    4. [neuer Adapter] smartgarden adapter for Gardena smart system
    • jpgorganizer
      jpgorganizer @stevie77 last edited by
      @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      Mein Adapter führt jetzt ca. alle halbe Minute eine "kostenpflichtige" Aktion aus, die den Count nach oben setzt. Ich musste ihn nun manuell stoppen.
      kannst du mal einen Ausschnitt mit 2,3 solchen Wiederholungen aus deinem Log zeigen? Ich habe einen Verdacht 🙂
      Ansonsten habe ich bereits oben geschrieben, dass dich die Gunst der Stunde nutze um das Fehlerhandling zu verbessern.
      VG jpgorganizer
        stevie77 @jpgorganizer last edited by
        @jpgorganizer Gerne, kommt hier:
        smartgarden.0	2020-10-25 12:18:23.677	info	(13004) Terminated (NO_ERROR): Without reason
        smartgarden.0	2020-10-25 12:18:23.676	info	(13004) terminating
        smartgarden.0	2020-10-25 12:18:23.626	info	(13004) 2/ cleaned everything up...
        smartgarden.0	2020-10-25 12:18:23.625	error	(13004) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29) at Request.self.call
        smartgarden.0	2020-10-25 12:18:23.623	error	(13004) uncaught exception: Unexpected end of JSON input
        smartgarden.0	2020-10-25 12:18:23.371	info	(13004) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1316,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
        smartgarden.0	2020-10-25 12:18:23.367	info	(13004) 2/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0	2020-10-25 12:18:23.364	info	(13004) 2/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0	2020-10-25 12:18:23.346	info	(13004) 2/ get_locations ...
        smartgarden.0	2020-10-25 12:18:23.345	info	(13004) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0	2020-10-25 12:18:23.343	info	(13004) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0	2020-10-25 12:18:23.002	info	(13004) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1315,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
        smartgarden.0	2020-10-25 12:18:22.994	info	(13004) 2/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
        smartgarden.0	2020-10-25 12:18:22.993	info	(13004) 2/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2020-10-25 12:18:22.857	info	(13004) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0	2020-10-25 12:18:22.819	info	(13004) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.21.0, js-controller: 3.1.6
        smartgarden.0	2020-10-25 12:17:49.927	info	(12950) Terminated (NO_ERROR): Without reason
        smartgarden.0	2020-10-25 12:17:49.926	info	(12950) terminating
        smartgarden.0	2020-10-25 12:17:49.878	info	(12950) 2/ cleaned everything up...
        smartgarden.0	2020-10-25 12:17:49.876	error	(12950) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29) at Request.self.call
        smartgarden.0	2020-10-25 12:17:49.874	error	(12950) uncaught exception: Unexpected end of JSON input
        smartgarden.0	2020-10-25 12:17:49.748	info	(12950) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1314,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
        smartgarden.0	2020-10-25 12:17:49.741	info	(12950) 2/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0	2020-10-25 12:17:49.737	info	(12950) 2/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0	2020-10-25 12:17:49.697	info	(12950) 2/ get_locations ...
        smartgarden.0	2020-10-25 12:17:49.694	info	(12950) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0	2020-10-25 12:17:49.691	info	(12950) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0	2020-10-25 12:17:49.398	info	(12950) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1313,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
        smartgarden.0	2020-10-25 12:17:49.391	info	(12950) 2/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
        smartgarden.0	2020-10-25 12:17:49.389	info	(12950) 2/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2020-10-25 12:17:49.284	info	(12950) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0	2020-10-25 12:17:49.245	info	(12950) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.21.0, js-controller: 3.1.6
        smartgarden.0	2020-10-25 12:17:16.629	info	(12935) Terminated (NO_ERROR): Without reason
        smartgarden.0	2020-10-25 12:17:16.626	info	(12935) terminating
        smartgarden.0	2020-10-25 12:17:16.576	info	(12935) 2/ cleaned everything up...
