    4. Test Adapter Solarlog v2.x.x latest
    • Agria4800
      Agria4800 @forelleblau last edited by
      @forelleblau sagte in Test Adapter Solarlog v2.0.x latest:
      Aktuelle Test Version 2.0.x
      Veröffentlichungsdatum 26.4.2020
      Github Link https://github.com/iobroker-community-adapters/ioBroker.solarlog
      Optimier: Code, NEU: Systemdaten und Zielwerte aus Solarlog
      V2.0.x
      Bekomme folgende Fehlermeldung:
      Was bedeutet das ?
      solarlog.0	2020-10-01 20:44:38.865	warn	(3357110) readSolarlogData - Fehler : TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:44:38.865	warn	(3357110) readSolarlogData - Fehler in sum data inverters: TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:44:08.646	warn	(3357110) readSolarlogData - Fehler : TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:44:08.646	warn	(3357110) readSolarlogData - Fehler in sum data inverters: TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:43:27.920	warn	(3357110) Fehler, noch nicht alle Unterzaehler angelegt
      solarlog.0	2020-10-01 20:43:27.919	warn	(3357110) Nicht alle WR/Zaehler gefunden
      solarlog.0	2020-10-01 20:43:25.919	warn	(3357110) Nicht alle WR/Zaehler gefunden
      solarlog.0	2020-10-01 20:43:23.917	warn	(3357110) Nicht alle WR/Zaehler gefunden
      solarlog.0	2020-10-01 20:43:21.916	warn	(3357110) Nicht alle WR/Zaehler gefunden
      solarlog.0	2020-10-01 20:43:07.528	warn	(3724) ERROR httpsRequest: socket hang up
      solarlog.0	2020-10-01 20:43:07.526	warn	(3724) readSolarlogData - Fehler : TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:43:07.526	warn	(3724) readSolarlogData - Fehler in sum data inverters: TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:42:37.302	warn	(3724) ERROR httpsRequest: socket hang up
      solarlog.0	2020-10-01 20:42:37.301	warn	(3724) readSolarlogData - Fehler : TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:42:37.301	warn	(3724) readSolarlogData - Fehler in sum data inverters: TypeError: Cannot read property 'indexOf' of undefined
      solarlog.0	2020-10-01 20:42:07.111	warn	(3724) ERROR httpsRequest: socket hang up
        forelleblau @Agria4800 last edited by
        @Agria4800 Hallo. Für mich sieht das aus, als würde der Adapter deinen solarlog gar nicht erreichen. Hat es bisher funktioniert? Ist es nur mit der aktuellsten version so? oder hast du den Adapter neu installiert? Was hat du für einen solarlog? Welche Sicherheitseinstellungen hat du (mit/ohne Benutzerpasswort?)
        Herzliche Grüsse Forelleblau
        Agria4800 1 Reply Last reply Reply Quote 0
        • Agria4800
          Agria4800 @forelleblau last edited by Agria4800
          @forelleblau danke dir für deine Nachricht.
          Habe gestern abend gemerkt, das sich mein Solarlog aufgehängt hat, das ist jetzt schon das 3mal innerhalb kurzer Zeit.
          Ich glaube, da geht die SD Karte kaputt... 😞
          Aktuell funktioniert wieder alles.
          Ich habe mal noch ne Frage zu Weiterentwicklung:
          Ist es möglich, die historischen Daten auch zu überarbeiten ? (z.B. Datenkorrektur)
          Ist es möglich, auch die Bilanzwerte (Ertrag - Verbrauch) auszulesen, da hätte ich großes Interesse
          Und was auch noch super cool wäre, wenn es eine z.b. json gibt, die eine Tabelle aller Daten auflistet (Je nach Wunsch, Tag, Monat, Jahr, Gesamt
          Eine grafische Darstellung analog der Solarlog Oberfläche aller Daten auflistet (Je nach Wunsch, Tag, Monat, Jahr, Gesamt wäre natürlich das i Tüpfelchen 🙂
          Ich bin leider kein Entwickler, nur Nutzer und kann mir nur in etwas vorstellen, das es viel Arbeit sein könnte...aber vielleicht habe ich & andere Nutzer Glück, dass einige Dinge leicht umsetzbar sind... ich würde mich als Tester gerne zu Verfügung stellen...
