    • simatec
      simatec Developer Most Active @Meister Mopper last edited by
      @Meister-Mopper
      Kann ich so nicht bestätigen.
      Zum einen wurde am CCU Backup in der Version nix gemacht und zu anderen läuft es auf all meinen Testsystemen.
      Das muss bei dir eine andere Ursache haben
      • Meister Mopper
        Meister Mopper @simatec last edited by
        @simatec Eigenartig, bis auf das Adapter-Update habe ich nichts verändert. Aber egal, es geht ja jetzt wieder. 😊
          hofmannha @Meister Mopper last edited by Negalein
          Hallo @Meister-Mopper,
          bei mir funktioniert der Adapter auch nicht mehr.
          Fehler:
          backitup.0	2020-11-01 11:57:22.270	error	(25641) Error: Sorry, the maximum number of clients (10) for this user are already connected.
          backitup.0	2020-11-01 11:57:22.077	info	(25641) [ccu] backup was activated at 01:30 every 3 day(s)
          backitup.0	2020-11-01 11:57:22.063	info	(25641) [iobroker] backup was activated at 12:00 every 1 day(s)
          backitup.0	2020-11-01 11:57:22.008	info	(25641) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0, js-controller: 3.1.6
          backitup.0	2020-11-01 11:57:13.236	info	(25207) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          backitup.0	2020-11-01 11:57:13.235	info	(25207) terminating
          backitup.0	2020-11-01 11:57:13.233	info	(25207) cleaned everything up...
          backitup.0	2020-11-01 11:57:13.231	info	(25207) Got terminate signal TERMINATE_YOURSELF
          backitup.0	2020-11-01 11:56:42.236	error	(25207) Error: Sorry, the maximum number of clients (10) for this user are already connected.
          backitup.0	2020-11-01 11:56:40.778	info	(25207) [ccu] backup was activated at 01:30 every 3 day(s)
          backitup.0	2020-11-01 11:56:40.683	info	(25207) [iobroker] backup was activated at 02:00 every 1 day(s)
          backitup.0	2020-11-01 11:56:40.434	info	(25207) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0, js-controller: 3.1.6
          backitup.0	2020-11-01 11:56:26.213	warn	(25207) slow connection to objects DB. Still waiting ...
          backitup.0	2020-11-01 11:55:56.345	info	(24515) Got terminate signal TERMINATE_YOURSELF
          Was kann das sein?
          Dr. Bakterius Thomas Braun simatec 3 Replies Last reply Reply Quote 0
          • Dr. Bakterius
            Dr. Bakterius Most Active @hofmannha last edited by
            @hofmannha sagte in Test Adapter Backitup v1.7.x:
            Daran wird es wohl liegen. Es gibt zu viele offene Verbindungen. Wohin sicherst du? Die einfachste (vorübergehende) Lösung: Gerät neu starten.
              Thomas Braun Most Active @hofmannha last edited by
              node: v10.19.0
              Würde ich auf node12 heben.
              Wo sicherst du die Backups denn hin?
                brain last edited by
                Kann mir jemand kurz auf die Sprünge helfen? Ich habe den Adapter vor Kurzem neu installiert und damit endlich eine automatische Backup-Lösung auf mein NAS realisiert. Mein CCU und mein iobroker Backup laufen einwandfrei. Sobald ich aber die History-Daten mitnehmen möchte, spuckt er eine Fehlermeldung aus ("historyDB: No source for compress!").
                Ich denke, das liegt an meiner Pfadangabe bei den History-Daten. Die Übernahme des Pfads per Ermitteln der Konfig scheint bei mir nicht zu funktionierten. Welcher Pfad ist dort anzugeben?
                • Nashra
                  Bei mir steht dies drin: /opt/iobroker/iobroker-data/history
                  • simatec
                    simatec Developer Most Active @hofmannha last edited by
                    @hofmannha
                    Du hast zu viele nicht abgemeldete Anmeldungen an deiner CCU. Starte die mal neu
                    • simatec
                      simatec Developer Most Active @brain last edited by
                      @brain
                      Du musst dort den exakt identischen Pfad eintragen, der auch im History Adapter hinterlegt ist.
                        brain @Nashra last edited by
                        @Nashra said in Test Adapter Backitup v1.7.x:
                        Danke, das habe ich eingetragen und erfolgreich getestet.