        smartgarden.0	2020-10-25 12:17:16.574	error	(12935) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29) at Request.self.call
        smartgarden.0	2020-10-25 12:17:16.572	error	(12935) uncaught exception: Unexpected end of JSON input
        smartgarden.0	2020-10-25 12:17:16.410	info	(12935) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1312,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
        smartgarden.0	2020-10-25 12:17:16.407	info	(12935) 2/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0	2020-10-25 12:17:16.404	info	(12935) 2/ state smartgarden.0.info.connection changed: true (ack = true)
        smartgarden.0	2020-10-25 12:17:16.385	info	(12935) 2/ get_locations ...
        smartgarden.0	2020-10-25 12:17:16.384	info	(12935) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0	2020-10-25 12:17:16.382	info	(12935) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0	2020-10-25 12:17:15.991	info	(12935) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1311,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
        smartgarden.0	2020-10-25 12:17:15.981	info	(12935) 2/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
        smartgarden.0	2020-10-25 12:17:15.981	info	(12935) 2/ state smartgarden.0.info.connection changed: false (ack = true)
        smartgarden.0	2020-10-25 12:17:15.886	info	(12935) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0	2020-10-25 12:17:15.807	info	(12935) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.21.0, js-controller: 3.1.6
        jpgorganizer 1 Reply Last reply Reply Quote 0
        • jpgorganizer
          @stevie77
          danke
          das dachte ich mir. Diese Art von Wiederholung kann ich nicht 100%-ig ausschließen, denn im Code sind/können immer Fehler enthalten sein. Hier gibt es einen uncaught exception: Unexpected end of JSON input. Daraufhin beendet sich der Adapter und wird duch ioBroker immer wieder neu gestartet. Keine Ahnung, ob man ioBroker diesen Neustart abgewöhnen kann (oder auch will).
          Diese o.a. uncaught exception ist in der nächsten Version dann aber auch behoben.
          Zu deiner Sorge, dass das nun Limit kostet: kann sein, glaube ich aber eher nicht, denn der Login geht schief. Auf wessen Limit sollte dies nun einzahlen. Um es aber genauer herauszufinden, müsste man auch die Gardena-Seite anschauen können - was ich aber nicht kann. Der Adapter zählt natürlich erst mal eins hoch; das ist in dem Fall dann vmtl. nicht korrekt; aber ich werde das auch nicht anpassen, denn die Überwachung soll ja dem Zweck dienen, dass man im Normalbetrieb sehen kann, ob die Limits gefährdet sind. Und egal wie man es macht, es kann trotz allem wieder nicht korrekt sein.
          VG jpgorganizer
            @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
            ann aber auch beho
            Okay, dann stimmt zwar also später, wenn es wieder läuft, der Counter nicht mehr (da der Counter des Adapters dann deutlich höher ist als der von Gardena, da dieser wegen fehlendem Login nicht inkrementiert wird), aber wenigstens beeinträchtigt das dann den weiteren Betrieb an den verbleibenden Tagen des Monats nicht. Das ist ja auch schon was... 😉
            • jpgorganizer
              jpgorganizer @stevie77 last edited by jpgorganizer
              Monat muss man wohl auch eher als 30 (evtl. 31) Tage Zeitraum ansehen .... ich habe oben irgendwo einen Link zu AWS, wo die Limits erklärt werden gepostet. Kannst ja mal lesen
              https://forum.iobroker.net/topic/31289/neuer-adapter-smartgarden-adapter-for-gardena-smart-system/539
              oberfragger 1 Reply Last reply Reply Quote 0
              • oberfragger
                oberfragger @jpgorganizer last edited by
                Vielen Dank in die Runde. Hatte auch nen 400er. Dann habe ich eine neu Applikation angelegt und das funktionierte bis heute Nachmittag 14.00 Uhr.
                Bei Github natürlich nicht in die geschlossenen Issues geschaut. Warten wir mal ab...
                • JohGre
                  JohGre last edited by
                  Seit heute 9:48 ist der Adapter bei mir wieder grün.