            @Agria4800 Hallo Agria4800
            Bisher kann der Adapter nur Daten aus dem solarlog lesen. Das Schreiben von Daten inkl. Abspeichern hab ich noch nicht ganz raus. Ich probiers ab und an aber wieder, weil ich gerne meine Smart-Energy Geräte, die am Solarlog hängen, vom Adapter aus manuell schalten möchten. Wenn das klappt, sollte dann ev. eine Datenkorrektur auch möglich sein. Wird aber wohl noch eine Weile dauern.
            Bei den Bilanzwerten ist es so, dass die - soweit ich es erkennen kann - auch im Solarlog erst für die Darstellung berechnet werden. Hinterlegt sind nur Ertrag und Verbrauch. Analog würde ich die Bilanzwerte auch erst z.B. bei einer Visualisierung berechnen.
            Bei der 'Tabelle aller Daten' ist mir nicht ganz klar, was du meinst. Hier https://github.com/iobroker-community-adapters/ioBroker.solarlog/blob/master/docs/solarlog_dataobjects.md habe ich zusammengestellt, was ich bisher aus dem solarlog abrufbares gefunden habe.
            Herzliche Grüsse
            forelleblau
              Jaschkopf @forelleblau last edited by
              @forelleblau Servus. Bei mir hängt sich jede Nacht um 3Uhr der Adapter auf und Startet neu. Hast du eine Idee woran das liegen kann? Hier sind die Eintrage im Log zu dem Event:
              2020-10-27 03:00:17.794 - warn: solarlog.0 (3168) readSolarlogData - Fehler in sum data inverters: TypeError: Cannot read property 'indexOf' of undefined
              2020-10-27 03:00:17.797 - warn: solarlog.0 (3168) readSolarlogData - Fehler : TypeError: Cannot read property 'indexOf' of undefined
              2020-10-27 03:00:49.855 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:49.858 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:49.860 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:49.863 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:49.865 - warn: solarlog.0 (3168) Mehrfach fehlerhafter http-Request, starte Adapter neu.
              2020-10-27 03:00:49.872 - info: host.iobroker stopInstance system.adapter.solarlog.0 (force=false, process=true)
              2020-10-27 03:00:49.873 - info: host.iobroker stopInstance system.adapter.solarlog.0 send kill signal
              2020-10-27 03:00:49.875 - info: solarlog.0 (3168) Got terminate signal TERMINATE_YOURSELF
              2020-10-27 03:00:49.876 - info: solarlog.0 (3168) [END] Stopping solarlog adapter...
              2020-10-27 03:00:49.876 - info: solarlog.0 (3168) terminating
              2020-10-27 03:00:49.876 - info: solarlog.0 (3168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2020-10-27 03:00:50.388 - info: host.iobroker instance system.adapter.solarlog.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2020-10-27 03:00:52.886 - info: host.iobroker instance system.adapter.solarlog.0 started with pid 22887
              2020-10-27 03:00:53.963 - warn: solarlog.0 (22887) Object solarlog.0.status.yieldyear is invalid: obj.common.type has an invalid value (timestamp) but has to be one of number, string, boolean, array, object, mixed, file, json
              2020-10-27 03:00:53.964 - warn: solarlog.0 (22887) This object will not be created in future versions. Please report this to the developer.
              2020-10-27 03:00:54.059 - info: solarlog.0 (22887) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.solarlog, node: v12.19.0, js-controller: 3.1.6
              2020-10-27 03:00:54.075 - info: solarlog.0 (22887) [START] Starting solarlog adapter
              2020-10-27 03:00:54.076 - info: solarlog.0 (22887) Unterzähler - Import: true
              2020-10-27 03:00:54.077 - info: solarlog.0 (22887) Historische Daten werden nicht abgerufen
              2020-10-27 03:00:54.077 - info: solarlog.0 (22887) Forecast - Datenabruf: true
              2020-10-27 03:00:54.099 - warn: solarlog.0 (22887) Fehler Login: Cannot read property 'toString' of undefined Benuterpasswort im Solalog aktiviert??
              2020-10-27 03:00:54.100 - warn: solarlog.0 (22887) Fehler Login: Cannot read property 'push' of undefined Benuterpasswort im Solalog aktiviert??
              2020-10-27 03:00:54.102 - warn: solarlog.0 (22887) Fehler Login: The "list" argument must be an instance of Array. Received undefined Benuterpasswort im Solalog aktiviert??
