    5. [gelöst] Kodi: Enduhrzeit berechnen
      Kuddel @paul53 last edited by Kuddel
      @paul53 ah danke das minus hatte ich falsch. ich werde testen.
      ja die DPs haben den gleichen Namen
      EDIT: Funktioniert, Vielen Dank
        Kuddel @Kuddel last edited by
        hier das Endergenis als Blockly-Export
         <variables>
           <variable id="Gv49fQ40~+/ya6#JMvO}">time_total</variable>
           <variable id="8?J4Jmf7%_-wS9!yell|">time</variable>
           <variable id="z6@)Eo%V776?qOlzgeJq">sekunden_total</variable>
           <variable id="c70ch.|4qGYP3!UEvS8x">sekunden</variable>
           <variable id="7gbI~lkqQ~M|C;mJ+cDq">i</variable>
           <variable id="fB}3.DkAG[Zns[jkc^B)">diff</variable>
         </variables>
         <block type="on_ext" id="UyS4Ckq]DK=u(E|IV5|a" x="-37" y="-412">
           <value name="OID0">
             <shadow type="field_oid" id="y%CApDq%H-@(J:5?MAiU">
               <field name="oid">kodi.0.state</field>
             <block type="controls_if" id="U|}v1P+7Z((QVxnb;L(Z">
                 <block type="logic_compare" id="_WknMe|%WU5qtbA=6L4y">
                   <field name="OP">NEQ</field>
                     <block type="get_value" id="ne2kI/B~3Ag$)Up_!s92">
                       <field name="OID">kodi.0.state</field>
                     <block type="text" id="^t@S/LR+s?0fdO/$$5Fr">
                       <field name="TEXT">stop</field>
                 <block type="variables_set" id="D63tdWNK3cfIk,(8*g[7">
                   <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field>
                     <block type="lists_split" id="#Bs8uF;CIVzH*#~zWC[Z">
                       <mutation mode="SPLIT"></mutation>
                       <field name="MODE">SPLIT</field>
                       <value name="INPUT">
                         <block type="get_value" id="O,$imajljBUn8`qd51tT">
                           <field name="OID">kodi.0.info.playing_time_total</field>
                       <value name="DELIM">
                         <shadow type="text" id="i][20zd:a%Z5WuNJbjiW">
                           <field name="TEXT">:</field>
                     <block type="variables_set" id="}rdCX^x;8$i%04ZJcd2o">
                       <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field>
                         <block type="lists_split" id="/Tn?XMzhD[7o!]%7bN|`">
                             <block type="get_value" id="DHiTi[yB@_!HVVYFZQ#{">
                               <field name="OID">kodi.0.info.playing_time</field>
                             <shadow type="text" id="9r`t]#N.!+f5CYhltB$5">
                         <block type="variables_set" id="N+qpos_aO8E|Dv1]If3E">
                           <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field>
                             <block type="math_number" id="e+Zv|}##KEg-jWW.VhR^">
                               <field name="NUM">0</field>
                             <block type="variables_set" id="CI6cuB*r3V3air$w}Th*">
                               <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field>
                                 <block type="math_number" id=")aK/~m.cZKr^5i+?jiyR">
                                 <block type="controls_for" id="05XR;DD2{J#JGlH#k1Pp">
                                   <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field>
                                   <value name="FROM">
                                     <shadow type="math_number" id="Z0e;xMGN}wF~qup4h:!n">
                                       <field name="NUM">1</field>
                                   <value name="TO">
                                     <shadow type="math_number" id="5v*f*V{Pbzjd%cm[w9}|">
                                       <field name="NUM">10</field>
                                     <block type="lists_length" id=";l8nh!gomPd#o,AWU(x~">
                                         <block type="variables_get" id="Fie%v/GluA(0/Uv2LjvW">
                                   <value name="BY">
                                     <shadow type="math_number" id="Na-(x3y(g|Ic]PwD}Bc6">
                                   <statement name="DO">
                                     <block type="math_change" id="#RfBewH#M+$qHo,i[pW]">
                                       <value name="DELTA">
                                         <shadow type="math_number" id="c)!+NvI${{Hqg6ODoKwG">
                                         <block type="math_arithmetic" id="DO0C_qkin^w7Zg`13^Ax" inline="false">
                                             <shadow type="math_number" id=":u]~YX#Px.)8XVC^+4OC">
                                             <block type="math_arithmetic" id="UthyNeMI|9X*q)Zg.`%k">
                                               <field name="OP">POWER</field>
                                                 <shadow type="math_number" id=")MuNoA~pKeC)=?cD[FLN">
                                                   <field name="NUM">60</field>
                                                 <shadow type="math_number" id="EZi-Gj-IR~d^|{BPNXC|">
                                                 <block type="math_arithmetic" id="ugyZ{PW4wVs9l6@OZ9s1">
                                                     <shadow type="math_number" id="qaDS=5JKYmJ..f7O8[rN">
                                                     <block type="variables_get" id="^49ie8|ms}QAX2RjO=B(">
                                                     <shadow type="math_number" id="#;ZqpYS`M@3`7V=OE{#H">
