    4. VIS von Sigi234
    VIS von Sigi234
      MartyBr @sigi234 last edited by
      @sigi234
      Habe den Thread gefunden.
      Hier der Inhalt im Reiter Script
      function hslToRgb(h, s, l){
          var r, g, b;
          if(s === 0) {
              r = g = b = l; // achromatic
          }else{
              var hue2rgb = function hue2rgb(p, q, t){
                  if(t < 0) t += 1;
                  if(t > 1) t -= 1;
                  if(t < 1/6) return p + (q - p) * 6 * t;
                  if(t < 1/2) return q;
                  if(t < 2/3) return p + (q - p) * (2/3 - t) * 6;
                  return p;
              var q = l < 0.5 ? l * (1 + s) : l + s - l * s;
              var p = 2 * l - q;
              r = hue2rgb(p, q, h + 1/3);
              g = hue2rgb(p, q, h);
              b = hue2rgb(p, q, h - 1/3);
          return [Math.round(r * 255), Math.round(g * 255), Math.round(b * 255)];
      function numberToColorHsl(i) {
          // as the function expects a value between 0 and 1, and red = 0° and green = 120°
          // we convert the input to the appropriate hue value
          var hue = i * 1.2 / 360;
          // we convert hsl to rgb (saturation 100%, lightness 50%)
          var rgb = hslToRgb(hue, 1, .5);
          // we format to css value and return
          return 'rgb(' + rgb[0] + ',' + rgb[1] + ',' + rgb[2] + ')';
      setTimeout(function () {
          // click-Eventhandler für "mdui-scale-" setzen
          $("#vis_container").on("click", "[class*='PINbutton']", function (event) {
              addNumber($(this));
              console.log("test");
              //$("[id*='w00027']")["0"].innerText='16';
              console.log($("[id*='w00040']"));
              //["0"].attributes["0"].value
          $("#vis_container").on("click", "[class*='PINbutton clear']", function (event) {
              clearForm($(this));
              //$("[id*='w00040']")["0"].innerText='16';
              console.log($("[id*='w00040']")["0"].innerText);
      }, 1000);
      function addNumber(e) {
          //document.getElementById('PINbox').value = document.getElementById('PINbox').value+element.value;
          var id = MDUI.getTargetID(e);
          var v = $("[id*='w00040']")["0"].innerText;
          $("[id*='w00040']")["0"].innerText = (v + e.attr("data-val"));
          console.log("V=" + v + " eigen:  " + e.attr("data-val") + "  td_ " + id);
      function clearForm(e) {
          //document.getElementById('PINbox').value = "";
          $("[id*='w00040']")["0"].innerText = "";
      function submitForm(e) {
          if (e.value === "") {
              alert("Enter a PIN");
          } else {
              alert("Your PIN has been sent! - " + e.value);
              data = {
                  pin: e.value
      		apiCall( data, function( r ) {
      			$( "#logo" ).attr( "src", r.site_logo );
      			$( ".title-msg" ).text( r.site_msg );
      			accent = r.accent;
      			$( ".accent-bg" ).css( "background-color", accent );
              $("#PINbox").val("");
        @sigi234
        Ich habe jetzt mal den CSS Code in der Version 2.5 eingespielt und einen neuen upload VIS gemacht.
        Keine Besserung.
          sigi234 Forum Testing Most Active @MartyBr last edited by sigi234
          @MartyBr sagte in VIS von Sigi234:
          @sigi234
          Keine Besserung.
          Skripte auch? Und CSS unter Projekt?
          #### Material Design CSS for ioBroker.vis
          (c) 2017ff Uhula, MIT License
          version: v2.5 30.04.2020
          source: https://github.com/Uhula/ioBroker-Material-Design-Style
          changelog: https://github.com/Uhula/ioBroker-Material-Design-Style/blob/master/changelog.MD
          // Zur sicheren CSS-Erkennung der Runtime eine CSS-Klasse anlegen
          document.documentElement.className +=  " mdui-runtime";
          // Überprüfen ob touch zur Verfügung steht und entsprechend eine
          // CSS Klasse touch bzw no-touch erzeugen
              (("ontouchstart" in document.documentElement) ? " mdui-touch" : " mdui-notouch");
             MDUI
             Sammlung von JS-Funktionen für das Material Design
          var MDUI = (function () {
          let defConfig = {"primary_color":"indigo",
                           "secondary_color":"blue",
                           "content_color":"#f8f8f8",
                           "color1":"#ff0000",
                           "color1_dark":"#800000",
                           "color2":"#00ff00",
                           "color2_dark":"#008000",
                           "color3":"#0000ff",
                           "color3_dark":"#000080"
              lastConfig = defConfig,
              styleSheet = null,
              lastPageID = "";
              observerSlider = null;
              observerConfig = null;
              observerPage = null;
              observerDialog = null;
              swipe = {enabled:false};
              tooltip = {hint:null, timeout:null};
              lockclick = false;
          //                      light         normal        dark
          let colors = {
                  red:        {c200:"#ff7961", c500:"#f44336", c700:"#ba000d" },
                  pink:       {c200:"#ff6090", c500:"#e91e63", c700:"#b0003a" },
                  purple:     {c200:"#d05ce3", c500:"#9c27b0", c700:"#6a0080" },
                  deeppurple: {c200:"#9a67ea", c500:"#673ab7", c700:"#320b86" },
                  indigo:     {c200:"#757de8", c500:"#3f51b5", c700:"#002984" },
                  blue:       {c200:"#6ec6ff", c500:"#2196f3", c700:"#0069c0" },
                  lightblue:  {c200:"#67daff", c500:"#03a9f4", c700:"#007ac1" },
                  cyan:       {c200:"#62efff", c500:"#00bcd4", c700:"#008ba3" },
                  teal:       {c200:"#52c7b8", c500:"#009688", c700:"#00675b" },
                  green:      {c200:"#80e27e", c500:"#4caf50", c700:"#087f23" },
                  lightgreen: {c200:"#bef67a", c500:"#8bc34a", c700:"#5a9216" },
                  lime:       {c200:"#ffff6e", c500:"#cddc39", c700:"#99aa00" },
                  yellow:     {c200:"#ffff72", c500:"#ffeb3b", c700:"#c8b900" },
                  amber:      {c200:"#fff350", c500:"#ffc107", c700:"#c79100" },
                  orange:     {c200:"#ffc947", c500:"#ff9800", c700:"#c66900" },
                  deeporange: {c200:"#ff8a50", c500:"#ff5722", c700:"#c41c00" },
                  brown:      {c200:"#a98274", c500:"#795548", c700:"#4b2c20" },
                  grey:       {c200:"#cfcfcf", c500:"#9e9e9e", c700:"#707070" },
                  darkgrey:   {c200:"#383838", c500:"#303030", c700:"#212121" },
                  bluegrey:   {c200:"#8eacbb", c500:"#607d8b", c700:"#34515e" },
                  white:      {c200:"#ffffff", c500:"#f8f8f8", c700:"#f0f0f0" },
                  black:      {c200:"#303030", c500:"#212121", c700:"#000000" }
          function _init() {
              observerSlider = new MutationObserver(function(mutations) {
                  mutations.forEach(function(mutation) {
                      _onChangeSlider( mutation.target );
              observerConfig = new MutationObserver(function(mutations) {
                      _onChangeConfig( mutation.target );
              observerPage = new MutationObserver(function(mutations) {
                      _onChangePage( mutation.target );
              observerDialog = new MutationObserver(function(mutations) {
                      _onChangeDialog( mutation.target );
          // für alle ui-slider-handle Instanzen "style" überwachen um die Wertanzeige via css
          // durchführen zu können (vis rendert dort die left/bottom neu)
          function _initObserverSlider() {
              observerSlider.disconnect();
              let nodelist = document.querySelectorAll('.mdui-slider .ui-slider-handle');
              if (nodelist) {
                  let i;
                  for (i = 0; i < nodelist.length; i++) {
                     _onChangeSlider( nodelist[i] );
                     observerSlider.observe(nodelist[i], {
                        attributes: true,
                        attributeFilter: ["style"]
          // für mdui-config Elemente überwachen
          function _initObserverConfig() {
              observerConfig.disconnect();
              let nodelist = document.querySelectorAll('.mdui-config');
              if (nodelist) {
                  let i;
                     observerConfig.observe(nodelist[i], {
                        subtree: true,
                        childList: true
          // vis_container überwachen: childlist
          function _initObserverPage() {
              observerPage.disconnect();
              let nodelist = document.querySelectorAll('#vis_container');
              if (nodelist) {
                  let i;
                     observerPage.observe(nodelist[i], {
                        subtree: true,
                        childList: true
          // ui-dialog
          function _initObserverDialog() {
              observerDialog.disconnect();
              let nodelist = document.querySelectorAll('.ui-dialog');
              if (nodelist) {
                  let i;
                     observerDialog.observe(nodelist[i], {
                        attributes: true,
          // ui-slider haben keine Werte im HTML, lediglich "left" bzw. "bottom" (bei vertikal)
          // werden für das ui-slider-handle gerendert. Hier wird dieser Wert in ein
          // neues Attribut "mdui-slider-value" gesetzt um dieses via CSS als Bubble
          // anzeigen zu können
          function _onChangeSlider( ele ) {
              let value = "0%";
              if (ele.style.left!=="")
                  value = ele.style.left;
              if (ele.style.bottom!=="")
                  value = ele.style.bottom;
              // nn% -> nn
              value = value.replace(/%/g, "");
                  ele.style.width = (100 - value) + "%";
                  ele.style.height = (100 - value) + "%";
              // mdui-range angegeben?
