    4. Raspberry startet neu
    UNSOLVED Raspberry startet neu
      Rushmed Most Active @Thomas Braun last edited by Rushmed
      @Thomas-Braun Bin mir nicht sicher ob es eingeschaltet war aber habs ausgeschaltet.
      Nun gibt
      dmesg
      Folgendes:
      pi@Servazamba:~ $ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 5.4.72-v7l+ (dom@buildbot) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #1356 SMP Thu Oct 22 13:57:51 BST 2020
      [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] On node 0 totalpages: 1012480
      [    0.000000]   DMA zone: 2304 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
      [    0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
      [    0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010176
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:67:6A:64 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirks=14cd:6116:u console=ttyS0,115200 console=tty1 root=PARTUUID=d9b3f436-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
      [    0.000000] Memory: 3654572K/4049920K available (10240K kernel code, 745K rwdata, 2836K rodata, 2048K init, 856K bss, 133204K reserved, 262144K cma-reserved, 3263488K highmem)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 31086 entries in 61 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] random: get_random_bytes called from start_kernel+0x338/0x520 with crng_init=0
      [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
      [    0.000022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
      [    0.000098] bcm2835: system timer (irq = 17)
      [    0.000737] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000752] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000768] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000780] Switching to timer-based delay loop, resolution 18ns
      [    0.001010] Console: colour dummy device 80x30
      [    0.001043] printk: console [tty1] enabled
      [    0.001096] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [    0.001117] pid_max: default: 32768 minimum: 301
      [    0.001263] LSM: Security Framework initializing
      [    0.001450] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.001472] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.002701] Disabling memory control group subsystem
      [    0.002821] CPU: Testing write buffer coherency: ok
      [    0.003311] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.004208] Setting up static identity map for 0x200000 - 0x20003c
      [    0.004415] rcu: Hierarchical SRCU implementation.
      [    0.005077] smp: Bringing up secondary CPUs ...
      [    0.006224] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.007507] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.008732] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.008886] smp: Brought up 1 node, 4 CPUs
      [    0.008903] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [    0.008916] CPU: All CPU(s) started in HYP mode.
      [    0.008928] CPU: Virtualization extensions available.
      [    0.009723] devtmpfs: initialized
      [    0.023384] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [    0.023626] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.023654] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.030277] pinctrl core: initialized pinctrl subsystem
      [    0.031324] NET: Registered protocol family 16
      [    0.035037] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.035610] audit: initializing netlink subsys (disabled)
      [    0.035859] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
      [    0.037030] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.037044] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.037360] Serial: AMBA PL011 UART driver
      [    0.040891] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.060806] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 13:59, variant start
      [    0.070823] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
      [    0.125419] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.130455] vgaarb: loaded
      [    0.130955] SCSI subsystem initialized
      [    0.131188] usbcore: registered new interface driver usbfs
      [    0.131244] usbcore: registered new interface driver hub
      [    0.131362] usbcore: registered new device driver usb
      [    0.131690] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
      [    0.133585] clocksource: Switched to clocksource arch_sys_counter
      [    0.840153] VFS: Disk quotas dquot_6.6.0
      [    0.840251] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.840446] FS-Cache: Loaded
      [    0.840636] CacheFiles: Loaded
      [    0.850833] thermal_sys: Registered thermal governor 'step_wise'
      [    0.851199] NET: Registered protocol family 2
      [    0.851925] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.851955] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.852013] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.852078] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.852216] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.852249] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.852500] NET: Registered protocol family 1
      [    0.853232] RPC: Registered named UNIX socket transport module.
      [    0.853245] RPC: Registered udp transport module.
      [    0.853258] RPC: Registered tcp transport module.
