Test Adapter mihome-vacuum v2.0.x
@Meistertr: Ich habe die Version 2.1.1 installiert habe aber das Problem, dass keine Verbindung zu meinem Roborter aufgebaut werden kann:
2020-10-16 07:17:13.620 - debug: mihome-vacuum.0 (8938) no answer for id:35 received, giving up 2020-10-16 07:17:13.620 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 2020-10-16 07:17:17.358 - info: admin.0 (574) Subscribe on all states again 2020-10-16 07:17:18.582 - debug: mihome-vacuum.0 (8938) Receive <<< Helo <<< 2131002000000000139bcd175f892cdfffffffffffffffffffffffffffffffff 2020-10-16 07:17:18.582 - warn: mihome-vacuum.0 (8938) Time difference between Mihome Vacuum and ioBroker: 1 sec 2020-10-16 07:17:18.583 - info: mihome-vacuum.0 (8938) connecting, this can take up to 10 minutes ... 2020-10-16 07:17:18.583 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 2020-10-16 07:17:18.585 - debug: mihome-vacuum.0 (8938) sendMsg[1] >>> {"id":36,"method":"get_status"} 2020-10-16 07:17:23.586 - debug: mihome-vacuum.0 (8938) sendMsg[2] >>> {"id":36,"method":"get_status"} 2020-10-16 07:17:24.459 - info: admin.0 (574) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0) 2020-10-16 07:17:28.588 - debug: mihome-vacuum.0 (8938) sendMsg[3] >>> {"id":36,"method":"get_status"} 2020-10-16 07:17:33.589 - debug: mihome-vacuum.0 (8938) no answer for id:36 received, giving up 2020-10-16 07:17:33.589 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 2020-10-16 07:17:38.651 - debug: mihome-vacuum.0 (8938) Receive <<< Helo <<< 2131002000000000139bcd175f892cf3ffffffffffffffffffffffffffffffff 2020-10-16 07:17:38.652 - warn: mihome-vacuum.0 (8938) Time difference between Mihome Vacuum and ioBroker: 1 sec 2020-10-16 07:17:38.653 - info: mihome-vacuum.0 (8938) connecting, this can take up to 10 minutes ... 2020-10-16 07:17:38.653 - debug: mihome-vacuum.0 (8938) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 2020-10-16 07:17:38.659 - debug: mihome-vacuum.0 (8938) sendMsg[1] >>> {"id":37,"method":"get_status"}
Kann mir jemand helfen, das Problem zu finden.
@ilovegym said in Test Adapter mihome-vacuum v2.0.x:
@Ahnungsbefreit genau, mit der roborock App geht es nicht, musst ihn in die mihome App einbinden.
Ich stehe vor den gleichen Problem, benutze auch die Roborock App. Die ist super eingerichtet Räume, Sperrzonen, etc.. Das möchte ich ungern verwerfen. Wird diese App in den Apapter zukünftig integriert werden? Das Problem ist ja der Token, den muss man doch irgendwie aus der App bekommen. Ist die Kommunikation über die Roborock App soviel anders? Kenne mich da zu wenig aus.
VG Torsten -
Sorry, falsch gedrückt
@JayR mal versucht den roboter neu zu starten?
@Meistertr : Ich mal wieder
Ich gehe mal davon aus, dass die Valetudo Anpassung erst im "Test Adapter mihome-vacuum 3.x.x" umgesetzt wird oder?
Grüssle Kristina
@Meistertr: Hat nicht geholfen. Hast du noch eine andere Idee?
@JayR: Ist der Adapter mit dem Xiaomi Mi Robot Vacuum Mop Pro kompatibel? Das Problem besteht nach wie vor.
@JayR die Version 2 nicht die 3er schon, aber kann bis lang nur die viomi Modelle, die musst du über meine git Seite installiert, ist aber noch alpha Stadium. Komme da gerade etwas schleppend vorran.
@schneidy76 die xiaomi sieht genau so aus wie die roborock. beiß in den sauren apfel, oder installier die xiaomi mal dazu. vllt übernimmt sie sogar deine einrichtung...
Moin,
ich habe mittlerweile zwei Sauger an zwei Standorten (somit auch verschiedenen Routern und verschiedenen Installationen vom ioborker)
Bei beiden bekomme ich keine Verbindung zum Sauger.
In der Xiaomi Home App laufen beide einwandfrei.
Über mein Konto kann ich sie auch beide in den iobroker einbinden.
Aber weiter geht es nicht. Unter Objekte kann ich zwar auf Start drücken, aber es kommt nichts beim Sauger an.
Zum einen habe ich den Xiaomi Mi Robot Vacuum Mop und zum anderen den Xiaomi Mi Robot Vacuum Mop Pro.Ländereinstellung/Server steht im Adapter, sowie in der App auf Deutschland. Habe mal gelesen, dass es da sinnvoll ist auf China zu stellen...ist das so?
