    4. Test Adapter mihome-vacuum v2.0.x
    • Qualle888
      Qualle888 @blackeagle998 last edited by
      @blackeagle998 vielen lieben Dank. Das ist meine Lösung. Danke Danke Danke 🙂
      • JayR
        JayR @Meistertr last edited by
        @Meistertr: Ich habe die Version 2.1.1 installiert habe aber das Problem, dass keine Verbindung zu meinem Roborter aufgebaut werden kann:
        2020-10-16 07:17:13.620 - debug: mihome-vacuum.0 (8938) no answer for id:35 received, giving up
        2020-10-16 07:17:13.620 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        2020-10-16 07:17:17.358 - info: admin.0 (574) Subscribe on all states again
        2020-10-16 07:17:18.582 - debug: mihome-vacuum.0 (8938) Receive <<< Helo <<< 2131002000000000139bcd175f892cdfffffffffffffffffffffffffffffffff
        2020-10-16 07:17:18.582 - warn: mihome-vacuum.0 (8938) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2020-10-16 07:17:18.583 - info: mihome-vacuum.0 (8938) connecting, this can take up to 10 minutes ...
        2020-10-16 07:17:18.583 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        2020-10-16 07:17:18.585 - debug: mihome-vacuum.0 (8938) sendMsg[1] >>> {"id":36,"method":"get_status"}
        2020-10-16 07:17:23.586 - debug: mihome-vacuum.0 (8938) sendMsg[2] >>> {"id":36,"method":"get_status"}
        2020-10-16 07:17:24.459 - info: admin.0 (574) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
        2020-10-16 07:17:28.588 - debug: mihome-vacuum.0 (8938) sendMsg[3] >>> {"id":36,"method":"get_status"}
        2020-10-16 07:17:33.589 - debug: mihome-vacuum.0 (8938) no answer for id:36 received, giving up
        2020-10-16 07:17:33.589 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        2020-10-16 07:17:38.651 - debug: mihome-vacuum.0 (8938) Receive <<< Helo <<< 2131002000000000139bcd175f892cf3ffffffffffffffffffffffffffffffff
        2020-10-16 07:17:38.652 - warn: mihome-vacuum.0 (8938) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2020-10-16 07:17:38.653 - info: mihome-vacuum.0 (8938) connecting, this can take up to 10 minutes ...
        2020-10-16 07:17:38.653 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        2020-10-16 07:17:38.659 - debug: mihome-vacuum.0 (8938) sendMsg[1] >>> {"id":37,"method":"get_status"}
        Kann mir jemand helfen, das Problem zu finden.
        Meistertr 1 Reply Last reply Reply Quote 0
          schneidy76 @Guest last edited by schneidy76
          @ilovegym said in Test Adapter mihome-vacuum v2.0.x:
          @Ahnungsbefreit genau, mit der roborock App geht es nicht, musst ihn in die mihome App einbinden.
          Ich stehe vor den gleichen Problem, benutze auch die Roborock App. Die ist super eingerichtet Räume, Sperrzonen, etc.. Das möchte ich ungern verwerfen. Wird diese App in den Apapter zukünftig integriert werden? Das Problem ist ja der Token, den muss man doch irgendwie aus der App bekommen. Ist die Kommunikation über die Roborock App soviel anders? Kenne mich da zu wenig aus.
          VG Torsten
          Knallochse da_Woody 2 Replies Last reply Reply Quote 0
          • Knallochse
            Knallochse @schneidy76 last edited by Knallochse
            Sorry, falsch gedrückt 😬
            • Meistertr
              Meistertr Developer @JayR last edited by
              @JayR mal versucht den roboter neu zu starten?
              JayR 1 Reply Last reply Reply Quote 0
                kristina.da @Meistertr last edited by
                @Meistertr : Ich mal wieder 🙂 Ich gehe mal davon aus, dass die Valetudo Anpassung erst im "Test Adapter mihome-vacuum 3.x.x" umgesetzt wird oder?
                Grüssle Kristina
                • JayR
                  @Meistertr: Hat nicht geholfen. Hast du noch eine andere Idee?
                  • JayR
                    JayR @JayR last edited by
                    @JayR: Ist der Adapter mit dem Xiaomi Mi Robot Vacuum Mop Pro kompatibel? Das Problem besteht nach wie vor.
                    • Meistertr
                      Meistertr Developer @JayR last edited by Meistertr
                      @JayR die Version 2 nicht die 3er schon, aber kann bis lang nur die viomi Modelle, die musst du über meine git Seite installiert, ist aber noch alpha Stadium. Komme da gerade etwas schleppend vorran.
                      • da_Woody
                        da_Woody @schneidy76 last edited by
                        @schneidy76 die xiaomi sieht genau so aus wie die roborock. beiß in den sauren apfel, oder installier die xiaomi mal dazu. vllt übernimmt sie sogar deine einrichtung...
