    3. Cloud Dienste
    4. IOT Alexa Geräte hinzufügen - weisse Seite
      eubecker @olly023 last edited by eubecker
      Ich kämpfe gerade auch mit dem Adapter.
      Nachdem die 1.7.x nicht wollte habe ich sie gelöscht und dann Installation aus der Stable (V 1.5.3) läuft wie die Beta mit Fehlermeldungen:
      $ ./iobroker add iot  --host erbse
      NPM version: 6.14.4
      npm install iobroker.iot@1.5.3 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp
      ERR! configure error
       gyp
      ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR!
       stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/canvasgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/iobroker.iot/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR!
       stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)node-pre-gyp ERR! System Linux 4.14.79-v7+node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/iobroker.iot/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR!
       cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/canvasnode-pre-gyp ERR! node -v v12.18.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      ERR!
       sharp
       Use with glibc 2.24 requires manual installation of libvips >= 8.9.1info sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo
       sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
      ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^
      compilation terminated.
      make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
      gyp
       ERR!
       build error gyp
       ERR! stack Error: `make` failed with exit code: 2gyp
      ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/sharpgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      host.erbse install adapter iot
      upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.293df86c.js static/js/runtime-main.293df86c.js application/javascript
      upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.998ec878.chunk.js.LICENSE.txt static/js/2.998ec878.chunk.js.LICENSE.txt text/plain
      upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.998ec878.chunk.js static/js/2.998ec878.chunk.js application/javascript
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.09585381.chunk.js.map static/js/2.09585381.chunk.js.map application/json
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.09585381.chunk.js.LICENSE.txt static/js/2.09585381.chunk.js.LICENSE.txt text/plain
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.09585381.chunk.js static/js/2.09585381.chunk.js application/javascript
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css.map static/css/2.b1b16afe.chunk.css.map application/json
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css static/css/2.b1b16afe.chunk.css text/css
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.bebcfb9ed8ff6b9f47417e68cd1ee624.js precache-manifest.bebcfb9ed8ff6b9f47417e68cd1ee624.js application/javascript
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.64c35f13f942d5febcd49006c799b298.js precache-manifest.64c35f13f942d5febcd49006c799b298.js application/javascript
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.537015042a8c3fa504c76d01ebb32c7c.js precache-manifest.537015042a8c3fa504c76d01ebb32c7c.js application/javascript
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      host.erbse object system.adapter.iot created/updated
      host.erbse create instance iot
      host.erbse object iot.0.certs.forceUserCreate created
      host.erbse object iot.0.certs.urlKey created
      host.erbse object iot.0.certs.certificate created
      host.erbse object iot.0.certs.private created
      host.erbse object iot.0.certs.public created
      host.erbse object iot.0.certs.id created
      host.erbse object iot.0.certs created
      host.erbse object iot.0.services created
      host.erbse object iot.0.smart.updatesResult created
      host.erbse object iot.0.smart.updatesYA created
      host.erbse object iot.0.smart.updatesGH created
      host.erbse object iot.0.smart.updates3 created
      host.erbse object iot.0.smart.updates created
      host.erbse object iot.0.smart.lastResponse created
      host.erbse object iot.0.smart.lastCommandObj created
      host.erbse object iot.0.smart.lastCommand created
      host.erbse object iot.0.smart.lastRoom created
      host.erbse object iot.0.smart.lastFunction created
      host.erbse object iot.0.info.remoteTill created
      host.erbse object iot.0.info.connection created
      host.erbse object iot.0.info created
      host.erbse object system.adapter.iot.0.sigKill created
      host.erbse object system.adapter.iot.0.eventLoopLag created
      host.erbse object system.adapter.iot.0.outputCount created
      host.erbse object system.adapter.iot.0.inputCount created
      host.erbse object system.adapter.iot.0.uptime created
      host.erbse object system.adapter.iot.0.memRss created
      host.erbse object system.adapter.iot.0.memHeapTotal created
      host.erbse object system.adapter.iot.0.memHeapUsed created
      host.erbse object system.adapter.iot.0.cputime created
      host.erbse object system.adapter.iot.0.cpu created
      host.erbse object system.adapter.iot.0.compactMode created
      host.erbse object system.adapter.iot.0.connected created
      host.erbse object system.adapter.iot.0.alive created
      host.erbse object system.adapter.iot.0 created
      process exited with code 0```
      Sollte mich die Fehlermeldung irritieren? Hinzufügen von Geräten scheint da aber zu laufen...
      Zu früh gefreut.
      Alexa hat die alten GEräte erkannt. nachdem ich die entfernt habe und nun ein einziges probehalber eingetragen habe findet Alexa nix mehr. Im Log finde ich nichts...
      Jemand einen Tipp was ich machen muss für eine fehlerfreie Installation? IOBroker und alle Adapter habe ich aktualisiert, apt-get update auch ausgeführt.
        Thomas Braun Most Active @eubecker last edited by
        @eubecker sagte in IOT Alexa Geräte hinzufügen - weisse Seite:
        pixman-1
        Nachinstallieren, 'canvas' neubauen. Gibt mehrere Threads dazu wie das geht.
          eubecker @Thomas Braun last edited by
          @Thomas-Braun
          Welche Threat sollte ich mir anschauen?
          Der Tipp, den ich gefunden habe, war leider erfolglos, weil er nix tut:
          sudo apt install libpixman-1-dev
          libpixman-1-dev ist schon die neueste Version (0.34.0-1+rpi1).
          libpixman-1-dev wurde als manuell installiert festgelegt.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 142 nicht aktualisiert.