              let values = ele.parentElement.parentElement.className;
              values = _getSuffix(values, "mdui-range-");
              if (values!="") {
                  values = values.split("-");
                  if (values.length>1)
                      value = value/100 * (values[1]-values[0]) + values[0] * 1.0;
                  else if (values.length>0)
                      value = value/100 * values[0];
              if (Math.abs(value)<10)
                value = Math.round( value*10 ) / 10;
              else
                value = Math.round( value );
              ele.setAttribute("mdui-slider-value",value);
          // wenn sich die config ändert, muss evtl ein reload der Seite stattfinden
          function _onChangeConfig( ele ) {
              _getConfig();
              _patchColors();
              _patchWidgetColors();
              _initObserverConfig();
          function _onLoad() {
            let sel = "#"+lastPageID+" ";
            try {
                  $(sel+"[class*='mdui-onload'][class*='mdui-expand']:not(.mdui-active)").each( function (index) {
                      _toggleExpand( $(this) );
                  $(sel+"[class*='mdui-onload'][class*='mdui-toggle']:not(.mdui-active)").each( function (index) {
                      _handleToggle( $(this) );
                  $(sel+"[class*='mdui-onload'][class*='mdui-fullscreen']:not(.mdui-active)").each( function (index) {
                      _toggleFullscreen( $(this) );
            } catch(err) { console.log("[MDUI._onLoad] ",err.message ); }
          function _onChangePage( ele ) {
              let pageID = "";
              let $eles = $( "#vis_container>:not([style*='display: none'])[id*='visview_']" );
              if ( $eles.length < 1 || $eles.length > 2) return;
              pageID = $eles[$eles.length-1].id;
          //console.log("[MDUI.onChangePage] ",lastPageID," ",pageID);
              // wenn ein ui-datepicker hinzugekommen ist, dann dort die Farben anpassen
              if (this.datepickerCount != $(".ui-datepicker").length ) {
                  this.datepickerCount = $(".ui-datepicker").length;
                  _patchColors();
              // beim Seitenwechsel ausführen
              if ( (pageID!="") && (lastPageID!=pageID) ) {
                  lastPageID=pageID;
                  setTimeout( function () {
                      _getConfig();
                      _patchColors();
                      _handleTables();
                      _handleDialogs();
                      _handleInputs();
                      _handleVIS();
                      _initObserverSlider();
                      _initObserverDialog();
                      _onResizeWindow( $(window) );
                      _onLoad();
                      // favicon anpassen
                      $("#vis_container>:not([style*='display: none']) .mdui-favicon img").each( function (index) {
                          if ($(this)[0].src)
                               $("link[rel='shortcut icon']").attr("href", $(this)[0].src);
                      // page-name anpassen
                      let pagename = decodeURI( window.location.hash.substr(1,255) );
                      $(".mdui-page-name").each( function (index) {
                          $(this).html( pagename );
                      $(".mdui-page-title").each( function (index) {
                          // "pageMeine_ioBroker_Vis" -> "Meine ioBroker Vis"
                          let title = '';
                          let c;
                          for (let i=0; i<pagename.length; i++) {
                              c = pagename[i];
                              if (title=='') {
                                  if (c==c.toUpperCase()) title += c;
                              } else {
                                  if (c=='_') c = ' ';
                                  title += c;
                          $(this).html( title );
                  }, 100);
              _initObserverPage();
          // wenn ein Dialog sichtbar wird, dann seine Farben anpassen
          function _onChangeDialog( ele ) {
              //_handleDialogs();
          // liefert den suffix einer gegebenen class zurück
          // Bsp: mdui-target-w00002 -> w00002
          //      mdui-range-100-200 -> 100-200
          function _getSuffix( s, classname ) {
              let suf = "";
              if (s.includes(classname)) {
                  suf = s.substr(s.indexOf(classname)+classname.length,1000)+" ";
                  suf = suf.substr(0,suf.indexOf(" "));
              return suf;
          // liefert den suffix einer gegebenen class eine $ele zurück
          function _getClassSuffix( $ele, classname ) {
              if ($ele)
                  return _getSuffix($ele.attr( "class" ),classname);
              else
                  return "";
          // aktuelle mdui-config entladen
          function _getConfig() {
              $("#vis_container>:not([style*='display: none']) [class*='mdui-config ']").each( function (index) {
                  try {
                      lastConfig = JSON.parse("{"+$(this)[0].innerText+"}");
                  } catch(err) { console.log( "MDUI._getConfig: ", err.message ); }
              if (!lastConfig.hasOwnProperty("primary_color"))
                  lastConfig.primary_color = defConfig.primary_color
              if (!lastConfig.hasOwnProperty("secondary_color"))
                  lastConfig.secondary_color = defConfig.secondary_color;
              if (!lastConfig.hasOwnProperty("content_color"))
                  lastConfig.content_color = defConfig.content_color;
          function _getGroupID( ele ) { return _getClassSuffix(ele, "mdui-group-" ); }
          function _getTargetID( ele ) { return _getClassSuffix(ele, "mdui-target-" ); }
          function _getScrollbarWidth() {
              let $outer = $('<div>').css({visibility: 'hidden', width: 100, overflow: 'scroll'}).appendTo('body'),
                  widthWithScroll = $('<div>').css({width: '100%'}).appendTo($outer).outerWidth();
              $outer.remove();
              return 100 - widthWithScroll;
          function _getScrollbarHeight() {
              var $outer = $('<div>').css({visibility: 'hidden', height: 100, overflow: 'scroll'}).appendTo('body'),
                  heightWithScroll = $('<div>').css({height: '100%'}).appendTo($outer).outerHeight();
              $outer.remove();
              return 100 - heightWithScroll;
          // action: command(param1,param2,...)
          function _executeAction(action){ try {
              if (action) {
                  let cmd = action.split('(')[0];
                  let param = action.split('(')[1];
                  param = param.slice(0,param.length-1);
                  param = param.split(',');
                  switch (cmd.toUpperCase() ) {
                      case 'SETVALUE' :
                          vis.setValue(param[0], param[1]);
                          break;
                      case 'CHANGEVIEW' :
                          vis.changeView( param[0] );
                          break;
                      //showMessage(message, title, icon, width, callback)
                      case 'SHOWMESSAGE' :
                          vis.showMessage( param[0], param[1], param[2], param[3] );
                          _patchColors();
                          break;
          } catch(err) { console.log( "[MDUI._executeAction] " + err.message ); }
          function _isDarkTheme(ele) {
            while (ele) {
                if (ele.classList.contains('mdui-dark'))
                    return true;
                ele = ele.parentElement;
            return false;
          function _formatDatetime(date, format) {
              function fill(comp) {
                  return ((parseInt(comp) < 10) ? ('0' + comp) : comp)
              var months = ['Jan', 'Feb', 'Mär', 'Apr', 'Mai', 'Jun', 'Jul', 'Aug', 'Sep', 'Okt', 'Nov', 'Dez'];
              var d = format;
              var o = {
                      "y+": date.getFullYear(), // year
                      "m+": fill(date.getMonth()+1), //month
                      "M+": months[date.getMonth()], //month
                      "d+": fill(date.getDate()), //day
                      "H+": fill((date.getHours() > 12) ? date.getHours() % 12 : date.getHours()), //hour
                      "h+": fill(date.getHours()), //hour
                      "n+": fill(date.getMinutes()), //minute
                      "s+": fill(date.getSeconds()), //second
                      "S+": fill(date.getMilliseconds()), //millisecond,
                      "b+": (date.getHours() >= 12) ? 'PM' : 'AM'
              for (var k in o) {
                  if (new RegExp("(" + k + ")").test(format)) {
                      d = d.replace(RegExp.$1, o[k]);
              return d;
          // alle Elemente mit class "mdui-group-XXX" togglen, in denen
          // XXX aus class "mdui-group-XXX" des ele ist UND
          // alle Elemente mit class "mdui-target-XXX" togglen, in denen
          // XXX aus class "mdui-target-XXX" des ele ist
          function _handleToggle( $ele ) {
              $ele.toggleClass("ui-state-active");
              $ele.toggleClass("mdui-active");
              var id = _getGroupID( $ele );
              if (id!=="")
                  $("[class*='mdui-group-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
                      $(this).toggleClass("mdui-hide");
                      $(this).toggleClass("mdui-hide-show");
              id = _getTargetID( $ele );
              if (id!=="")
                  $( "[class*='mdui-target-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
          // das nächste übergeordnete .mdui-card* Element wird
          // - collapsed, wenn es expanded ist
          // - expanded, wenn es collapsed ist
          function _toggleExpand( $ele ){
              if (!$ele) return;
              let $target = $ele.closest("[class*='mdui-listitem']");
              if ($target.length===0) $target = $ele.closest("[class*='mdui-card']");
              if ($target.length===0) return;
              // wurde im ele eine Höhe mit angegeben?
