    3. Entwicklung
    4. ZigBee neue/unbekannte Geräte - ab 1.3.0
      memoire @arteck last edited by
      @arteck
      Hallo Arteck,
      vielen Dank, dass du dich gemeldet hast. Hier das LOG. Hoffe, es ist so wie du es wolltest.
      Die LED leuchtete aber nur wenn man auf die "1" Tasten gedrückt hat, bei "0" leuchtete sie nicht.
      zigbee.3	2020-11-05 16:22:59.751	debug	(4909) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.3
      zigbee.3	2020-11-05 16:22:59.751	debug	(4909) getMap result: {"lqis":[{"parent":"0x00124b001ca604ef","networkAddress":61134,"ieeeAddr":"0x00158d0002a4e6e3","lqi":76,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001ca604e
      zigbee.3	2020-11-05 16:22:59.751	debug	(4909) Get map succeeded [{"parent":"0x00124b001ca604ef","networkAddress":61134,"ieeeAddr":"0x00158d0002a4e6e3","lqi":76,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001ca604ef","n
      zigbee.3	2020-11-05 16:22:59.750	debug	(4909) Routing table succeeded for '0x8418260000daabf5'
      zigbee.3	2020-11-05 16:22:59.750	debug	(4909) Routing for '0x8418260000daabf5': {"neighbors":[{"linkquality":36,"networkAddress":0,"ieeeAddr":"0x00124b001ca604ef","relationship":2,"depth":1},{"linkquality":20,"networkAddress":8897,"ieeeAdd
      zigbee.3	2020-11-05 16:22:59.750	debug	(4909) Failed to execute routing table for '0x8418260000daabf5'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitres
      zigbee.3	2020-11-05 16:22:59.554	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:59.554	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtRtgReq - {"status":0}
      zigbee.3	2020-11-05 16:22:59.554	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 50 - [0] - 86
      zigbee.3	2020-11-05 16:22:59.554	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:59.554	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:59.547	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,50,227,236,0,27]
      zigbee.3	2020-11-05 16:22:59.547	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtRtgReq - {"dstaddr":60643,"startindex":0}
      zigbee.3	2020-11-05 16:22:59.546	debug	(4909) LQI succeeded for '0xccccccfffe89fb2c'
      zigbee.3	2020-11-05 16:22:59.546	debug	(4909) Failed to execute LQI for '0xccccccfffe89fb2c'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35
      zigbee.3	2020-11-05 16:22:49.781	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.781	debug	(4909) zigbee-herdsman:adapter:zStack:znp:error Error while parsing to ZpiObject 'RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 5 at boun
      zigbee.3	2020-11-05 16:22:49.780	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 5 - 2 - 5 - 178 - [232,174,132,0,50] - 2
      zigbee.3	2020-11-05 16:22:49.780	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,5,69,178,232,174,132,0,50,2]
      zigbee.3	2020-11-05 16:22:49.780	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [50,2]
      zigbee.3	2020-11-05 16:22:49.780	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,5,69,178,232,174,132,0]
      zigbee.3	2020-11-05 16:22:49.779	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,5,69,178,232,174,132,0]
      zigbee.3	2020-11-05 16:22:49.750	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.747	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtRtgReq - {"status":0}
      zigbee.3	2020-11-05 16:22:49.746	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 50 - [0] - 86
      zigbee.3	2020-11-05 16:22:49.746	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:49.746	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:49.740	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,50,232,174,0,82]
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtRtgReq - {"dstaddr":44776,"startindex":0}
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) LQI succeeded for '0x8418260000daabf5'
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":44776,"status":0,"neighbortableentries":4,"startindex":3,"neighborlqilistcount":1,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 5 - 177 - [232,174,0,4,3,1,221,221,221,221,221,221,221,221,86,103,125,60,223,140,207,4,195,150,66,1,1,32] - 119
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,3,1,221,221,221,221,221,221,221,221,86,103,125,60,223,140,207,4,195,150,66,1,1,32,119]
      zigbee.3	2020-11-05 16:22:49.739	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [119]
      zigbee.3	2020-11-05 16:22:49.738	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,3,1,221,221,221,221,221,221,221,221,86,103,125,60,223,140,207,4,195,150,66,1,1,32]
      zigbee.3	2020-11-05 16:22:49.738	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [207,4,195,150,66,1,1,32]
      zigbee.3	2020-11-05 16:22:49.737	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,3,1,221,221,221,221,221,221,221,221,86,103,125,60,223,140]
      zigbee.3	2020-11-05 16:22:49.737	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,86,103,125,60,223,140]
      zigbee.3	2020-11-05 16:22:49.737	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,3,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.736	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [3,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.736	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.736	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.704	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.704	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:49.704	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:49.704	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.704	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.697	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,232,174,3,82]
      zigbee.3	2020-11-05 16:22:49.697	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":44776,"startindex":3}
      zigbee.3	2020-11-05 16:22:49.697	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.697	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":44776,"status":0,"neighbortableentries":4,"startindex":2,"neighborlqilistcount":1,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:49.697	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 5 - 177 - [232,174,0,4,2,1,221,221,221,221,221,221,221,221,44,251,137,254,255,204,204,204,227,236,18,1,1,255] - 216
      zigbee.3	2020-11-05 16:22:49.697	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,2,1,221,221,221,221,221,221,221,221,44,251,137,254,255,204,204,204,227,236,18,1,1,255,216]
      zigbee.3	2020-11-05 16:22:49.696	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [216]
      zigbee.3	2020-11-05 16:22:49.696	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,2,1,221,221,221,221,221,221,221,221,44,251,137,254,255,204,204,204,227,236,18,1,1,255]