Hier ein Auszug aus meinem log.
mihome-vacuum.0 2020-10-22 07:30:31.700 debug (628) no answer for get_status(id:13410) received, giving up mihome-vacuum.0 2020-10-22 07:30:30.037 debug (628) system.adapter.admin.0: logging true mihome-vacuum.0 2020-10-22 07:30:25.727 info (628) should trigger cleaning all null, but is currently active. Add to queue mihome-vacuum.0 2020-10-22 07:30:25.719 debug (628) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-10-22 07:30:25.719 debug (628) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1603344625718,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1603262874086} mihome-vacuum.0 2020-10-22 07:30:25.278 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:30:25.277 info (628) Connected mihome-vacuum.0 2020-10-22 07:30:25.253 info (628) Disconnect mihome-vacuum.0 2020-10-22 07:30:23.253 info (628) should trigger cleaning all null, but is currently active. Add to queue mihome-vacuum.0 2020-10-22 07:30:23.252 debug (628) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-10-22 07:30:23.252 debug (628) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1603344623218,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1603262874086} mihome-vacuum.0 2020-10-22 07:30:19.828 debug (628) no answer for get_sound_volume(id:13408) received, giving up mihome-vacuum.0 2020-10-22 07:30:19.629 debug (628) no answer for get_clean_summary(id:13407) received, giving up mihome-vacuum.0 2020-10-22 07:30:19.429 debug (628) no answer for get_consumable(id:13406) received, giving up mihome-vacuum.0 2020-10-22 07:30:11.699 debug (628) no answer for get_status(id:13405) received, giving up mihome-vacuum.0 2020-10-22 07:30:04.426 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:29:52.200 debug (628) no answer for get_sound_volume(id:13403) received, giving up mihome-vacuum.0 2020-10-22 07:29:52.000 debug (628) no answer for get_clean_summary(id:13402) received, giving up mihome-vacuum.0 2020-10-22 07:29:51.800 debug (628) no answer for get_consumable(id:13401) received, giving up mihome-vacuum.0 2020-10-22 07:29:51.799 debug (628) no answer for get_status(id:13400) received, giving up mihome-vacuum.0 2020-10-22 07:29:36.798 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:29:36.797 info (628) Connected mihome-vacuum.0 2020-10-22 07:29:36.697 info (628) Disconnect mihome-vacuum.0 2020-10-22 07:29:31.698 debug (628) no answer for get_status(id:13399) received, giving up mihome-vacuum.0 2020-10-22 07:29:19.830 debug (628) no answer for get_sound_volume(id:13397) received, giving up mihome-vacuum.0 2020-10-22 07:29:19.630 debug (628) no answer for get_clean_summary(id:13396) received, giving up mihome-vacuum.0 2020-10-22 07:29:19.430 debug (628) no answer for get_consumable(id:13395) received, giving up mihome-vacuum.0 2020-10-22 07:29:12.265 debug (628) no answer for get_sound_volume(id:13393) received, giving up mihome-vacuum.0 2020-10-22 07:29:12.065 debug (628) no answer for get_clean_summary(id:13392) received, giving up mihome-vacuum.0 2020-10-22 07:29:11.864 debug (628) no answer for get_consumable(id:13391) received, giving up mihome-vacuum.0 2020-10-22 07:29:11.864 debug (628) no answer for get_status(id:13390) received, giving up mihome-vacuum.0 2020-10-22 07:29:04.427 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:28:56.862 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:28:56.861 info (628) Connected mihome-vacuum.0 2020-10-22 07:28:56.695 info (628) Disconnect mihome-vacuum.0 2020-10-22 07:28:51.697 debug (628) no answer for get_status(id:13389) received, giving up mihome-vacuum.0 2020-10-22 07:28:49.733 debug (628) no answer for undefined(id:13388) received, giving up mihome-vacuum.0 2020-10-22 07:28:43.183 debug (628) no answer for get_sound_volume(id:13386) received, giving up mihome-vacuum.0 2020-10-22 07:28:42.984 debug (628) no answer for get_clean_summary(id:13385) received, giving up mihome-vacuum.0 2020-10-22 07:28:42.781 debug (628) no answer for get_consumable(id:13384) received, giving up mihome-vacuum.0 2020-10-22 07:28:42.781 debug (628) no answer for get_status(id:13383) received, giving up mihome-vacuum.0 2020-10-22 07:28:38.666 debug (628) system.adapter.admin.0: logging false mihome-vacuum.0 2020-10-22 07:28:34.693 info (628) trigger cleaning all null mihome-vacuum.0 2020-10-22 07:28:34.443 debug (628) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0 mihome-vacuum.0 