              let h = _getClassSuffix( $ele, "mdui-expand-" ) ;
              if (h==="") h="64";
              // element um 180° drehen
              let styleold = $ele.attr("styleold");
              if (styleold) {
                  $ele.attr("style",styleold);
                  $ele.removeAttr("styleold");
              } else {
                  styleold = $ele.attr("style");
                  $ele.attr("styleold",styleold);
                  $ele.attr("style",styleold + " transform:rotate(180deg); transition:transform 0.33s; ");
              // target Element expandieren oder collabieren
              styleold = $target.attr("styleold") || "";
              if (styleold!=="") {
                  $target.attr("style",styleold + " transition:all 0.33s;");
                  $target.removeAttr("styleold");
              } else {
                  styleold = $target.attr("style") || "";
                  if (styleold==="") styleold="top:0;";
                  $target.attr("styleold",styleold);
                  $target.attr("style",styleold + " max-height:"+h+"px !important; " + " min-height:"+h+"px !important; transition:all 0.33s; ");
          // das nächste übergeordnete .vis-view Element wird
          // - fullscreen angezeigt, wenn es noch nicht fullscreen ist
          // - wieder normal angezeigt, wenn es fullscreen ist
          /* <div class="vis-widget mdui-button mdui-fullscreen mdui-center vis-tpl-basic-HTML" style="width: 36px; height: 36px; left: calc(100% - 52px); top: 16px; z-index: 1;" id="w00005">
                  <div class="vis-widget-body">
                      <i class="material-icons">fullscreen</i>
                  </div>
              </div>
          function _toggleFullscreen( $ele ){
              if (!$ele) return;
              let $target = $ele.closest(".vis-view");
              if (!$target) return;
              var styleold = $target.attr("styleold");
              if (styleold) {
                  let html = $ele.html();
                  html = html.replace(/fullscreen_exit/g, "fullscreen");
                  $ele.html( html );
                  $target.attr("style",styleold);
                  $target.appendTo(".mdui-id-"+$target.attr("id"));
              } else {
                  html = html.replace(/fullscreen/g, "fullscreen_exit");
                  $ele.html( html );
                  $target.parent().addClass("mdui-id-"+$target.attr("id"));
                  $target.attr("styleold",$target.attr("style"));
                  // dark-theme?
                  if ($ele.closest(".mdui-content.mdui-dark").length) $target.addClass("mdui-dark");
                  $target.attr("style","position:fixed; left:8px; top:8px; min-width:0; width:calc(100% - 16px); min-height:0; height:calc(100% - 16px); z-index: 2147483647 !important; background-color: "+lastConfig.content_color+" !important;   box-shadow: 0 0 0 1px rgba(0,0,0,0.3), 0 14px 28px rgba(0,0,0,0.65), 0 10px 10px rgba(0,0,0,0.62); border-radius: 4px;");
                  $target.appendTo( "body" );
          // ele muss class Einträge für das Target und den Skalierungsmodus haben
          // "mdui-target-(id) mdui-scale-(scalemode)"
          // id: Ziel-Element mit id=id, welches ein zu skalierendes img enthält
          // scalemode: fit / hfit / vfit / in / out / (number)
          // number: Zahl in %
          function _scale( ele ) {
              var id = _getTargetID( ele );
              var $img = $( "#"+id+" img" );
              if ($img) {
                  var scale = _getClassSuffix(ele, "mdui-scale-" );
                  $img.width("1px"); // Scrollbars entfernen um die echte Höhe zu bekommen
                  $img.height("1px");
                  var dim = {
                      pw : $img.parent().width(),
                      ph : $img.parent().height(),
                      w  : $img[0].naturalWidth,
                      h  : $img[0].naturalHeight
                  switch(scale) {
                      case "fit":
                          if (dim.pw / dim.w < dim.ph / dim.h ) scale = dim.pw / dim.w;
                          else scale = dim.ph / dim.h;
                          break;
                      case "hfit":
                          else scale = (dim.pw - _getScrollbarWidth() - 4  ) / dim.w;
                          break;
                      case "vfit":
                          if ( dim.pw / dim.w > dim.ph / dim.h ) scale = dim.ph / dim.h;
                          else scale = (dim.ph - _getScrollbarHeight() - 4  ) / dim.h;
                          break;
                      case "in":
                      case "out":
                          var old = $img.attr( "style" );
                          old = old.substr(old.indexOf("scale(")+6,20);
                          old = old.substr(0,old.indexOf(")"));
                          if (old * 1==0) scale = 1;
                          else if (scale=="in") scale = old * 1.41;
                               else scale = old / 1.41;
                          break;
                      default:
                          if (scale<=0 || scale>10000)
                              scale = 100;
                          scale = scale/100;
                  scale = Math.round(scale*100)/100;
                  $img.attr( "style", "position:absolute;top:0;left:0;transform-origin:0 0;transition: transform 0.3s ease-out; transform:scale("+scale+");" );
          // ersetzt im src-Attribute des Unter-Elements von (id) den "&range=&
          // durch den Wert des in ele angegebenen (span). Für flot-Diagramme
          // "mdui-target-(id) mdui-timespan-(span)"
          // id: Ziel-Element mit id=id, welches das flot (src) enthält
          // span: inc / dec / (number)
          // number: Zahl in Minuten
          function _timespan( ele ) {
              var src = "";
              function __patchParam( paramName, offset ) {
                  let reParam = RegExp(paramName+"=[^&]*", "i");
                  let reVal = RegExp("[+-][0-9]*", "i");
                  let param = src.match(reParam);
                  console.log("timespan param:",param);
                  if ( param ) {
                      param = param[0];
                      let paramval = param.match( reVal );
                      if (paramval) {
                          paramval = Math.floor(paramval) + offset;
                          param = param.replace( reVal, paramval<0 ? paramval : "-0" );
                      } else {
                          if ( (param[param.length-2]=="/") && ("smhdwMy".indexOf(param[param.length-1])>=0) )
                              param = param.substr(0,param.length-2) + (offset<0 ? offset : "-0") + param[param.length-1] + param.substr(param.length-2,2);
                      console.log("timespan src:",src);
                      src = src.replace(reParam, param);
              var target = $( "#"+id+" [src]" );
              if (target) {
                  let timespan = _getClassSuffix(ele, "mdui-timespan-" );
                  src = target.attr( "src" );
                  // flot
                  if (src.indexOf("&range=">=0)) {
                      let min = src.substr(src.indexOf("&range=")+7,20);
                      min = min.substr(0,min.indexOf("&"));
                      switch(timespan) {
                          case "inc":
                              min = min * 2;
                              break;
                          case "dec":
                              min = min / 2;
                              break;
                          default:
                              if ( timespan<=0 )
                                  timespan = 1440;
                              min = timespan;
                      src = src.replace(/&range=[0-9]*&/g, "&range="+min+"&");
                      target.attr("src",src);
                  // grafana
                  // from=now/d, from=now-1d/d
                  if (src.indexOf("from=">=0) && src.indexOf("to=">=0)) {
                      __patchParam( "from", timespan=="inc" ? +1 : -1);
                      __patchParam( "to", timespan=="inc" ? +1 : -1);
          // ersetzt im src-Attribute des Unter-Elements von (id) einen url-Parameter
          function _srcparam( ele ) {
              if (target) {
                  let params = _getClassSuffix(ele, "mdui-srcparam-" ).split("&");
                  let src = target.attr( "src" );
                  // grafana
                  // http://192.168.2.8:3000/d/ek8fMryWz/iobroker-cpu?orgId=1&from=1580383496316&to=1580405096316&var-ID_WC_Temp=20&var-ID_HZR_Temp=17&panelId=4&fullscreen
                  for (let i=0; i<params.length; i++) {
                      let key = params[i].substr(0,params[i].indexOf("="));
                      let value = params[i].substr(key.length+1,1000);
                      let re = new RegExp(key+"=[^&]*", 'g');
                      src = src.replace(re, key+"="+value);  // encodeURI()
          function _resetTable( $ele, $table ) {
              $table.find("tbody>tr").each( function(index) {
                  $(this).width("auto");
                  $(this).height("auto");
                  $(this).find("td").each( function(index) {
                      $(this).attr("labelth","");
          function _handleTable( $ele, $table, opt ) {
              function setColWidth( colwidth ) {
                      $(this).outerWidth(colwidth);
              function setColHeight() {
                  var height = 0;
                      if ($(this).height() > height ) height = $(this).height();
                  if ( height > 0 )
                          $(this).height( height );
              var innerWidth = $ele.innerWidth();
              _resetTable($ele, $table);
              if (opt.label) {
                  // Zellen mit Labels aus <th> ergänzen ?
