    4. XBOX Adapter Fehler Pi4
    SOLVED XBOX Adapter Fehler Pi4
      Smallfeuer @foxriver76 last edited by
      @foxriver76 Hier kommt folgendes:
      Defaulting to user installation because normal site-packages is not writeableCollecting gevent
        Using cached gevent-20.9.0.tar.gz (5.8 MB)
        Installing build dependencies ... done
        Getting requirements to build wheel ... done
          Preparing wheel metadata ... done
      Collecting zope.event
        Using cached zope.event-4.5.0.tar.gz (18 kB)
      Collecting zope.interface
        Using cached zope.interface-5.1.0.tar.gz (225 kB)
      Collecting greenlet>=0.4.17; platform_python_implementation == "CPython"
        Using cached greenlet-0.4.17.tar.gz (61 kB)
      Collecting setuptools
        Using cached setuptools-44.1.1.zip (858 kB)
      Skipping wheel build for zope.event, due to binaries being disabled for it.
      Skipping wheel build for zope.interface, due to binaries being disabled for it.
      Skipping wheel build for greenlet, due to binaries being disabled for it.
      Skipping wheel build for setuptools, due to binaries being disabled for it.
      Building wheels for collected packages: gevent
        Building wheel for gevent (PEP 517) ... done
        Created wheel for gevent: filename=gevent-20.9.0-cp27-cp27mu-linux_armv7l.whl size=4501677 sha256=34465c35edb88c52b43a8565da7443a911e1feea7161dcb1d10647a3653d50b3
        Stored in directory: /home/pi/.cache/pip/wheels/3b/b7/3e/f9e38f94c533b9b3549acf90ae8fc70283aab07f8f01ff527a
      Successfully built gevent
      Installing collected packages: setuptools, zope.event, zope.interface, greenlet, gevent
        Attempting uninstall: setuptools
          Found existing installation: setuptools 44.1.1
          Uninstalling setuptools-44.1.1:
            Successfully uninstalled setuptools-44.1.1
          Running setup.py install for setuptools ... done
        Attempting uninstall: zope.event
          Found existing installation: zope.event 4.5.0
          Uninstalling zope.event-4.5.0:
            Successfully uninstalled zope.event-4.5.0
          Running setup.py install for zope.event ... done
        Attempting uninstall: zope.interface
          Found existing installation: zope.interface 5.1.0
          Uninstalling zope.interface-5.1.0:
            Successfully uninstalled zope.interface-5.1.0
          Running setup.py install for zope.interface ... done
        Attempting uninstall: greenlet
          Found existing installation: greenlet 0.4.17
          Uninstalling greenlet-0.4.17:
            Successfully uninstalled greenlet-0.4.17
          Running setup.py install for greenlet ... done
        Attempting uninstall: gevent
          Found existing installation: gevent 1.3.7
          Uninstalling gevent-1.3.7:
            Successfully uninstalled gevent-1.3.7
      ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
      We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
      xbox-smartglass-core 1.1.1 requires gevent==1.3.7, but you'll have gevent 20.9.0 which is incompatible.
        Smallfeuer @r0b1zZle last edited by
        @r0b1zZle
        @foxriver76
        Habe heut die Version 0.7.0 installiert die bei Github online ist... ENDLICH 😉 Danke @foxriver76
        Bischen Lustig das es zum Release der neuen Xbox Series läuft... jetzt hab ich nen bischen Angst vor dem Upgrade :). Aber mal schauen...
          Smallfeuer @Smallfeuer last edited by
          @foxriver76 nach manuellem Start des Servers die gleichen Fehler, also durch das Workaround kein Eingriff an den betroffenen Zeilen -und auf Grund der Meldung am Ende auch keine Option:
          **%(#ff0000)[ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts]**
            @foxriver76 Hab mal eine LOG von der Installation gemacht:
            > iobroker.xbox@0.6.8 install /opt/iobroker/node_modules/iobroker.xbox
            > npip install
            No python_modules directory; installing pip locally if needed.