      zigbee.3	2020-11-05 16:22:49.696	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [204,204,227,236,18,1,1,255]
      zigbee.3	2020-11-05 16:22:49.695	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,2,1,221,221,221,221,221,221,221,221,44,251,137,254,255,204]
      zigbee.3	2020-11-05 16:22:49.695	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,44,251,137,254,255,204]
      zigbee.3	2020-11-05 16:22:49.694	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,2,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.694	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [2,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.694	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.693	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.672	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.671	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:49.671	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:49.671	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.671	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.664	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,232,174,2,83]
      zigbee.3	2020-11-05 16:22:49.664	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":44776,"startindex":2}
      zigbee.3	2020-11-05 16:22:49.657	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.657	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":44776,"status":0,"neighbortableentries":4,"startindex":1,"neighborlqilistcount":1,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:49.657	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 5 - 177 - [232,174,0,4,1,1,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,37,1,1,20] - 237
      zigbee.3	2020-11-05 16:22:49.656	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,1,1,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,37,1,1,20,237]
      zigbee.3	2020-11-05 16:22:49.656	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [237]
      zigbee.3	2020-11-05 16:22:49.655	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,1,1,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,37,1,1,20]
      zigbee.3	2020-11-05 16:22:49.655	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [176,124,193,34,37,1,1,20]
      zigbee.3	2020-11-05 16:22:49.654	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,1,1,221,221,221,221,221,221,221,221,76,44,173,0,170,62]
      zigbee.3	2020-11-05 16:22:49.654	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,76,44,173,0,170,62]
      zigbee.3	2020-11-05 16:22:49.654	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,1,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.654	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [1,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.653	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.653	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.611	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.611	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:49.611	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:49.611	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.611	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.604	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,232,174,1,80]
      zigbee.3	2020-11-05 16:22:49.604	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":44776,"startindex":1}
      zigbee.3	2020-11-05 16:22:49.604	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.604	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":44776,"status":0,"neighbortableentries":4,"startindex":0,"neighborlqilistcount":1,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:49.603	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 5 - 177 - [232,174,0,4,0,1,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,36] - 163
      zigbee.3	2020-11-05 16:22:49.603	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,0,1,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,36,163]
      zigbee.3	2020-11-05 16:22:49.603	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [18,0,0,0,36,1,1,36,163]
      zigbee.3	2020-11-05 16:22:49.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,0,1,221,221,221,221,221,221,221,221,239,4,166,28,0,75]
      zigbee.3	2020-11-05 16:22:49.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,239,4,166,28,0,75]
      zigbee.3	2020-11-05 16:22:49.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4,0,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [0,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:49.601	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.601	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,69,177,232,174,0,4]
      zigbee.3	2020-11-05 16:22:49.552	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.551	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:49.551	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:49.551	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.551	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.544	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,232,174,0,81]
      zigbee.3	2020-11-05 16:22:49.544	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":44776,"startindex":0}
      zigbee.3	2020-11-05 16:22:49.544	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:49.544	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:49.544	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:49.544	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.543	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:49.537	debug	(4909) Routing table succeeded for '0xccccccfffe89fb2c'
      zigbee.3	2020-11-05 16:22:49.537	debug	(4909) Routing for '0xccccccfffe89fb2c': undefined
      zigbee.3	2020-11-05 16:22:49.537	debug	(4909) Failed to execute routing table for '0xccccccfffe89fb2c'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitres
      zigbee.3	2020-11-05 16:22:49.537	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,227,236,0,24]
      zigbee.3	2020-11-05 16:22:49.536	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":60643,"startindex":0}
      zigbee.3	2020-11-05 16:22:39.690	debug	(4909) Routing table succeeded for '0x7cb03eaa00ad2c4c'
      zigbee.3	2020-11-05 16:22:39.690	debug	(4909) Routing for '0x7cb03eaa00ad2c4c': {"neighbors":[{"linkquality":50,"networkAddress":0,"ieeeAddr":"0x00124b001ca604ef","relationship":2,"depth":1},{"linkquality":30,"networkAddress":45791,"ieeeAd
      zigbee.3	2020-11-05 16:22:39.690	debug	(4909) Failed to execute routing table for '0x7cb03eaa00ad2c4c'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitres
      zigbee.3	2020-11-05 16:22:39.535	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:39.535	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtRtgReq - {"status":0}
      zigbee.3	2020-11-05 16:22:39.535	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 50 - [0] - 86