                  var labels = [];
                  $table.find("thead>tr>th").each( function(index) {
                      labels[index] = $(this).text();
                          if (index < labels.length)
                              $(this).attr("labelth",labels[index]);
              if (opt.colwidth>1) setColWidth(opt.colwidth);
              if (opt.colwidth>2) setColHeight();
              return true;
          /* Alle mdui-table durchlaufen und überprüfen, ob die minimale Width erreicht
          wurde um sie in den responsive State zu überführen
          mdui-table-(mode)(-opt1)(-opt2)...(-optn)
          mdui-table-ascard-r600-w200-l */
          function _handleTables( ) {
              $("[class*='mdui-table-']").each( function (index) {
                  var $ele = $(this);
                  var $table;
                  $table = $ele;
                  if (!$table.is("table")) $table=$table.find("table");
                  if (!$table.is("table")) return true; // next each
                  var classes = $ele.attr("class")
                      .split(" ")
                      .filter( function ( ele ) {
                              return  (ele.indexOf("mdui-table-opt") > -1); });
                  var opts = [];
                  var opt;
                  for (var i = 0; i < classes.length; i++) {
                      opts[i] = [];
                      opts[i].reswidth = 9999;
                      opts[i].colwidth = 0;
                      opts[i].label = false;
                      opt = classes[i].substr(15,200).split("-");
                      for (var j = 0; j < opt.length; j++) {
                          switch(opt[j][0]) {
                          case "r":
                              opts[i].reswidth = parseInt(opt[j].substr(1,5));
                              break;
                          case "w":
                              opts[i].colwidth = parseInt(opt[j].substr(1,5));
                              break;
                          case "c":
                              if (opts[i].colwidth>0) opts[i].colwidth = (innerWidth-_getScrollbarWidth()) / opts[i].colwidth - 10;
                              break;
                          case "l":
                              opts[i].label = true;
                              break;
                          default:
                  opts.sort(function(a, b){return a.reswidth-b.reswidth});
                  if (opts.length === 0) return true; // next each
                  var handled = false;
                  for (i = 0; i < opts.length; i++) {
                      if ( innerWidth < opts[i].reswidth )
                         handled = _handleTable( $ele, $table, opts[i]);
                      if (handled) break;
                  if (!handled) _resetTable($ele, $table);
          /* Dialogtitle|class=mdui-red-bg|style=min-width:50%;min-height:90%; */
          function _handleDialogs( ) {
            try {
              $("[class*='ui-dialog ']").each( function (index) {
                  var $ele = $(this);
                  var $title = $ele.find("div>span[class*='ui-dialog-title']");
                  if ( ($title) && ($title.html()!=="") ) {
                     var html = '';
                     var params = $title.html().split("|");
                     var param = '';
                     for (var p = 0; p < params.length; p++) {
                         param = params[p];
                         if (param.substr(0,6)=="class=")
                            $ele.addClass(param.substr(6,1024));
                         else if (param.substr(0,6)=="style=") {
                                 var csss =  $ele.attr('style') + param.substr(6,1024);
                                 $ele.attr('style', csss );
                              } else html = html + param + " ";
                      $title.html( html );
            } catch(err) { console.log("[MDUI.handleDialogs] ", err.message ); }
          /* Aus dem "text" Input bei mdui-input-number ein "number" machen */
          function _handleInputs( ) {
            try {
              $("[class*='mdui-placeholder-']").each( function (index) {
                  let s = _getClassSuffix( $(this), "mdui-placeholder-" );
                  $(this).find("input").each( function (index) {
                      $(this)[0].placeholder = s;
              $(".mdui-input-number input").each( function () {
                  let $ele = $(this);
                  $ele[0].type = "number";
              $(".mdui-input-color input").each( function () {
                  let $ele = $(this);
                  $ele[0].type = "color";
              $(".mdui-input-date input").each( function () {
                  let $ele = $(this);
                  $ele[0].type = "date";
              $(".mdui-input-time input").each( function () {
                  let $ele = $(this);
                  $ele[0].type = "time";
            } catch(err) { console.log("[MDUI.handleInputs] ", err.message ); }
          function _handleVIS( ) { try {
              function _addHeadline(headline) {
                  return `<tr>
          <td class='mdui-value mdui-blue'>${headline}</td>
          <td></td>
          </tr>`;
              function _addRow(key, keydef, val) {
                  let icon = keydef.hasOwnProperty('icon')?keydef.icon:'';
                  return `<tr>
          <td class='mdui-subtitle' style='width:50%;'>${key}</td>
          <td class='mdui-label' style='width:50%;'>${val}</td>
          </tr>`;
              const VIS_INFO = {
                  'version':{'icon':'build'},
                  'user':{'icon':'person'},
                  'language':{'icon':'language'},
                  'instance':{'icon':'looks_one'},
                  'activeView':{'icon':'crop_square'},
                  'isTouch':{'icon':'touch_app'},
                  '__views_count':{},
                  '__states_count':{}
              const VIS_INFO_CONN = {
                  'namespace':{},
                  '_isConnected':{},
                  '_reloadInterval':{},
                  '_reconnectInterval':{}
              const HEAD = `<table style='width:100%; table-layout:fixed; word-break:break-all;'>`;
              const FOOT = `</table>`;
              vis.__views_count = Object.keys(vis.views).length;
              vis.__states_count = Math.round( Object.keys(vis.states).length / 4);
              $(".mdui-vis-info").each( function () {
                  let ele = $(this)[0];
                  let html='', key='';
                  html += _addHeadline('vis');
                  for (key in VIS_INFO)
                      html += _addRow(key,VIS_INFO[key],vis[key]);
                  html += _addHeadline('vis connection');
                  for (key in VIS_INFO_CONN)
                      html += _addRow(key,VIS_INFO_CONN[key],vis.conn[key]);
                  html += _addHeadline('views');
                  for (key in vis.views) {
                      let val=vis.views[key].hasOwnProperty('widgets')?Object.keys(vis.views[key].widgets).length:'0';
                      html += _addRow(key,{},val+' Widgets');
                  html += _addHeadline('states');
                  for (key in vis.states) {
                      if (key.includes('.val'))
                          html += _addRow(key,{},vis.states[key]);
                  ele.innerHTML = HEAD + html + FOOT;
          } catch(err) { console.log("[MDUI.handleVIS] ", err.message ); }
          // wandelt ein integer in die #rrggbb Darstellung um
          function _toRGB(n) {
              if ( (n.length>0) && ((n[0]<"0") || (n[0]>"9")) )
                  return n;
              if(n < 0) {
                  n = 0xFFFFFFFF + n + 1;
              return "#" + ("000000" + n.toString(16).toUpperCase()).substr(-6);
          // wandelt eine Farbe im hex-Format (#000000) in ein RGB-Array[2] um
          function _hexToRGB(hex) {
              var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
              return result
                  ? [parseInt(result[1],16),parseInt(result[2],16),parseInt(result[3],16)]
                  : [0,0,0];
          function _hexToRGBA(hex, transparence) {
              let RGB = _hexToRGB(hex);
              return 'rgba('+RGB[0]+','+RGB[1]+','+RGB[2]+','+transparence+')';
          function _getLuminance(r, g, b) {
              var a = [r, g, b].map(function (v) {
                  v /= 255;
                  return v <= 0.03928
                      ? v / 12.92
                      : Math.pow( (v + 0.055) / 1.055, 2.4 );
              return a[0] * 0.2126 + a[1] * 0.7152 + a[2] * 0.0722;
          function _contrast(rgb1, rgb2) {
              var l1 = _getLuminance(rgb1[0], rgb1[1], rgb1[2]) + 0.05;
              var l2 = _getLuminance(rgb2[0], rgb2[1], rgb2[2]) + 0.05;
              if ( l1 > l2 )
                  return l1 / l2
              else
