    4. Error Installation KNX Adapter Ver. 10.0.39
    UNSOLVED Error Installation KNX Adapter Ver. 10.0.39
      Thomas Braun Most Active @tobiii1810 last edited by Thomas Braun
      @tobiii1810
      Hatte ich mir fast gedacht.
      Dann halt so:
      sudo adduser tobi
      sorgfältig ausfüllen.
      Dann
      sudo usermod -a -G sudo tobi
      Dann als tobi anmelden.
      Danach
      sudo deluser iobroker
      Und dann den
      iobroker fix
        tobiii1810 @Thomas Braun last edited by
        @Thomas-Braun
        tobi@IoBrokerThinClient:~$ iobroker add knx  --prefix "/opt/iobroker"
        host.IoBrokerThinClient install adapter knx
        npm install --loglevel error --production (System call) in "/node_modules/iobroker.knx"
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /node_modules/iobroker.knx
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.knx'
        npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.knx'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/node_modules/iobroker.knx'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T20_56_23_245Z-debug.log
        Cannot install iobroker.knx: 243
          @tobiii1810 Alles bei den Usern gerade gezogen?
          iobroker fix
          vorher ausgeführt?
            @Thomas-Braun
            tobi@IoBrokerThinClient:~$ sudo deluser iobroker
            [sudo] Passwort für tobi:
            Entferne Benutzer »iobroker« ...
            userdel: user iobroker is currently used by process 3645
            /usr/sbin/deluser: »/sbin/userdel iobroker« gab den Fehlercode 8 zurück. Programmende.
              @Thomas-Braun
                @tobiii1810 Achso, vorher den iobroker stoppen.
                iobroker stop
                  @Thomas-Braun
                  tobi@IoBrokerThinClient:~$ iobroker stop
                  userdel: Gruppe iobroker nicht entfernt, da sie noch andere Mitglieder hat.
                  Fertig.
                    @tobiii1810
                    cat /etc/group | grep iobroker
                      @Thomas-Braun
                      tobi@IoBrokerThinClient:~$ cat /etc/group | grep iobroker
                      iobroker:x:1000:tobi
                        @tobiii1810
                        id
                          @Thomas-Braun
                          uid=1001(tobi) gid=1001(tobi) Gruppen=1001(tobi),27(sudo),1000(iobroker)
                            @tobiii1810
                            sudo -u iobroker id
                              @Thomas-Braun
                              sudo: Unbekannter Benutzer: iobroker
                              sudo: Regelwerks-Plugin konnte nicht initialisiert werden
                                @tobiii1810 Gut. Starte mal durch.
                                Kann sein, dass der iobroker dann klemmt.
                                Dann
                                iobroker stop
                                iobroker fix
                                iobroker start
                                  @Thomas-Braun
                                  Er hängt jetzt wie du sagtest
                                  library: loaded
                                  Library version=2020-06-12
                                      Welcome to the ioBroker installation fixer!
                                      Script version: 2020-06-15
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/3)
                                  OK:1 http://security.debian.org/debian-security buster/updates InRelease
                                  OK:2 http://deb.debian.org/debian buster InRelease
                                  OK:3 http://deb.debian.org/debian buster-updates InRelease
                                  OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                  Installed gcc-c++
                                      Checking ioBroker user and directory permissions (2/3)
                                  useradd: Gruppe iobroker existiert - wenn Sie den Benutzer zur Gruppe hinzufügen
                                  möchten, benutzen Sie -g.
                                  User iobroker created
                                  Created /etc/sudoers.d/iobroker
                                  usermod: Benutzer »iobroker« ist nicht vorhanden.
                                  Fixing directory permissions...
                                  chown: ungültiger Benutzer: „iobroker:iobroker“
                                      Checking autostart (3/3)
                                  Enabling autostart...
                                  Autostart enabled!
                                      Your installation was fixed successfully
                                      Run iobroker start to start ioBroker again!
                                  tobi@IoBrokerThinClient:~$ iobroker start
                                    @tobiii1810
                                    sudo -u iobroker groups
                                      @Thomas-Braun
                                      tobi@IoBrokerThinClient:~$ sudo -u iobroker groups
                                        @tobiii1810
                                        cat /etc/passwd | grep iobroker
                                          @Thomas-Braun
                                          tobi@IoBrokerThinClient:~$ cat /etc/passwd | grep iobroker
                                            @tobiii1810
                                            sudo useradd -m -s /usr/sbin/nologin iobroker
                                            iobroker
                                            4206