      [    0.853271] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.853291] PCI: CLS 0 bytes, default 64
      [    0.855456] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
      [    0.857611] Initialise system trusted keyrings
      [    0.857851] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      [    0.868584] FS-Cache: Netfs 'nfs' registered for caching
      [    0.869286] NFS: Registering the id_resolver key type
      [    0.869317] Key type id_resolver registered
      [    0.869330] Key type id_legacy registered
      [    0.869353] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.870421] Key type asymmetric registered
      [    0.870434] Asymmetric key parser 'x509' registered
      [    0.870626] bounce: pool size: 64 pages
      [    0.870681] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.870901] io scheduler mq-deadline registered
      [    0.870915] io scheduler kyber registered
      [    0.874872] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    0.874896] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      [    0.874967] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
      [    0.875039] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
      [    0.935708] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
      [    0.936012] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    0.936031] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    0.936051] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
      [    0.936109] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    0.936376] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    0.939631] PCI: bus0: Fast back to back transfers disabled
      [    0.939873] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    0.940021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    0.940453] pci 0000:01:00.0: PME# supported from D0 D3cold
      [    0.943733] PCI: bus1: Fast back to back transfers disabled
      [    0.943791] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    0.943814] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    0.943896] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    0.943920] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    0.944243] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [    0.944470] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
      [    0.944849] pcieport 0000:00:00.0: AER: enabled with IRQ 56
      [    0.945187] pci 0000:01:00.0: enabling device (0140 -> 0142)
      [    0.949672] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
      [    0.952685] iproc-rng200 fe104000.rng: hwrng registered
      [    0.953027] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
      [    0.953716] vc-sm: Videocore shared memory driver
      [    0.954281] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    0.966188] brd: module loaded
      [    0.978307] loop: module loaded
      [    0.979706] Loading iSCSI transport class v2.0-870.
      [    0.981681] libphy: Fixed MDIO Bus: probed
      [    0.982289] bcmgenet fd580000.ethernet: failed to get enet clock
      [    0.982309] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    0.982332] bcmgenet fd580000.ethernet: failed to get enet-wol clock
      [    0.982353] bcmgenet fd580000.ethernet: failed to get enet-eee clock
      [    0.982381] bcmgenet: Skipping UMAC reset
      [    0.993627] libphy: bcmgenet MII bus: probed
      [    1.073717] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.074722] usbcore: registered new interface driver r8152
      [    1.074801] usbcore: registered new interface driver lan78xx
      [    1.074858] usbcore: registered new interface driver smsc95xx
      [    1.075276] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.075309] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    1.077911] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
      [    1.079184] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
      [    1.079202] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.079218] usb usb1: Product: xHCI Host Controller
      [    1.079233] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
      [    1.079248] usb usb1: SerialNumber: 0000:01:00.0
      [    1.079857] hub 1-0:1.0: USB hub found
      [    1.079953] hub 1-0:1.0: 1 port detected
      [    1.080523] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.080549] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    1.080573] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.081103] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
      [    1.081121] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.081137] usb usb2: Product: xHCI Host Controller
      [    1.081152] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
      [    1.081167] usb usb2: SerialNumber: 0000:01:00.0
      [    1.081753] hub 2-0:1.0: USB hub found
      [    1.081848] hub 2-0:1.0: 4 ports detected
      [    1.083317] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.083673] dwc_otg: FIQ enabled
      [    1.083686] dwc_otg: NAK holdoff enabled
      [    1.083698] dwc_otg: FIQ split-transaction FSM enabled
      [    1.083714] Module dwc_common_port init
      [    1.084178] usbcore: registered new interface driver uas
      [    1.084293] usbcore: registered new interface driver usb-storage
      [    1.084482] mousedev: PS/2 mouse device common for all mice
      [    1.086341] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.089738] sdhci: Secure Digital Host Controller Interface driver
      [    1.089750] sdhci: Copyright(c) Pierre Ossman