                  return l2 / l1;
          // liefert die fontColor auf Basis der backgroundColor durch Berechnung
          // des Kontrasts
          function _getFontColor(bc) {
              if ( _contrast(_hexToRGB(bc),_hexToRGB("#000000")) < 6 )
                  return "#ffffff";
              else
                  return "#000000";
          // ersetzt in bekannten WIdgets schwarze und weisse Font
          function _patchWidgetColors( ) {
              let fontColor = _getFontColor( _getColorFromConfig("content_color",lastConfig.content_color,200,defConfig.content_color) );
              let isDark = fontColor=="#ffffff";
              // flot Widget
              $("#vis_container:not([style*='display: none']) iframe[src*='flot'],.ui-dialog iframe[src*='flot']").each(
                function (index) {
                  var $ele = $(this)[0];
                  var src = $ele.src;
                  src = src.replace(/&bg=%23[0-9]*&/g, "&bg=%23f00000&");
                  src = src.replace(/&x_labels_color=%23[0-9]*&/g, "&x_labels_color=%23f00000&");
                  if (isDark) {
                      src = src.replace(/%23000000/g, "%23111111");
                      src = src.replace(/%23ffffff/g, "%23000001");
                      src = src.replace(/%23111111/g, "%23fffffe");
                  } else {
                      src = src.replace(/%23000001/g, "%23111111");
                      src = src.replace(/%23fffffe/g, "%23000000");
                      src = src.replace(/%23111111/g, "%23ffffff");
                  $ele.src = src;
              // svg-clock
              /* Striche, Ticks */
              $(".svg--clock defs line").each( function (index) {
                  $(this)[0].style.stroke = fontColor;
              /* Stundenzeiger */
              $("#hands > g.hand--h").each( function (index) {
              $("#hands > g.hand--h > line").each( function (index) {
              /* Minutenzeiger */
              $("#hands > g.hand--m").each( function (index) {
              $("#hands > g.hand--m > line").each( function (index) {
              /* Ziffern */
              $(".svg--clock .svg--ticks text").each( function (index) {
                  $(this)[0].style.fill = fontColor;
              // meteoblue (Wetter)
              $("#vis_container:not([style*='display: none']) iframe[src*='meteoblue'], .ui-dialog iframe[src*='meteoblue']").each( function (index) {
                  var src = $ele.src;
                  if (isDark) {
                      src = src.replace(/layout=light/g, "layout=dark");
                  } else {
                      src = src.replace(/layout=dark/g, "layout=light");
                  $ele.src = src;
              // flot Widget
              $("#vis_container:not([style*='display: none']) iframe[src*='orgId='],.ui-dialog iframe[src*='orgId=']").each(
                  function (index) {
                    var src = $ele.src;
                    if (isDark) {
                        src = src.replace(/&theme=light/ig, "&theme=dark");
                    } else {
                      src = src.replace(/&theme=dark/ig, "&theme=light");
                    $ele.src = src;
          // holt den CSSFarbwert aus dem Colors-Array
          function _getColorFromColors( color, luminance ) {
              // colorType in Config?
              if (colors.hasOwnProperty(color) )
                  switch(luminance) {
                      case 200: color = colors[color].c200; break;
                      case 700: color = colors[color].c700; break;
                      default:  color =  colors[color].c500;
              return color;
          // wandelt den gewünschten Color-Wert in eine CSSColor um
          function _getColorFromConfig( colorType, color, luminance, defColor ) {
          //console.log("[_getColorFromConfig]:",colorType,color,luminance,defColor);
              if (lastConfig.hasOwnProperty(colorType) && colors.hasOwnProperty(lastConfig[colorType]) ) {
                      color = _getColorFromColors(lastConfig[colorType], luminance);
              // Check color
              try {
                  let $div = $("<div>");
                  $div.css("border", "1px solid "+color);
                  $div = $div.css("border-color");
                  if ( ($div=="") || ($div=="initial") ) color = _getColorFromColors(defColor,luminance);
              } catch(err) {
                  console.log( "[MDUI.getColorFromConfig] (",color,") ", err.message );
          //console.log("[_getColorFromConfig] return:",color);
              return color;
          function _setBKColor(selector, bkcolor, varname) {
              // wenn die fc=#ffffff ist, also dark-scheme, dann mdui-dark setzen
              if (_getFontColor( bkcolor )=='#ffffff') $(selector).addClass("mdui-dark")
              else $(selector).removeClass("mdui-dark");
              if (varname!="") document.documentElement.style.setProperty(varname, bkcolor);
          function _patchColors() {
             try {
                  let primary_color = defConfig.primary_color,
                      secondary_color = defConfig.secondary_color,
                  // lastConfig entladen
                  primary_color = _getColorFromConfig("primary_color",lastConfig.primary_color,500,defConfig.primary_color);
                  let abar_color=primary_color;
                  let tnav_color=primary_color;
                  let bnav_color=primary_color;
                  // abar
                  abar_color = _getColorFromConfig("abar_color",lastConfig.abar_color,700,abar_color);
                  _setBKColor('.mdui-abar',abar_color,'--abar-background');
                  // tnav
                  tnav_color = _getColorFromConfig("tnav_color",lastConfig.tnav_color,700,tnav_color);
                  _setBKColor('.mdui-tnav',tnav_color,'--tnav-background');
                  // bnav
                  bnav_color = _getColorFromConfig("bnav_color",lastConfig.bnav_color,700,bnav_color);
                  _setBKColor('.mdui-bnav',bnav_color,'--bnav-background');
                  // content
                  content_color = _getColorFromConfig("content_color",lastConfig.content_color,200,defConfig.content_color);
                  let lnav_color = content_color;
                  let rnav_color = content_color;
                  _setBKColor('.mdui-content',content_color,'--content-background');
                  _setBKColor('.ui-dialog',content_color,'');
                  _setBKColor('.ui-datepicker',content_color,'');
                  // lnav
                  lnav_color = _getColorFromConfig("lnav_color",lastConfig.lnav_color,500,lnav_color);
                  _setBKColor('.mdui-lnav',lnav_color,'--lnav-background');
                  // rnav
                  rnav_color = _getColorFromConfig("rnav_color",lastConfig.rnav_color,500,rnav_color);
                  _setBKColor('.mdui-rnav',rnav_color,'--rnav-background');
                  // secondary
                  secondary_color = _getColorFromConfig("secondary_color",lastConfig.secondary_color,500,defConfig.secondary_color);
                  document.documentElement.style.setProperty('--accent-color', secondary_color);
                  document.documentElement.style.setProperty('--accent-color-033', _hexToRGBA(secondary_color, 0.33));
                  // custom
                  let custom = _getColorFromConfig("color1",lastConfig.color1,200,defConfig.color1);
                  document.documentElement.style.setProperty('--color1', custom);
                  custom = _getColorFromConfig("color1_dark",lastConfig.color1_dark,500,defConfig.color1_dark);
                  document.documentElement.style.setProperty('--color1-dark', custom);
                  custom = _getColorFromConfig("color2",lastConfig.color2,200,defConfig.color2);
                  document.documentElement.style.setProperty('--color2', custom);
                  custom = _getColorFromConfig("color2_dark",lastConfig.color2_dark,500,defConfig.color2_dark);
                  document.documentElement.style.setProperty('--color2-dark', custom);
                  custom = _getColorFromConfig("color3",lastConfig.color3,200,defConfig.color3);
                  document.documentElement.style.setProperty('--color3', custom);
                  custom = _getColorFromConfig("color3_dark",lastConfig.color3_dark,500,defConfig.color3_dark);
                  document.documentElement.style.setProperty('--color3-dark', custom);
          //console.log("primary:",primary_color,"secondary:",secondary_color,"content:",content_color," abar:",abar_color," tnav:",tnav_color," lnav:",lnav_color);
              } catch(err) { console.log( "[MDUI.patchColors] " + err.message ); }
          function _onResizeWindow( $ele ) {
            var win = $ele; //this = window
          //console.log("[MDUI.onResizeWindow] width:",win.width());
            // lnav als fixiertes Seitenmenü?
