    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
    • iomountain
      iomountain last edited by
      schön das es jetzt läuft, hab noch viel Spass mit iobroker.
      Vielleicht kannst du noch Deine Version posten und den Tread auf gelöst setzen.
      Viele Grüße
      Ralph
        ap2017 last edited by ap2017
        Have this issue with ASTRO again after adding few different lights to control by ASTRO. Same problem as before, function ASTRO is ignored by the system - nothing in debug log.
        Here is my script:
        schedule({astro: "goldenHour", shift: 0}, function () {
        console.log('astro_on_golden_hour');
        // Florida Room
        setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
        // Living
        setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, true);
        // TV Room
        setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
        // Office
        setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
        schedule({astro: "dusk", shift: 0}, function () {
        console.log('astro_on_sunset');
        // Outside
        setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, true);
        // Front Door
        setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
        schedule("30 23 * * *", function () {
        console.log('schedule_off');
        // Florida Room
        setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
        // Living
        setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, false);
        // Outside
        setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, false);
        // TV Room
        setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
        // Office
        setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
        // Front Door
        setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
        // Basement Light
        on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: true}, function (obj) {
        var value = obj.state.val;
        setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, true);
        setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, true);
        on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: false}, function (obj) {
        setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, false);
        setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, false);
          cbr last edited by cbr
          Hello everybody,
          first of all I'm new to ioBroker (I installed it on a Raspberry Pi 4 just recently).
          However I'm having a similar problem.
          I have two scripts:
          Switch by ping
          var bool_NightTime;
          function HS100_switch() {
          if (bool_NightTime == true && getState("ping.0.raspberrypi.IP").val == true) {
          setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, true);
          } else {
          setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, false);
          bool_NightTime = compareTime(getAstroDate("sunrise", undefined, 0), getAstroDate("sunset", undefined, -20), "not between", null);
          console.log(('NightTime: ' + String(('' + bool_NightTime))));
          schedule({astro: "sunset", shift: -20}, function () {
          console.log('Sonne untergegangen -20 Min');
          bool_NightTime = true;
          HS100_switch();
          schedule({astro: "sunrise", shift: 0}, function () {
          bool_NightTime = false;
          HS100_switch();
          on({id: "ping.0.raspberrypi.IP"/Rechnername/, change: "ne"}, function (obj) {
          HS100_switch();
          Switch by power
          var _const_val_PowerLimit, bool_NightTime;
          if (getState("hs100.0.IP.power").val < _const_val_PowerLimit && bool_NightTime == true && getState("fb-checkpresence.0.presence").val == true) {
          setState("hs100.0.IP.state"/HS100/, true);
          } else {
          setState("hs100.0.IP.state"/HS100/, false);
          _const_val_PowerLimit = 90;
          bool_NightTime = compareTime(getAstroDate("sunset", undefined, -20), '23:00', "between", null) && compareTime('22:30', null, "<", getAstroDate("sunset", undefined, -20));
          if (compareTime("22:30", "null", "<")) {
          HS100_switch();
          schedule("0 23 * * *", function () {
          HS100_switch();
          on({id: "hs100.0.IP.power"/HS110/, change: "ne"}, function (obj) {
          HS100_switch();
          on({id: "fb-checkpresence.0.presence"/presence/, change: "ne"}, function (obj) {
          HS100_switch();
          In both of them I use:
            /* additional code */
          However the astro function today only triggered for the "Switch by ping" script- see logfile:
          2020-04-01 19:35:27.992  - ^[[32minfo^[[39m: javascript.0 (665) script.js.common.Switch_by_ping: Sonne untergegangen -20 Min
          Yesterday it was working for both scripts. (Also the days before it was already inconsistent - however I only had the "Switch by power" script at that time.)
          I'm restarting my raspberry every night and only added the console.log by today so I cannot tell about the recent days.
          Any idea what could cause this issue?
            ap2017 @cbr last edited by
            @cbr Any luck with astro? I was not using it for a while, got back to it - same issue, works intermittent. Some days it works, some does not. Where are you located? I was thinking this is related to iobroker incorrectly interpreting my astro location settings. I am in US, most other users in Europe and they are not complaning about it.
              Thomas Braun Most Active @ap2017 last edited by Thomas Braun
              @ap2017 You have multiple triggers in you blockly. That is not possible.
              A AlCalzone 2 Replies Last reply Reply Quote 0
                ap2017 @Thomas Braun last edited by
                @Thomas-Braun What do you mean? Why?
                  @ap2017 Do you still have two purple blocks on the left side of your blockly? Please upload a screenshot of the current version.
                    @Thomas-Braun here we go, in two parts. Script works stable except for astro triggers.
                      @ap2017
                      You should have only one trigger element per action.
                      Separate it into independent blocks.
                      • AlCalzone
                        AlCalzone Developer @Thomas Braun last edited by
                        @Thomas-Braun sagte in ASTRO function. Does not work again:
                        That is not true. You can have as many as you like, but you should NEVER nest them.
                        blockly
                        7583