                          hofmannha @Dr. Bakterius last edited by
                          Hallo @Dr-Bakterius,
                          Danke für die Hilfe. Genau das war’s. Ich habe die Raspberrymatic neu gestartet und Siege da, Backup macht jetzt wieder ein Backup von der ccu.
                          Trotzdem bleibt mir ein Problem. Der Backup-Adapter macht mir das Backup per ftp nicht auf meine Nas. Das hat bis Anfang September problemlos funktioniert und geändert habe ich auch nichts.
                          Hast Du eine Idee?
                          • simatec
                            @hofmannha
                            Zeige bitte mal den Debuglog ...
                            • gelberlemmy
                              gelberlemmy @simatec last edited by
                              @simatec moin, ich habe mein Backup von Dropbox auf meine NAS gewechselt. So wie ich es sehe, auch ohne Fehler im Log. Aber wenn ich über mein Telegram Adapter schaue, steht da folgendes :
                              BackItUp:
                              Die Sicherung wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!!
                              cifs: Error: EACCES: permission denied, open '/home/iobroker_2020_11_04-21_51_31_IOBroker Backup_backupiobroker.tar.gz'
                              Es ist aber auf der Nas vorhanden. Was sagt mir das? Mir ist jetzt nicht EACCES geläufig. Schreiben scheint zu gehen... Lesen nicht?
                              Gruss Andre
                                Thomas Braun Most Active @gelberlemmy last edited by
                                @gelberlemmy
                                Nicht ausreichende Rechte.
                                  Flyor87 last edited by Flyor87
                                  Ich bekomme leider auch jede Nacht nach dem geplanten Backup die altbekannte Fehlermeldung:
                                  backitup.0	2020-11-05 02:00:54.047	info	(17562) [iobroker] backup was activated at 02:00 every 1 day(s)
                                  backitup.0	2020-11-05 02:00:54.035	info	(17562) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.19.0, js-controller: 3.1.6
                                  host.ubuntu	2020-11-05 02:00:53.117	info	instance system.adapter.backitup.0 started with pid 17562
                                  host.ubuntu	2020-11-05 02:00:23.108	info	Restart adapter system.adapter.backitup.0 because enabled
                                  host.ubuntu	2020-11-05 02:00:23.108	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                  host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:343:18)
                                  host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                  host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
                                  host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15)
                                  host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: Error: Rate Limit Exceeded
                                  host.ubuntu	2020-11-05 02:00:23.107	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
                                  backitup.0	2020-11-05 02:00:22.598	info	(901) Terminated (NO_ERROR): Without reason
                                  backitup.0	2020-11-05 02:00:22.597	info	(901) terminating
                                  backitup.0	2020-11-05 02:00:22.586	info	(901) cleaned everything up...
                                  backitup.0	2020-11-05 02:00:22.585	error	(901) Error: Rate Limit Exceeded at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/t
                                  backitup.0	2020-11-05 02:00:22.576	error	(901) unhandled promise rejection: Rate Limit Exceeded
                                  backitup.0	2020-11-05 02:00:22.574	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().```
                                  F simatec 2 Replies Last reply Reply Quote 0
                                    Flyor87 @Flyor87 last edited by Flyor87
                                    Hab mit jetzt den Thread durchgelesen, den Adapter auf Debug gestellt und manuell gestartet. Da kam die Meldung nicht:
                                    backitup.0	2020-11-05 02:12:14.074	debug	(18915) [iobroker] exec: done
                                    backitup.0	2020-11-05 02:12:13.923	debug	(18915) [iobroker/googledrive] done
                                    backitup.0	2020-11-05 02:12:12.358	debug	(18915) [iobroker/googledrive] Google Drive: Copy zigbee.0_2020_11_05-02_12_04_backupiobroker.tar.gz...
                                    backitup.0	2020-11-05 02:12:05.989	debug	(18915) [iobroker] exec: done
                                    backitup.0	2020-11-05 02:12:05.839	debug	(18915) [iobroker/history] backitup.0.history.json
                                    backitup.0	2020-11-05 02:12:05.837	debug	(18915) [iobroker/history] backitup.0.history.html
                                    backitup.0	2020-11-05 02:12:05.079	debug	(18915) [iobroker/clean] done
                                    backitup.0	2020-11-05 02:12:05.078	debug	(18915) [iobroker/googledrive] Google Drive: Copy iobroker_2020_11_05-02_12_00_Saves_backupiobroker.tar.gz...