      zigbee.3	2020-11-05 16:22:39.535	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:39.534	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:39.527	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,50,227,236,0,27]
      zigbee.3	2020-11-05 16:22:39.527	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtRtgReq - {"dstaddr":60643,"startindex":0}
      zigbee.3	2020-11-05 16:22:39.527	debug	(4909) LQI succeeded for '0xccccccfffe89fb2c'
      zigbee.3	2020-11-05 16:22:39.526	debug	(4909) Failed to execute LQI for '0xccccccfffe89fb2c'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35
      zigbee.3	2020-11-05 16:22:29.721	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.721	debug	(4909) zigbee-herdsman:adapter:zStack:znp:error Error while parsing to ZpiObject 'RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 5 at boun
      zigbee.3	2020-11-05 16:22:29.721	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 5 - 2 - 5 - 178 - [193,34,132,0,50] - 167
      zigbee.3	2020-11-05 16:22:29.721	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,5,69,178,193,34,132,0,50,167]
      zigbee.3	2020-11-05 16:22:29.720	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [50,167]
      zigbee.3	2020-11-05 16:22:29.720	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,5,69,178,193,34,132,0]
      zigbee.3	2020-11-05 16:22:29.719	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,5,69,178,193,34,132,0]
      zigbee.3	2020-11-05 16:22:29.690	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.689	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtRtgReq - {"status":0}
      zigbee.3	2020-11-05 16:22:29.689	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 50 - [0] - 86
      zigbee.3	2020-11-05 16:22:29.689	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:29.689	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,50,0,86]
      zigbee.3	2020-11-05 16:22:29.682	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,50,193,34,0,247]
      zigbee.3	2020-11-05 16:22:29.682	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtRtgReq - {"dstaddr":8897,"startindex":0}
      zigbee.3	2020-11-05 16:22:29.682	debug	(4909) LQI succeeded for '0x7cb03eaa00ad2c4c'
      zigbee.3	2020-11-05 16:22:29.682	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.682	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":8897,"status":0,"neighbortableentries":10,"startindex":9,"neighborlqilistcount":1,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:29.681	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 5 - 177 - [193,34,0,10,9,1,221,221,221,221,221,221,221,221,94,177,63,2,0,141,21,0,107,70,18,1,1,42] - 86
      zigbee.3	2020-11-05 16:22:29.681	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,193,34,0,10,9,1,221,221,221,221,221,221,221,221,94,177,63,2,0,141,21,0,107,70,18,1,1,42,86]
      zigbee.3	2020-11-05 16:22:29.681	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [86]
      zigbee.3	2020-11-05 16:22:29.681	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,193,34,0,10,9,1,221,221,221,221,221,221,221,221,94,177,63,2,0,141,21,0,107,70,18,1,1,42]
      zigbee.3	2020-11-05 16:22:29.681	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [21,0,107,70,18,1,1,42]
      zigbee.3	2020-11-05 16:22:29.680	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,193,34,0,10,9,1,221,221,221,221,221,221,221,221,94,177,63,2,0,141]
      zigbee.3	2020-11-05 16:22:29.680	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,94,177,63,2,0,141]
      zigbee.3	2020-11-05 16:22:29.679	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,193,34,0,10,9,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.679	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [9,1,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.678	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.678	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.649	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.649	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:29.649	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:29.649	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.649	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.642	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,193,34,9,253]
      zigbee.3	2020-11-05 16:22:29.642	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":8897,"startindex":9}
      zigbee.3	2020-11-05 16:22:29.642	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.642	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":8897,"status":0,"neighbortableentries":10,"startindex":6,"neighborlqilistcount":3,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:29.642	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 72 - 2 - 5 - 177 - [193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,66,1,1,14,221,221,221,221,221,221,2
      zigbee.3	2020-11-05 16:22:29.641	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,66,1,1,14,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.641	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [37,1,1,24,161]
      zigbee.3	2020-11-05 16:22:29.641	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [218,0,0,38,24,132,232,174]
      zigbee.3	2020-11-05 16:22:29.640	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,66,1,1,14,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.640	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,245,171]
      zigbee.3	2020-11-05 16:22:29.639	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [143,72,34,1,1,16,221,221]
      zigbee.3	2020-11-05 16:22:29.639	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,66,1,1,14,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.639	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [169,63,65,254,255,20,46,132]
      zigbee.3	2020-11-05 16:22:29.638	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,66,1,1,14,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.638	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.637	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,66,1,1,14]
      zigbee.3	2020-11-05 16:22:29.637	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [51,188,188,31,66,1,1,14]
      zigbee.3	2020-11-05 16:22:29.636	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221,221,221,236,32,40,254,255,172]
      zigbee.3	2020-11-05 16:22:29.636	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,236,32,40,254,255,172]