              2020-10-27 03:00:54.591 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:54.595 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:54.599 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:54.604 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
              2020-10-27 03:00:54.610 - warn: solarlog.0 (22887) Mehrfach fehlerhafter http-Request, starte Adapter neu.
              2020-10-27 03:00:54.616 - info: host.iobroker stopInstance system.adapter.solarlog.0 (force=false, process=true)
              2020-10-27 03:00:54.616 - info: host.iobroker stopInstance system.adapter.solarlog.0 send kill signal
              2020-10-27 03:00:54.621 - info: solarlog.0 (22887) Got terminate signal TERMINATE_YOURSELF
              2020-10-27 03:00:54.621 - info: solarlog.0 (22887) [END] Stopping solarlog adapter...
              2020-10-27 03:00:54.622 - info: solarlog.0 (22887) terminating
              2020-10-27 03:00:54.622 - info: solarlog.0 (22887) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2020-10-27 03:00:55.135 - info: host.iobroker instance system.adapter.solarlog.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2020-10-27 03:00:57.627 - info: host.iobroker instance system.adapter.solarlog.0 started with pid 23039
              2020-10-27 03:00:59.251 - warn: solarlog.0 (23039) Object solarlog.0.status.yieldyear is invalid: obj.common.type has an invalid value (timestamp) but has to be one of number, string, boolean, array, object, mixed, file, json
              2020-10-27 03:00:59.252 - warn: solarlog.0 (23039) This object will not be created in future versions. Please report this to the developer.
              2020-10-27 03:00:59.624 - info: solarlog.0 (23039) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.solarlog, node: v12.19.0, js-controller: 3.1.6
              2020-10-27 03:00:59.636 - info: solarlog.0 (23039) [START] Starting solarlog adapter
              2020-10-27 03:00:59.637 - info: solarlog.0 (23039) Unterzähler - Import: true
              2020-10-27 03:00:59.637 - info: solarlog.0 (23039) Historische Daten werden nicht abgerufen
              2020-10-27 03:00:59.637 - info: solarlog.0 (23039) Forecast - Datenabruf: true
              2020-10-27 03:01:01.644 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
              2020-10-27 03:01:01.644 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
              2020-10-27 03:01:01.644 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
              2020-10-27 03:01:03.643 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
              2020-10-27 03:01:03.644 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
              2020-10-27 03:01:03.644 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
              2020-10-27 03:01:05.644 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
              2020-10-27 03:01:05.644 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
              2020-10-27 03:01:05.644 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
              2020-10-27 03:01:07.644 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
              2020-10-27 03:01:07.644 - warn: solarlog.0 (23039) Fehler, noch nicht alle Unterzaehler angelegt
              2020-10-27 03:01:07.645 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
              2020-10-27 03:01:07.645 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
              Gruß Jaschkopf
                forelleblau @Jaschkopf last edited by
                @Jaschkopf Hallo Jaschkopf. Das sieht aus, als würde der Adapter nicht erreichen. Startet ev dein Solarlog jede Nacht neu? Oder ein Gerät dazwischen?
                  @forelleblau Soweit ich das beurteilen kann eigentlich nicht. Der SolarLog sowie der iobroker hängen direkt per Kabel an der Fritzbox. Kann das etwas mit der zwangstrennung der Internetverbindung Nachts zu tun haben?
                  Gruß Jaschkopf
                    forelleblau @Jaschkopf last edited by forelleblau
                    Aktuelle Test Version 2.1.4
                    Veröffentlichungsdatum 26.8.2021
                    v2.1.4
                    Neu werden auch bei Solarlog 500 - Geräten die History & Selfcons - Werte korrekt ausgefüllt.
                    J Agria4800 2 Replies Last reply Reply Quote 1
                      @forelleblau Habe neue Erkentnisse. Im Ereignisslog des SolarLog erkennt man, dass sich jede Nacht um 03:00:48Uhr der Modbus Zähler für ca. 1min trennt. Woran das Liegt kann ich noch nicht sagen, scheint aber eine Art "geplanter Neustart" der Modbus Schnittstelle zu sein. Ich habe SolarLog dazu eine Mail geschrieben, in der Hoffnung, dass sie mir dazu mehr sagen können.