                          moviehunter last edited by moviehunter
                          Moin,
                          ich habe mittlerweile zwei Sauger an zwei Standorten (somit auch verschiedenen Routern und verschiedenen Installationen vom ioborker)
                          Bei beiden bekomme ich keine Verbindung zum Sauger.
                          In der Xiaomi Home App laufen beide einwandfrei.
                          Über mein Konto kann ich sie auch beide in den iobroker einbinden.
                          Aber weiter geht es nicht. Unter Objekte kann ich zwar auf Start drücken, aber es kommt nichts beim Sauger an.
                          Zum einen habe ich den Xiaomi Mi Robot Vacuum Mop und zum anderen den Xiaomi Mi Robot Vacuum Mop Pro.
                          Ländereinstellung/Server steht im Adapter, sowie in der App auf Deutschland. Habe mal gelesen, dass es da sinnvoll ist auf China zu stellen...ist das so?
                          Hier ein Auszug aus meinem log.
                          mihome-vacuum.0	2020-10-22 07:30:31.700	debug	(628) no answer for get_status(id:13410) received, giving up
                          mihome-vacuum.0	2020-10-22 07:30:30.037	debug	(628) system.adapter.admin.0: logging true
                          mihome-vacuum.0	2020-10-22 07:30:25.727	info	(628) should trigger cleaning all null, but is currently active. Add to queue
                          mihome-vacuum.0	2020-10-22 07:30:25.719	debug	(628) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-10-22 07:30:25.719	debug	(628) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1603344625718,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1603262874086}
                          mihome-vacuum.0	2020-10-22 07:30:25.278	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:30:25.277	info	(628) Connected
                          mihome-vacuum.0	2020-10-22 07:30:25.253	info	(628) Disconnect
                          mihome-vacuum.0	2020-10-22 07:30:23.253	info	(628) should trigger cleaning all null, but is currently active. Add to queue
                          mihome-vacuum.0	2020-10-22 07:30:23.252	debug	(628) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-10-22 07:30:23.252	debug	(628) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1603344623218,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1603262874086}
                          mihome-vacuum.0	2020-10-22 07:30:19.828	debug	(628) no answer for get_sound_volume(id:13408) received, giving up
                          mihome-vacuum.0	2020-10-22 07:30:19.629	debug	(628) no answer for get_clean_summary(id:13407) received, giving up
                          mihome-vacuum.0	2020-10-22 07:30:19.429	debug	(628) no answer for get_consumable(id:13406) received, giving up
                          mihome-vacuum.0	2020-10-22 07:30:11.699	debug	(628) no answer for get_status(id:13405) received, giving up
                          mihome-vacuum.0	2020-10-22 07:30:04.426	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:29:52.200	debug	(628) no answer for get_sound_volume(id:13403) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:52.000	debug	(628) no answer for get_clean_summary(id:13402) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:51.800	debug	(628) no answer for get_consumable(id:13401) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:51.799	debug	(628) no answer for get_status(id:13400) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:36.798	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:29:36.797	info	(628) Connected
                          mihome-vacuum.0	2020-10-22 07:29:36.697	info	(628) Disconnect
                          mihome-vacuum.0	2020-10-22 07:29:31.698	debug	(628) no answer for get_status(id:13399) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:19.830	debug	(628) no answer for get_sound_volume(id:13397) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:19.630	debug	(628) no answer for get_clean_summary(id:13396) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:19.430	debug	(628) no answer for get_consumable(id:13395) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:12.265	debug	(628) no answer for get_sound_volume(id:13393) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:12.065	debug	(628) no answer for get_clean_summary(id:13392) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:11.864	debug	(628) no answer for get_consumable(id:13391) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:11.864	debug	(628) no answer for get_status(id:13390) received, giving up
                          mihome-vacuum.0	2020-10-22 07:29:04.427	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:28:56.862	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:28:56.861	info	(628) Connected
                          mihome-vacuum.0	2020-10-22 07:28:56.695	info	(628) Disconnect
                          mihome-vacuum.0	2020-10-22 07:28:51.697	debug	(628) no answer for get_status(id:13389) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:49.733	debug	(628) no answer for undefined(id:13388) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:43.183	debug	(628) no answer for get_sound_volume(id:13386) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:42.984	debug	(628) no answer for get_clean_summary(id:13385) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:42.781	debug	(628) no answer for get_consumable(id:13384) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:42.781	debug	(628) no answer for get_status(id:13383) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:38.666	debug	(628) system.adapter.admin.0: logging false
                          mihome-vacuum.0	2020-10-22 07:28:34.693	info	(628) trigger cleaning all null
                          mihome-vacuum.0	2020-10-22 07:28:34.443	debug	(628) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-10-22 07:28:34.367	debug	(628) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1603344514357,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1603262874086}