      zigbee.3	2020-11-05 16:22:29.636	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,6,3,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.636	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [6,3,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.635	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.635	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,72,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.610	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.609	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:29.609	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:29.609	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.609	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.603	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,193,34,6,242]
      zigbee.3	2020-11-05 16:22:29.602	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":8897,"startindex":6}
      zigbee.3	2020-11-05 16:22:29.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.602	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":8897,"status":0,"neighbortableentries":10,"startindex":3,"neighborlqilistcount":3,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:29.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 72 - 2 - 5 - 177 - [193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46,221,221,221,221,221,221,221,2
      zigbee.3	2020-11-05 16:22:29.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.602	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [66,1,1,8,31]
      zigbee.3	2020-11-05 16:22:29.601	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.601	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [137,254,255,204,204,204,89,101]
      zigbee.3	2020-11-05 16:22:29.600	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.600	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,44,251]
      zigbee.3	2020-11-05 16:22:29.599	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [206,238,66,1,1,8,221,221]
      zigbee.3	2020-11-05 16:22:29.599	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.599	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [227,230,164,2,0,141,21,0]
      zigbee.3	2020-11-05 16:22:29.598	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:29.598	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.597	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141,21,0,142,43,18,1,1,46]
      zigbee.3	2020-11-05 16:22:29.597	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [21,0,142,43,18,1,1,46]
      zigbee.3	2020-11-05 16:22:29.597	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221,221,221,239,155,137,2,0,141]
      zigbee.3	2020-11-05 16:22:29.597	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,239,155,137,2,0,141]
      zigbee.3	2020-11-05 16:22:29.596	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,3,3,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.596	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [3,3,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.595	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.595	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,72,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.566	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.566	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:29.566	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:29.566	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.565	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.559	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,193,34,3,247]
      zigbee.3	2020-11-05 16:22:29.559	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":8897,"startindex":3}
      zigbee.3	2020-11-05 16:22:29.559	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.559	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":8897,"status":0,"neighbortableentries":10,"startindex":0,"neighborlqilistcount":3,"neighborlqilist":[{"extPandId":"0xdd
      zigbee.3	2020-11-05 16:22:29.558	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 72 - 2 - 5 - 177 - [193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,50,221,221,221,221,221,221,221,221,23
      zigbee.3	2020-11-05 16:22:29.558	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,50,221,221,221,221,221,221,221,221,232,
      zigbee.3	2020-11-05 16:22:29.558	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [18,1,1,50,243]
      zigbee.3	2020-11-05 16:22:29.552	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,50,221,221,221,221,221,221,221,221,232,
      zigbee.3	2020-11-05 16:22:29.552	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [125,60,223,140,207,4,195,150]
      zigbee.3	2020-11-05 16:22:29.551	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,50,221,221,221,221,221,221,221,221,232,
      zigbee.3	2020-11-05 16:22:29.551	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [223,178,18,1,1,30,221,221,221,221,221,221,221,221,86,103]
      zigbee.3	2020-11-05 16:22:29.550	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [232,123,79,3,0,141,21,0]
      zigbee.3	2020-11-05 16:22:29.550	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,50,221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.549	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.549	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75,18,0,0,0,36,1,1,50]
      zigbee.3	2020-11-05 16:22:29.548	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [18,0,0,0,36,1,1,50]
      zigbee.3	2020-11-05 16:22:29.548	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221,221,221,239,4,166,28,0,75]
      zigbee.3	2020-11-05 16:22:29.548	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,239,4,166,28,0,75]
      zigbee.3	2020-11-05 16:22:29.547	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10,0,3,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.547	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [0,3,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:29.546	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,72,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.546	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,72,69,177,193,34,0,10]
      zigbee.3	2020-11-05 16:22:29.525	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.525	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:29.525	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:29.525	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.525	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.518	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,227,236,0,24]
      zigbee.3	2020-11-05 16:22:29.518	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":60643,"startindex":0}
      zigbee.3	2020-11-05 16:22:29.518	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:29.517	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:29.517	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:29.517	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.517	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85]
      zigbee.3	2020-11-05 16:22:29.511	debug	(4909) Routing table succeeded for '0x7cb03eaa00ad2c4c'