          Und was heißt "Canvas neu bauen"? Sorry, verstehe ich nicht.
            Thomas Braun Most Active @eubecker last edited by Thomas Braun
            Das kannst du zuerst mal in Ordnung bringen
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
            Und
            Ist auch nicht richtig, denn:
            apt policy libpixman-1-dev
            libpixman-1-dev:
              Installiert:           0.36.0-1+rpt1
              Installationskandidat: 0.36.0-1+rpt1
              Versionstabelle:
             *** 0.36.0-1+rpt1 500
                    500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 0.36.0-1 500
              @eubecker Und zu allem Überfluss ist nodeJS auch noch krumm:
              /usr/local/bin/node
              Zieh das nach dieser Anleitung gerade:
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/3
                eubecker @Thomas Braun last edited by eubecker
                @Thomas-Braun Ok, dann schaue ich mal...
                Hm...
                /opt/iobroker $ sudo apt update
                Holen:2 http://archive.raspberrypi.org/debian stretch InRelease [25,4 kB]
                OK:3 http://mirrordirector.raspbian.org/raspbian stretch InRelease
                Holen:1 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease [15,5 kB]
                OK:4 https://deb.nodesource.com/node_13.x stretch InRelease
                Fehl:1 http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease
                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY C2518248EEA14886
                W: GPG-Fehler: http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY C2518248EEA14886
                E: The repository 'http://ppa.launchpad.net/webupd8team/java/ubuntu trusty InRelease' is not signed.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                und nun?
                  @eubecker Wenn das alles gerade ist kannst dich ja wieder melden, wenn du mit canvas nicht weiter kommen solltest.
                    Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                    @eubecker
                    Quatsch, löschen:
                    node_13 ist auch Quatsch, auf node_12 setzen:
                      @Thomas-Braun Sorry, das ist etwas kurz, was du da schreibst, ich weiss nicht, was ich machen soll 😞
                      Ich komme leidlich mit dem Raspi zurecht, bin aber kein Linux-Profi 😞
                      Wo stelle ich das ein?
                      apt-cache policy
                      liefert beide Repositories, Java habe ich in /etc/apt/sources.list gefunden und raus geworfen, aber node_13 finde ich da nicht, auch nicht in /etc/apt/sources.list.d/raspi.list
                      Gefunden 🙂 Weiter geht's
                        williwuff @haselchen last edited by
                        @haselchen hier die Daten
                        Alexa 2 3.3.1
                        IoT 1.7.13
                        node 12.16.2
                        nodejs 12.19
                        iobroker 3.1.16
                        Script Engine 4.9.8
                        ok so, oder fehlt noch etwas?
                          @eubecker
                          nodesource-Repo korrigieren:
                          sudo nano /etc/apt/sources.list.d/nodesource.list
                          Dann dort aus der 13 eine 12 machen, Datei speichern.
                          Zu dem ppa-Kram:
                          ls -la /etc/apt/sources.list.d/
                          anschauen, da müsste eine entsprechende Datei liegen. Namen weiß ich nicht. Die dann löschen.
                          @williwuff Deine node-Installation ist auch schief. Kannst du direkt auch gerade ziehen.
                            @eubecker
                            Zeig nochmal
                            sudo apt update
                            her.
                              williwuff @Thomas Braun last edited by
                              @Thomas-Braun danke werd ich mal durchziehen
                                @Thomas-Braun Kannst du bitte mal /etc/apt/sources.list.d/nodesource.list hier posten? Finde ich nicht und bin nicht sicher, ob meine korrekt ist
                                  @eubecker
                                  Meine sieht so aus:
                                  # node 12
                                  deb https://deb.nodesource.com/node_12.x buster main
                                  deb-src https://deb.nodesource.com/node_12.x buster main
                                    A Former User @williwuff last edited by
                                    @williwuff sagte in IOT Alexa Geräte hinzufügen - weisse Seite:
                                    Alexa 2 3.3.1
                                    IoT 1.7.13
                                    node 12.16.2
                                    nodejs 12.19
                                    iobroker 3.1.16
                                    Script Engine 4.9.8
                                    Habe auch leeren Screen wenn ich hinzufügen möchte.
                                      Thomas Braun Most Active @Guest last edited by Thomas Braun
                                      @biker Installier die stable Version 1.5.3. vom iot-Adapter.
                                      Die ganzen wackeren Beta-Tester hier im Thread...
                                      Die Issues habt ihr aber als gewissenhafte Beta-Ritter schon gelesen, oder?
                                      https://github.com/ioBroker/ioBroker.iot/issues/176
                                      guergen1 created this issue in ioBroker/ioBroker.iot
                                      closed Dialogfeld "ID auswählen" ist nicht mehr da #176
                                      ? W 2 Replies Last reply Reply Quote 0
                                        A Former User @Thomas Braun last edited by
                                        @Thomas-Braun sagte in IOT Alexa Geräte hinzufügen - weisse Seite:
                                        ehrlich gesagt nicht 😉
                                          @biker
                                          Dann eine Bitte: Stell den Verwahrort auf STABLE/DEFAULT um und lass die Finger von BETA. Danke.
                                            Stell den Verwahrort auf STABLE/DEFAULT im und lass die Finger von BETA. Danke.
                                            ich muss mich bedanken - .. und verstehe natürlich den Hinweis!
                                            alexa iot pro
                                            5030