2020-10-22 07:28:34.367 debug (628) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1603344514357,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1603262874086} mihome-vacuum.0 2020-10-22 07:28:27.780 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:28:27.779 info (628) Connected mihome-vacuum.0 2020-10-22 07:28:27.698 info (628) Disconnect mihome-vacuum.0 2020-10-22 07:28:22.699 debug (628) no answer for get_status(id:13382) received, giving up mihome-vacuum.0 2020-10-22 07:28:19.830 debug (628) no answer for get_sound_volume(id:13380) received, giving up mihome-vacuum.0 2020-10-22 07:28:19.628 debug (628) no answer for get_clean_summary(id:13379) received, giving up mihome-vacuum.0 2020-10-22 07:28:19.427 debug (628) no answer for get_consumable(id:13378) received, giving up mihome-vacuum.0 2020-10-22 07:28:04.426 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:28:02.698 debug (628) no answer for get_status(id:13377) received, giving up mihome-vacuum.0 2020-10-22 07:27:43.100 debug (628) no answer for get_sound_volume(id:13375) received, giving up mihome-vacuum.0 2020-10-22 07:27:42.902 debug (628) no answer for get_clean_summary(id:13374) received, giving up mihome-vacuum.0 2020-10-22 07:27:42.701 debug (628) no answer for get_consumable(id:13373) received, giving up mihome-vacuum.0 2020-10-22 07:27:42.700 debug (628) no answer for get_status(id:13372) received, giving up mihome-vacuum.0 2020-10-22 07:27:27.699 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:27:27.698 info (628) Connected mihome-vacuum.0 2020-10-22 07:27:27.695 info (628) Disconnect mihome-vacuum.0 2020-10-22 07:27:22.697 debug (628) no answer for get_status(id:13371) received, giving up mihome-vacuum.0 2020-10-22 07:27:19.829 debug (628) no answer for get_sound_volume(id:13369) received, giving up mihome-vacuum.0 2020-10-22 07:27:19.629 debug (628) no answer for get_clean_summary(id:13368) received, giving up mihome-vacuum.0 2020-10-22 07:27:19.428 debug (628) no answer for get_consumable(id:13367) received, giving up mihome-vacuum.0 2020-10-22 07:27:04.426 debug (628) requesting params every: 60 Sec mihome-vacuum.0 2020-10-22 07:27:02.695 debug (628) no answer for get_status(id:13366) received, giving up mihome-vacuum.0 2020-10-22 07:26:43.169 debug (628) no answer for get_sound_volume(id:13364) received, giving up mihome-vacuum.0 2020-10-22 07:26:42.969 debug (628) no answer for get_clean_summary(id:13363) received, giving up mihome-vacuum.0 2020-10-22 07:26:42.770 debug (628) no answer for get_consumable(id:13362) received, giving up
Habt ihr eine Lösung dafür?
@moviehunter lies mal 2 Posts weiter oben!! du hast auch die viomi modelle die aufgrund der geänderten api nicht mit der version 2 gehen, lad mal diese version (ACHTUNG ALPHA) https://github.com/MeisterTR/ioBroker.mihome-vacuum
@moviehunter sagte in Test Adapter mihome-vacuum v2.0.x:
Ist das so? Ich habe einen Gen. 1, den ich seit zwei Jahren erfolgreich eingebunden habe. Super Adapter großes Lob an @Meistertr. Jetzt kommt ein S5 max dazu. Ich habe historisch bedingt den Gen 1 und auch ein Gateway über die China Server angemeldet. Muß ich jetzt mal schauen, ob der "deutsche" S5 max sich auch an den China Servern anmelden läßt. Wäre das für den Adapter von Vorteil?
Ich möchte nicht alle Geräte ummelden müssen.
Grüße Andreas -
super, das hat geklappt. Danke.
Aber mehrere Instanzen sind noch nicht möglich..oder?
Zumindest bekomme ich sobald ich eine zweite anlege bei keiner mehr eine Verbindung. -
@moviehunter hast du bei der zweiten Instanz den Port geändert? Bspw. eins mehr?
Grüße Andreas -
@moviehunter sollte eigentlich gehen, hab ich bis lang noch nciht getestet, was sagt denn der log dazu?
@Meistertr @weimaraner
hat geklappt. Hab den falschen Port angepasst gehabt.
Danke. -
hi, kann irgendwie der Xiaomi Nasswischroboter (SWDK ZDG300) eingebunden werden?
@da_Woody des habe ich getan, für Alle: die Karte bleibt bestehen, die Einrichtung der Räume muss man eben neu machen. Das geht relativ easy. Was nervt, die App verlangt alle paar Tage eine neue Anmeldung...
VG Torsten
@schneidy76 said in Test Adapter mihome-vacuum v2.0.x:
die xiaomi??? ne.
@reini nicht ohne zutun.. wenn du mich via teamviewer mal auf deinen rechner lässt, könnte ich versuchen die Befehle die für den wischer erforderlich sind herauszufinden. kannst mich am besten dazu mal bei telegram oder discond anschreiben