      zigbee.3	2020-11-05 16:22:29.511	debug	(4909) Routing for '0x7cb03eaa00ad2c4c': {"neighbors":[{"linkquality":52,"networkAddress":0,"ieeeAddr":"0x00124b001ca604ef","relationship":2,"depth":1},{"linkquality":30,"networkAddress":45791,"ieeeAd
      zigbee.3	2020-11-05 16:22:29.511	debug	(4909) Failed to execute routing table for '0x7cb03eaa00ad2c4c'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitres
      zigbee.3	2020-11-05 16:22:29.511	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,193,34,0,244]
      zigbee.3	2020-11-05 16:22:29.510	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":8897,"startindex":0}
      zigbee.3	2020-11-05 16:22:25.682	debug	(4909) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.3
      zigbee.3	2020-11-05 16:22:25.681	debug	(4909) getBinding result: []
      zigbee.3	2020-11-05 16:22:25.556	debug	(4909) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.3
      zigbee.3	2020-11-05 16:22:25.556	debug	(4909) getDevices result: [{"type":"device","common":{"name":"lumi.sensor_switch_cg","type":"WXKG01LM","icon":"img/xiaomi_wireless_switch.png"},"native":{"id":"00158d0002899bef"},"from":"system.adapte
      zigbee.3	2020-11-05 16:22:25.490	debug	(4909) Routing table succeeded for 'Coordinator'
      zigbee.3	2020-11-05 16:22:25.490	debug	(4909) Routing for 'Coordinator': {"table":[{"destinationAddress":44776,"status":"ACTIVE","nextHop":44776},{"destinationAddress":61134,"status":"DISCOVERY_FAILED","nextHop":65534},{"destinationAddress
      zigbee.3	2020-11-05 16:22:25.489	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:25.489	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtRtgRsp - {"srcaddr":0,"status":0,"routingtableentries":5,"startindex":0,"routingtablelistcount":5,"routingtablelist":[{"destNwkAddr":44776,
      zigbee.3	2020-11-05 16:22:25.485	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 31 - 2 - 5 - 178 - [0,0,0,5,0,5,232,174,0,232,174,206,238,2,254,255,107,135,2,254,255,227,236,0,232,174,195,150,2,254,255] - 59
      zigbee.3	2020-11-05 16:22:25.485	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,31,69,178,0,0,0,5,0,5,232,174,0,232,174,206,238,2,254,255,107,135,2,254,255,227,236,0,232,174,195,150,2,254,255,59]
      zigbee.3	2020-11-05 16:22:25.485	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,255,107,135,2,254,255,227,236,0,232,174,195,150,2,254,255,59]
      zigbee.3	2020-11-05 16:22:25.484	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,31,69,178,0,0,0,5,0,5,232,174,0,232,174,206,238,2]
      zigbee.3	2020-11-05 16:22:25.484	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [232,174,0,232,174,206,238,2]
      zigbee.3	2020-11-05 16:22:25.483	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,31,69,178,0,0,0,5,0,5]
      zigbee.3	2020-11-05 16:22:25.483	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [69,178,0,0,0,5,0,5]
      zigbee.3	2020-11-05 16:22:25.482	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,31]
      zigbee.3	2020-11-05 16:22:25.482	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtRtgReq - {"status":0}
      zigbee.3	2020-11-05 16:22:25.482	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 50 - [0] - 86
      zigbee.3	2020-11-05 16:22:25.482	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,50,0,86,254,31]
      zigbee.3	2020-11-05 16:22:25.481	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,50,0,86,254,31]
      zigbee.3	2020-11-05 16:22:25.478	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,50,0,0,0,20]
      zigbee.3	2020-11-05 16:22:25.478	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtRtgReq - {"dstaddr":0,"startindex":0}
      zigbee.3	2020-11-05 16:22:25.477	debug	(4909) LQI succeeded for 'Coordinator'
      zigbee.3	2020-11-05 16:22:25.477	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:25.477	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":0,"status":0,"neighbortableentries":8,"startindex":6,"neighborlqilistcount":2,"neighborlqilist":[{"extPandId":"0xdddddd
      zigbee.3	2020-11-05 16:22:25.477	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 50 - 2 - 5 - 177 - [0,0,0,8,6,2,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,41,2,255,85,221,221,221,221,221,221,221,2
      zigbee.3	2020-11-05 16:22:25.477	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,41,2,255,85,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:25.477	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [41,2,255,57,168]
      zigbee.3	2020-11-05 16:22:25.476	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,41,2,255,85,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:25.476	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [218,0,0,38,24,132,232,174]
      zigbee.3	2020-11-05 16:22:25.475	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,41,2,255,85,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:25.475	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,245,171]
      zigbee.3	2020-11-05 16:22:25.474	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124,193,34,41,2,255,85,221,221]
      zigbee.3	2020-11-05 16:22:25.474	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [193,34,41,2,255,85,221,221]
      zigbee.3	2020-11-05 16:22:25.474	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221,76,44,173,0,170,62,176,124]
      zigbee.3	2020-11-05 16:22:25.473	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [76,44,173,0,170,62,176,124]
      zigbee.3	2020-11-05 16:22:25.473	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:25.473	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [69,177,0,0,0,8,6,2,221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:25.472	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50]
      zigbee.3	2020-11-05 16:22:25.472	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:25.472	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:25.472	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.471	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.467	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,0,0,6,17]
      zigbee.3	2020-11-05 16:22:25.467	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":0,"startindex":6}
      zigbee.3	2020-11-05 16:22:25.467	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:25.466	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":0,"status":0,"neighbortableentries":8,"startindex":4,"neighborlqilistcount":2,"neighborlqilist":[{"extPandId":"0xdddddd
      zigbee.3	2020-11-05 16:22:25.466	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 50 - 2 - 5 - 177 - [0,0,0,8,4,2,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,18,2,1,55,221,221,221,221,221,221,221,2
