    4. Test Adapter Calendar v1.2.x
    • J.A.R.V.I.S.
      J.A.R.V.I.S. Developer @Bostil last edited by
      @Bostil vergangene Termine werden aktuell nicht unterstützt.
      • da_Woody
        da_Woody @Bostil last edited by
        @Bostil nur um zu verstehn? wozu soll das gut sein?
          HoffmannOs last edited by
          Ich erhalte beim Einrichten immer folgenden fehler :
          host.iobroker	2020-09-22 12:27:46.852	error	instance system.adapter.calendar.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker	2020-09-22 12:27:46.852	error	Caught by controller[0]: }
          host.iobroker	2020-09-22 12:27:46.852	error	Caught by controller[0]: requestPath: 'rrule'
          host.iobroker	2020-09-22 12:27:46.852	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/rrule/package.json',
          host.iobroker	2020-09-22 12:27:46.852	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.iobroker	2020-09-22 12:27:46.852	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32) {
          host.iobroker	2020-09-22 12:27:46.852	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.calendar/lib/vevent.js:2:22)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:952:27)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:682:18)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:321:19)
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/rrule/dist/es5/rrule.js'. Please verify that the package.json has a valid "main" entry
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: ^
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: throw err;
          host.iobroker	2020-09-22 12:27:46.851	error	Caught by controller[0]: internal/modules/cjs/loader.js:329
          J.A.R.V.I.S. 1 Reply Last reply Reply Quote 0
          • J.A.R.V.I.S.
            J.A.R.V.I.S. Developer @HoffmannOs last edited by
            @HoffmannOs da scheint eine Abhängigkeit nicht installiert worden zu sein.
            Hast du den Adapter schon einmal komplett deinstalliert und wieder neuinstalliert?
              HoffmannOs @J.A.R.V.I.S. last edited by
              @J-A-R-V-I-S ja habe ich versucht. keine veränderung
                m0skit0 last edited by
                ich habe mir einen Nextcloud Kalender eingerichtet und möchte nun meine Kalenderdaten in den iobroker einfügen.
                Ich habe mir soweit wie möglich alles in diesem Post herraus gefiltert, was mit der nextcloud und diesem Adapter zu tun hat, leider bin ich immer noch nicht dahinter gekommen was ich in den FQDN und Port Einstellungne eintragen soll.
                Ich arbeite mit einen Proxmox Server , vieleicht kann mir ja jemand von Euch auf die Sprünge helfen wie man das einrichtet.
                Ich wäre Euch sehr dankbar.
                Lg
                m0skit0
                • J.A.R.V.I.S.
                  @HoffmannOs ich habe den Adapter bei einem Testsystem (Windows) einmal neuinstalliert. Da hat alles soweit gepasst.
                  Kannst du einmal schauen ob folgender Ordner bzw. Datei existiert: /opt/iobroker/node_modules/rrule/dist/es5/rrule.js bzw. /opt/iobroker/node_modules/iobroker.calendar/node_modules/rrule/dist/es5/rrule.js
                  • J.A.R.V.I.S.
                    J.A.R.V.I.S. Developer @m0skit0 last edited by
                    @m0skit0 schau dir mal diesen Post an https://forum.iobroker.net/topic/28663/test-adapter-calendar-v1-2-x/232
                    Mehr benötigst du für Nextcloud nicht.
                    Falls du weitere Hilfe benötigst, meld dich einfach.
                      m0skit0 @J.A.R.V.I.S. last edited by m0skit0
                      @J-A-R-V-I-S
                      vielen vielen Dank für die Hilfe.
                      ich bekomme immer den Fehler 401 was ist das ?
                      lg
                      m0skit0
                      • J.A.R.V.I.S.
                        @m0skit0 das ist ein HTTP-Statuscode. Der Code bedeuted, dass die Anfrage nicht ohne Authentifizierung durchgeführt werden kann.
                        Hast du einen Benutzernamen und Kennwort angegeben?
                          @J-A-R-V-I-S
                          ja Benutzer und Kennwort sind korrekt eingegeben .
                          • D3ltoroxp
                            D3ltoroxp last edited by
                            Guten Abend, habe hier schon etwas länger nicht mehr reingeschaut, viel um die Ohren. Gibts hier irgendwas neues bezüglich Geburtstage usw ? Das man die direkt bekommt ? Oder muss ich das nach wie vor aus den einzelnen Terminen rausfiltern ? Auch andere Events usw ?
                            Abfall hab ich mir jetzt über ein Script raus geholt, das klappt ganz gut.
                            • wendy2702
                              wendy2702 last edited by
                              jemand eine Idee was mir das im log sagt wenn ich versuche einen Nextcloud calender auszulesen:
                              calendar.0	2020-10-28 20:23:18.174	error	(25555) VCalendarError: <constructor> <parse> Unknown RRULE property 'Europe'
                              Als Objekte sehe ich nur das:
                              • D3ltoroxp
                                Hätte jemand nen Script, men dem ich mir für die vis die Geburtstage holen kann, Name und vllt das Alter dazu ?
                                • da_Woody
                                  da_Woody @D3ltoroxp last edited by
                                  @D3ltoroxp geburtstagskalender als instanz und gut ists. basic - table, objectID ical.x.data.table
                                  • D3ltoroxp
                                    D3ltoroxp @da_Woody last edited by D3ltoroxp
                                    Also neue instanz von diesem Adapter und dort nur den Geburtstags rein ?
                                    @da_Woody said in Test Adapter Calendar v1.2.x:
                                    Da komm ich leider noch nicht ganz mit ? Solche Objekte habe ich nicht im Adapter.
                                    EDIT: Du meinst ical instanz ? Hm wollte aber eigentlich wenn dann nur ein Adapter für Kalender nutzen. Müsste hier doch auch irgendwie gehen ?
                                    • da_Woody
                                      da_Woody @D3ltoroxp last edited by da_Woody
                                      @D3ltoroxp na woher willst du die geburtstage bekommen?
                                      ah, sorry, übersehn. ich verwend den google kalender...
                                      • D3ltoroxp
                                        @da_Woody Ich nutze ja auch den Google Kalender, dort habe ich mehrere Gruppen erstellt, Müll, Geburtstag usw.
                                        Diese habe ich alle im Calendar Adapter geadded, aber es ist nicht so einfach die Daten da jetzt sauber für ne VIS heraus zu bekommen.
                                        Du nutzt den ical Adapter, wenn ich das richtig verstanden habe ?
                                        • da_Woody
                                          @D3ltoroxp genau
                                          so als schnelles beispiel
                                          bergjet 1 Reply Last reply Reply Quote 1
                                          • bergjet
                                            bergjet @da_Woody last edited by bergjet
                                            Hallo, ich bekomme den Adapter nicht richtig zum laufen.
                                            Ich möchte einen Mac ical einbinden. Dazu habe ich den selben Pfad wie beim ical-Adapter eingegeben.
                                            Ich bekomme jedoch nur die Fehlermeldung.
                                            Und die Datenpunkte sind leer.
                                            Was mache ich da falsch?
                                            31.7k
                                            79.8k
                                            adapter calendar google kalender test tester
                                            47
                                            379
                                            51965
