.19.0-1nodesource1
                                      Installationskandidat: 12.19.0-1nodesource1
                                      Versionstabelle:
                                     *** 12.19.0-1nodesource1 500
                                    jedoch weiterhin Fehlermeldungen beim Starten des Adapters:
                                    host.iobroker-docker	2020-10-20 15:07:58.918	error	Caught by controller[1]: }
                                    host.iobroker-docker	2020-10-20 15:07:58.918	error	Caught by controller[1]: ]
                                    host.iobroker-docker	2020-10-20 15:07:58.918	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.telegram/main.js'
                                    host.iobroker-docker	2020-10-20 15:07:58.918	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js',
                                    host.iobroker-docker	2020-10-20 15:07:58.918	error	Caught by controller[1]: requireStack: [
                                    host.iobroker-docker	2020-10-20 15:07:58.918	error	Caught by controller[1]: code: 'MODULE_NOT_FOUND',
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at internal/main/run_main_module.js:17:47 {
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Function.Module._load (internal/modules/cjs/loader.js:724:14)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Module.load (internal/modules/cjs/loader.js:879:32)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1035:10)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Module._compile (internal/modules/cjs/loader.js:1015:30)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/main.js:23:15)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at require (internal/modules/cjs/helpers.js:74:18)
                                    host.iobroker-docker	2020-10-20 15:07:58.917	error	Caught by controller[1]: at Module.require (internal/modules/cjs/loader.js:903:19)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Module.load (internal/modules/cjs/loader.js:879:32)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1035:10)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Module._compile (internal/modules/cjs/loader.js:1015:30)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js:13:41)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Array.forEach (<anonymous>)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js:14:43
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at require (internal/modules/cjs/helpers.js:74:18)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Module.require (internal/modules/cjs/loader.js:903:19)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Function.Module._load (internal/modules/cjs/loader.js:687:27)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:831:15)
                                    host.iobroker-docker	2020-10-20 15:07:58.916	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/index.js
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[1]: Require stack:
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[1]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/auth/@eaDir'
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[1]: ^
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[1]: throw err;
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[1]: internal/modules/cjs/loader.js:834
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:1015:30
                                    host.iobroker-docker	2020-10-20 15:07:58.915	error	Caught by controller[0]: In the future, you will have to enable it yourself.
                                    host.iobroker-docker	2020-10-20 15:07:58.914	error	Caught by controller[0]: Tue, 20 Oct 2020 13:07:58 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                                    • Glasfaser
                                      @mumurik
                                      Hast du die Befehle die ich dir oben genannt habe einmal gemacht !!!!
                                      Thomas Braun M 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @Glasfaser last edited by
                                        @Glasfaser @mumurik
                                        Vielleicht auch mal ein rebuild?
                                        iobroker rebuild telegram
                                        müsste der Befehl sein.
                                        • Glasfaser
                                          @Thomas-Braun
                                          nee lass erstmal ... der Schrott muß erstmal runter
                                            @Glasfaser
                                            Ist da irgendwas aus der Synology reingeschwappt?
                                            @eaDir/.bin@SynoResource" hört sich irgendwie so an.
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1528705