      zigbee.3	2020-11-05 16:22:25.466	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,4,2,221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,18,2,1,55,221,221,221,221,221,221,221,221
      zigbee.3	2020-11-05 16:22:25.465	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,221,221,236,32,40,254,255,172,51,188,188,31,18,2,1,55,221,221,221,221,221,221,221,221,255,255,255,255,255,255,255,255,34,
      zigbee.3	2020-11-05 16:22:25.465	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,4,2]
      zigbee.3	2020-11-05 16:22:25.465	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [69,177,0,0,0,8,4,2]
      zigbee.3	2020-11-05 16:22:25.458	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50]
      zigbee.3	2020-11-05 16:22:25.458	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:25.458	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:25.458	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.458	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.455	debug	(4909) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.3
      zigbee.3	2020-11-05 16:22:25.454	debug	(4909) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
      zigbee.3	2020-11-05 16:22:25.454	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,0,0,4,19]
      zigbee.3	2020-11-05 16:22:25.454	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":0,"startindex":4}
      zigbee.3	2020-11-05 16:22:25.453	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:25.453	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":0,"status":0,"neighbortableentries":8,"startindex":2,"neighborlqilistcount":2,"neighborlqilist":[{"extPandId":"0xdddddd
      zigbee.3	2020-11-05 16:22:25.453	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 50 - 2 - 5 - 177 - [0,0,0,8,2,2,221,221,221,221,221,221,221,221,118,84,61,2,0,141,21,0,128,83,18,2,1,88,221,221,221,221,221,221,221,221,114
      zigbee.3	2020-11-05 16:22:25.453	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,2,2,221,221,221,221,221,221,221,221,118,84,61,2,0,141,21,0,128,83,18,2,1,88,221,221,221,221,221,221,221,221,114,1
      zigbee.3	2020-11-05 16:22:25.452	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [18,2,1,95,92]
      zigbee.3	2020-11-05 16:22:25.442	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,2,2,221,221,221,221,221,221,221,221,118,84,61,2,0,141,21,0,128,83,18,2,1,88,221,221,221,221,221,221,221,221,114,1
      zigbee.3	2020-11-05 16:22:25.442	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [69,177,0,0,0,8,2,2,221,221,221,221,221,221,221,221,118,84,61,2,0,141,21,0,128,83,18,2,1,88,221,221,221,221,221,221,221,221,114,137,130,2,0,141,21
      zigbee.3	2020-11-05 16:22:25.437	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50]
      zigbee.3	2020-11-05 16:22:25.437	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:25.437	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:25.436	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.436	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.429	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,0,0,2,21]
      zigbee.3	2020-11-05 16:22:25.429	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":0,"startindex":2}
      zigbee.3	2020-11-05 16:22:25.429	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
      zigbee.3	2020-11-05 16:22:25.429	debug	(4909) zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - mgmtLqiRsp - {"srcaddr":0,"status":0,"neighbortableentries":8,"startindex":0,"neighborlqilistcount":2,"neighborlqilist":[{"extPandId":"0xdddddd
      zigbee.3	2020-11-05 16:22:25.428	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 50 - 2 - 5 - 177 - [0,0,0,8,0,2,221,221,221,221,221,221,221,221,227,230,164,2,0,141,21,0,206,238,18,2,1,76,221,221,221,221,221,221,221,221,
      zigbee.3	2020-11-05 16:22:25.428	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,0,2,221,221,221,221,221,221,221,221,227,230,164,2,0,141,21,0,206,238,18,2,1,76,221,221,221,221,221,221,221,221,42
      zigbee.3	2020-11-05 16:22:25.428	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [18,2,1,70,149]
      zigbee.3	2020-11-05 16:22:25.421	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,0,2,221,221,221,221,221,221,221,221,227,230,164,2,0,141,21,0,206,238,18,2,1,76,221,221,221,221,221,221,221,221,42
      zigbee.3	2020-11-05 16:22:25.421	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [221,221,221,221,221,221,42,117,40,2,0,141,21,0,114,215]
      zigbee.3	2020-11-05 16:22:25.420	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,0,2,221,221,221,221,221,221,221,221,227,230,164,2,0,141,21,0,206,238,18,2,1,76,221,221]
      zigbee.3	2020-11-05 16:22:25.420	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [206,238,18,2,1,76,221,221]
      zigbee.3	2020-11-05 16:22:25.419	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,0,2,221,221,221,221,221,221,221,221,227,230,164,2,0,141,21,0]
      zigbee.3	2020-11-05 16:22:25.419	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [227,230,164,2,0,141,21,0]
      zigbee.3	2020-11-05 16:22:25.418	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50,69,177,0,0,0,8,0,2,221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:25.418	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [69,177,0,0,0,8,0,2,221,221,221,221,221,221,221,221]
      zigbee.3	2020-11-05 16:22:25.417	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,50]
      zigbee.3	2020-11-05 16:22:25.417	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SRSP <-- ZDO - mgmtLqiReq - {"status":0}
      zigbee.3	2020-11-05 16:22:25.417	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 5 - 49 - [0] - 85
      zigbee.3	2020-11-05 16:22:25.417	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.416	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,101,49,0,85,254,50]
      zigbee.3	2020-11-05 16:22:25.414	debug	(4909) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.3
      zigbee.3	2020-11-05 16:22:25.414	debug	(4909) getGroups result: {"1":"GROUPID"}
      zigbee.3	2020-11-05 16:22:25.412	debug	(4909) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.3
      zigbee.3	2020-11-05 16:22:25.411	debug	(4909) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,3,37,49,0,0,0,23]
      zigbee.3	2020-11-05 16:22:25.411	debug	(4909) zigbee-herdsman:adapter:zStack:znp:SREQ --> ZDO - mgmtLqiReq - {"dstaddr":0,"startindex":0}
        @arteck
        ach ja, ein Batteriezustand kommt auch nicht - das ist alles was ich sehe - in den Objekten wird dieser nicht angelegt.
        • MichMein
          MichMein last edited by
          @Asgothian ,
          @arteck hat mich quasi an Dich verwiesen. Ich habe irgendwo schon mal gelesen das Du nicht so sehr auf die Tuya Geräte „stehst“, aber könntest Du mir bei den folgenden Dingen behilflich sein?
          Hier und hier bitte.
          Vielen Dank im voraus.