                                             <shadow type="math_number" id="Hc[Z7Ru]=Ptfd}zfJPK)">
                                             <block type="convert_tonumber" id="jsfEtcf|%mTFET*+J97e">
                                                 <block type="lists_getIndex" id="{,3_@Jd`[eLJtDn9%zQ.">
                                                   <field name="WHERE">FROM_END</field>
                                                     <block type="variables_get" id="t-j[3g5C#p5(I;hJu6`{">
                                                   <value name="AT">
                                                     <block type="variables_get" id="#k^6{@JW.j_lLZz-!au[">
                                     <block type="controls_for" id="*i`Bgncmb]fI%^@Yqe+d">
                                       <value name="FROM">
                                         <shadow type="math_number" id="T:rLT72NA!Ldh.=kc(#!">
                                       <value name="TO">
                                         <shadow type="math_number">
                                         <block type="lists_length" id="/bH4Y.WEZHIFo-V02N1!">
                                             <block type="variables_get" id="0CwKH!7j{{B.14[u{-pc">
                                       <value name="BY">
                                         <shadow type="math_number" id="S?1g$6pH5gYVMz44YY[!">
                                         <block type="math_change" id="^$zYDn-;*4Y1zrxPf`|r">
                                             <block type="math_arithmetic" id="~T0g:DWVaNElI(yal`W!" inline="false">
                                                 <block type="math_arithmetic" id="1k[z/FsR547Q9QvY8WT%">
                                                     <shadow type="math_number" id="#dXtj]g-7}K4y(W0N?_1">
                                                     <block type="math_arithmetic" id="b-Q:1*!1y!-0ROIQ}2mg">
                                                         <block type="variables_get" id=";Yi(1HBUE0);GL[iBTB=">
                                                         <shadow type="math_number" id="b8dUH`nESfT3H]?K#I!?">
                                                 <block type="convert_tonumber" id="Gz7jq)g)/PC(]P*_n@hr">
                                                     <block type="lists_getIndex" id="7M0K,#1MX$pd$@jGnpXu">
                                                         <block type="variables_get" id="5jm{qI-%F/VhD?1%BdF4">
                                                       <value name="AT">
                                                         <block type="variables_get" id="}m`fxeU`x/9js9M#}FPY">
                                         <block type="variables_set" id=")?r?W1sUUKIHU@q^jKu2">
                                           <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field>
                                             <block type="math_arithmetic" id="9xBzQF]l!H5ehz:-`(nh" inline="false">
                                                 <shadow type="math_number" id="^}W9TM?z6jjL}N_j,Mx^">
                                                   <field name="NUM">1000</field>
                                                 <shadow type="math_number" id="5SNb|`kFhqCJGU|p/@JB">
                                                 <block type="math_arithmetic" id="CaGXbf_m9_?=FT}9C8ic" inline="false">
                                                     <shadow type="math_number" id="-czVq.1JE(QbLjRK7NMa">
                                                     <block type="variables_get" id="+vZTtD$s`!^[Woo)#Rk^">
                                                     <shadow type="math_number" id=";7BwHg}pRu600~Q4*No]">
                                                     <block type="variables_get" id="e[e9GA[x@o4N9f0,%5.^">
                                             <block type="control" id="ZHfzdb6%v,`[zO_!f:6d">
                                               <field name="OID">javascript.0.sonstige.kodi_endzeit</field>
                                                 <block type="convert_from_date" id="423)BA7-JL#+K^YrxtY!">
                                                   <field name="OPTION">hh:mm</field>
                                                     <block type="math_arithmetic" id="M~;ci|@Wq$,ydkp6uLd1">
                                                       <field name="OP">ADD</field>
                                                         <shadow type="math_number" id="?TYndgc}q5yB$k0|Tp?@">
                                                         <block type="time_get" id="OGG8/S@3l23!N9-LzSR{">
                                                           <field name="OPTION">object</field>
                                                         <shadow type="math_number" id="s-,[jty8kUa~cG{-qS1Z">
                                                         <block type="variables_get" id="v)f?IW~A1oRX9GvWUZMp">
               <statement name="ELSE">
                 <block type="control" id="VSZMp_fJpd1OzYCY=~xN">
                     <block type="text" id="b8vzkml]yd@f[0(Q`e(2">
                       <field name="TEXT"></field>
          dos1973 @Kuddel last edited by
          @Kuddel
          Danke Dir für das Bereitstellen des fertigen Blockeis
          ich habe bei mir den DP
          kodi.0.seek
          ergänzt
          das hat den Vorteil dass ich vorspulen kann und die Enduhrzeit aktualisiert sich aus gleich.
