    4. Error Installation KNX Adapter Ver. 10.0.39
    UNSOLVED Error Installation KNX Adapter Ver. 10.0.39
      tobiii1810 @Thomas Braun last edited by
      @Thomas-Braun
      Auch ein reboot bringt keinen Erfolg. Sollte ich iobroker komplett neu aufsetzten?
        Thomas Braun Most Active @tobiii1810 last edited by
        @tobiii1810
        iobroker add knx  --prefix "/opt/iobroker"
        Versuch mal so.
        T Glasfaser 2 Replies Last reply Reply Quote 0
          @Thomas-Braun said in Error Installation KNX Adapter Ver. 10.0.39:
          Gleiches Fehlerbild.
            @tobiii1810 Bitte Ausgaben posten.
              @Thomas-Braun
              iobroker@IoBrokerThinClient:/$ iobroker add knx  --prefix "/opt/iobroker"
              host.IoBrokerThinClient install adapter knx
              npm install --loglevel error --production (System call) in "/node_modules/iobroker.knx"
              npm ERR! code EACCES
              npm ERR! syscall access
              npm ERR! path /node_modules/iobroker.knx
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.knx'
              npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.knx'] {
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'access',
              npm ERR!   path: '/node_modules/iobroker.knx'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T20_09_43_507Z-debug.log
              Cannot install iobroker.knx: 243
              • Glasfaser
                Glasfaser @Thomas Braun last edited by Glasfaser
                @Thomas-Braun
                ich vermute mal der Ordner ist/war schon da ... aber falsche Rechte gesetzt .
                und der Fix greift nicht ...
                  Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                  @Glasfaser Nee, da greift der Prefix /opt/iobroker nicht und die Installation soll in / erfolgen. Und das darf der iobroker natürlich nicht. Ich weiß aber nicht wo das einzustellen ist.
                  Das Environment für einen Standarduser weicht ja auch vom Systemuser iobroker ab:
                  pi:x:1000:1000:,,,:/home/pi:/bin/bash
                  iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                  Ich bin aber nicht sicher, ob das damit zu tun haben könnte.
                  In einem 'sauberen' System läuft die Installation ja auch in das richtige Directory rein:
                  iobroker add knx
                  NPM version: 6.14.8
                  npm install iobroker.knx@1.0.42 --loglevel error --prefix "/opt/iobroker" (System call)
                  • Glasfaser
                    Glasfaser @tobiii1810 last edited by Glasfaser
                    @Thomas-Braun
                    Er hat :
                    müsste das nicht so sein !?
                    iobroker@IoBrokerThinClient:~#
                    am Ende
                      @Glasfaser Nee, das ist schon richtig.
                      # für root
                      $ für U$ER
                      Trotzdem ist iobroker kein 'normaler' User.
                      Glasfaser T 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        @Thomas-Braun
                        Oh ...
                        stimmt ich muß immer umdenken , da es bei der Synology (Docker) anders ist ( root) 🙂
                          @Thomas-Braun
                          Bei der Debian Installation habe ich einen User mit dem Namen "iobroker" angelegt. Vielleicht verwirrt der Name nur ein wenig...
                            @tobiii1810 Ääääääh...
                            GAAAAAAAAAANZ doofe Idee!
                            Der iobroker ist für andere Dinge vorgesehen.
                              @Thomas-Braun
                              Kann ich den Usernamen nachträglich ändern?
                                @tobiii1810
                                cat /etc/passwd | grep iobroker
                                  @Thomas-Braun
                                  iobroker@IoBrokerThinClient:/$ cat /etc/passwd | grep iobroker
                                  iobroker:x:1000:1000:Iobroker,,,:/home/iobroker:/bin/bash
                                    @tobiii1810
                                    Ja, das ist für die UID 1000 das richtige Setup, aber der falsche Name...
                                    Der User iobroker läuft eigentlich so:
                                      Thomas Braun Most Active @Thomas Braun last edited by
                                      @Thomas-Braun
                                        @tobiii1810
                                        sudo usermod -l neueruser iobroker
                                        Für neueruser halt was passendes nehmen. tobi z. B.
                                          @Thomas-Braun
                                          Kann den Usernamen wahrscheinlich nicht ändern da ich mit ihm angemeldet bin oder?
                                          iobroker@IoBrokerThinClient:/$ sudo usermod -l tobi iobroker
                                          [sudo] Passwort für iobroker:
                                          usermod: user iobroker is currently used by process 776
                                            Thomas Braun Most Active @tobiii1810 last edited by Thomas Braun
                                            @tobiii1810
                                            Hatte ich mir fast gedacht.
                                            Dann halt so:
                                            sudo adduser tobi
                                            sorgfältig ausfüllen.
                                            Dann
                                            sudo usermod -a -G sudo tobi
                                            Dann als tobi anmelden.
                                            Danach
                                            sudo deluser iobroker
                                            Und dann den
                                            iobroker fix
                                            iobroker
                                            4199