            arteck Developer Most Active @memoire last edited by
            @memoire hast du das Geröt gelöscht .. dann adapter neu installiert von git und dann neu angelernt
              @arteck
              ja, vor ein paar Tagen - ich dachte, ich versuche es einfach ´mal
                @memoire JETZT alter JETZT
                M B 2 Replies Last reply Reply Quote 1
                  @arteck
                  gerade gemacht... beim pairen kommt folgendes
                  danach:
                  Und jetzt habe ich mehr Infos:
                  zigbee.3	2020-11-05 17:36:31.165	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:31.165	debug	(5050) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":10}
                  zigbee.3	2020-11-05 17:36:31.165	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,1,10] - 204
                  zigbee.3	2020-11-05 17:36:31.164	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,1,10,204]
                  zigbee.3	2020-11-05 17:36:31.164	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,1,10,204]
                  zigbee.3	2020-11-05 17:36:30.159	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:30.159	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequest - {"status":0}
                  zigbee.3	2020-11-05 17:36:30.159	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 1 - [0] - 100
                  zigbee.3	2020-11-05 17:36:30.159	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:30.159	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:30.155	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,15,36,1,227,236,4,1,1,0,10,0,30,5,24,54,11,10,0,31]
                  zigbee.3	2020-11-05 17:36:30.154	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequest - {"dstaddr":60643,"destendpoint":4,"srcendpoint":1,"clusterid":1,"transid":10,"options":0,"radius":30,"len":5,"data":{"type":"Buffe
                  zigbee.3	2020-11-05 17:36:30.154	debug	(5050) zigbee-herdsman:adapter:zStack:adapter sendZclFrameToEndpointInternal %s:%i/%i (%i,%i,%i)
                  zigbee.3	2020-11-05 17:36:30.154	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:30.154	debug	(5050) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":9}
                  zigbee.3	2020-11-05 17:36:30.154	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,1,9] - 207
                  zigbee.3	2020-11-05 17:36:30.154	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,1,9,207]
                  zigbee.3	2020-11-05 17:36:30.153	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,1,9,207]
                  zigbee.3	2020-11-05 17:36:29.147	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:29.147	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequest - {"status":0}
                  zigbee.3	2020-11-05 17:36:29.147	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 1 - [0] - 100
                  zigbee.3	2020-11-05 17:36:29.147	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:29.146	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:29.142	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,15,36,1,227,236,4,1,1,0,9,0,30,5,24,54,11,10,0,28]
                  zigbee.3	2020-11-05 17:36:29.142	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequest - {"dstaddr":60643,"destendpoint":4,"srcendpoint":1,"clusterid":1,"transid":9,"options":0,"radius":30,"len":5,"data":{"type":"Buffer
                  zigbee.3	2020-11-05 17:36:29.141	debug	(5050) zigbee-herdsman:adapter:zStack:adapter sendZclFrameToEndpointInternal %s:%i/%i (%i,%i,%i)
                  zigbee.3	2020-11-05 17:36:29.141	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:29.141	debug	(5050) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":8}
                  zigbee.3	2020-11-05 17:36:29.141	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,1,8] - 206
                  zigbee.3	2020-11-05 17:36:29.141	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,1,8,206]
                  zigbee.3	2020-11-05 17:36:29.140	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,1,8,206]
                  zigbee.3	2020-11-05 17:36:28.133	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:28.133	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequest - {"status":0}
                  zigbee.3	2020-11-05 17:36:28.133	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 1 - [0] - 100
                  zigbee.3	2020-11-05 17:36:28.133	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:28.133	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:28.128	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,15,36,1,227,236,4,1,1,0,8,0,30,5,24,54,11,10,0,29]
                  zigbee.3	2020-11-05 17:36:28.128	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequest - {"dstaddr":60643,"destendpoint":4,"srcendpoint":1,"clusterid":1,"transid":8,"options":0,"radius":30,"len":5,"data":{"type":"Buffer
                  zigbee.3	2020-11-05 17:36:28.128	debug	(5050) zigbee-herdsman:adapter:zStack:adapter sendZclFrameToEndpointInternal %s:%i/%i (%i,%i,%i)
                  zigbee.3	2020-11-05 17:36:28.128	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:28.128	debug	(5050) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":7}
                  zigbee.3	2020-11-05 17:36:28.128	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,1,7] - 193
                  zigbee.3	2020-11-05 17:36:28.127	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,1,7,193]
                  zigbee.3	2020-11-05 17:36:28.127	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,1,7,193]
                  zigbee.3	2020-11-05 17:36:27.124	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:27.123	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequest - {"status":0}
                  zigbee.3	2020-11-05 17:36:27.123	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 1 - [0] - 100
                  zigbee.3	2020-11-05 17:36:27.123	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:27.123	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:27.119	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,15,36,1,227,236,4,1,1,0,7,0,30,5,24,54,11,10,0,18]
                  zigbee.3	2020-11-05 17:36:27.119	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequest - {"dstaddr":60643,"destendpoint":4,"srcendpoint":1,"clusterid":1,"transid":7,"options":0,"radius":30,"len":5,"data":{"type":"Buffer
                  zigbee.3	2020-11-05 17:36:27.119	debug	(5050) zigbee-herdsman:adapter:zStack:adapter sendZclFrameToEndpointInternal %s:%i/%i (%i,%i,%i)
                  zigbee.3	2020-11-05 17:36:27.118	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:27.118	debug	(5050) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":6}
                  zigbee.3	2020-11-05 17:36:27.118	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,1,6] - 192
                  zigbee.3	2020-11-05 17:36:27.118	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,1,6,192]
                  zigbee.3	2020-11-05 17:36:27.118	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,1,6,192]
                  zigbee.3	2020-11-05 17:36:25.103	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:25.103	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequest - {"status":0}
                  zigbee.3	2020-11-05 17:36:25.102	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 1 - [0] - 100
                  zigbee.3	2020-11-05 17:36:25.102	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:25.102	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,1,0,100]
                  zigbee.3	2020-11-05 17:36:25.098	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,15,36,1,227,236,4,1,1,0,6,0,30,5,24,54,11,10,0,19]
                  zigbee.3	2020-11-05 17:36:25.098	debug	(5050) zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequest - {"dstaddr":60643,"destendpoint":4,"srcendpoint":1,"clusterid":1,"transid":6,"options":0,"radius":30,"len":5,"data":{"type":"Buffer
                  zigbee.3	2020-11-05 17:36:25.098	debug	(5050) zigbee-herdsman:adapter:zStack:adapter sendZclFrameToEndpointInternal %s:%i/%i (%i,%i,%i)
                  zigbee.3	2020-11-05 17:36:25.097	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                  zigbee.3	2020-11-05 17:36:25.097	debug	(5050) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":5}
                  zigbee.3	2020-11-05 17:36:25.097	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,1,5] - 195
                  zigbee.3	2020-11-05 17:36:25.097	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,1,5,195]
                  zigbee.3	2020-11-05 17:36:25.097	debug	(5050) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,1,5,195]
                  zigbee.3	2020-11-05 17:36:24.126	error	(5050) Device 0xccccccfffe89fb2c "ROB_200-007-0" not described in statesMapping.
