    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Вопросы по написанию скриптов
      creo last edited by
      Готово
      ! 20:35:34.143 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:35:34.143 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479334138,"ack":true,"lc":1474479334138,"from":"system.adapter.megad.1"} 20:35:34.244 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:35:34.244 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479334239,"ack":true,"lc":1474479334239,"from":"system.adapter.megad.1"} 20:35:37.399 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:35:37.399 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479337396,"ack":true,"lc":1474479337396,"from":"system.adapter.megad.1"} 20:35:37.500 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:35:37.501 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479337497,"ack":true,"lc":1474479337497,"from":"system.adapter.megad.1"} 20:35:49.257 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:35:49.257 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479349252,"ack":true,"lc":1474479349252,"from":"system.adapter.megad.1"} 20:35:49.355 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:35:49.356 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479349352,"ack":true,"lc":1474479349352,"from":"system.adapter.megad.1"} 20:36:04.770 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:04.770 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479364766,"ack":true,"lc":1474479364766,"from":"system.adapter.megad.1"} 20:36:04.872 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:04.872 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479364867,"ack":true,"lc":1474479364867,"from":"system.adapter.megad.1"} 20:36:07.400 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:07.401 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479367397,"ack":true,"lc":1474479367397,"from":"system.adapter.megad.1"} 20:36:07.503 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:07.503 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479367499,"ack":true,"lc":1474479367499,"from":"system.adapter.megad.1"} 20:36:21.801 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:21.801 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479381790,"ack":true,"lc":1474479381790,"from":"system.adapter.megad.1"} 20:36:21.892 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:21.893 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479381889,"ack":true,"lc":1474479381889,"from":"system.adapter.megad.1"} 20:36:29.213 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:29.214 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479389208,"ack":true,"lc":1474479389208,"from":"system.adapter.megad.1"} 20:36:29.312 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:29.313 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479389309,"ack":true,"lc":1474479389309,"from":"system.adapter.megad.1"} 20:36:31.897 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:31.898 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479391893,"ack":true,"lc":1474479391893,"from":"system.adapter.megad.1"} 20:36:32.008 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:32.009 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479391997,"ack":true,"lc":1474479391997,"from":"system.adapter.megad.1"} 20:36:34.856 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:34.857 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479394853,"ack":true,"lc":1474479394853,"from":"system.adapter.megad.1"} 20:36:34.958 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:34.959 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479394953,"ack":true,"lc":1474479394953,"from":"system.adapter.megad.1"} 20:36:37.411 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:37.412 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479397405,"ack":true,"lc":1474479397405,"from":"system.adapter.megad.1"} 20:36:37.501 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:37.502 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479397498,"ack":true,"lc":1474479397498,"from":"system.adapter.megad.1"} 20:36:41.742 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:36:41.742 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479401732,"ack":true,"lc":1474479401732,"from":"system.adapter.megad.1"} 20:36:41.841 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:36:41.841 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479401833,"ack":true,"lc":1474479401833,"from":"system.adapter.megad.1"} 20:37:02.262 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:02.264 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479422255,"ack":true,"lc":1474479422255,"from":"system.adapter.megad.1"} 20:37:02.361 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:02.362 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479422355,"ack":true,"lc":1474479422355,"from":"system.adapter.megad.1"} 20:37:07.409 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:07.410 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479427405,"ack":true,"lc":1474479427405,"from":"system.adapter.megad.1"} 20:37:07.512 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:07.513 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479427509,"ack":true,"lc":1474479427509,"from":"system.adapter.megad.1"} 20:37:07.942 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:07.944 