            Successfully completed pip check.
            Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
            Collecting xbox-smartglass-core>=1.2.2
              Using cached xbox_smartglass_core-1.2.2-py2.py3-none-any.whl (84 kB)
            Collecting gevent==1.5a3
              Downloading https://www.piwheels.org/simple/gevent/gevent-1.5a3-cp37-cp37m-linux_armv7l.whl (6.3 MB)
            Collecting xbox-webapi>=1.1.8
              Using cached xbox_webapi-1.1.8-py2.py3-none-any.whl (48 kB)
            Collecting Flask
              Using cached Flask-1.1.2-py2.py3-none-any.whl (94 kB)
            Collecting cryptography==2.8
              Downloading https://www.piwheels.org/simple/cryptography/cryptography-2.8-cp37-cp37m-linux_armv7l.whl (852 kB)
            Collecting marshmallow-objects
              Using cached marshmallow_objects-2.3.0-py3-none-any.whl (6.7 kB)
            Collecting dpkt
              Using cached dpkt-1.9.4-py3-none-any.whl (149 kB)
            Collecting construct==2.10.56
              Downloading https://www.piwheels.org/simple/construct/construct-2.10.56-py3-none-any.whl (56 kB)
            Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
              Downloading https://www.piwheels.org/simple/greenlet/greenlet-0.4.17-cp37-cp37m-linux_armv7l.whl (47 kB)
            Collecting appdirs
              Using cached appdirs-1.4.4-py2.py3-none-any.whl (9.6 kB)
            Collecting urwid
              Downloading https://www.piwheels.org/simple/urwid/urwid-2.1.1-cp37-cp37m-linux_armv7l.whl (258 kB)
            Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from xbox-webapi>=1.1.8->xbox-smartglass-core>=1.2.2) (2.21.0)
            Collecting demjson
              Downloading https://www.piwheels.org/simple/demjson/demjson-2.2.4-py3-none-any.whl (60 kB)
            Collecting itsdangerous>=0.24
              Using cached itsdangerous-1.1.0-py2.py3-none-any.whl (16 kB)
            Collecting click>=5.1
              Using cached click-7.1.2-py2.py3-none-any.whl (82 kB)
            Collecting Werkzeug>=0.15
              Using cached Werkzeug-1.0.1-py2.py3-none-any.whl (298 kB)
            Collecting Jinja2>=2.10.1
              Using cached Jinja2-2.11.2-py2.py3-none-any.whl (125 kB)
            Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==2.8->xbox-smartglass-core>=1.2.2) (1.12.0)
            Collecting cffi!=1.11.3,>=1.8
              Downloading https://www.piwheels.org/simple/cffi/cffi-1.14.3-cp37-cp37m-linux_armv7l.whl (345 kB)
            Collecting marshmallow>=3.0.0
              Using cached marshmallow-3.8.0-py2.py3-none-any.whl (46 kB)
            Collecting MarkupSafe>=0.23
              Downloading https://www.piwheels.org/simple/markupsafe/MarkupSafe-1.1.1-cp37-cp37m-linux_armv7l.whl (33 kB)
            Collecting pycparser
              Using cached pycparser-2.20-py2.py3-none-any.whl (112 kB)
            Installing collected packages: greenlet, gevent, appdirs, urwid, demjson, xbox-webapi, itsdangerous, click, Werkzeug, MarkupSafe, Jinja2, Flask, pycparser, cffi, cryptography, marshmallow, marshmallow-objects, dpkt, construct, xbox-smartglass-core
            Successfully installed Flask-1.1.2 Jinja2-2.11.2 MarkupSafe-1.1.1 Werkzeug-1.0.1 appdirs-1.4.4 cffi-1.14.3 click-7.1.2 construct-2.10.56 cryptography-2.8 demjson-2.2.4 dpkt-1.9.4 gevent-1.5a3 greenlet-0.4.17 itsdangerous-1.1.0 marshmallow-3.8.0 marshmallow-objects-2.3.0 pycparser-2.20 urwid-2.1.1 xbox-smartglass-core-1.2.2 xbox-webapi-1.1.8
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
            + iobroker.xbox@0.6.8
            added 1 package from 1 contributor and removed 1702 packages in 77.297s
            npm update hatt die WARN auch nicht weg bekommen- ist aber wenn ich das hier richtig lese nur für WIN User wichtig.