                                    backitup.0	2020-11-05 02:12:04.627	debug	(18915) [iobroker/zigbee] done
                                    backitup.0	2020-11-05 02:12:04.627	debug	(18915) [iobroker/zigbee] found zigbee database: zigbee.0
                                    backitup.0	2020-11-05 02:12:04.024	debug	(18915) [iobroker/iobroker] done
                                    backitup.0	2020-11-05 02:12:03.018	debug	(18915) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_11_05-02_12_00_Saves_backupiobroker.tar.gz
                                    backitup.0	2020-11-05 02:12:01.758	debug	(18915) [iobroker/iobroker] host.ubuntu 7223 objects saved
                                    backitup.0	2020-11-05 02:12:01.750	debug	(18915) [iobroker/iobroker] host.ubuntu 5928 states saved
                                    backitup.0	2020-11-05 02:12:00.503	debug	(18915) Backup has started ...
                                    backitup.0	2020-11-05 02:11:37.868	debug	(18915) No backup file was found
                                    backitup.0	2020-11-05 02:11:35.099	info	(18915) [iobroker] backup was activated at 02:00 every 1 day(s)
                                    backitup.0	2020-11-05 02:11:35.081	info	(18915) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.19.0, js-controller: 3.1.6
                                    backitup.0	2020-11-05 02:11:35.049	debug	(18915) Plugin sentry Initialize Plugin (enabled=true)
                                    backitup.0	2020-11-05 02:11:34.629	debug	(18915) statesDB connected
                                    backitup.0	2020-11-05 02:11:34.628	debug	(18915) States connected to redis: 127.0.0.1:9000
                                    backitup.0	2020-11-05 02:11:34.625	debug	(18915) States create System PubSub Client
                                    backitup.0	2020-11-05 02:11:34.625	debug	(18915) States create User PubSub Client
                                    backitup.0	2020-11-05 02:11:34.622	debug	(18915) Redis States: Use Redis connection: 127.0.0.1:9000
                                    backitup.0	2020-11-05 02:11:34.622	debug	(18915) objectDB connected
                                    backitup.0	2020-11-05 02:11:34.620	debug	(18915) Objects connected to redis: 127.0.0.1:9001
                                    backitup.0	2020-11-05 02:11:34.617	debug	(18915) Objects client initialize lua scripts
                                    backitup.0	2020-11-05 02:11:34.616	debug	(18915) Objects create User PubSub Client
                                    backitup.0	2020-11-05 02:11:34.616	debug	(18915) Objects create System PubSub Client
                                    backitup.0	2020-11-05 02:11:34.615	debug	(18915) Objects client ready ... initialize now
                                    backitup.0	2020-11-05 02:11:34.607	debug	(18915) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    host.ubuntu	2020-11-05 02:11:34.095	info	instance system.adapter.backitup.0 started with pid 18915
                                    host.ubuntu	2020-11-05 02:11:31.598	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    backitup.0	2020-11-05 02:11:31.087	info	(18085) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    backitup.0	2020-11-05 02:11:31.087	info	(18085) terminating
                                    backitup.0	2020-11-05 02:11:31.087	info	(18085) cleaned everything up...
                                    backitup.0	2020-11-05 02:11:31.086	info	(18085) Got terminate signal TERMINATE_YOURSELF
                                    host.ubuntu	2020-11-05 02:11:31.085	info	stopInstance system.adapter.backitup.0 send kill signal
                                    host.ubuntu	2020-11-05 02:11:31.083	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    • JayR
                                      JayR @simatec last edited by JayR
                                      @simatec : Ich habe ein Problem, beim herstellen eines Backups, dass auf einem Pi 4 gemacht wurde und auf einem 3er hergestellt wird. Hast du eine Idee, wie ich das Backup auf dem Pi3 herstellen kann?
                                      pi@raspberrypi:/opt/iobroker $ sudo iobroker restore 0
                                      host.raspberrypi Using backup file iobroker_2020_11_04-02_00_10_iobroker_backupiobroker.tar.gz
                                      iobroker controller daemon is not running
                                      host.raspberrypi OK.