                      Alternativ könnte man den Fehler "überbrücken" wenn man in den Adaptereinstellungen das Verbindungstimeout erhöhen könnte. In meinem Fall auf 90sek ca. Dann würde der Adapter das Problem einfach "vertuschen". Vielleicht kannst du das mit einem Update integrieren? 🤓
                      Gruß Jaschkopf
                        Jaschkopf @Jaschkopf last edited by
                        Ich habe gerade schon eine Antwort vom Support erhalten:
                        Sehr geehrter Herr Jaschkopf,
                        der Solar-Log™ macht jede Nacht um 3 Uhr einen Neustart, daher die Trennung der Verbindung.
                        Das Verhalten lässt sich nicht konfigurieren und ist wichtig für die Reorganisation des Systems.
                        Gruß Jaschkopf
                          @Jaschkopf Danke für den Input. Das ist wohl das einfachste, dass ich den letzten 'Retry' etwas rausschiebe. Werds mal einpflegen, wenn ich dazukomme.
                          Herzliche Grüsse forelleblau
                            mauseb @forelleblau last edited by
                            @forelleblau said in Test Adapter Solarlog v2.0.x latest:
                            Aktuelle Test Version 2.1.x
                            Veröffentlichungsdatum 04.04.2021
                            NEU: Werte aus Cockpit-Grafik und LCD-Display
                            V2.1.1
                            Neu werden alle Werte aus der Grafik im Cockpit und die Anzeige einiger Icons und Fehlermeldungen (resp. ob OK steht) importiert.
                            V2.0.2
                            Neu werden die Smart-Energy Schaltgruppen mit Name, verknüpfter Hardware (inkl. Untereinheit wo vorhanden), Schaltereinstellung (on/off/auto) und Schaltzustand im Adapter abgebildet. Voraussetzung ist der Import der 'Wechselrichter und Gerätedaten' in den erweiterten Einstellungen.
                            V2.0.1
                            Da beim ersten Start des Adapters immer mehr Daten aus dem Solarlog geholt werden, sind Fälle aufgetreten, in denen das Timing zwischen Datenbeschaffung und Objekte anlegen im Adapter nicht mehr passend war. Dies wurde korrigiert.
                            Danke den Meldern.
                            V2.0.x
                            Die neue Version bringt eine ganz neue Struktur der Kommunikation mit dem Solarlog. Die Anzahl Anfragen an den Solarlog kann damit massiv reduziert werden. Es wird gebündelter und gezielter abgefragt. Beide Systeme werden so weniger belastet.
                            Zudem werden neu ein paar technische / Systemdaten abgerufen und im .info - channel bereitgestelt und es werden aus den im Solarlog eingetragenen Daten eine Tages-, Monats(laufender und alle)-, und Jahressollwert berechnet und zur Verfügung gestellt. Die Werte sind im .forecast-channel zu finden und sind mit 'setpoint' bezeichnet um sie von 'forecast' - Werten, die optional von forecast.solar abgerufen werden können abzugrenzen (mit besten Grüssen an @hmanfred ). Die Sollwerte funktionieren auf jeden Fall bei Einzelanlagen. Besteht eine Anlage aus mehreren Anlagegruppen, stimmen die Werte möglicherweise nicht. Sollte dies der Fall sein. bitte ich um Feedback hier oder im Issue zum Thema auf github.
                            V.1.3.x
                            Mit der neuen Version 1.3.x kann nun im Solarlog das Benutzerpasswort aktiviert / gesetzt werden. Gleichzeitig muss in den Adaptereinstellungen das Häkchen dafür gesetzt und das Benutzerpasswort vom Solarlog angegeben werden.
                            Will man auf die Solarlog - UI (per solarlog-ip im Browser) zugreifen, sollte der Adapter aber gestoppt werden, da sonst Authentifizierungsprobleme entstehen. Ebenso sollte nicht von mehreren Instanzen gleichzeitig auf den Solarlog zugegriffen werden. Für den 'Mehrfachzugriff' empfiehlt sich nur die Variante mit deaktiviertem Benutzerpasswort.
                            Danke fürs Testen und für Feedback an dieser Stelle, freue mich auch über positives.
                            forelleblau
                            Hallo, ich bin ganz neu bei ioBrocker und teste gerade mein Solarlog 300.
                            Soweit ich es nun sehe scheint eine Verbindung zum Solarlog da zu sein.
                            Leider weiß ich noch nicht wo die Einträge stehen, dachte ich kann es mit History mir Sichern und dann Anzeigen lassen. Der speichert aber nur true/false ab.
                            Bekomme dieses nun angezeigt.
                            Hat jemand damit schon Erfahrungen und kann einen Neuling helfen ?