            Unsupported platform for fsevents@1.0.14: wanted
              @foxriver76 falls es etwas nutzt:
              In der _bootstrap.py Zeile 72 steht dann: "if lock is None:" Leider reichen meine Linux Kenntnisse hier bei weitem nicht aus 😞 74 wäre dann "tid = lock.owner"
                  def has_deadlock(self):
                      # Deadlock avoidance for concurrent circular imports.
                      me = _thread.get_ident()
                      tid = self.owner
                      while True:
                          lock = _blocking_on.get(tid)
                          if lock is None:
                              return False
                          tid = lock.owner
                          if tid == me:
                Wenn die Xbox läuft kommt noch dieser Fehler:
                xbox.0	2020-09-25 12:30:13.259	debug	(1823) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                xbox.0	2020-09-25 12:30:13.258	debug	(1823) [CONNECT] Check connection
                xbox.0	2020-09-25 12:30:13.256	error	(1823) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                xbox.0	2020-09-25 12:30:13.248	debug	(1823) [DISCOVER] Searching for consoles
                xbox.0	2020-09-25 12:30:13.245	debug	(1823) [PING] Xbox online
                xbox.0	2020-09-25 12:30:13.243	debug	(1823) [CHECK] Auth is not established
                xbox.0	2020-09-25 12:30:11.776	warn	(1823) [LOGIN] Connection refused, will try again
                xbox.0	2020-09-25 12:30:11.775	debug	(1823) Could not parse body
                xbox.0	2020-09-25 12:30:09.268	warn	(1823) [LOGIN] Connection refused, will try again
                  @foxriver76 Der Workaround bringt nichts, hast du noch eine Idee was ich testen kann, bzw. gehst du dem Problem aktuell noch nach?
                  • foxriver76
                    foxriver76 Developer @Smallfeuer last edited by
                    @Smallfeuer Es gibt mittlerweile zumindest ein Issue bei smartglass-core https://github.com/OpenXbox/xbox-smartglass-core-python/issues/42
                    foxt created this issue in OpenXbox/xbox-smartglass-core-python
                    closed SIGSEGV whenever I try to do anything. #42
                      r0b1zZle last edited by r0b1zZle
                      Gibt es schon Neuigkeiten? Stehe vor dem selben Problem.
                      pi@raspi:~ $ /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                      -bash: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: Datei oder Verzeichnis nicht gefunden
                      /usr/local/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: greenlet.greenlet size changed, may indicate binary incompatibility. Expected 72 from C header, got 76 from PyObject
                        return f(*args, **kwds)
                      Traceback (most recent call last):
                        File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
                          from xbox.scripts.rest_server import main
                        File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/scripts/rest_server.py", line 6, in <module>
                          from xbox.scripts import main_cli  # noqa: E402
                        File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/scripts/main_cli.py", line 20, in <module>
                          from xbox.handlers import tui, gamepad_input, text_input, fallout4_relay
                        File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/handlers/tui.py", line 8, in <module>
                          import urwid
                      ModuleNotFoundError: No module named 'urwid'
                      pi@raspi:~ $ pip install "urwid==2.0.1"
                      Requirement already satisfied: urwid==2.0.1 in ./.local/lib/python3.7/site-packages (2.0.1)
                      foxriver76 S 2 Replies Last reply Reply Quote 0
                      • foxriver76
                        foxriver76 Developer @r0b1zZle last edited by
                        @r0b1zZle es sind mittlerwele zwei Issues offen im smartglass package, habe nun auch nochmal was zu geschrieben. Kann von meiner Seite leider nichts machen.