                  • jpgorganizer
                    jpgorganizer @JohGre last edited by jpgorganizer
                    @All
                    Gardena hat das Problem gelöst. Man sollte sich somit wieder einloggen können.
                    Dank an das Gardena Support Team!
                    Viel Spass
                    jpgorganizer
                    oberfragger S 2 Replies Last reply Reply Quote 0
                    • oberfragger
                      Sehr schön. Bei mir löppts auch wieder.
                        stevie77 @jpgorganizer last edited by stevie77
                        @jpgorganizer Hallo, nachdem die Gartenpumpe ein paar Tage funktioniert hat, hat sie heute Vormittag ihren Dienst versagt. Ausgelöst hat ioBroker, aber ich habe eine Fehlermeldung Unauthorized. Der Adapter stand heute Abend auf gelb. Nach einem einfachen Reload ist er nun wieder grün und ich vermute, dass morgen alles läuft. Nun habe ich solche Aussetzer schon öfters gehabt. Es scheint ja kein permanenter Fehler zu sein (mein Limit scheint auch nicht überschritten zu sein). Der Fehler ist mit einem Reload des Adapters behoben.
                        Frage: Wenn ich länger im Urlaub bin, kann und will ich nicht alle paar Tage kontrollieren, ob der Adapter/die Instanz noch läuft. Wäre es möglich eine Art Auto-Refresh-Funktion einzubauen, sozusagen als Selbstheilungsfunktion? Oder kann man in ioBroker evtl. einstellen, dass eine Instanz alle n Tage aktualisiert wird?
                        2020-11-05 10:02:00.023  - info: smartgarden.0 (1155) 2/ state smartgarden.0.LOCATION_5feeadcd-xyz.DEVICE_ceb387e1-xyz.SERVICE_VALVE_ceb387e1-xyz.duration_value changed: 300 (ack = false)
                        2020-11-05 10:02:00.041  - info: smartgarden.0 (1155) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1525,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21":{"count":8},"22":{"count":1},"23":{"count":2},"count":52},"2020-10-11":{"12":{"count":6},"13":{"count":4},"14":{"count":2},"15":{"count":2},"23":{"count":2},"count":33,"02":{"count":6},"03":{"count":8},"08":{"count":3}},"2020-10-12":{"13":{"count":9},"23":{"count":2},"count":16,"01":{"count":3},"08":{"count":2}},"2020-10-13":{"23":{"count":5},"count":8,"01":{"count":1},"08":{"count":2}},"2020-10-14":{"17":{"count":5},"18":{"count":21},"19":{"count":13},"20":{"count":8},"21":{"count":8},"22":{"count":4},"23":{"count":13},"count":75,"08":{"count":3}},"2020-10-15":{"11":{"count":4},"20":{"count":2},"21":{"count":2},"23":{"count":2},"count":45,"00":{"count":10},"01":{"count":6},"02":{"count":6},"03":{"count":4},"04":{"count":2},"05":{"count":2},"06":{"count":2},"08":{"count":3}},"2020-10-16":{"23":{"count":2},"count":5,"08":{"count":3}},"2020-10-17":{"11":{"count":2},"14":{"count":2},"23":{"count":2},"count":7,"08":{"count":1}},"2020-10-18":{"10":{"count":2},"11":{"count":2},"20":{"count":2},"23":{"count":2},"count":15,"02":{"count":2},"08":{"count":3},"09":{"count":2}},"2020-10-19":{"11":{"count":4},"23":{"count":4},"count":13,"01":{"count":3},"08":{"count":2}},"2020-10-20":{"15":{"count":9},"16":{"count":8},"18":{"count":2},"19":{"count":10},"20":{"count":4},"22":{"count":2},"23":{"count":2},"count":40,"08":{"count":3}},"2020-10-21":{"11":{"count":4},"13":{"count":2},"22":{"count":2},"23":{"count":2},"count":49,"02":{"count":2},"03":{"count":4},"04":{"count":6},"05":{"count":2},"06":{"count":4},"07":{"count":8},"08":{"count":9},"09":{"count":4}},"2020-10-22":{"17":{"count":9},"18":{"count":2},"19":{"count":2},"21":{"count":2},"23":{"count":2},"count":20,"08":{"count":3}},"2020-10-23":{"15":{"count":1},"23":{"count":13},"count":17,"08":{"count":3}},"2020-10-24":{"12":{"count":31},"count":891,"00":{"count":211},"01":{"count":212},"02":{"count":210},"03":{"count":212},"04":{"count":14},"08":{"count":1}},"2020-10-25":{"11":{"count":6},"count":30,"03":{"count":24}},"2020-10-26":{"10":{"count":8},"11":{"count":8},"12":{"count":4},"13":{"count":6},"count":31,"09":{"count":5}},"2020-10-27":{"18":{"count":2},"count":6,"00":{"count":2},"09":{"count":2}},"2020-10-28":{"15":{"count":1},"20":{"count":2},"count":8,"00":{"count":2},"09":{"count":3}},"2020-10-29":{"10":{"count":3},"11":{"count":2},"17":{"count":2},"21":{"count":6},"22":{"count