      [    1.090356] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [    1.091001] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.094759] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.095065] hidraw: raw HID events driver (C) Jiri Kosina
      [    1.095259] usbcore: registered new interface driver usbhid
      [    1.095271] usbhid: USB HID core driver
      [    1.096247] vchiq: vchiq_init_state: slot_zero = (ptrval)
      [    1.097765] [vc_sm_connected_init]: start
      [    1.103982] [vc_sm_connected_init]: end - returning 0
      [    1.106210] Initializing XFRM netlink socket
      [    1.106248] NET: Registered protocol family 17
      [    1.106348] Key type dns_resolver registered
      [    1.106816] Registering SWP/SWPB emulation handler
      [    1.107117] registered taskstats version 1
      [    1.107135] Loading compiled-in X.509 certificates
      [    1.107677] Key type ._fscrypt registered
      [    1.107691] Key type .fscrypt registered
      [    1.118248] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.118332] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
      [    1.124951] printk: console [ttyS0] disabled
      [    1.125028] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 30, base_baud = 62500000) is a 16550
      [    1.125097] printk: console [ttyS0] enabled
      [    1.125845] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.126822] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.126837] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.178526] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    1.180184] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.181852] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.185454] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.187127] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.193910] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      [    1.197020] of_cfs_init
      [    1.197143] of_cfs_init: OK
      [    1.197967] Waiting for root device PARTUUID=d9b3f436-02...
      [    1.232383] random: fast init done
      [    1.255818] mmc1: new high speed SDIO card at address 0001
      [    1.443625] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.626257] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    1.626275] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.626291] usb 1-1: Product: USB2.0 Hub
      [    1.627948] hub 1-1:1.0: USB hub found
      [    1.628284] hub 1-1:1.0: 4 ports detected
      [    1.774043] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
      [    1.808922] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
      [    1.808940] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
      [    1.808956] usb 2-1: Product: ASM105x
      [    1.808971] usb 2-1: Manufacturer: ASMedia
      [    1.808987] usb 2-1: SerialNumber: 2013E3F26E9A
      [    1.832164] scsi host0: uas
      [    1.837448] scsi 0:0:0:0: Direct-Access     ASMedia  ASM105x          0    PQ: 0 ANSI: 6
      [    1.839086] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
      [    1.839261] sd 0:0:0:0: [sda] Write Protect is off
      [    1.839279] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
      [    1.839585] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      [    1.840244] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
      [    1.842761]  sda: sda1 sda2
      [    1.845516] sd 0:0:0:0: [sda] Attached SCSI disk
      [    1.861554] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [    1.861627] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [    1.862046] devtmpfs: mounted
      [    1.870642] Freeing unused kernel memory: 2048K
      [    1.903901] Run /sbin/init as init process
      [    1.953653] usb 1-1.4: new high-speed USB device number 3 using xhci_hcd
      [    2.086642] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
      [    2.086661] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    2.086678] usb 1-1.4: Product: USB2.0 Hub
      [    2.086694] usb 1-1.4: Manufacturer: GenesysLogic
      [    2.088399] systemd[1]: System time before build time, advancing clock.
      [    2.089334] hub 1-1.4:1.0: USB hub found
      [    2.089815] hub 1-1.4:1.0: 4 ports detected
      [    2.140022] NET: Registered protocol family 10
      [    2.141367] Segment Routing with IPv6
      [    2.162085] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    2.162863] systemd[1]: Detected architecture arm.
      [    2.235078] systemd[1]: Set hostname to <Servazamba>.
      [    2.413732] usb 1-1.4.3: new full-speed USB device number 4 using xhci_hcd
      [    2.560506] usb 1-1.4.3: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
      [    2.560525] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    2.560542] usb 1-1.4.3: Product: CC2538 USB CDC
      [    2.560558] usb 1-1.4.3: Manufacturer: Texas Instruments
      [    2.663681] usb 1-1.4.4: new full-speed USB device number 5 using xhci_hcd
      [    2.730363] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
      [    2.731864] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
      [    2.735758] systemd[1]: Configuration file /etc/systemd/system/wetterstation.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    2.805920] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
      [    2.833049] usb 1-1.4.4: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
      [    2.833067] usb 1-1.4.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
      [    2.833083] usb 1-1.4.4: Product: CSR8510 A10
      [    2.834391] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
      [    2.936588] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.956629] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.959148] systemd[1]: Listening on Journal Socket (/dev/log).