                  zigbee.3	2020-11-05 17:36:24.126	debug	(5050) Publish {"battery":50}
                  zigbee.3	2020-11-05 17:36:24.125	error	(5050) Device 0xccccccfffe89fb2c "ROB_200-007-0" not described in statesMapping.
                  zigbee.3	2020-11-05 17:36:24.124	error	(5050) Device 0xccccccfffe89fb2c "ROB_200-007-0" not described in statesMapping.
                  zigbee.3	2020-11-05 17:36:24.123	error	(5050) Device 0xccccccfffe89fb2c "ROB_200-007-0" not described in statesMapping.
                    @memoire das kann nicht.. da muss jetzt zumindest ein Bild kommen.. vom GIT gezogen ?? über Katze installiert ??
                      memoire @arteck last edited by
                      @arteck
                      Ja, genau wie du gesagt hattest - daher habe ich ja jetzt mehr Infos.
                      Unter Objekte erscheint er auch nicht
                        @arteck
                        Adapter gelöscht, Schalter zurückgesetzt, alles neu installiert und der er ist drin:
                        aber unter Objekte nur dies:
                        • O
                          Ogerix88 @arteck last edited by
                          @arteck Vielen Dank! Er findet den RGBW-Controller. Leider fehlt dann aber der Datenpunkt für die Farben. Der Datenpunkt für die Farbtemperatur ist zwar da, bewirkt aber auch nix
                            BigMike71 @arteck last edited by
                            @arteck
                            Danke für das Deckenpanel, funktioniert einwandfrei 🙂
                            • Asgothian
                              Asgothian Developer @MichMein last edited by
                              @MichMein
                              Ohne einen Thermostat kann ich mir das nicht anschauen. Die TuYa Geräte haben den Nachteil das sie halt nicht nach den "normalen" Zigbee Regeln spielen.
                              Auch das mit dem Bild ist so eine Sache. Wenn ich das Bild austausche (was einfach ist) meldet sich ggf. demnächst jemand der einen Thermostat hat der so aussieht wie der auf dem alten Bild.
                              Um da etwas zu tun muss ich mir den Thermostat am lebenden Objekt anschauen. Das können wir versuchen. Dazu wird benötigt:
                              • Discord, damit wir reden und nicht tippen können
                              • Anydesk oder eine ähnliche Software so das ich auf deinen ioBroker zugreifen kann
                              • 3 Stunden Zeit.
                              A.
                                DennisMenger @Ogerix88 last edited by
                                @Ogerix88 und alle
                                Beim OSRAM Smart+ LED Streifen, ZigBee fehlt mir leider auch der Datenpunkt für die Farben. Heißt glaube ich "sat" oder so. Ich habe leider keine Ahnung wie man an den rankommen könnte.
                                • Asgothian
                                  Asgothian Developer @DennisMenger last edited by
                                  @DennisMenger
                                  Poste mal bitte die Kachel dazu, dann kann ich im Code nachschauen warum der DP nicht existiert.
                                  A.
                                    DennisMenger @Asgothian last edited by DennisMenger
                                    @Asgothian sehr gerne
                                    hier heißt der LED-Stripe allerdings Lightify Indoor Flex, ist identisch meiner Meinung nach
                                    EDIT: Nutze den Conbee II Stick
                                      Und hier einmal die Objekte
                                      • Asgothian
                                        @DennisMenger
                                        So.. nachgeschaut.
                                        Bei diesen Lightstrips ist die Ansteuerung per Hue, Saturation, Brightness nicht mit einkonfiguriert. Ich kann das tun, (oder dir sagen wie das geht), kann es aber nicht testen. Wenn Du Pech hast dann hast du die Datenpunkte und es geht trotzdem nicht.
                                        A.
                                          @Asgothian Super danke
                                          Was heißt nicht mit einkonfiguriert?
                                          Änderungen über die Objekte am Datenpunkt "level.color.temperature" bringen Veränderungen am Licht.
                                          Wir können es ja erst mal so probieren, dass du mir das erläuterst und ich versuche das umzusetzen.
                                          • Asgothian
                                            Asgothian Developer @DennisMenger last edited by Asgothian
                                            @DennisMenger Ich bin morgen wahrscheinlich zwischen 5 und 7 im Discord, da kann ich das erklären.
                                            A.
                                            Nachtrag: Heute.. Mitternacht is um. 🙂
                                            1.0k
                                            converter herdsman neuer adapter zigbee
                                            50
                                            231
                                            36021
