    4. Yahka - Fehlermeldung bei KNX Einbindung/Nutzung
    UNSOLVED Yahka - Fehlermeldung bei KNX Einbindung/Nutzung
      ws][Raptor last edited by ws][Raptor
      wenn ich über den Yahka Adapter meine KNX-Rollläden steuern möchte, so laufen diese nicht. Über die eigentliche KNX App funktioniert es problemlos.
      Bei einem Neustart des Yahka Adapters kommt folgender Fehlermeldung im Log:
      yahka.0	2020-10-22 14:48:47.401	info	(20339) adding Rollladen Wohnzimmer with UUID: ba0e1bbb-bd82-45b5-aff0-014b15597102
      yahka.0	2020-10-22 14:48:47.392	info	(20339) adapter ready, checking config
      yahka.0	2020-10-22 14:48:47.354	info	(20339) starting. Version 0.11.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v12.19.0, js-controller: 3.1.6
      host.raspberrypi	2020-10-22 14:48:45.872	info	instance system.adapter.yahka.0 started with pid 20339
      host.raspberrypi	2020-10-22 14:48:45.805	info	"system.adapter.yahka.0" enabled
      host.raspberrypi	2020-10-22 14:48:45.012	info	instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-10-22 14:48:45.012	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT EventedHTTPServer [::ffff:192.168.183.45] HTTP Response is finished
      host.raspberrypi	2020-10-22 14:48:45.011	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT Accessory [Yahka] Registering Characteristic "Obstruction Detected" for events
      host.raspberrypi	2020-10-22 14:48:45.011	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT Accessory [Yahka] Registering Characteristic "Position State" for events
      host.raspberrypi	2020-10-22 14:48:45.011	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT Accessory [Yahka] Registering Characteristic "Target Position" for events
      host.raspberrypi	2020-10-22 14:48:45.011	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT Accessory [Yahka] Registering Characteristic "Current Position" for events
      host.raspberrypi	2020-10-22 14:48:45.010	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT Accessory [Yahka] Processing characteristic set: [{"aid":3,"iid":9,"ev":true},{"aid":3,"iid":10,"ev":true},{"aid":3,"iid":11,"ev":true},{"aid":
      host.raspberrypi	2020-10-22 14:48:45.010	error	Caught by controller[25]: Thu, 22 Oct 2020 12:48:26 GMT HAPServer [a9:b8:3b:e0:d9:42] HAP Request: PUT /characteristics
      host.raspberrypi	2020-10-22 14:48:45.009	error	Caught by controller[24]: Thu, 22 Oct 2020 12:48:26 GMT EventedHTTPServer [::ffff:192.168.183.45] HTTP request: /characteristics
      Kann mir jemand einen Gedankenanstoß geben wie ich dies lösen kann bzw. wo das Problem sitzt?
      Vorab vielen Dank.
      Asgothian L 3 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @ws][Raptor last edited by
        @ws-Raptor als erstes musst du das Log mal in
        </> (code) tags setzen, sonst ist das unlesbar
        so in etwa
          loverz @ws][Raptor last edited by
          @ws-Raptor zeig mir mal bitte, wie du deine Rollos in YAHKA eingebunden hast.
          Bei mir sieht es so aus:
          Geräte Typ: Window Covering
          Service Typ: Window Covering
          • Asgothian
            @ws-Raptor
            Leider ist das Log unvollständig - es sind mehrere Zeilen rechts abgeschnitten.
            Ich selber kenne einen solchen Fehler aber durchaus. Dieser kann entstehen wenn du einem Yahka Device versuchst mehrere Dienste des gleichen Typs hinzu zu fügen. Damit kann der Adapter anscheinend nicht umgehen. Ist das ggf. auch bei Dir der Fall ?
            A.
            error knx yahka