            if (lastConfig.hasOwnProperty("lnav_fixed_width")) {
                if (win.width() >= lastConfig.lnav_fixed_width) {
                    $( "#vis_container" ).addClass("mdui-lnav-fixed");
                    // sofort öffnen?
                    if ( (lastConfig.hasOwnProperty("lnav_fixed_open")) &&
                         (lastConfig.lnav_fixed_open=="true") ) {
                        $( "#vis_container" ).addClass( "mdui-lnav-fixed-open" );
                } else {
                    $( "#vis_container" ).removeClass("mdui-lnav-fixed-open");
                    $( "#vis_container" ).removeClass("mdui-lnav-fixed");
          // swipe
          // mdui-swipe-left?dist=48&background=red&icon=delete&text=Löschen&action=setValue(demo_listitem,listitem0+swipeleft+delete)
          function _checkSwipeTo(swipeTo, swipeX) { try {
              swipeX.enabled = false;
              let s = _getSuffix( swipe.ele.className, 'mdui-swipe-'+swipeTo+'?' );
              if (!s || s=='') return;
              s = '{"'+s.replace(/:/g,'":"')+'"}';
              s = s.replace(/;/g,'","');
              s = s.replace(/\+/g,' ');
              swipeX.opt = JSON.parse(s);
              swipeX.enabled = swipeX.opt.dist!=null;
              if (swipeX.enabled) {
                  swipeX.ele = document.createElement('div');
                  swipeX.ele.style.position = 'absolute';
                  swipeX.ele.style.overflow = 'hidden';
                  swipeX.ele.style.zIndex = '32000';
                  switch (swipeTo) {
                      case 'left' :
                        swipeX.ele.style.left = (swipe.ele.offsetLeft + swipe.ele.offsetWidth - 2)+'px';
                        swipeX.ele.style.top = swipe.ele.offsetTop+'px';
                        swipeX.ele.style.height = swipe.ele.offsetHeight+'px';
                        swipeX.ele.style.width = '0px';
                        break;
                      case 'right' :
                        swipeX.ele.style.left = swipe.ele.offsetLeft + 2 +'px';
                        break;
                      case 'up' :
                        swipeX.ele.style.left = swipe.ele.offsetLeft+'px';
                        swipeX.ele.style.top = (swipe.ele.offsetTop+swipe.ele.offsetHeight-2)+'px';
                        swipeX.ele.style.height = '0px';
                        swipeX.ele.style.width = swipe.ele.offsetWidth+'px';
                        break;
                      case 'down' :
                        swipeX.ele.style.top = swipe.ele.offsetTop+2+'px';
                        break;
                  if (swipeX.opt.background) {
                      swipeX.ele.style.background = _getColorFromColors( swipeX.opt.background, swipe.isDarkTheme?500:200 );
                  swipeX.ele.style.display = 'flex';
                  swipeX.ele.style.alignItems = 'center';
                  swipeX.ele.style.justifyContent = 'center';
                  swipeX.ele.style.flexWrap = 'wrap';
                  s='';
                  if (swipeX.opt.icon)
                      s ='<div class="mdui-icon">'+swipeX.opt.icon+'</div>';
                  if (swipeX.opt.text)
                      s+= '<div style="font-size:0.7em">'+swipeX.opt.text+'</div>'
                  swipeX.ele.innerHTML=s;
                  // als sibling anhängen
                  swipe.ele.parentNode.insertBefore(swipeX.ele, swipe.ele.nextSibling);  }
              } catch(err) { console.log( "[MDUI._checkSwipeTo] " + err.message ); }
          function _swipeStart() {
              swipe.swipeLeft={enabled:false};
              swipe.swipeRight={enabled:false};
              swipe.swipeUp={enabled:false};
              swipe.swipeDown={enabled:false};
          //    swipe.ele.classList.remove('mdui-lockclick');
              lockclick = false;
              swipe.isDarkTheme = _isDarkTheme(swipe.ele);
              // auf jede swipe-Art untersuchen
              _checkSwipeTo('left',swipe.swipeLeft);
              _checkSwipeTo('right',swipe.swipeRight);
              _checkSwipeTo('up',swipe.swipeUp);
              _checkSwipeTo('down',swipe.swipeDown);
              swipe.enabled =  swipe.swipeLeft.enabled || swipe.swipeRight.enabled || swipe.swipeUp.enabled || swipe.swipeDown.enabled;
          function _swipeMove() {
              if (!swipe.enabled) return false;
              let x=0, y=0;
              const tresholdStart = 0.25;
              const tresholdEnd = 0.90;
              // welche swipes sind aktiv?
              if (swipe.swipeLeft.enabled) {
                    swipe.swipeLeft.val = swipe.clientX - swipe.fromX;
                    if ( 0-swipe.swipeLeft.val > swipe.swipeLeft.opt.dist ) swipe.swipeLeft.val = 0-swipe.swipeLeft.opt.dist;
                    swipe.swipeLeft.active = swipe.swipeLeft.val <= 0-swipe.swipeLeft.opt.dist*tresholdStart;
                    swipe.swipeLeft.swiped = swipe.swipeLeft.val <= (0-swipe.swipeLeft.opt.dist)*tresholdEnd;
                    if (swipe.swipeLeft.active) x = swipe.swipeLeft.val;
              if (swipe.swipeRight.enabled) {
                    swipe.swipeRight.val = swipe.clientX - swipe.fromX;
                    if ( swipe.swipeRight.val > swipe.swipeRight.opt.dist ) swipe.swipeRight.val = swipe.swipeRight.opt.dist;
                    swipe.swipeRight.active = swipe.swipeRight.val >= swipe.swipeRight.opt.dist*tresholdStart;
                    swipe.swipeRight.swiped = swipe.swipeRight.val >= swipe.swipeRight.opt.dist*tresholdEnd;
                    if (swipe.swipeRight.active) x = swipe.swipeRight.val;
              if (swipe.swipeUp.enabled) {
                    swipe.swipeUp.val = swipe.clientY - swipe.fromY;
                    if ( 0-swipe.swipeUp.val > swipe.swipeUp.opt.dist ) swipe.swipeUp.val = 0-swipe.swipeUp.opt.dist;
                    swipe.swipeUp.active = swipe.swipeUp.val <= 0-swipe.swipeUp.opt.dist*tresholdStart;
                    swipe.swipeUp.swiped = swipe.swipeUp.val <= (0-swipe.swipeUp.opt.dist)*tresholdEnd;
                    if (swipe.swipeUp.active) y = swipe.swipeUp.val;
              if (swipe.swipeDown.enabled) {
                    swipe.swipeDown.val = swipe.clientY - swipe.fromY;
                    if ( swipe.swipeDown.val > swipe.swipeDown.opt.dist ) swipe.swipeDown.val = swipe.swipeDown.opt.dist;
                    swipe.swipeDown.active = swipe.swipeDown.val >= swipe.swipeDown.opt.dist*tresholdStart;
                    swipe.swipeDown.swiped = swipe.swipeDown.val >= swipe.swipeDown.opt.dist*tresholdEnd;
                    if (swipe.swipeDown.active) y = swipe.swipeDown.val;
              // aktive swipes anwenden
                  if (swipe.swipeLeft.active ) {
                      swipe.swipeLeft.ele.style.width = (0-swipe.swipeLeft.val)+'px';
                      swipe.swipeLeft.ele.style.transform = 'translate('+swipe.swipeLeft.val+'px,'+y+'px)';
                      if (swipe.swipeLeft.swiped) swipe.swipeLeft.ele.style.borderRadius = '0';
                      else swipe.swipeLeft.ele.style.borderRadius = '0 5em 5em 0';
                  } else {
                      swipe.swipeLeft.ele.style.width = '0';
                  if (swipe.swipeRight.active ) {
                      swipe.swipeRight.ele.style.width = swipe.swipeRight.val+'px';
                      swipe.swipeRight.ele.style.transform = 'translate(0px,'+y+'px)';
                      if (swipe.swipeRight.swiped) swipe.swipeRight.ele.style.borderRadius = '0';
                      else swipe.swipeRight.ele.style.borderRadius = '5em 0  0 5em';
                  } else {
                       swipe.swipeRight.ele.style.width = '0';
                  if (swipe.swipeUp.active) {
                      swipe.swipeUp.ele.style.height = (0-swipe.swipeUp.val)+'px';
                      swipe.swipeUp.ele.style.transform = 'translate('+x+'px,'+swipe.swipeUp.val+'px)';
                      if (swipe.swipeUp.swiped) swipe.swipeUp.ele.style.borderRadius = '0';
                      else swipe.swipeUp.ele.style.borderRadius = '0 0 5em 5em';
                  } else {
