    4. Test Adapter HeatingControl v2.12.x
    • Rene_HM
      Rene_HM Developer @danny_v1 last edited by
      @danny_v1 Im github liegt aber eine V1.1.0 und du startest eine V1.0.0. Du bist sicher, du installierst von https://github.com/rg-engineering/ioBroker.heatingcontrol ?
        sigi234 Forum Testing Most Active @Rene_HM last edited by sigi234
        @Rene_HM
        Hallo, irgendwas stimmt nicht bei mir. Habe sicher was Falsch eingestellt
        heatingcontrol.0	2020-10-23 21:12:05.237	warn	(19424) handling actors out of heating period not implemented yet
        heatingcontrol.0	2020-10-23 21:11:05.711	info	(19424) 12 cron job(s) created
        heatingcontrol.0	2020-10-23 21:11:05.691	info	(19424) set thermostat hm-rpc.0.OEQ0655913.4.SET_TEMPERATURE to 0; current is 4.5
        web.0	2020-10-23 21:10:58.453	info	(19904) ==>Connected system.user.admin from ::1
        web.0	2020-10-23 21:10:58.119	info	(19904) <==Disconnect system.user.admin from ::1 vis.0
        heatingcontrol.0	2020-10-23 21:10:53.508	info	(19424) 12 cron job(s) created
        heatingcontrol.0	2020-10-23 21:10:53.484	error	(19424) vis: error: for Rooms.Esszimmer.ActiveTimeSlot got null
        heatingcontrol.0	2020-10-23 21:10:53.484	error	(19424) could not read current active time slot in FindNextPeriod
        heatingcontrol.0	2020-10-23 21:10:53.473	error	(19424) vis: error: for Profiles.0.Esszimmer.none.WindowOpenDecrease got null
        heatingcontrol.0	2020-10-23 21:10:53.469	error	(19424) vis: error: for Profiles.0.Esszimmer.none.VacationAbsentDecrease got null
        heatingcontrol.0	2020-10-23 21:10:53.466	error	(19424) vis: error: for Profiles.0.Esszimmer.none.PartyDecrease got null
        heatingcontrol.0	2020-10-23 21:10:53.464	error	(19424) vis: error: for Profiles.0.Esszimmer.none.GuestIncrease got null
        heatingcontrol.0	2020-10-23 21:10:53.461	error	(19424) vis: error: for Profiles.0.Esszimmer.none.AbsentDecrease got null
        heatingcontrol.0	2020-10-23 21:10:53.345	info	(19424) starting vis part 2
        heatingcontrol.0	2020-10-23 21:10:53.342	info	(19424) starting vis
        heatingcontrol.0	2020-10-23 21:10:53.337	info	(19424) subscribe roomBedroom hm-rpc.0.OEQ0926852.1.STATE
        heatingcontrol.0	2020-10-23 21:10:53.336	info	(19424) subscribe Esszimmer hm-rpc.0.NEQ1826414.1.STATE
        heatingcontrol.0	2020-10-23 21:10:53.336	info	(19424) subscribe Vorraum hm-rpc.0.NEQ1818500.1.STATE
        heatingcontrol.0	2020-10-23 21:10:53.336	info	(19424) subscribe for UseActors Esszimmer hm-rpc.0.OEQ0655913.4.ACTUAL_TEMPERATURE
        heatingcontrol.0	2020-10-23 21:10:53.333	info	(19424) 12 cron job(s) created
        heatingcontrol.0	2020-10-23 21:10:53.315	error	(19424) could not read current active time slot in FindNextPeriod
          danny_v1 @Rene_HM last edited by
          @Rene_HM ich hab den link bei Adapter aus beliebiger Quelle installieren eingefügt und installiert.
          Das bringt mir die Ausgabe:
          $ ./iobroker url "https://github.com/rg-engineering/ioBroker.heatingcontrol/tree/master" --debug
          install https://github.com/rg-engineering/ioBroker.heatingcontrol/tree/master/tarball/137f15dab3aa9a09b74d2e07bc0e26bb21e7accf
          NPM version: 6.14.4
          npm install https://github.com/rg-engineering/ioBroker.heatingcontrol/tree/master/tarball/137f15dab3aa9a09b74d2e07bc0e26bb21e7accf --loglevel error --prefix "/opt/iobroker" (System call)
          npm ERR! code E404npm ERR! 404 Not Found - GET https://github.com/rg-engineering/ioBroker.heatingcontrol/tree/master/tarball/137f15dab3aa9a09b74d2e07bc0e26bb21e7accfnpm ERR! 404 npm ERR! 404 'https://github.com/rg-engineering/ioBroker.heatingcontrol/tree/master/tarball/137f15dab3aa9a09b74d2e07bc0e26bb21e7accf' is not in the npm registry.npm ERR! 404 Your package name is not valid, because npm ERR! 404 1. name can only contain URL-friendly charactersnpm ERR! 404 2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-10-23T19_56_00_575Z-debug.log
          upload [4] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/words.js words.js application/javascript
          upload [3] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/styles.css styles.css text/css
          upload [2] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/index_m.html index_m.html text/html
          upload [1] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/img/info-big.png img/info-big.png image/png
          upload [0] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/heatingcontrol.png heatingcontrol.png image/png
          process exited with code 0
          • Rene_HM
            Rene_HM Developer @sigi234 last edited by
            @sigi234 heatingcontrol.0.HeatingPeriodActive ist aus?