                                      <--- Last few GCs --->
                                      [1202:0x22292e0]     6704 ms: Scavenge 13.6 (16.7) -> 11.8 (17.2) MB, 3.8 / 0.0 ms  (average mu = 0.973, current mu = 0.979) allocation failure
                                      [1202:0x22292e0]     9239 ms: Mark-sweep 153.3 (157.5) -> 151.4 (157.5) MB, 17.3 / 0.0 ms  (+ 0.9 ms in 2 steps since start of marking, biggest step 0.9 ms, walltime since start of marking 2220 ms) (average mu = 0.992, current mu = 0.995) allocation failu
                                      <--- JS stacktrace --->
                                      Cannot get stack trace in GC.
                                      FATAL ERROR: MarkCompactCollector: semi-space copy, fallback in old gen Allocation failed - JavaScript heap out of memory
                                      /usr/bin/iobroker: Zeile 8:  1201 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                      RAM:
                                      pi@raspberrypi:/opt/iobroker $ free
                                      Mem:         947032       46132      619760        2672      281140      845912
                                      Swap:        102396        3840       98556
                                      Vielen Dank und Gruß
                                        Thomas Braun Most Active @JayR last edited by Thomas Braun
                                        @JayR
                                        Ohne sudo vorweg.
                                        Warum nutzt du nicht den Backitup-Adapter?
                                        [Edit:] Doppelpost! Hier geht es weiter:
                                        https://forum.iobroker.net/topic/38346/backup-kann-nicht-wieder-hergestellt-werden
                                        • simatec
                                          simatec Developer Most Active @Flyor87 last edited by
                                          @Flyor87
                                          Kannst du mir mal bitte deine Config als json hier posten?
                                          Du nutzt wie ich sehe Google Drive. Wie viele Backups hast du zur in der Cloud liegen, bevor gelöscht wird?
                                            Snapergy last edited by Snapergy
                                            Hab seit einigen Tagen ein komisches Verhalten beim Adapter. Jeden Tag um 1:00 Uhr in der Nacht wird das Backup ausgeführt und auch eine Backup-Datei (korrekt) angelegt, jedoch sind die Objekte iobrokerSuccess auf false und iobrokerLastTime beginnt mit "error". Ein händisch ausgeführtes Backup führte wieder zu einer erfolgreichen Durchführung und Setzen des Success-Wertes auf true, doch seit heute geht auch das nicht mehr. Der Log wirft aus meiner Sicht aber keinen Fehler
                                            backitup.0	2020-11-11 07:39:45.581	debug	(7494) No backup file was found
                                            backitup.0	2020-11-11 07:39:45.577	debug	(7494) [iobroker] 10 00 01 */1 * *
                                            backitup.0	2020-11-11 07:39:45.565	info	(7494) [iobroker] backup was activated at 01:00 every 1 day(s)
                                            backitup.0	2020-11-11 07:39:45.524	info	(7494) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0, js-controller: 3.1.6
                                            backitup.0	2020-11-11 07:39:45.045	debug	(7494) Plugin sentry Initialize Plugin (enabled=true)
                                            backitup.0	2020-11-11 07:39:43.879	debug	(7494) statesDB connected
                                            backitup.0	2020-11-11 07:39:43.878	debug	(7494) States connected to redis: 127.0.0.1:9000
                                            backitup.0	2020-11-11 07:39:43.867	debug	(7494) States create System PubSub Client
                                            backitup.0	2020-11-11 07:39:43.865	debug	(7494) States create User PubSub Client
                                            backitup.0	2020-11-11 07:39:43.857	debug	(7494) Redis States: Use Redis connection: 127.0.0.1:9000
                                            backitup.0	2020-11-11 07:39:43.855	debug	(7494) objectDB connected
                                            backitup.0	2020-11-11 07:39:43.848	debug	(7494) Objects connected to redis: 127.0.0.1:9001
                                            backitup.0	2020-11-11 07:39:43.833	debug	(7494) Objects client initialize lua scripts
                                            backitup.0	2020-11-11 07:39:43.832	debug	(7494) Objects create User PubSub Client
                                            backitup.0	2020-11-11 07:39:43.831	debug	(7494) Objects create System PubSub Client
                                            backitup.0	2020-11-11 07:39:43.827	debug	(7494) Objects client ready ... initialize now
                                            backitup.0	2020-11-11 07:39:43.796	debug	(7494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                            170
                                            2780
                                            2343724