          Was mir etwas Kopfzerbrechen macht ist die Häufigkeit der Aktualisierung da der DP "Seek" aufgrund der 3 "Komma Nachstellen" sehr viele Aktualisierungen erfährt, das geht sozusagen im Sekunden Takt.
          wie schätzt du das ein, kann ich das ignorieren oder sollte so etwas vermieden werden.
          paul53 K 2 Replies Last reply Reply Quote 0
            paul53 @dos1973 last edited by
            @dos1973 sagte:
            Mit Sekundentakt sollte eine moderne Hardware zurecht kommen.
              Kuddel @dos1973 last edited by
              @dos1973 ja das mit seek macht sinn. habe ich direkt mit eingebaut
                dos1973 @Kuddel last edited by dos1973
                @Kuddel
                am liebsten wäre es mir, wenn eine Zeit Aktualisierung bei ganzen Zahlen des "Seek" erfolg. Aktuell zeigt der DP den Wert "27.0689" in % aber ich wüsste nicht wie und wo ich das anpasse/ anheften müsste.
                Ich stelle mich schwer mit Blockly 😞
                  @dos1973 wird glaube nicht funktionieren.
                  wenn man seek als Trigger nimmt, löst das Skript bei jeder noch so kleinen Änderung vom seek wert aus.
                  man könnte evtl. versuchen mit einmal falls Block zu prüfen ob es ein *.0 wert ist und nur dann die Berechnung ausführen
                  D paul53 2 Replies Last reply Reply Quote 0
                    @Kuddel
                    Ich habe den Ansatz Verfolgt bei Änderung von Seek ein Timeout zu setzen (2-5sekunden) und dann zu aktualisieren.
                    aber hat bisher nicht gefruchtet
                    E
                      paul53 @Kuddel last edited by
                      @Kuddel sagte:
                      Die Prüfung wird nur selten erfolgreich sein. Besser runden und auf Änderung zum vorherigen gerundeten Wert prüfen.
                        @dos1973 macht auch keinen sinn. das skript startet ja trotzdem bei jeder änderung. die berechnung folgt dann nur ein paar sekunden später
                          @Kuddel
                          Soll ja auch, ich will ja die ende Uhrzeit haben.
                          Oder haben wir ein Missverständnis ?
                            dos1973 @dos1973 last edited by
                            Es ist nicht im Sekundenbereich,
                            Eher im ms Sekunden Bereich wo das Script dann immer ausgeführt wird. Ich denke dass kann dann schon zu Engpässen führen
                            K 3 Replies Last reply Reply Quote 0
                              @dos1973 das finde ich auch.
                              also den trigger selber mit kodi.0.state und kodi.0.seek wird man nicht verbessern können.
                              somit startet das skirpt quasi permanent.
                              Entweder prüft man jetzt auf den % Wert, sodass die weitere Berechnung nicht ausgeführt wird.
                              Oder man baut das Skript komplett um:
                              Trigger = kodi.0.state
                              wenn state = play -> alle 1000ms Schleife, die die Berechnung durchführt.
                              wenn state = stop -> beende Schleife
                                Kuddel @dos1973 last edited by Kuddel
                                @dos1973 habe mein Skript nochmal umgebaut.
                                Als Trigger nehme ich nach wie vor kodi.0.state.
                                Wenn state = play oder pause -> Skript läuft in einer Schleife, alle 30 Sekunden
                                Somit wird auch während einer Pause sowie wenn man Spult die Endzeit korrekt berechnet.
