    4. Test Adapter Plex v0.8.x
      sigi234 Forum Testing Most Active @Zefau last edited by
      @Zefau
      Hallo, seit einen Update auf Admin 4.0.5, Web 3.0.1 und socketio 3.0.1 geht der Adapter nicht mehr:
      plex.0	2020-02-24 15:14:34.546	info	(14916) Terminated (NO_ERROR): Without reason
      plex.0	2020-02-24 15:14:34.545	info	(14916) terminating
      plex.0	2020-02-24 15:14:34.544	info	(14916) Adapter stopped und unloaded.
      plex.0	2020-02-24 15:14:34.543	error	(14916) TypeError: Cannot read property 'val' of null at adapter.getStates (C:\Program Files\iobroker\Test\node_modules\iobroker.plex\plex.js:166:41) at states.getStates (C:\Program Files\iobr
      plex.0	2020-02-24 15:14:34.543	error	(14916) uncaught exception: Cannot read property 'val' of null
      plex.0	2020-02-24 15:14:34.501	info	(14916) Establishing insecure connection to Plex Media Server...
      plex.0	2020-02-24 15:14:34.490	info	(14916) starting. Version 0.8.10 in C:/Program Files/iobroker/Test/node_modules/iobroker.plex, node: v10.16.3
      plex.0	2020-02-24 15:14:02.715	info	(15232) Terminated (NO_ERROR): Without reason
      plex.0	2020-02-24 15:14:02.715	info	(15232) terminating
      plex.0	2020-02-24 15:14:02.713	info	(15232) Adapter stopped und unloaded.
      plex.0	2020-02-24 15:14:02.712	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      plex.0	2020-02-24 15:14:02.712	error	at promise.then (C:\Program Files\iobroker\Test\node_modules\standard-as-callback\built\index.js:19:49)
      plex.0	2020-02-24 15:14:02.712	error	at tryCatcher (C:\Program Files\iobroker\Test\node_modules\standard-as-callback\built\utils.js:11:23)
      plex.0	2020-02-24 15:14:02.712	error	at client.mget (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:619:13)
      plex.0	2020-02-24 15:14:02.712	error	at states.getStates (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:5922:17)
      plex.0	2020-02-24 15:14:02.712	error	at adapter.getStates (C:\Program Files\iobroker\Test\node_modules\iobroker.plex\plex.js:166:41)
      plex.0	2020-02-24 15:14:02.712	error	(15232) TypeError: Cannot read property 'val' of null
      plex.0	2020-02-24 15:14:02.712	error	(15232) uncaught exception: Cannot read property 'val' of null
      plex.0	2020-02-24 15:14:02.610	info	(15232) Establishing insecure connection to Plex Media Server...
      liv-in-sky Zefau 2 Replies Last reply Reply Quote 0
        liv-in-sky @sigi234 last edited by
        @sigi234 das ist jetzt schonb das zweite, was nicht funktioniert mit dem neuen socket - ich glaub, den installier ich im moment nicht - hast du das schon weitergegeben?
          sigi234 Forum Testing Most Active @liv-in-sky last edited by
          @liv-in-sky sagte in Test Adapter Plex v0.8.x:
          Wurde schon gemeldet, glaube ich. Bin wieder zurück .
          • Zefau
            Zefau @sigi234 last edited by
            @sigi234 sagte in Test Adapter Plex v0.8.x:
            Probier mal bitte v0.8.11 von Github.
              @Zefau sagte in Test Adapter Plex v0.8.x:
              Jupp geht, teste weiter. 👍
                Megabeit last edited by
                Hi, ich habe eher ein kleines Problem.
                Habe den Plex Adapter (Version 0.9.0) bei mir installiert. Adapter ist auch grün und liefert zuverlässig Werte vom richtigen Plexserver. Es ist jedoch die falsche IP Adresse des Plexserver im ioBroker hinterlegt, also sowohl in der Übersicht als auch in der Adapterliste, wo man per Button direkt auf den Plexserver springen kann. Genau genommen wird in der Übersicht die gleiche IP-Adresse/Port angezeigt, wie bei der VIS !?!?
                In der Konfig des Adapters ist die korrekte IP hinterlegt. Irgendeine Idee, wie/wo ich das korrigieren kann?
                • Zefau
                  Zefau @Megabeit last edited by
                  @Megabeit Wo genau in ioBroker steht die falsche IP? In der Übersicht mit den Kacheln ist ein Interface verlinkt, welches die letzten Aktivitäten zeigt. Das Interface läuft auf ioBroker, daher ist dort auch die ioBroker IP zu sehen. Der Link soll nicht zum Plex Server führen, sondern zu folgendem Interface:
                    Megabeit @Zefau last edited by
                    @Zefau
                    Ja, genau. Ich meinte die Kachel in der Übersicht. Okay, das war mir nicht klar.