      [    2.959576] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.959913] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    3.065561] i2c /dev entries driver
      [    3.523883] EXT4-fs (sda2): re-mounted. Opts: (null)
      [    3.621794] systemd-journald[112]: Received request to flush runtime journal from PID 1
      [    4.193274] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      [    4.197322] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
      [    4.200273] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      [    4.204411] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      [    4.249039] mc: Linux media interface: v0.10
      [    4.261136] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.276492] videodev: Linux video capture interface: v2.00
      [    4.276541] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    4.277348] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.279322] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.279343] [vc_sm_connected_init]: start
      [    4.290778] [vc_sm_connected_init]: installed successfully
      [    4.301593] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.303435] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.307278] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.310605] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.334065] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    4.334469] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    4.334879] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    4.335208] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    4.335233] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    4.335256] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    4.335283] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    4.335324] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    4.335517] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    4.339589] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.365300] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    4.365350] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    4.375386] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    4.375434] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    4.380170] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    4.380209] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    4.620948] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    4.648066] Bluetooth: Core ver 2.22
      [    4.648157] NET: Registered protocol family 31
      [    4.648171] Bluetooth: HCI device and connection manager initialized
      [    4.648196] Bluetooth: HCI socket layer initialized
      [    4.648216] Bluetooth: L2CAP socket layer initialized
      [    4.648247] Bluetooth: SCO socket layer initialized
      [    4.722152] usbcore: registered new interface driver btusb
      [    4.734911] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    4.771149] cdc_acm 1-1.4.3:1.0: ttyACM0: USB ACM device
      [    4.772581] usbcore: registered new interface driver cdc_acm
      [    4.772595] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    4.820047] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    4.851694] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    4.866704] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    4.867577] usbcore: registered new interface driver brcmfmac
      [    4.871278] sd 0:0:0:0: Attached scsi generic sg0 type 0
      [    4.876453] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
      [    5.036057] [drm] No displays found. Consider forcing hotplug if HDMI is attached
      [    5.036173] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [    5.036194] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
      [    5.036207] [drm] No driver support for vblank timestamp query.
      [    5.036219] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
      [    5.056289] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    5.122897] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.137804] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
      [    6.675954] random: crng init done
      [    6.675970] random: 7 urandom warning(s) missed due to ratelimiting
      [    7.530091] 8021q: 802.1Q VLAN Support v1.8
      [    7.543725] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [    7.543741] Bluetooth: BNEP filters: protocol multicast
      [    7.543768] Bluetooth: BNEP socket layer initialized
      [    7.843786] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
      [    7.926460] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [    8.281943] Bluetooth: RFCOMM TTY layer initialized
      [    8.281962] Bluetooth: RFCOMM socket layer initialized
      [    8.281987] Bluetooth: RFCOMM ver 1.11
      [    8.320199] bcmgenet: Skipping UMAC reset
      [    8.322739] bcmgenet fd580000.ethernet: configuring instance for external RGMII
      [    8.328426] bcmgenet fd580000.ethernet eth0: Link is Down
      [   12.473724] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [   12.473761] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   13.466380] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      [   13.677603] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        Thomas Braun Most Active @Rushmed last edited by Thomas Braun
        @Rushmed sagte in Raspberry startet neu:
        Würde ich mir mal anschauen.
        Warum läuft da ein xrdp? Würde ich ausschalten. Zusammen mit dem kompletten X-server.
        Irgendwas über i2c aktiv? Ansonsten abschalten.
        Da scheint mir noch eine ganze Menge an vermutlich überflüssigem Zeug zu laufen. samba sehe ich da auch noch.