            • Rene_HM
              @danny_v1 Die URL ist https://github.com/rg-engineering/ioBroker.heatingcontrol
              ohne "/tree/master"
              Das sieht dann so aus
                @Rene_HM Ich werd verrückt, kaum mach ich es richtig geht es! Vielen Dank!!! 👍 👍
                Da das nun geht hätte ich noch ne Frage (hoffe ich stell mich da nicht wieder so dumm an). Ist es möglich alles so einzustellen das z.b. Party now oder Gäste anwesend nur Auswirkungen auf bestimmte Räume hat? Muss ja nicht im Schlafzimmer wärmer werden wenn die Gäste im Wohnzimmer sind.
                  @Rene_HM sagte in Test Adapter HeatingControl v1.0.x:
                  Ja, habe es jetzt auf True gesetzt.
                  Keine Änderung.
                  • Rene_HM
                    @danny_v1 sagte in Test Adapter HeatingControl v1.0.x:
                    Die Absenk-Temperaturen sind doch Raum-spezifisch. Wenn du also keine Absenkung für das Schafzimmer konfigurierst, wird dort auch nicht abgesenkt...
                    • Rene_HM
                      @sigi234 sagte in Test Adapter HeatingControl v1.0.x:
                      Keine Änderung.
                      aber das log sollte jetzt anders aussehen, oder?
                        Keine Änderung.
                        Ja
                        heatingcontrol.0	2020-10-24 09:02:29.188	info	(11456) handle actors Esszimmer current 23.9 target 22
                        heatingcontrol.0	2020-10-24 09:02:05.447	info	(11456) 35 cron job(s) created
                        heatingcontrol.0	2020-10-24 09:02:05.418	error	(11456) vis: error: for Rooms.Esszimmer.ActiveTimeSlot got null
                        heatingcontrol.0	2020-10-24 09:02:05.417	error	(11456) could not read current active time slot in FindNextPeriod
                        heatingcontrol.0	2020-10-24 09:02:05.410	error	(11456) vis: error: for Profiles.0.Esszimmer.none.WindowOpenDecrease got null
                        heatingcontrol.0	2020-10-24 09:02:05.409	error	(11456) vis: error: for Profiles.0.Esszimmer.none.VacationAbsentDecrease got null
                        heatingcontrol.0	2020-10-24 09:02:05.407	error	(11456) vis: error: for Profiles.0.Esszimmer.none.PartyDecrease got null
                        heatingcontrol.0	2020-10-24 09:02:05.406	error	(11456) vis: error: for Profiles.0.Esszimmer.none.GuestIncrease got null
                        heatingcontrol.0	2020-10-24 09:02:05.189	info	(11456) starting vis part 2
                        heatingcontrol.0	2020-10-24 09:02:05.185	info	(11456) starting vis
                        heatingcontrol.0	2020-10-24 09:02:05.180	info	(11456) subscribe Esszimmer hm-rpc.0.NEQ1826414.1.STATE
                        heatingcontrol.0	2020-10-24 09:02:05.180	info	(11456) subscribe for UseActors Esszimmer hm-rpc.0.OEQ0655913.4.ACTUAL_TEMPERATURE
                        heatingcontrol.0	2020-10-24 09:02:05.175	info	(11456) 35 cron job(s) created
                        heatingcontrol.0	2020-10-24 09:02:05.139	error	(11456) could not read current active time slot in FindNextPeriod
                        heatingcontrol.0	2020-10-24 09:02:05.132	info	(11456) external states checked, done
                        heatingcontrol.0	2020-10-24 09:02:05.128	info	(11456) checking all external states
                        heatingcontrol.0	2020-10-24 09:02:05.125	info	(11456) 0 actors are on of 0
                        heatingcontrol.0	2020-10-24 09:02:05.125	info	(11456) checking all actors
                        heatingcontrol.0	2020-10-24 09:02:05.119	info	(11456) Esszimmer window open on Terrassentuer.STATE
                        heatingcontrol.0	2020-10-24 09:02:05.117	info	(11456) 35 cron job(s) created
                        heatingcontrol.0	2020-10-24 09:02:04.930	info	(11456) no temperature degrease configured 3
                        heatingcontrol.0	2020-10-24 09:02:04.859	info	(11456) starting. Version 1.1.0 in C:/Program Files/iobroker/Heizung/node_modules/iobroker.heatingcontrol, node: v12.18.4, js-controller: 3.1.6
                        Erledigt, der Absenkmodus war auf kein absenken.