                    Bei mir zeigt das Interface aber keine Daten an. Muss ich da in Plex oder Tautulli noch was aktivieren?
                    • Zefau
                      @Megabeit entweder Plex Pass den Webhook konfigurieren oder in Tautulli den Webhook konfigurieren. Steht alles auf Github: https://github.com/Zefau/ioBroker.plex#22-advanced-setup-plex-pass-or-tautulli
                      Winni 1 Reply Last reply Reply Quote 1
                      • Winni
                        Winni @Zefau last edited by Winni
                        Hallo, ich versuche den Adapter bei mir zum laufen zu bringen. Ich scheitere aber bei der Übernahme des Authentifizierungs-Token. Ich gebe auf der Seite http://www.plex.tv/pin den Pin ein und bekomme die Meldung "Account Linked Your account has been successfully linked, please revisit your app to continue" Aber das war es dann auch, ich kann nirgends einen Authentifizierungs-Token entdecken und der Adapter bleibt gelb. Wo ist mein Fehler 😖
                        Nach mehreren Versuchen hats doch funktioniert..
                        • Du-Bass
                          Du-Bass @Zefau last edited by
                          @Zefau
                          Good day!
                          I installed this adapter. Filled in ip and tried to get PIN, but couldn't get it... What did i do wrong?
                          Du-Bass 1 Reply Last reply Reply Quote 0
                          • Du-Bass
                            Du-Bass @Du-Bass last edited by
                            @Du-Bass said in Test Adapter Plex v0.8.x:
                            @Zefau
                            Good day!
                            Solved this question.
                            I have to change instance to debug, and at log check th PIN. I think it will great to add to readme for this adapter
                            • Negalein
                              @Zefau
                              hab heute deinen Adapter installiert.
                              Mir füllt es das Log extrem an.
                              Hab den Adapter schon auf warn gestellt. Wird aber nicht unterdrückt.
                              plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries.4-horror" is missing the required property "common.type"
                              plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries.10-filme" is missing the required property "common.type"
                              plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries" is missing the required property "common.type"
                              plex.0 2022-01-05 23:15:03.913	warn	Object of state "plex.0.settings.other" is missing the required property "common.type"
                              • Negalein
                                Negalein Global Moderator @sigi234 last edited by
                                Arbeite schon an einer Vis:
                                Servus Sigi!
                                Verwendest du noch Plex und gibt es deinen View noch?
                                  ticaki last edited by
                                  wow ist das Problem schon alt.
                                  ich hab die common.type Warnung gefixt bitte testen
                                  https://github.com/ticaki/ioBroker.plex
                                  Dann mache ich eine PR draus.
                                    liv-in-sky @ticaki last edited by
                                    @ticaki
                                    die common.type sind nicht gekommen - aber evtl möchtest du das noch ansehen - beim starten eines videos
                                    plex.0
                                    2023-08-12 15:24:50.482	info	State value to set for "plex.0._playing._recent-player.playing" has to be type "string" but received type "boolean"
                                    plex.0
                                    2023-08-12 15:24:50.479	info	State value to set for "plex.0._playing._recent-player.Metadata.parentRatingKey" has to be type "number" but received type "string"
                                    plex.0
                                    2023-08-12 15:24:50.479	info	State value to set for "plex.0._playing._recent-player.Metadata.grandparentRatingKey" has to be type "number" but received type "string"
                                      @ticaki und nochmals danke - wäre schade um den adapter
                                        ticaki @liv-in-sky last edited by ticaki
                                        @liv-in-sky
                                        kannst du dieses Addon(Tautulli) testen? Das ist seit 2021 archiviert und ich wollte sowas altes nicht installieren. Oder gibts da was gepflegtes für?
                                        Ich gucke auch mal nach diesen typen
                                          liv-in-sky @ticaki last edited by liv-in-sky
                                          @ticaki sagte in Test Adapter Plex v0.8.x:
                                          habe ich angesehen (tautulli) - es wurde sofort das laufende video übertragen und in tautulli sichtbar - hat mir erstmal gereicht - brauchst du ws besonderes
                                            @liv-in-sky
                                            Nein danke, muß nur den Code besser verstehen. Also ist das Tautulli noch ok? Kann ich das ohne furcht installieren? 😂
                                            plex
                                            14
                                            312
                                            45800