        Beim Aufsetzen des Systems einfach mal auf Verdacht alles aktiviert?
          hans_999 @Rushmed last edited by
          @Rushmed said in Raspberry startet neu:
          in letzter Zeit, es könnte mit dem Umstieg auf eine SSD als Bootplatte zusammenhängen, startet mein Pi unregelmäßig etwa einmal alle acht Tage neu
          Was hast du denn für eine Stromversorgung am PI? 5V? 5V1?
          Hast du schon einmal das kernel log nach Meldungen "Under-voltage" durchsucht?
          https://forum.iobroker.net/topic/31937/pi-verliert-lan-nicht-erreichbar/34
            @Thomas-Braun sagte in Raspberry startet neu:
            Das ist das Script zum Einbinden meiner Wetterstation, das muss ausführbar sein.
            Ich muss manchmal meinen Windows Rechner nutzen um auf den Desktop des Raspi zu kommen. Kann ich den X-Server deaktiviern und XRDP weiter nutzen?
            Das ist im Prinzip noch meine erste Raspi Installation von vor einem Jahr. Habe damals nur istalliert was ich heute noch nutze:
            • ioBroker
            • InfluxDB
            • Grafana
            • Plex
            • das Script für die Wetterstation
              und Wiring Pi nach dieser Anleitung. Ob die 433 MHz Sender und Empfänger die ich an den GPIOS habe per i2C gesterert werden kann ich garnicht sagen.
              SMB habe ich auch eingerichtet um von Windows auf den Raspi zuzugreifen.
            @hans_999 sagte in Raspberry startet neu:
            Am Raspi habe ich ein 5V Netzteil, der USB Adapter für die SSD ist ebenfalls mit Spannung versorgt. Im Log ist nichts "voltage" enthaltendes.
              Desktop des Raspi
              Auf dem Raspi läuft in einer gescheiten Installation kein Desktop. Und deswegen auch kein rdp oder sowas.
                @Thomas-Braun Das mag ja sein, ich bin halt ahnungslos und brauche es manchmal als fallback.
                Meinst du dass die XRDP Installation etwas mit den Neustarts zu tun hat?
                  @Rushmed
                  Möglich...
                  Ist halt unnötiger zusätzlicher Code, der abstürzen kann und dir die dringend anderweitig benötigten Ressourcen auf dem kleinen Ding klaut.
                  Mir ist auch nicht ganz klar, wozu man auf dem Server einen Desktop braucht? Per SSH auf die Kiste drauf und in der Kommandozeile hantieren, bzw. so Dinge wie der ioBroker wird eh über http /webfrontend verwaltet.
                  In system.d legt man als service auch keine ausführbaren skripte ab.
                  Ich weiß nicht wo das herkommt, hört sich aber falsch an. Da linkt man höchstens auf entsprechendes.
                    @Thomas-Braun Danke für deine Antwort aber dass ist so nicht zielführend.
                    Meine eingehende Frage war wie ich die Ursache meiner Abstürze herausfinden kann.
                      @Rushmed
                      Alles unnötige ausknipsen und dann beobachten.
                        @Thomas-Braun In meinen Augen ist alles unnötige aus.
                        Angenommen ich schalte jetzt weiter Sachen aus und dann habe ich wieder einen Neustart, wie finde ich dann die Ursache?
                          In meinen nicht. Zum debuggen halt alles auf das minimum herunterfahren. Im Serverbetrieb ohnehin nichts unnötiges laufen haben.
                          Kommt auf die Ursache an. /var/log/messages ist aber ein guter Anlaufpunkt.
                          dmesg
                          kann man auch mal in Auge behalten, oft meckert da irgendwer schon frühzeitig.