                          deta Most Active last edited by
                          Moin,
                          ich glaube ich hab ein Bug in der aktuellen Git Version gefunden. Gestern Abend runtergeladen.
                          Wollte ein weitere Zeit Peri eintragen. Hab das Default 5 auf 6 erhöht. Sollte doch dann ein6 Punkt in den Objekten entstehen. Leider nein es bleibt bei 5.
                          Instanz wurde auch bereits neu gestartet.
                          • Rene_HM
                            Rene_HM Developer @deta last edited by
                            @deta aber das sind doch 6 Perioden (0 bis 5)?
                              Jupp, er hat 0 nicht mitgezählt.
                                deta Most Active @sigi234 last edited by
                                🤓 Ja klar. Dann wird es im VIS nicht angezeigt
                                  @Rene_HM said in Test Adapter HeatingControl v1.0.x
                                  Ah ok da hab ich das übersehen.
                                  Also die Thermeratur Übernahme von Thermostat geht jetzt. Aber dann funktioniert auch die Sensor Erkennung nicht mehr. Und wenn man händisch auf den ursprünglichen Wert zurückregelt, könnte es ja dann eigentlich auch wieder im "normalen" Modus weitergehen?
                                  • Rene_HM
                                    ja, so ist es implementiert. Im Override reagiert der Adapter auch auf die Sensoren, also muss ich das hier noch einbauen
                                    ja, das könnte ich noch einbauen...
                                    • Rene_HM
                                      Rene_HM Developer @Rene_HM last edited by
                                      ABER: hier braucht es einen größeren Umbau. Aktuell entsteht eine Endlosschleife:
                                      • Änderung kommt vom Thermostat, weil jemand daran dreht
                                      • Änderung wird übernommen
                                      • Fenster geht auf
                                      • reduzierte Temperatur wird auf das Thermostat geschrieben
                                      • vom Thermostat kommt die reduzierte Temperatur wieder zurück
                                      • diese wird aktuell als neue Änderung vom Thermostat übernommen und mit der Reduzierung wegen "Fenster auf" wieder auf das Thermostat geschrieben... und so weiter...
                                      Ich lasse das also in der 1.1.0 so, wie es ist. In einer 2.x gehe ich dieses Thema an...
                                        @Rene_HM Also wenn rein kommt, dass wenn man das Thermostat wieder auf den Wert vom Profil stellt der "normale" Modus wieder an ist wäre das schon super (Aber was passiert, wenn ich im Profil 18°C habe, dann stelle ich am Thermostat 20°C ein, mache ein Fenster auf und dann dreh ich wieder auf 18°C?).
                                        Sonst könnte man ja auch den Override nehmen und die Override Zeit bis zum nächsten Profil Punkt per Skript berechnen.
                                          Jens Lattwesen last edited by Jens Lattwesen
                                          Moin,
                                          Frage eines "Beginners". Habe den Adapter installiert, ein Profil angelegt (jeder Tag versch) und dann über die VIS je Raum die Temperaturen eingegeben. MAX Cube und deren Thermostate sind vorhanden, stehen alle auf "manuell"
                                          Problem 1: Er stellt die Temperaturen nicht ein
                                          Problem 2: Die VIS liest die Temperaturen nicht aus, d.h. wenn ich gestern in einem Raum 22 Grad eingegeben habe, steht dort heute etwas Anderes. (ggfs. frage ich auch mal im "VIS-Post")
                                          Habe ich da falsche Einstellungen genommen?
                                            Pittini Developer @Jens Lattwesen last edited by
                                            @Jens-Lattwesen sagte in Test Adapter HeatingControl v1.0.x:
                                            Hast Du die Vis Nutzung im Adapteradmin überhaupt aktiviert?
                                            81.1k
                                            heating
                                            236
                                            3158
                                            1998736