                                Export:
                                 <variables>
                                   <variable type="interval" id="Pause">Pause</variable>
                                   <variable id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</variable>
                                 </variables>
                                 <block type="on_ext" id="q-.)uV_$xX9EqI#0)1V{" x="-37" y="-270">
                                   <value name="OID0">
                                     <shadow type="field_oid" id="3Y]sGqJzX97#Y#bnc%2B">
                                     <block type="controls_if" id="#KCO]0`h|hPacKdL)=A2">
                                         <block type="logic_operation" id="Fk*MZyx-?jaWVfOUD74{" inline="false">
                                           <field name="OP">AND</field>
                                             <block type="logic_operation" id="7^bj8pwH}Zu%AB)noQ?@" inline="false">
                                               <field name="OP">OR</field>
                                                 <block type="logic_compare" id="f;Y93jeAj5hLE=HpAXci">
                                                   <field name="OP">EQ</field>
                                                     <block type="get_value" id="+oIYTrzhXShgXD?-dx?!">
                                                     <block type="text" id="L7`/vLtiabj}GQ5_)n?I">
                                                       <field name="TEXT">play</field>
                                                 <block type="logic_compare" id="q@QCe9klq^hq~N~GDy45">
                                                     <block type="get_value" id=".a9WA=7@YR;|n8VLbG6V">
                                                     <block type="text" id=".JZ%Qo2ld8Wni+Ay9fQu">
                                                       <field name="TEXT">pause</field>
                                             <block type="logic_compare" id="S;@tsc#Y9J{l-nz(8#%L">
                                                 <block type="variables_get" id="_lYj.M;X6{:Ig+t1H-OG">
                                                   <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field>
                                                 <block type="logic_boolean" id=":eRp?twu(kMNOV|nraj#">
                                         <block type="timeouts_setinterval" id="uGdM,D)hhj,Ipm210S*$">
                                           <field name="NAME">Pause</field>
                                           <field name="INTERVAL">30000</field>
                                           <field name="UNIT">ms</field>
                                             <block type="variables_set" id="0o{kX1g9TrRziofKKE`n">
                                                 <block type="logic_boolean" id="57_A}S_9aHo-D7/*Q-bz">
                                                 <block type="variables_set" id="fTK`7dy@}I9{xOUk:fdm">
                                                     <block type="lists_split" id="fSNHlFM[e|2s~?~WLoA]">
                                                         <block type="get_value" id="%}I/[z=}v|bA_s+cN3T+">
                                                         <shadow type="text" id="bO/MuTT:URPjI@SOF^wu">
                                                     <block type="variables_set" id="3L:9B.c/-jdK~YPS;}kk">
                                                         <block type="lists_split" id="m0vWY?4A}Fy?zECIMa-g">
                                                             <block type="get_value" id="cmBA^z.eb9hODfdHQbW8">
                                                             <shadow type="text" id=";o/sw@k#dD0mWkC4+b)M">
                                                         <block type="variables_set" id=";/]R)Ct0Dfu6i-d@fN1=">
                                                             <block type="math_number" id="!A%IT%#arX*{$UY8=Kva">
                                                             <block type="variables_set" id="%LYJ{05i.|T3]O%OZlti">
        <block type="math_number" id="-:ZTaSM~NWM#h9LoWuBz">
        <block type="controls_for" id="2R-$*vTVI{p#n(T8RV.d">
        <value name="FROM">
        <shadow type="math_number" id="yo3lqjuQw}eovRb+XXQ?">
        <value name="TO">
        <block type="lists_length" id="030ssz#WyY6qdm{Y]+%7">