                          • MichMein
                            MichMein last edited by
                            @Rushmed hi, ich hatte vor einiger Zeit bei gleicher Hardware Konfiguration auch Probleme mit einem einfrieren des Systems. Zuerst habe ich einen neuen SATA Adapter besorgt, das brachte aber keinen Erfolg. Letztendlich habe ich ein Image meiner SSD erstellt und das dann auf eine nagelneue SSD zurück geschrieben und seitdem habe ich keine Abstürze mehr, dies ist jetzt zweieinhalb Wochen her. Vorher war es ca. alle 5 bis 7 Tage, von daher gehe ich davon aus das die alte SSD nen Schuss hatte.
                              Rushmed Most Active last edited by
                              Ich danke euch, ich werd die Sache weiter verfolgen nachdem ich ja jetzt schon etwas deaktiviert hab.
                              dmsg und /var/log/messages sind solche Tipps nach denen ich gesucht habe.
                              @MichMein Ich vermute auch ein Hardwareproblem gerade weil das System vor der SSD fehlerfrei lief.
                              Ist deine SSD per USB angeschlossen? Hast du eine extra Spannungsversorgung an deinem SSD Adapter?
                              MichMein Thomas Braun 2 Replies Last reply Reply Quote 0
                              • MichMein
                                MichMein @Rushmed last edited by
                                @Rushmed ja per USB aber ohne extra Spannungsversorgung.
                                  Aber nicht die dicken Brocken.
                                  Wie ist der Raspi eigentlich an RAM ausgestattet? Wenigstens die Version mit 4 oder 8 GB?
                                    @Thomas-Braun 4 GB, die Auslastung im normalen Betrieb ist im Bild vom ersten Post zu sehen.
                                    Nach reiflicher überlegung werd heute Abend I2c deaktivieren.
                                      @Rushmed Lass doch die Kiste dauerhaft im runlevel 3 laufen und wenn es denn unbedingt als notwendig betrachtet wird da mit rdpd oder sowas zu hantieren startest du den runlevel 5 nur kurz dafür.
                                        Homoran Global Moderator Administrators @Rushmed last edited by
                                        habe ioBroker auf einem Pi4 laufen
                                        Ist es das???
                                        Dann brauche ich aber Nachhilfe wie ein Pi4 mit 3,5 MHz getaktet werden kann.
                                        Solltest du den tatsächlich soweit übertakten wundert mich ein Absturz überhaupt nicht
                                          Rushmed Most Active @Homoran last edited by
                                          @Homoran Jepp ist es. Jetzt wo du es erwähnst kommt es mir auch komisch vor aber der Wert kommt bis auf ein Bisschen Umrechnung der Einheit aus rpi2.0.cpu.load1. Die 3,5 GHz sind ja nur ein Spitzenwert aber 1,7 GHz average... muss ne gute Charge gewesen sein😊. Übertaktet ist hier garnichts. Das behalt ich mal im Auge. Ich hatte eigentlich wegen der RAM Auslastung auf die Grafik verwiesen.
                                          @Thomas-Braun Die Kiste läuft bereits im RL3 und I2C ist auch nicht aktiviert.
                                            das sind keine CPU frequency, sondern eben die Load, also Auslastung der I/O Prozesse und der Prozessorlast.
                                            Wenn du die irgendwoher pro Kern bekommst sollte die nie über 1 gehen.
                                            Üblicherweise wird die LOAD aber gesamt angegeben und da darf es bei einem 4-Kerner auch mal bis 4 hochgehen.
                                            Die Load hat keine Einheit!
                                            Wenn der Wert wirklich auf einen Kern bezogen ist kann der Pi natürlich bei einer LOAD average von 6 zeitweise keine Prozesse mehr zeitnah abarbeiten. Wenn das zu lange dauert, kann auch mal der ein oder andere Prozess beendet werden oder bei iobroker auch der Controller mal neu starten.
                                            Das ist dein Problem.
                                            Wenn andere Werte aber besser geeignet sind um Probleme zu erkennen, darf man sie nicht ausser Acht lassen.
                                            neustart problem raspberry
                                            1248