                      swipe.swipeUp.ele.style.height = '0';
                  if (swipe.swipeDown.active ) {
                      swipe.swipeDown.ele.style.height = swipe.swipeDown.val+'px';
                      swipe.swipeDown.ele.style.transform = 'translate('+x+'px,0px)';
                      if (swipe.swipeDown.swiped) swipe.swipeDown.ele.style.borderRadius = '0';
                      else swipe.swipeDown.ele.style.borderRadius = '5em 5em 0 0';
                  } else {
                      swipe.swipeDown.ele.style.height = '0';
              if (x==0 && y==0) {
                  swipe.ele.style.transform = 'none';
                  return true;
              } else {
                  swipe.ele.style.transform = 'translate('+x+'px,'+y+'px)';
                  // nach dem 1.swipe click sperren
          //        swipe.ele.classList.add('mdui-lockclick');
                  lockclick = true;
                  return false;
          function _swipeEnd() {
              if (!swipe.enabled) return;
              if (swipe.swipeLeft.enabled) swipe.swipeLeft.ele.remove();
              if (swipe.swipeRight.enabled) swipe.swipeRight.ele.remove();
              if (swipe.swipeUp.enabled) swipe.swipeUp.ele.remove();
              if (swipe.swipeDown.enabled) swipe.swipeDown.ele.remove();
              if ( swipe.swipeLeft.swiped ) _executeAction(swipe.swipeLeft.opt.action);
              if ( swipe.swipeRight.swiped ) _executeAction(swipe.swipeRight.opt.action);
              if ( swipe.swipeUp.swiped ) _executeAction(swipe.swipeUp.opt.action);
              if ( swipe.swipeDown.swiped ) _executeAction(swipe.swipeDown.opt.action);
              swipe.enabled = false;
          function _swipeTouchStart(event, $ele) {
              let touchobj = event.originalEvent.changedTouches[0]; // erster Finger
              swipe.fromX = parseInt(touchobj.clientX);
              swipe.fromY = parseInt(touchobj.clientY);
              swipe.ele = $ele[0];
              _swipeStart();
          function _swipeTouchMove(event, $ele) {
              swipe.clientX = parseInt(touchobj.clientX);
              swipe.clientY = parseInt(touchobj.clientY);
              _swipeMove();
              event.preventDefault();
              event.stopImmediatePropagation();
          function _swipeTouchEnd(event, $ele) {
              _swipeEnd();
          function _swipeMouseDown(event, $ele) {
              if (swipe.enabled) return;
              swipe.fromX = parseInt(event.originalEvent.x);
              swipe.fromY = parseInt(event.originalEvent.y);
              _swipeStart();
              if (swipe.enabled) {
                _captureMouseEvents(_swipeMouseMove, _swipeMouseUp);
                event.stopPropagation();
          function _swipeMouseMove(event, $ele) {
              swipe.clientX = parseInt(event.originalEvent.x);
              swipe.clientY = parseInt(event.originalEvent.y);
              if (_swipeMove()) {
          function _swipeMouseUp(event, $ele) {
          console.log('_swipeMouseUp' );
              _swipeEnd();
              _releaseMouseEvents(_swipeMouseMove, _swipeMouseUp);
          function _releaseMouseEvents(move,up) {
            document.removeEventListener ('mousemove', move, true);
            document.removeEventListener ('mouseup', up, true);
          function _captureMouseEvents (move,up) {
            document.addEventListener ('mousemove', move, true);
            document.addEventListener ('mouseup', up, true);
          // click
          function _click(event, $ele) { try {
          console.log('_click');
              // durch swipe gelockt?
          if (ele.classList.contains('mdui-lockclick')) {
                  return;
              if (lockclick) {
                  lockclick=false;
                  return;
              let s = _getSuffix( $ele[0].className, 'mdui-click?' );
              let opt = JSON.parse(s);
              if (opt.action)
                  _executeAction(opt.action);
          } catch(err) { console.log( "[MDUI._click] " + err.message ); }
          // tooltip
          // mdui-tooltip?text:(text);background:(color);state:(stateid)
          function _tooltipShow(ele) { try {
              if (tooltip.timeout!=null) clearTimeout(tooltip.timeout);
              tooltip.timeout = null;
              if (tooltip.hint!=null) tooltip.hint.remove();
              tooltip.ele = ele;
              tooltip.timeout = setTimeout( () => {
                let s = _getSuffix( tooltip.ele.className, 'mdui-tooltip?' );
                tooltip.opt = JSON.parse(s);
                // text aus state ?
                if (tooltip.opt.state && vis.states.hasOwnProperty(tooltip.opt.state+'.val'))
                    tooltip.opt.text += ' ' + vis.states[tooltip.opt.state+'.val'];
                let rect = tooltip.ele.getBoundingClientRect();
                let win = tooltip.ele.ownerDocument.defaultView;
                rect.top = rect.top + win.pageYOffset,
                rect.left = rect.left + win.pageXOffset
                tooltip.hint = document.createElement('div');
                tooltip.hint.classList.add('mdui-tooltip');
                tooltip.hint.style.left = rect.left+'px';
                tooltip.hint.style.top = rect.top+'px';
                if (tooltip.opt.background)
                    tooltip.hint.style.background = _getColorFromColors( tooltip.opt.background, 500) ;
                tooltip.hint.innerHTML=tooltip.opt.text;
                document.documentElement.appendChild(tooltip.hint);
                tooltip.width = tooltip.hint.clientWidth;
                tooltip.height = tooltip.hint.clientHeight;
                let x = (rect.left-tooltip.width/2+tooltip.ele.offsetWidth/2);
                if (x<0) x = 8;
                if (x+tooltip.width > document.documentElement.clientWidth) x=document.documentElement.clientWidth - tooltip.width - 8;
                tooltip.hint.style.left = Math.floor(x)+'px';
                let y = rect.top + tooltip.ele.offsetHeight + 8;
                if (y+tooltip.height > document.documentElement.clientHeight) y= document.documentElement.clientHeight - tooltip.height - rect.height - 8;
                tooltip.hint.style.top = Math.floor(y)+'px';
                tooltip.timeout = setTimeout(_tooltipHide, 1000 + s.length * 40);
              }, 700);
          } catch(err) { console.log( "[MDUI._tooltipShow] " + err.message ); }
          function _tooltipHide() {
              if (tooltip.hint==null) return;
              tooltip.hint = null;
          function _tooltipMouseEnter(event, $ele) {
              _tooltipShow($ele[0]);
          function _tooltipMouseLeave(event, $ele) {
              _tooltipHide();
          return {
              init: _init,
              initObserverPage:_initObserverPage,
              handleToggle: _handleToggle,
              toggleFullscreen: _toggleFullscreen,
              toggleExpand: _toggleExpand,
              scale: _scale,
              timespan: _timespan,
              srcparam: _srcparam,
              handleTables: _handleTables,
              handleDialogs: _handleDialogs,
              onChangePage : _onChangePage,
              onLoad : _onLoad,
              patchColors : _patchColors,
              swipeTouchStart : _swipeTouchStart,
              swipeTouchMove : _swipeTouchMove,
              swipeTouchEnd : _swipeTouchEnd,
              swipeMouseDown : _swipeMouseDown,
              swipeMouseMove : _swipeMouseMove,
              swipeMouseUp : _swipeMouseUp,
              tooltipMouseEnter : _tooltipMouseEnter,
              tooltipMouseLeave : _tooltipMouseLeave,
              click : _click,
              onResizeWindow : _onResizeWindow
          // Eventhandler für body-Delegators setzen (früher:#vis_container)
          function mdui_init() {
              MDUI.init();
              // click-Event für das left-nav Element zum Öffnen
              $("body").on( "click", ".mdui-lnavbutton", function() {
                  // lnav als popupmenu oder fixed?