":6},"23":{"count":4},"count":55,"00":{"count":4},"01":{"count":9},"02":{"count":4},"03":{"count":10},"04":{"count":2},"09":{"count":3}},"2020-10-30":{"11":{"count":2},"12":{"count":2},"13":{"count":2},"15":{"count":4},"17":{"count":4},"19":{"count":2},"22":{"count":4},"count":104,"00":{"count":14},"01":{"count":8},"02":{"count":6},"03":{"count":10},"04":{"count":12},"05":{"count":12},"06":{"count":2},"07":{"count":10},"08":{"count":6},"09":{"count":4}},"2020-10-31":{"22":{"count":1},"count":5,"00":{"count":2},"09":{"count":2}}},"2020-11":{"count":74,"2020-11-01":{"21":{"count":2},"22":{"count":3},"count":12,"00":{"count":2},"01":{"count":2},"09":{"count":3}},"2020-11-02":{"18":{"count":4},"19":{"count":6},"20":{"count":10},"22":{"count":1},"count":41,"00":{"count":2},"02":{"count":3},"03":{"count":10},"04":{"count":2},"09":{"count":3}},"2020-11-03":{"22":{"count":1},"count":6,"00":{"count":2},"09":{"count":3}},"2020-11-04":{"22":{"count":1},"count":13,"00":{"count":2},"08":{"count":9},"09":{"count":1}},"2020-11-05":{"count":2,"09":{"count":2}}}},"last30days":{"count":79},"last31days":{"count":79}} (ack = true)
                        2020-11-05 10:02:00.187  - info: smartgarden.0 (1155) 2/ Valve Command failure.
                        2020-11-05 10:02:00.187  - info: smartgarden.0 (1155) 2/ command: options_valve_control={"url":"https://api.smart.gardena.dev/v1/command/ceb387xyz:0","method":"PUT","json":{"data":{"id":"cmdid_START_SECONDS_TO_OVERRIDE","type":"VALVE_CONTROL","attributes":{"command":"START_SECONDS_TO_OVERRIDE","seconds":300}}},"headers":{"accept":"*/*","Content-Type":"application/vnd.api+json","Authorization":"Bearer ","Authorization-Provider":"husqvarna","X-Api-Key":"xyz"}}
                        2020-11-05 10:02:00.188  - info: smartgarden.0 (1155) 2/ Valve command failure: response.statusCode/Message=401/Unauthorized
                        JohGre 1 Reply Last reply Reply Quote 0
                        • JohGre
                          JohGre @stevie77 last edited by
                          @stevie77 Ich hab mir da ein Reconnect-script gebastelt
                          var timeout;
                          on ('smartgarden.0.info.connection', function (obj) {
                              if (obj.state.val) {
                                  (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();//löschen des vorherigen Aufrufs
                                  //log('SmartGarden Adapter Connection WIEDER VERBUNDEN!!!','warn');
                              } else {
                                  //log('SmartGarden Adapter Connection VERLOREN!!!','warn');
                                  timeout = setTimeout(function () {
                                      const instanceObj = getObject("system.adapter.smartgarden.0");
                                      instanceObj.common.enabled = false;                               // Adapter ausschalten
                                      setObject('system.adapter.smartgarden.0', instanceObj, function (err) {
                                                  if (err) log('Cannot write object: ' + err, 'error');
                                      log('SmartGarden Adapter ausgeschaltet ', 'warn');
                                      setTimeout(function() {
                                          instanceObj.common.enabled = true;                               // Adapter anschalten
                                                  if (err) log('Cannot write object: ' + err);
                                          log('SmartGarden Adapter eingeschaltet ', 'warn');
                                          getStatus();
                                      },  120*1000  );
                                  }, 60*1000);// x minuten Wartezeit ob Connection wieder selbst hergestellt wird
                          • jpgorganizer
                            jpgorganizer @jpgorganizer last edited by
                            @stevie77
                            ich zitiere mich mal selbst 🙂
                            Ich habe die Chance genutzt und hab das Fehlerhandling an der Stelle verbessert. Kommt dann mit der nächsten Version. Aber ich warte erst mal noch ab mit der Veröffentlichung.