                            Danke im voraus
                            Björn
                            1d25555d-05d7-4566-8ec5-b141a703ca1c-Bildschirmfoto 2021-04-09 um 21.36.26.png
                              forelleblau @mauseb last edited by
                              @mauseb Hallo Björn
                              Da sollten natürlich Zahlen stehen und nicht true oder false. Hast du im solarlog die json-schnittstelle aktiviert? Benutzerpasswort aktiviert oder nicht und im Adapter entsprechend e8ngetragen?
                              Lieber Gruss Marcel
                                @mauseb Hallo Björn
                                Lieber Gruss Marcel
                                Hallo Marcel,
                                vielen Dank für den Hinweis. Hatte überhaupt nicht mehr an das Webinterface von SolarLog gedacht. Hatte dort noch eine Firmware von 2013 drauf. Update drauf und nun kommen dort auch die Daten.
                                Danke nochmal, tolles Forum
                                jetzt gerne noch eine tolle Vis und ich wäre glücklich
                                Gruß Björn
                                  schmuh last edited by
                                  Hi Marcel,
                                  zur Info, falls du es noch nicht mitbekommen haben solltest. Nach dem Upgrade de js-controllers 3.3.1 (Latest Rep.) gibt es viele Warnungen im Log.
                                  Man sotte dies dem Entwickler melden: https://forum.iobroker.net/topic/44624/js-controller-3-3-jetzt-im-latest
                                  NACH der Installation
                                  Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                                  Logs:
                                  solarlog.0	2021-04-30 15:09:40.000	warn	(9274) State value to set for "solarlog.0.INV.SMA STL 8000-20.PAC" has wrong type "string" but has to be "number"
                                  solarlog.0	2021-04-30 15:09:40.000	warn	(9274) State value to set for "solarlog.0.INV.PV-Erzeugung.PAC" has wrong type "string" but has to be "number"
                                  solarlog.0	2021-04-30 15:09:39.999	warn	(9274) State value to set for "solarlog.0.INV.Eigenverbrauch.PAC" has wrong type "string" but has to be "number"
                                  solarlog.0	2021-04-30 15:08:53.985	warn	(9274) State value to set for "solarlog.0.forecast.tomorrow" has wrong type "number" but has to be "string"
                                  solarlog.0	2021-04-30 15:08:53.984	warn	(9274) State value to set for "solarlog.0.forecast.today" has wrong type "number" but has to be "string"
                                  solarlog.0	2021-04-30 15:08:53.586	info	(9274) Alle WR/Zaehler gefunden
                                  Viele Grüße
                                  Werner
                                    forelleblau @schmuh last edited by
                                    @schmuh Danke für den Hinweis, Werner. Habs noch nicht mitbkommen. Werd mich drum kümmern, wenn ich dazukomme, kann aber paar Tage dauern.
                                    Grüsse Marcel
                                      forelleblau @forelleblau last edited by
                                      @schmuh
                                      Hallo Alle
                                      Die aufgetretenen Fehler sind behoben (sollten behoben sein) mit V2.1.2. die ab sofort im latest / auf github verfügbar ist.
                                      Grüsse
                                      Marcel
                                        schmuh @forelleblau last edited by
                                        @forelleblau
                                        Hi Marcel,
                                        wie immer, klasse Arbeit. Funktioniert perfekt! 👍
                                        Beste Grüße
                                        Werner
                                          @schmuh Danke Werner! Freut mich wenn alles läuft.
                                          Schönes Wochenende, Marcel
                                          Agria4800 S 2 Replies Last reply Reply Quote 0
                                          • Agria4800
                                            @forelleblau : Auch von meiner Seite aus als "stiller Nutzer" ein DANKE an dich 👍
                                            Ach, na gut, wenn ich schon dabei bin, dann auch gleich mit ne Frage!
                                            Ist es für dich ein großer Aufwand, alle DP außer Aktuell von Watt in kW zu ändern?
                                            Ich mache das aktuell mit JS, dabei generiere ich mir noch den Eigenverbrauch pro Monat(indem ich die Tageswerte addiere) und verrechne somit diese mit Verbrauch und Erzeugung, sodass ich den Bezug und der Ertrag erhalte. Das wäre natürlich auch ein Traum, wenn das der Adapter leiten könnte...
                                            Okay, jetzt sind es schon 2 Fragen... 😊
                                            solarlog
                                            12
                                            76
                                            6115