                          @foxriver76 Danke trotzdem für deine Mühe.
                          @r0b1zZle Das Problem besteht bei mir noch immer. Wenn sich im Issue etwas tut wäre es toll eine Info zu bekommen. Würde mich dann nochmal ransetzen und probieren ob ich es zum Laufen bekomme. Aktuell scheint der Adapter sogar in die Alexa Skill Verbindung rein zu gretschen. Immer wenn ich den Adapter an hatte, kann ich den Skill neu installieren, dass er wieder läuft. Über Iobroker ist es immerhin möglich die Alexa Xbox devices einzuschalten, leider funktioniert die Rückmeldung zu langsam und ungenau. Ansonsten wäre das für die Steuerung eine alternative gewesen.
                          Also Abwarten.....
                            r0b1zZle @Smallfeuer last edited by r0b1zZle
                            @Smallfeuer Hier steht noch, dass man ein Downgrade auf Greenlet 0.4.13 machen soll. Hat bei mir aber nichts gebracht, eventuell bei euch?
                              @r0b1zZle
                              @foxriver76
                              • foxriver76
                                @Smallfeuer Leider habe ich noch keine Rückmeldung zu der Authentifizierunggeschichte von Team Open Xbox, das möchte ich definitiv wieder verbessern. Ich hoffe die Series X is bald wieder im MS Store on stock, damit man sie mit Guthaben kaufen kann. 😉
                                  Smallfeuer @foxriver76 last edited by Smallfeuer
                                  @foxriver76 Ja, das einloggen war etwas fehlerbehaftet und ist im weißen Screen von firefox geendet... eine schöne Bestätigung wäre da noch gut. Aber es läuft erstmal...👍
                                  Gibts hier irgendwo eine XBox billiger? 😊
                                  foxriver76 U 2 Replies Last reply Reply Quote 0
                                  • foxriver76
                                    foxriver76 Developer @Smallfeuer last edited by foxriver76
                                    @Smallfeuer Naja, ich habe die One X damals mit Guthaben aus Key Stores gekauft (50 € Guthaben für 40 €, macht dann 100 € Ersparnis bei 500€ Konsole), da kann man meist etwas sparen, gerade in der Anfangszeit wenn es noch nicht so gute Angebote geben wird. Allerdings natürlich alles eher so "Grauzone" mit dem Guthaben aus den Keystores.
                                    • U
                                      useful_idiot @Smallfeuer last edited by useful_idiot
                                      Das ist schon mal ein großer Fortschritt für mich: mit dem Adapter in der 0.70 konnte ich auch endlich zumindest wieder eine direkte Verbindung herstellen. Bei der Authentifizierung bei Live ist der Name localhost hinterlegt, der Link wird bei mir aber auch im Firefox geöffnet (https://login.live.com/oauth20_authorize.srf?client_id=XXX&response_type=code&approval_prompt=auto&scope=Xboxlive.signin+Xboxlive.offline_access&redirect_uri=http://localhost:5557/auth/callback&state=YYY) und sagt dann, dass er auf localhost natürlich keine Verbindung auf Port 5557 bekommt. Hatte auch mal vergeblich versucht, den dann mit elinks im CLI aufzurufen oder die redirect_uri auf meinen Raspberry abzuändern. Mit eLinks bekomme ich beim Aufruf der return_uri
                                      http://localhost:5557/auth/callback?code=XXX&state=YYY dann auch tatsächlich JSON (token_type=bearer mit acces_token usw) zurück, aber wohin damit? @Smallfeuer wie hast du denn die Auth am Ende hinbekommen?
