    4. iCal Adapter Fehler: Error: Unknown RRULE property 'RRULE'
    UNSOLVED iCal Adapter Fehler: Error: Unknown RRULE property 'RRULE'
      pxstd last edited by pxstd
      ich habe eben den iCal Adapter Version 1.7.4 installiert.
      Nach dem Versuch der Einrichtung meines Nextcloud Kalenders erhalte ich im Log:
      ical.0	2020-11-04 13:15:36.345	info	(84855) Terminated (NO_ERROR): Without reason
      ical.0	2020-11-04 13:15:36.344	info	(84855) terminating
      ical.0	2020-11-04 13:15:36.326	error	at Object.parseLines (/opt/iobroker/node_modules/node-ical/ical.js:499:18)
      ical.0	2020-11-04 13:15:36.326	error	at Object.handleObject (/opt/iobroker/node_modules/node-ical/ical.js:452:39)
      ical.0	2020-11-04 13:15:36.326	error	at Object.END (/opt/iobroker/node_modules/node-ical/ical.js:415:30)
      ical.0	2020-11-04 13:15:36.326	error	at Function.RRule.fromString (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/rrule.ts:127:28)
      ical.0	2020-11-04 13:15:36.326	error	at Function.parseString (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:7:41)
      ical.0	2020-11-04 13:15:36.326	error	at Array.map (<anonymous>)
      ical.0	2020-11-04 13:15:36.326	error	at parseLine (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:42:14)
      ical.0	2020-11-04 13:15:36.326	error	at parseRrule (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:56:9)
      ical.0	2020-11-04 13:15:36.326	error	at Array.forEach (<anonymous>)
      ical.0	2020-11-04 13:15:36.326	error	at /opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:98:15
      ical.0	2020-11-04 13:15:36.326	error	(84855) Error: Unknown RRULE property 'RRULE'
      ical.0	2020-11-04 13:15:36.326	error	(84855) uncaught exception: Unknown RRULE property 'RRULE'
      Schema der Eintragung:
      URL: https://<domain>/nextcloud/remote.php/dav/calendars/<user>/<kalender>/?export
      Benutzer: <user>
      SSL Fehler ignorieren
      Ideen?
        Thomas Braun Most Active @pxstd last edited by Thomas Braun
        @pxstd
        Node-Version?
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          pxstd @Thomas Braun last edited by pxstd
          @Thomas-Braun
          Mhhh
          strange. Nodejs ist installiert, aber scheinbar nicht korrekt verlinkt.
          #:~# dpkg -l |grep nodejs
          ii  nodejs                               10.23.0-deb-1nodesource1          amd64        Node.js event-based server-side javascript engine
          #:~# which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/node
          v10.23.0
          /usr/bin/npm
          6.14.8
          nodejs:
            Installiert:           10.23.0-deb-1nodesource1
            Installationskandidat: 10.23.0-deb-1nodesource1
            Versionstabelle:
           *** 10.23.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_10.x focal/main amd64 Packages
                  100 /var/lib/dpkg/status
               10.19.0~dfsg-3ubuntu1 500
                  500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
            @pxstd
            Richtig, bei ubuntu sollte man die linken.
            Wie das geht steht hier:
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            Ich würde auch gleich mal auf node12 gehen.
              @Thomas-Braun
              Update Erledigt, leider...
              # which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              /usr/bin/nodejs
              v12.19.0
              /usr/bin/node
              v12.19.0
              /usr/bin/npm
              6.14.8
              nodejs:
                Installiert:           12.19.0-deb-1nodesource1
                Installationskandidat: 12.19.0-deb-1nodesource1
                Versionstabelle:
               *** 12.19.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x focal/main amd64 Packages
              ... bleibt der Fehler bestehen 😕
              ical.0	2020-11-04 13:41:30.229	info	(1779) Terminated (NO_ERROR): Without reason
              ical.0	2020-11-04 13:41:30.228	info	(1779) terminating
              ical.0	2020-11-04 13:41:30.212	error	(1779) Error: Unknown RRULE property 'RRULE' at /opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:98:15 at Array.forEach (<anonymous>) at parseRrule (/opt/iobroke
              ical.0	2020-11-04 13:41:30.211	error	(1779) uncaught exception: Unknown RRULE property 'RRULE'
              ical.0	2020-11-04 13:41:28.259	info	(1779) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.0, js-controller: 3.1.6
                pxstd @pxstd last edited by
                Anyone? 😕
                  @pxstd
                  Die Fehlermeldung ist nicht komplett, da fehlt in der dritten Zeile der Rest.
                  Ich glaube, das sollte sich einer der devs mal anschaun. Mach ein Issue auf:
                  https://github.com/iobroker-community-adapters/ioBroker.ical/issues
                  error ical rrule