                          mihome-vacuum.0	2020-10-22 07:28:27.780	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:28:27.779	info	(628) Connected
                          mihome-vacuum.0	2020-10-22 07:28:27.698	info	(628) Disconnect
                          mihome-vacuum.0	2020-10-22 07:28:22.699	debug	(628) no answer for get_status(id:13382) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:19.830	debug	(628) no answer for get_sound_volume(id:13380) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:19.628	debug	(628) no answer for get_clean_summary(id:13379) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:19.427	debug	(628) no answer for get_consumable(id:13378) received, giving up
                          mihome-vacuum.0	2020-10-22 07:28:04.426	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:28:02.698	debug	(628) no answer for get_status(id:13377) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:43.100	debug	(628) no answer for get_sound_volume(id:13375) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:42.902	debug	(628) no answer for get_clean_summary(id:13374) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:42.701	debug	(628) no answer for get_consumable(id:13373) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:42.700	debug	(628) no answer for get_status(id:13372) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:27.699	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:27:27.698	info	(628) Connected
                          mihome-vacuum.0	2020-10-22 07:27:27.695	info	(628) Disconnect
                          mihome-vacuum.0	2020-10-22 07:27:22.697	debug	(628) no answer for get_status(id:13371) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:19.829	debug	(628) no answer for get_sound_volume(id:13369) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:19.629	debug	(628) no answer for get_clean_summary(id:13368) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:19.428	debug	(628) no answer for get_consumable(id:13367) received, giving up
                          mihome-vacuum.0	2020-10-22 07:27:04.426	debug	(628) requesting params every: 60 Sec
                          mihome-vacuum.0	2020-10-22 07:27:02.695	debug	(628) no answer for get_status(id:13366) received, giving up
                          mihome-vacuum.0	2020-10-22 07:26:43.169	debug	(628) no answer for get_sound_volume(id:13364) received, giving up
                          mihome-vacuum.0	2020-10-22 07:26:42.969	debug	(628) no answer for get_clean_summary(id:13363) received, giving up
                          mihome-vacuum.0	2020-10-22 07:26:42.770	debug	(628) no answer for get_consumable(id:13362) received, giving up
                          Habt ihr eine Lösung dafür?
                          Meistertr W 2 Replies Last reply Reply Quote 0
                          • Meistertr
                            Meistertr Developer @moviehunter last edited by
                            @moviehunter lies mal 2 Posts weiter oben!! du hast auch die viomi modelle die aufgrund der geänderten api nicht mit der version 2 gehen, lad mal diese version (ACHTUNG ALPHA) https://github.com/MeisterTR/ioBroker.mihome-vacuum
                              weimaraner @moviehunter last edited by
                              @moviehunter sagte in Test Adapter mihome-vacuum v2.0.x:
                              Ist das so? Ich habe einen Gen. 1, den ich seit zwei Jahren erfolgreich eingebunden habe. Super Adapter großes Lob an @Meistertr. Jetzt kommt ein S5 max dazu. Ich habe historisch bedingt den Gen 1 und auch ein Gateway über die China Server angemeldet. Muß ich jetzt mal schauen, ob der "deutsche" S5 max sich auch an den China Servern anmelden läßt. Wäre das für den Adapter von Vorteil?
                              Ich möchte nicht alle Geräte ummelden müssen.
                              Grüße Andreas
                                moviehunter @Meistertr last edited by
                                @Meistertr
                                super, das hat geklappt. Danke.
                                Aber mehrere Instanzen sind noch nicht möglich..oder?
                                Zumindest bekomme ich sobald ich eine zweite anlege bei keiner mehr eine Verbindung.
                                W Meistertr 2 Replies Last reply Reply Quote 0
                                  @moviehunter hast du bei der zweiten Instanz den Port geändert? Bspw. eins mehr?
                                  Grüße Andreas
                                  • Meistertr
                                    @moviehunter sollte eigentlich gehen, hab ich bis lang noch nciht getestet, was sagt denn der log dazu?
                                      @Meistertr @weimaraner
                                      hat geklappt. Hab den falschen Port angepasst gehabt.
                                      Danke.
                                        reini last edited by
                                        hi, kann irgendwie der Xiaomi Nasswischroboter (SWDK ZDG300) eingebunden werden?
                                        Meistertr R 2 Replies Last reply Reply Quote 0
                                          schneidy76 @da_Woody last edited by
                                          @da_Woody des habe ich getan, für Alle: die Karte bleibt bestehen, die Einrichtung der Räume muss man eben neu machen. Das geht relativ easy. Was nervt, die App verlangt alle paar Tage eine neue Anmeldung...
                                          VG Torsten
                                          • da_Woody
                                            @schneidy76 said in Test Adapter mihome-vacuum v2.0.x:
                                            die xiaomi??? ne.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            445123
