    4. Error Installation KNX Adapter Ver. 10.0.39
    UNSOLVED Error Installation KNX Adapter Ver. 10.0.39
      tobiii1810 @Thomas Braun last edited by
      @Thomas-Braun
      iobroker@IoBrokerThinClient:~$ iobroker add knx
      host.IoBrokerThinClient install adapter knx
      npm install --loglevel error --production (System call) in "/node_modules/iobroker.knx"
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /node_modules/iobroker.knx
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.knx'
      npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.knx'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/node_modules/iobroker.knx'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T19_48_30_277Z-debug.log
      Cannot install iobroker.knx: 243
        Thomas Braun Most Active @tobiii1810 last edited by
        @tobiii1810
        Da stimmt der prefix offenbar nicht.
        cd /opt/iobroker
        iobroker add knx
        T Glasfaser 2 Replies Last reply Reply Quote 0
          @Thomas-Braun
          Hat leider nichts gebracht
          iobroker@IoBrokerThinClient:~$ cd /opt/iobroker
          iobroker@IoBrokerThinClient:/opt/iobroker$ iobroker add knx
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T19_52_36_875Z-debug.log
          • Glasfaser
            Glasfaser @tobiii1810 last edited by
            @tobiii1810
            iobroker fix
              tobiii1810 @Glasfaser last edited by
              @Glasfaser
              Hat @Thomas-Braun oben schon geschrieben und wurde auch schon ausgeführt.
              • Glasfaser
                Glasfaser @Thomas Braun last edited by Glasfaser
                @Thomas-Braun
                ich würde die Kiste mal neu durchstarten lassen .....!?
                  Thomas Braun Most Active @Glasfaser last edited by
                  @Glasfaser Ja.
                  @tobiii1810
                  sudo reboot
                  Und ich würde mir auch einen vernünftigen USER anlegen. Da mit dem iobroker rumzumachen ist nicht gerade günstig.
                    @Thomas-Braun
                    Auch ein reboot bringt keinen Erfolg. Sollte ich iobroker komplett neu aufsetzten?
                      @tobiii1810
                      iobroker add knx  --prefix "/opt/iobroker"
                      Versuch mal so.
                        @Thomas-Braun said in Error Installation KNX Adapter Ver. 10.0.39:
                        Gleiches Fehlerbild.
                          @tobiii1810 Bitte Ausgaben posten.
                            @Thomas-Braun
                            iobroker@IoBrokerThinClient:/$ iobroker add knx  --prefix "/opt/iobroker"
                            npm ERR! errno -13
                            npm ERR! }
                            npm ERR!
                            npm ERR!
                            npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T20_09_43_507Z-debug.log
                            • Glasfaser
                              @Thomas-Braun
                              ich vermute mal der Ordner ist/war schon da ... aber falsche Rechte gesetzt .
                              und der Fix greift nicht ...
                                Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                                @Glasfaser Nee, da greift der Prefix /opt/iobroker nicht und die Installation soll in / erfolgen. Und das darf der iobroker natürlich nicht. Ich weiß aber nicht wo das einzustellen ist.
                                Das Environment für einen Standarduser weicht ja auch vom Systemuser iobroker ab:
                                pi:x:1000:1000:,,,:/home/pi:/bin/bash
                                iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                                Ich bin aber nicht sicher, ob das damit zu tun haben könnte.
                                In einem 'sauberen' System läuft die Installation ja auch in das richtige Directory rein:
                                iobroker add knx
                                NPM version: 6.14.8
                                npm install iobroker.knx@1.0.42 --loglevel error --prefix "/opt/iobroker" (System call)
                                • Glasfaser
                                  Glasfaser @tobiii1810 last edited by Glasfaser
                                  @Thomas-Braun
                                  Er hat :
                                  müsste das nicht so sein !?
                                  iobroker@IoBrokerThinClient:~#
                                  am Ende
                                    @Glasfaser Nee, das ist schon richtig.
                                    # für root
                                    $ für U$ER
                                    Trotzdem ist iobroker kein 'normaler' User.
                                    Glasfaser T 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      @Thomas-Braun
                                      Oh ...
                                      stimmt ich muß immer umdenken , da es bei der Synology (Docker) anders ist ( root) 🙂
                                        @Thomas-Braun
                                        Bei der Debian Installation habe ich einen User mit dem Namen "iobroker" angelegt. Vielleicht verwirrt der Name nur ein wenig...
                                          @tobiii1810 Ääääääh...
                                          GAAAAAAAAAANZ doofe Idee!
                                          Der iobroker ist für andere Dinge vorgesehen.
                                            @Thomas-Braun
                                            Kann ich den Usernamen nachträglich ändern?
                                            iobroker
                                            4199