        <block type="variables_get" id="LtjmBy}A-?%QRfowFhZH">
        <value name="BY">
        <shadow type="math_number" id="W4)e3sbN-C[AtksvJyb0">
        <block type="math_change" id="gZ[fn:P}L%w5Hu*/k[w]">
        <block type="math_arithmetic" id="_nrssb{}I|MM@7r=B2*[" inline="false">
        <block type="math_arithmetic" id="?QRRgY%9F+.UW^4Wl#AO">
        <shadow type="math_number" id="`nZhdJ)1xBsAmv:WOH{$">
        <block type="math_arithmetic" id="%5v;FD87a~}IdxMU?0vb">
        <block type="variables_get" id="~kv8]AFICio,y}2%8r:A">
        <shadow type="math_number" id="By?4fEM=/cIUg=PVf-%.">
        <block type="convert_tonumber" id="Xjk8qkB+rf0:[Z@JKl{4">
        <block type="lists_getIndex" id="=M7:!eN*k,;Op`ncPBu)">
        <block type="variables_get" id="4n4]sPE}}yOyCqIR6sK$">
        <value name="AT">
        <block type="variables_get" id="5KN91f+6[?BIQQU^P+T/">
        <block type="controls_for" id="/[|3}k{qYeK4wFiN6#lx">
        <value name="FROM">
        <shadow type="math_number" id="1FErI$q)qi=X^N_:%Js?">
        <value name="TO">
        <block type="lists_length" id="yJ$~7a^l4Gd#j:0c3$xr">
        <block type="variables_get" id="Lh*:^j)}o|0jC8rH:.-+">
        <value name="BY">
        <shadow type="math_number" id="T3rAediff*:%E88l7+4%">
        <block type="math_change" id="Bsy0,}!M#a)Xi$$B[t]z">
        <block type="math_arithmetic" id="ecXevA40kHBJjiNry:#^" inline="false">
        <block type="math_arithmetic" id="K#Ey7v.v;+lcl{1f@5]H">
        <shadow type="math_number" id="a~E=mS#u_.VcC[jX^/;*">
        <block type="math_arithmetic" id="p}_MS2!F;,r~o9#j=$`e">
        <block type="variables_get" id="Wr7+iV$a;ynQ,P%0v/|h">
        <shadow type="math_number" id="7DDk.nAP2`-o[3:5T/`V">
        <block type="convert_tonumber" id="95Wkc=Wn9wjOL/~emwC:">
        <block type="lists_getIndex" id="):n}4;0GiBs#gE+_-.uf">
        <block type="variables_get" id="WCs.rt_18?skHj|HC;)H">
        <value name="AT">
        <block type="variables_get" id="dA]HyO~W)iY5ROXqc$PI">
        <block type="variables_set" id="x8t?3^{cNVFaKtPFnFq9">
        <block type="math_arithmetic" id="2+`tDY!LQG^9AZO8#!ZQ" inline="false">
        <shadow type="math_number" id="(_=}+a~Ov.r2s~-^a_*5">
        <block type="math_arithmetic" id="D.`(%|9dOcm*(umN9bT@" inline="false">
        <block type="variables_get" id="u7f(0GaP.#L;(fYVBLIF">
        <block type="variables_get" id="]@3~@l|_;uO[L%2ioP,k">
        <block type="control" id="E.QKHpVBex}})iCx|o|3">
        <block type="text_join" id="r1UQi]J^lm7$v9OOADL%">
        <value name="ADD0">
        <block type="convert_from_date" id="TgQBU@2m$Aam**8naRqf">
        <block type="math_arithmetic" id="vFX,u4337mHL^[94MZjL">
        <block type="time_get" id="WGy*s;07oKI/J`GDI-x3">
        <block type="variables_get" id="%/#p`[h/wlvqSaXg{l2J">
        <value name="ADD1">
        <block type="text" id="+v9neh|_70u#CP~sT+@%">
        <field name="TEXT"> Uhr</field>
                                         <block type="timeouts_clearinterval" id="Jb@;uzYL;m`:c=QqzD4L">
                                             <block type="variables_set" id="iv;KGC[hF6MD=bcKz-}~">
                                                 <block type="logic_boolean" id="V0z@IGk2vj.t5+#2j3f;">
                                  @dos1973 habe die Restzeit auch noch eingebaut:
                                  Das Skript läuft jetzt sekündlich, so lange kodi.0.state nicht gleich stop
                                  <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="q-.)uV_$xX9EqI#0)1V{" x="-37" y="-270">
                                   <value name="OID0">
                                           <field name="NAME">calc</field>
                                           <field name="INTERVAL">1000</field>
        <value name="FROM">
        <value name="TO">
        <value name="BY">
        <value name="AT">
        <value name="FROM">
        <value name="TO">
        <value name="BY">
        <value name="AT">
        <value name="ADD0">
        <value name="ADD1">
        <block type="variables_set" id="nhKmUFQhs[6|q%}ff0,i">
        <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field>
        <block type="math_round" id="x}`o/-C2Wlv:@=^_3G[a">
        <field name="OP">ROUNDDOWN</field>
        <value name="NUM">