                                      1. Edit: ich glaube der Aufruf in eLinks hat doch was gebracht, bin tatsächlich authentifiziert 🙂 allerdings wird bisher nur mein Gamertag gefüllt, activeTitleName oder launchTitle funktionieren leider noch nicht (auf series x)
                                      S foxriver76 2 Replies Last reply Reply Quote 0
                                        Smallfeuer @useful_idiot last edited by
                                        @useful_idiot genau, der Mozilla läuft zwar in ein WhiteScreen, aber nach einem Adapter Neustart hat die Auth dann funktioniert. Mir ging es auch hauptsächlich um An/Aus - Umschalten von TV / Yamaha und Gute Nacht Routinen. Das sind wohl die wichtigsten Funktionen wo Alexa es einem erspart erst 3 Fernbedienungen in die Hand zu nehmen. Zum Glück funkt. es auch bei der neuen X Series. 🙂 Einzigster Wehrmutstropfen ist, das der HDMI2.1 taugliche Yamaha 2080 nun doch nur 4k@60hz kann. Somit musste ich direkt an den LG. Dank EArc aber kein Problem mit Atmos etc. 🙂
                                        • foxriver76
                                          foxriver76 Developer @useful_idiot last edited by
                                          @useful_idiot mit der auth bin ich dran, es funktioniert derzeit nur wenn du von dem Device aus dich verifizierst auf dem der Adapter laeuft. Siehe https://github.com/OpenXbox/xbox-smartglass-core-python/issues/49#issuecomment-725420560
                                          tuxuser created this issue in OpenXbox/xbox-smartglass-core-python
                                          open HELP! Everything is broken! OMG #49
                                          • foxriver76
                                            Habe soeben eine 0.7.2 gemacht, hatte noch die ein oder andere Stelle verpasst beim migrieren, weshalb die ganzen currentTitles Geschichten und Bild und Co nicht gesetzt wurde. Geht jetzt wieder. Ebenso behoben, dass es vorkommen konnte, das beim Adapterstopp ein Fehler geloggt wurde, weil der Rest-Server Prozess (korrekterweise) beendet wurde.
                                            Fürs Authentifizieren ist momentan folgende Vorgehensweise möglich:
                                            • Warten bis das Logging für Rest-Server gestartet erscheint, dann auf den Link im Log klicken oder in den Adaptereinstellungen auf den Link klicken
                                            • Hier werdet ihr entweder aufgefordert euch einzuloggen, oder ihr wurdet automatisch bei MS eingeloggt
                                            • Dann sollte ein Fehler erscheinen, dass die Seite nicht verfügbar ist, Link sollte mit localhost starten
                                            • Link kopieren, aufs Terminal gehen und curl "<Link einfügen>" absetzen
                                            • Nun sollte im Log stehen, dass ihr authentifziert seid
                                            • Nach Neustart des Server ist man leider wieder ausgeloggt, ich warte nach wie vor auf Rückmeldung, dass das alles wieder nutzerfreunlicher wird.
                                              Hallo @foxriver76,
                                              klappt leider nicht so einfach, auch nach restart der Instanz kein LogIn.:
                                              curl http://localhost:5557/auth/callback?code=M.R
                                              sudo curl http://localhost:5557/auth/callback?code="****"
                                              [2] 27631
                                              [1]   Fertig                  curl http://localhost:5557/auth/callback?code="****"
                                              xbox.0	2020-11-24 09:41:55.269	warn	(27688) Not logged in, authenticate at https://login.live.com/oauth20_authorize.srf?client_id="****"&response_type=code&approval_prompt=auto&scope=Xboxlive.signin+Xboxli
                                              xbox.0	2020-11-24 09:41:55.259	warn	(27688) Could not login, please check adapter config. Code: 401
                                              xbox.0	2020-11-24 09:41:54.285	info	(27688) [START] Successfully started REST server
                                              xbox.0	2020-11-24 09:41:51.394	info	(27688) [START] Starting REST server
                                              xbox.0	2020-11-24 09:41:51.363	info	(27688) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.18.4, js-controller: 3.1.6
                                              xbox adapter
                                              2755