                  if ($( "#vis_container.mdui-lnav-fixed" ).length==0)
                      $( ".mdui-lnav" ).toggleClass( "mdui-lnav-open" );
                  else
                      $( "#vis_container" ).toggleClass( "mdui-lnav-fixed-open" );
              // click-Event für die left-nav zum Schließen
              $("body").on( "click", ".mdui-lnav", function() {
                      $( ".mdui-lnav" ).removeClass( "mdui-lnav-open" );
              // click-Event für das right-nav Element zum Öffnen
              $("body").on( "click", ".mdui-rnavbutton", function() {
                  $( ".mdui-rnav" ).addClass( "mdui-rnav-open" );
              // click-Event für die right-nav zum Schließen
              $("body").on( "click", ".mdui-rnav", function() {
                  $( ".mdui-rnav" ).removeClass( "mdui-rnav-open" );
              $("body").on( "click", "[class*='mdui-scale-']", function(event) {
                  MDUI.scale( $(this) );
              // click-Handler für "mdui-toggle"
              $("body").on( "click", "[class*='mdui-toggle']", function(event) {
                  MDUI.handleToggle( $(this) );
              // click-Handler für "mdui-info"
              $("body").on( "click", ".mdui-info", function(event) {
              // click-Handler für "mdui-expand"
              $("body").on( "click", "[class*='mdui-expand']", function(event) {
                  MDUI.toggleExpand( $(this) );
              // click-Handler für "mdui-fullscreen"
              $("body").on( "click", ".mdui-fullscreen", function(event) {
                  MDUI.toggleFullscreen( $(this) );
              // click-Handler für "mdui-timepsan-"
              $("body").on( "click", "[class*='mdui-timespan-']", function(event) {
                  MDUI.timespan( $(this) );
              // click-Handler für "mdui-srcparam-"
              $("body").on( "click", "[class*='mdui-srcparam-']", function(event) {
                  MDUI.srcparam( $(this) );
              // event-Handler für "mdui-swipe"
              $("body").on( "touchstart", "[class*='mdui-swipe']", function(event) {
                  MDUI.swipeTouchStart(event, $(this) );
              $("body").on( "touchmove", "[class*='mdui-swipe']", function(event) {
                  MDUI.swipeTouchMove(event, $(this) );
              $("body").on( "touchend", "[class*='mdui-swipe']", function(event) {
                  MDUI.swipeTouchEnd(event, $(this) );
              $("body").on( "mousedown", "[class*='mdui-swipe']", function(event) {
                  MDUI.swipeMouseDown(event, $(this) );
              $("body").on( "mousemove", "[class*='mdui-swipe']", function(event) {
                  MDUI.swipeMouseMove(event, $(this) );
              $("body").on( "mouseup", "[class*='mdui-swipe']", function(event) {
                  MDUI.swipeMouseUp(event, $(this) );
              // event-Handler für "mdui-click"
              $("body").on( "click", "[class*='mdui-click']", function(event) {
                  MDUI.click(event, $(this) );
              // event-Handler für tooltips
              $("body").on( "mouseenter", "[class*='mdui-tooltip']", function(event) {
                  MDUI.tooltipMouseEnter(event, $(this) );
              $("body").on( "mouseleave", "[class*='mdui-tooltip']", function(event) {
                  MDUI.tooltipMouseLeave(event, $(this) );
              $("body").on( "click", "[class*='mdui-tooltip']", function(event) {
              $( window ).on("resize", function() {
                MDUI.handleTables( $(this) );
                MDUI.onResizeWindow( $(this) );
              MDUI.initObserverPage();
              // für den ersten load einmal aufrufen
              setTimeout( MDUI.onChangePage(), 100);
          setTimeout( mdui_init(), 100);
          // vis ... Menu ausblenden
          if (typeof app !== 'undefined') $('#cordova_menu').hide();
            @sigi234 Das Script ist auch eingespielt, ich habe den ioBroker komplett neu gestartet. Keine Änderung.
            Cache im Browser geleert, auch anderen Browser getestet, keine Änderung.
              @MartyBr
              Komisch, ist es schon mal gegangen? Welche Vis Version?
                MartyBr @sigi234 last edited by MartyBr
                @sigi234 Das lief ja die ganze Zeit, genau bis heute. Bis ich auf die Idee mit dem Material Advanced Adapter gekommen bin. In der Test Umgebung hatte ich auch keine Probleme, es betrifft nur genau diese Icons / Widgets im Alarm View 😞
                VIS: 1.2.4
                Web: 3.0.9
                Kannst du mir mal ein Bewegungsmelder Widget posten? Das teste ich dann mal.
                  [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"false","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/message_presence.svg","stretch":false,"visibility-oid":"hm-rpc.1.00091A49A082FC.1.MOTION","name":"Alarm Bewegung Vorraum ok","filterkey":"Bild","class":"mdui-green-glow"},"style":{"left":"26px","top":"479px","z-index":"5","width":"79px","height":"66px"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/message_presence.svg","stretch":false,"visibility-oid":"hm-rpc.1.00091A49A082FC.1.MOTION","name":"Alarm Bewegung Vorraum red","filterkey":"Bild","class":"mdui-red-glow"},"style":{"left":"26px","top":"479px","z-index":"5","width":"79px","height":"66px"},"widgetSet":"basic"}]
                  Du weißt schon das das 2 Widgets übereinander sind!
                  M 2 Replies Last reply Reply Quote 1
                    @sigi234 Klar, über die Sichtbarkeit gesteuert. Aber eines müsste rot, das andere grün erscheinen. Beide bleiben aber weiß. Das wird die CSS Klasse -> mdui-red-glow nicht ausgewertet.
                    Kann die die Widget nicht anders färben?
                      @sigi234 Ich habe gerade gesehen, dass nach dem Neustart die alte CSS und die alte Script Einstellung wieder da sind 🤕
                      Wo kommen die denn wieder her?
                      Update: 21:07
                      CSS und Script wieder eingespielt und neue Neustart funktioniert wieder alles.
                      @sigi234
                      Vielen Dank für deine Unterstützung am Sonntag.
                      • Nashra
                        Hallo @sigi234,
                        du hast im VIEW_LGTV ein iframe drin für LiveTV, komme da aber nicht mit klar d.h.
                        wie bekomme ich da ein Bild vom TV rein, muß ich da am TV irgendwas einstellen
                        und wenn ja wo und wie. Haben erst seit dem Wochenende das Teil 😁
                          sigi234 Forum Testing Most Active @Nashra last edited by
                          @Nashra sagte in VIS von Sigi234:
                          War eine Webcam auf den TV gerichtet, habe ich zum einstellen der View so gemacht.
                          • Nashra
                            Nashra Most Active Forum Testing @sigi234 last edited by
                            @sigi234 sagte in VIS von Sigi234:
                            Ah, hatte gedacht das man eben eine Livebild hat vom eingestellte Sender.
                            Wobei das ja noch das iTüpfelchen wäre 😁
                            Danke für die Info
                              bob der 1. @Nashra last edited by
                              @Nashra
                              Mit einenm Enigma Receiver sollte es gehen.
                              Ist aich nur ein Stream.
                              • Nashra
                                Nashra Most Active Forum Testing @bob der 1. last edited by
                                @bob-der-1 sagte in VIS von Sigi234:
                                @Nashra
                                Hm, der Aufwand lohnt sich nicht 🙂
                                • Nashra
                                  Was mir gerade auffällt. Ist es normal das der LG wenn er auf StandBy ist, nicht mehr im Netzwerk ist?
                                  d.h. er lässt sich ja dann auch nicht mehr einschalten über die VIS 🤔
                                  da_Woody Garfonso 2 Replies Last reply Reply Quote 0
                                  • da_Woody
                                    da_Woody @Nashra last edited by
                                    @Nashra das haben so einige fernrseher schwachsinniger weise. auch frühere samsung glotzen konntest du nicht mehr ansprechen.
                                    • Nashra
                                      Nashra Most Active Forum Testing @da_Woody last edited by
                                      @da_Woody sagte in VIS von Sigi234:
                                      Hm der 10 Jahre alte Philips hatte das auch nicht, war jetzt nur etwas verwundert. Hatte den Neuen zuerst über WLan und jetzt über Lan angeschlossen da Kabel vorhanden. Deswegen kommen die wohl auch auf diese niedrigen Stromwerte beim Standbye obwohl ich das auch für Blödsinn halte. Ob ich jetzt 0,5 Watt oder 1 Watt verbrauch ist mir ehrlich gesagt
                                      schnuppe.
                                      • da_Woody
                                        @Nashra tja, gibt leute, die glauben, sie ersparen sich viele € bei einem W im jahr... 😉
                                        • Garfonso
                                          Garfonso Developer @Nashra last edited by
                                          @Nashra
                                          für das Problem hab ich den cec2 Adapter gebaut (allerdings bisher nur auf github, muss den mal was fertiger mache), wenn ein Raspi per HDMI an den TV angeschlossen ist, kann man den damit an/aus schalten (und noch ein paar Sachen mehr).
                                          • Nashra
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            598675