        <shadow type="math_number" id="Rguwmsm{fn2;p`R/F+a:">
        <field name="NUM">3.1</field>
        <block type="math_arithmetic" id="+onb0BIs?/9$Yw3z|L~1" inline="false">
        <field name="OP">DIVIDE</field>
        <shadow type="math_number" id="1ayYAO}MFY09NC(V(*GM">
        <block type="math_arithmetic" id="s!0#t?dmhC6%l^`PxZe}" inline="false">
        <shadow type="math_number" id="#7%I3W~1uE-TD~wta#+4">
        <block type="variables_get" id="SgkpuEuN:JsZXnT2uiEq">
        <block type="variables_get" id="qn{!2^XJ4`(v,M5e*2D(">
        <shadow type="math_number" id="^L@[tikpu/4]}P`vZMd!">
        <block type="variables_set" id="Ig)k@jiA9xaKTc]*wBI1">
        <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field>
        <block type="math_arithmetic" id="7;16331LR(~*?2+JX6w(" inline="false">
        <shadow type="math_number" id="CIIcN4{7e~{BnyvZ*~^6">
        <block type="math_arithmetic" id=";3*On@WOxyMp^0y1_Z(Y" inline="false">
        <block type="variables_get" id="b%.CyBM,CrX$vS8~1tsR">
        <block type="variables_get" id="G)4-/!z*)m%l/V.ry4?R">
        <shadow type="math_number" id=".+85]3KB6[(gBZ%[,7Y~">
        <block type="math_arithmetic" id="zmhqTi9sN}dQKx97##xL" inline="false">
        <shadow type="math_number" id="lis_nxPR2u]H-3F[$b~S">
        <block type="variables_get" id="Bt;RhM}rb7h:@KbT}11W">
        <shadow type="math_number" id="LKQ#wr7Q=}y?2oYqM^Z(">
        <block type="controls_if" id="NQRm#kW6C~H}~,#%L^7%">
        <block type="logic_compare" id="LB3RPmG+6NgIm[`*dHW*">
        <field name="OP">LT</field>
        <block type="variables_get" id="x8kn5l:/}[T/I1{38:!m">
        <block type="math_number" id="4MfeA;EPvu1_2Q5)5*18">
        <block type="variables_set" id="S4e+8dy%x$|x`kw^Y1eG">
        <block type="text_join" id="m8@abxaQFWUShO4Yh?^e">
        <value name="ADD0">
        <block type="text" id="CGW`SmYv*y^!z[QWs^o[">
        <field name="TEXT">0</field>
        <value name="ADD1">
        <block type="variables_get" id="jhU!RpxkLcDqpJhV*2c2">
        <block type="control" id="Ea:z~+62@$PdX^kjvAcF">
        <field name="OID">javascript.0.sonstige.kodi_restzeit</field>
        <block type="text_join" id="Ha28o];Hw|$Cmy5!r;{L">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="variables_get" id="7OYB3%b#mpP$M/XIeJ%S">
        <value name="ADD1">
        <block type="text" id="qD7(2)-oK%;2Rz.5k,:`">
        <value name="ADD2">
        <block type="variables_get" id="zNo@n~vAZH2|)3f|_NT}">
        <value name="ADD3">
        <block type="text" id="gMw;QinOi/kC}T?H,Gbn">
        <field name="TEXT"> Min.</field>
                                                     <block type="control" id="AIf3cY6ex%9}xpyKmOtB">
                                                         <block type="text" id="nX.)Ffq{`}-Hsq,#!6^6">
                                    @Kuddel
                                    Wow, ich bin begeistert.
                                    Beide Werte sind vorhanden. ich habe bei mir den wert auf 5 Sekunden angepasst.
                                    aber was ist den "calc"
                                    rein optisch gesehen bei Restzeit 76:22, würde ich folgende Formatierung "01:16:22" ansprechender finden.
                                    Klasse Ding. Vielen Dank für deine Mühe!
                                      @dos1973 calc ist die Schleife. kannst du ignorieren. habe das Skript schon wieder umgebaut.
                                      nehme jetzt die Spielzeit als trigger.
                                      baue seine Vorschlag mit der Formatierung morgen noch ein
                                        @Kuddel
                                        playing time, habe ich auch schon dran gedacht - das ist ja auf sekundenbasis.
                                        Jo, schonmal Danke & bis morgen.
                                          @paul53 kann man die Umrechnung der Restzeit evtl. besser bauen?
                                          Ich habe das aktuell so umgesetzt:
                                          Würde auch irgendwie mit Konvertierung gehen ?
                                          Irgendwie so ?
                                            @Kuddel sagte:
                                            Ja, man muss die Zeitzone berücksichtigen.
                                            1677
