    4. VIS von Sigi234
    VIS von Sigi234
      MartyBr @sigi234 last edited by MartyBr
      @sigi234 Das lief ja die ganze Zeit, genau bis heute. Bis ich auf die Idee mit dem Material Advanced Adapter gekommen bin. In der Test Umgebung hatte ich auch keine Probleme, es betrifft nur genau diese Icons / Widgets im Alarm View 😞
      VIS: 1.2.4
      Web: 3.0.9
      Kannst du mir mal ein Bewegungsmelder Widget posten? Das teste ich dann mal.
        sigi234 Forum Testing Most Active @MartyBr last edited by sigi234
        @MartyBr sagte in VIS von Sigi234:
        [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"false","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/message_presence.svg","stretch":false,"visibility-oid":"hm-rpc.1.00091A49A082FC.1.MOTION","name":"Alarm Bewegung Vorraum ok","filterkey":"Bild","class":"mdui-green-glow"},"style":{"left":"26px","top":"479px","z-index":"5","width":"79px","height":"66px"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/message_presence.svg","stretch":false,"visibility-oid":"hm-rpc.1.00091A49A082FC.1.MOTION","name":"Alarm Bewegung Vorraum red","filterkey":"Bild","class":"mdui-red-glow"},"style":{"left":"26px","top":"479px","z-index":"5","width":"79px","height":"66px"},"widgetSet":"basic"}]
        Du weißt schon das das 2 Widgets übereinander sind!
        M 2 Replies Last reply Reply Quote 1
          @sigi234 Klar, über die Sichtbarkeit gesteuert. Aber eines müsste rot, das andere grün erscheinen. Beide bleiben aber weiß. Das wird die CSS Klasse -> mdui-red-glow nicht ausgewertet.
          Kann die die Widget nicht anders färben?
            @sigi234 Ich habe gerade gesehen, dass nach dem Neustart die alte CSS und die alte Script Einstellung wieder da sind 🤕
            Wo kommen die denn wieder her?
            Update: 21:07
            CSS und Script wieder eingespielt und neue Neustart funktioniert wieder alles.
            @sigi234
            Vielen Dank für deine Unterstützung am Sonntag.
            • Nashra
              Hallo @sigi234,
              du hast im VIEW_LGTV ein iframe drin für LiveTV, komme da aber nicht mit klar d.h.
              wie bekomme ich da ein Bild vom TV rein, muß ich da am TV irgendwas einstellen
              und wenn ja wo und wie. Haben erst seit dem Wochenende das Teil 😁
                sigi234 Forum Testing Most Active @Nashra last edited by
                @Nashra sagte in VIS von Sigi234:
                War eine Webcam auf den TV gerichtet, habe ich zum einstellen der View so gemacht.
                • Nashra
                  Nashra Most Active Forum Testing @sigi234 last edited by
                  @sigi234 sagte in VIS von Sigi234:
                  Ah, hatte gedacht das man eben eine Livebild hat vom eingestellte Sender.
                  Wobei das ja noch das iTüpfelchen wäre 😁
                  Danke für die Info
                    bob der 1. @Nashra last edited by
                    @Nashra
                    Mit einenm Enigma Receiver sollte es gehen.
                    Ist aich nur ein Stream.
                    • Nashra
                      Nashra Most Active Forum Testing @bob der 1. last edited by
                      @bob-der-1 sagte in VIS von Sigi234:
                      @Nashra
                      Hm, der Aufwand lohnt sich nicht 🙂
                      • Nashra
                        Was mir gerade auffällt. Ist es normal das der LG wenn er auf StandBy ist, nicht mehr im Netzwerk ist?
                        d.h. er lässt sich ja dann auch nicht mehr einschalten über die VIS 🤔
                        da_Woody Garfonso 2 Replies Last reply Reply Quote 0
                        • da_Woody
                          da_Woody @Nashra last edited by
                          @Nashra das haben so einige fernrseher schwachsinniger weise. auch frühere samsung glotzen konntest du nicht mehr ansprechen.
                          • Nashra
                            Nashra Most Active Forum Testing @da_Woody last edited by
                            @da_Woody sagte in VIS von Sigi234:
                            Hm der 10 Jahre alte Philips hatte das auch nicht, war jetzt nur etwas verwundert. Hatte den Neuen zuerst über WLan und jetzt über Lan angeschlossen da Kabel vorhanden. Deswegen kommen die wohl auch auf diese niedrigen Stromwerte beim Standbye obwohl ich das auch für Blödsinn halte. Ob ich jetzt 0,5 Watt oder 1 Watt verbrauch ist mir ehrlich gesagt
                            schnuppe.
                            • da_Woody
                              @Nashra tja, gibt leute, die glauben, sie ersparen sich viele € bei einem W im jahr... 😉
                              • Garfonso
                                Garfonso Developer @Nashra last edited by
                                @Nashra
                                für das Problem hab ich den cec2 Adapter gebaut (allerdings bisher nur auf github, muss den mal was fertiger mache), wenn ein Raspi per HDMI an den TV angeschlossen ist, kann man den damit an/aus schalten (und noch ein paar Sachen mehr).
                                • Nashra
                                  • Nashra
                                    Nashra Most Active Forum Testing @Garfonso last edited by
                                    @Garfonso sagte in VIS von Sigi234:
                                    @Nashra
                                    Das hört sich ja mal gut an und Raspi's hab ich hier noch ein paar rumliegen 🙂
                                      jwerlsdf @sigi234 last edited by
                                      @sigi234
                                      vielen Dank für deine Views!!! Tolle Arbeit. Würdest du mir bitte die Icons von folgendes Views zur Verfügung stellen?
                                      View-IT, View-WebSpeedy, View-Netzwerkstatus
                                        sigi234 Forum Testing Most Active @jwerlsdf last edited by sigi234
                                        @jwerlsdf sagte in VIS von Sigi234:
                                        @sigi234
                                        Zeig mal Screenshots davon wie es bei dir aussieht.
                                        Edit:
                                        Icons View-Netzwerkstatus hinzugefügt
                                        View-IT:
                                        Da brauchst du Widgetsset icons-mfd-svg und icons-mfd-png und:
                                          jwerlsdf @sigi234 last edited by jwerlsdf
                                          @sigi234
                                          Vielen Dank. Mir haben wohl einige Adapter gefehlt.
                                          Nachinstalliert und nu geht es. Nur eines geht noch nicht: Ich sehe keine Schrift für den Speedtest (starte Speedtest???). Die Farbe ist in Rot?!
                                            Dragon @sigi234 last edited by
                                            @sigi234 DU hast in der einen Vis so lustige Mülltonnen mit Gesicht und Armen verwendet. Könntest du mir sagen wo ich die her bekomme oder sie zur Verfügung stellen?
                                            LG
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            599456