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479427935,"ack":true,"lc":1474479427935,"from":"system.adapter.megad.1"} 20:37:08.039 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:08.042 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479428035,"ack":true,"lc":1474479428035,"from":"system.adapter.megad.1"} 20:37:10.819 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:10.820 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479430810,"ack":true,"lc":1474479430810,"from":"system.adapter.megad.1"} 20:37:10.919 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:10.920 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479430913,"ack":true,"lc":1474479430913,"from":"system.adapter.megad.1"} 20:37:14.094 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:14.095 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479434089,"ack":true,"lc":1474479434089,"from":"system.adapter.megad.1"} 20:37:14.191 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:14.192 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479434188,"ack":true,"lc":1474479434188,"from":"system.adapter.megad.1"} 20:37:16.631 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:16.631 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479436625,"ack":true,"lc":1474479436625,"from":"system.adapter.megad.1"} 20:37:16.738 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:16.738 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479436732,"ack":true,"lc":1474479436732,"from":"system.adapter.megad.1"} 20:37:20.461 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:20.463 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479440454,"ack":true,"lc":1474479440454,"from":"system.adapter.megad.1"} 20:37:20.562 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:20.563 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479440556,"ack":true,"lc":1474479440556,"from":"system.adapter.megad.1"} 20:37:24.479 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: true[ack: true], onSensor: 0 20:37:24.480 [info] javascript.0 script.js.common.test_on: {"val":true,"ts":1474479444473,"ack":true,"lc":1474479444473,"from":"system.adapter.megad.1"} 20:37:24.581 [info] javascript.0 script.js.common.test_on: svetOn: 1, p1_Движение_гостинная: false[ack: true], onSensor: 0 20:37:24.583 [info] javascript.0 script.js.common.test_on: {"val":false,"ts":1474479444575,"ack":true,"lc":1474479444575,"from":"system.adapter.megad.1"} !
      • Bluefox
        Bluefox last edited by
        Ну ты то хоть понимаешь, что ты видишь? Как бы ты это интерпретировал?
          creo last edited by
          Да у меня блин стоит в настройке "при размыкании" вот и шлёт постоянно true, а false при сработке (
          • Bluefox
            @creo:
            Да у меня блин стоит в настройке "при размыкании" вот и шлёт постоянно true, а false при сработке ( `
            А почему каждые 5 секунд? Может выключение света вызывать срабатывание движения?
            • I
              instalator last edited by
              @creo:
              Посади порт на землю, тоже самое?
                andrey99986 last edited by
                Добавил ещё один драйвер javascript.
                Как создавать и переносить скрипты в новый драйвер js? Не могу найти переключение в админке.
                Хочу чтобы часть скриптов (потенциально опасных) работало под одним,
                Другая часть - отлаженных и отвечающих за безопасность дома под другим.
                Так как уже неоднократно ошибки в скриптах "ложили" драйвер со всеми другими скриптами.
                Надеюсь что при этом глобальные переменные останутся доступны в обоих драйверах.
                  Haus last edited by
                  @andrey99986:
                  Надеюсь что при этом глобальные переменные останутся доступны в обоих драйверах. `
                  В вкладке скрипты возле названия скрипта у тебя "0" поменяй ” на "1"
                    @Haus:
                    @andrey99986:
                    Надеюсь что при этом глобальные переменные останутся доступны в обоих драйверах. В вкладке скрипты возле названия скрипта у тебя "0" поменяй ” на "1"
                    Понял, спасибо.
                      Ho Hum last edited by
                      Можно ли из скрипта изменить значение свойства "unit" существующего объекта?
                      Пример - хочу выводить на экран свободное место на диске и, в зависимости от его значения прописывать в unit Gb, Mb, Kb.
                      • I
                        @Ho Hum:
                        Пример - хочу выводить на экран свободное место на диске и, в зависимости от его значения прописывать в unit Gb, Mb, Kb. `
                        в vis выводи Gb, Mb, Kb. отдельным виджетом с формулой. Или создай скрипт и добавляй к цифрам нужное и сохраняй в другой объект
                          Да, про это я тоже думал, просто хотелось сделать покрасивее 🙂
                          Спасибо.
                            Для управления контентом в vis надо использовать readFile, writeFile.
                            А что использовать для корректного удаления файла?
                            Ситуация такая:
                            удалил файл:
                            fs.unlinkSync(small_img);
                            в файловой системе файла нет. В проводнике редактора Vis-а тоже нет.
                            В браузере (на котором ни разу к этому урлу не обращались, то есть дело не в кэше клиента) на клиенте файл-картинка загружается.
                            Перезапускал драйвер vis, web - не помогает.
                              spectrekr last edited by
                              Странности с indexof
                              var arr_name = [], arr_work = [];
                              ! sendTo('sql.0', 'query', "SELECT name FROM work.work GROUP BY name", function(res) {
                              if (res.error) {
                              console.error(res.error);
                              for (var a in res.result) {
                              arr_name.push(res.result[a].name);
                              ! if(prev_command === name_cust && arr_work.indexOf(command) < 0){
                              for (var a in arr_work) {
                              log(arr_work[a]);
                              log(typeof(arr_work));
                              log(arr_work.indexOf(command));
                              возвращает -1, хо 1 элемент в массиве, хоть несколько. Правда элементы кириллический текст.
                              • I
                                @spectrekr:
                                ! var arr_name = [], arr_work = [];
                                ! if (res.error) {
                                ! console.error(res.error);
                                ! for (var a in res.result) {
                                ! arr_name.push(res.result[a].name);
                                ! for (var a in arr_work) {
                                ! log(arr_work[a]);
                                ! log(typeof(arr_work));
                                ! log(arr_work.indexOf(command));
                                возвращает -1, хо 1 элемент в массиве, хоть несколько. Правда элементы кириллический текст. `
                                Что пишет в лог?
                                var arr_name = [], arr_work = []; ! sendTo('sql.0', 'query', "SELECT name FROM work.work GROUP BY name", function(res) { if (res.error) { console.error(res.error); } for (var a in res.result) { arr_name.push(res.result[a].name); } log('Масиив = ' + JSON.stringify(arr_name)); ! if(prev_command === name_cust && ~arr_work.indexOf(command)){ for (var b in arr_work) { log(arr_work[b]); } log(typeof(arr_work)); log(arr_work.indexOf(command)); } ! });[/b]
                                  Есть ли возможность подписаться на открытие(загрузку) web-страницы, созданной в vis?
                                  Другими словами при открытии определённой страницы (/vis/index.html#mypage) надо запустить определённую функцию, созданную в "Скриптах" админки ( на стороне сервера).
                                    Код
                                    sendTo('sql.0', 'query','SELECT SenderNumber, ReceivingDateTime, TextDecoded FROM smsd.inbox WHERE ID = ' + id, function(res) {
                                    if (res.error) {
                                    log(res.error);
                                    a = {"phone" : res.result[0].SenderNumber,
                                    "time" : formatDate(new Date(res.result[0].ReceivingDateTime), 'DD.MM.YYYY hh:mm'),
                                    "text" : res.result[0].TextDecoded
                                    setState('sms.in.phone', res.result[0].SenderNumber);
                                    setState('sms.in.time', formatDate(new Date(res.result[0].ReceivingDateTime), 'DD.MM.YYYY hh:mm'));
                                    setState('sms.in.text', res.result[0].TextDecoded);
                                    //setState('sms.in.json', a);
                                    setState('sms.in.json', JSON.stringify(res));
                                    setState('sms.in.id', id);
                                      AvaloncheG last edited by
                                      Поделитесь кто то скриптом управления шаговым двигателем или ссылкой на форуме где почитать.
                                      Планирую с MegaESP через драйвер ULN2003.
                                      Спасибо.
                                      • I
                                        @AvaloncheG:
                                        Спасибо. `
                                        А причем тут скрипт? Пиши прошивку для есп, а из иоб будешь задавать только угол поворота или скорость и шаги
                                          @AvaloncheG:
                                          Спасибо. `
                                          Или посмотрите в сторону прошивки wifi-iot, там шаговый реализован, а с iob можно через mqtt связать.
                                            @instalator:
                                            А причем тут скрипт? `
                                            Через скрипт нереально?
                                            Просто хотелось какой то унификации, и не выделять одно устройство только для двигателя.
                                            Я конечно не программист, но как то не вижу принципиальной разницы ноги будет дергать прошивка, или внешняя прога.
                                            Поправьте если ошибаюсь 😃
                                            1.0k
                                            358
                                            104235