                            VG jpgorganizer
                              @jpgorganizer Okay, wusste nicht, dass du damit auch solche Fälle meinst. Damals ging es ja darum, dass sehr oft eine Wiederverbindung versucht wurde und dies das Limit überreizte. Die jetzige Frage bezog sich darauf einmal in der Nacht einen Verbindungstest zu machen und wenn der nicht funktioniert, die Instanz neu zu starten.
                              Aber um so besser, wenn das alles abdeckt. 🙂
                              Dann die Frage: Wann denkst du, dass das kommt? Noch im November oder doch erst wieder zu Saisonbeginn?
                              • jpgorganizer
                                mit "alles" bin ich vorsichtig ... ist zu allgemein 🙂
                                mir schwebt Saisonbeginn vor, so im Februar wäre aus meiner Sicht ein guter Zeitpunkt. Jetzt im Winter sind die Gardena-Geräte typischerweise ja außer Betrieb und bevor es wieder losgeht das Update.
                                Was würde für "Update jetzt" sprechen?
                                VG jpgorganizer
                                S jpgorganizer 2 Replies Last reply Reply Quote 0
                                  Okay, konkreter: Ich meinte beide Probleme, die ich bisher hatte. 😉
                                  Hmm, vielleicht, dass meine Geräte noch nicht außer Betrieb sind? 😉 Naja, der Mäher darf dann wohl jetzt auch bald ins Winterlager (wobei es erst 6 Tage her ist, dass wir hier fast 20 Grad hatten). Die Gartenpumpe muss noch ein bisschen den Teich auffüllen, solange der Bachlauf noch läuft und etwas Wasser verliert. Aber letztlich hast du Recht - viel passiert da jetzt nicht mehr... 🙂
                                  • jpgorganizer
                                    @all
                                    Ich habe soeben den Adapter auf github und bei npm aktualisiert. Neue Version ist v1.0.3.
                                    Mit dieser Version erwarte ich bei einem Verbindungsabbruch mit dem Gardena Webservice eine bessere Wieder-Verbindung. Dazu gibt es einen neuen Parameter connection retry interval.
                                    Das Update sollte ohne weiteren Eingriff direkt lauffähig sein.
                                    Weiter viel Spass damit
                                    jpgorganizer
                                    Changelog
                                    1.0.3
                                    • improved error handling
                                    • new parameter connection retry interval
                                    • axios vulnerability solved, using version >=0.21.1
                                      Happyuser20 last edited by
                                      @jpgorganizer
                                      Hallo
                                      Ich hab mal vor Saisonstart den Adapter installiert.
                                      Der Adapter ist verbunden und grün, doch im Log habe ich jetzt folgende Warnungen.
                                      2021-02-21 07:26:14.804 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.name" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.846 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.duration_leftover_i" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.847 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.duration_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.847 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.duration_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.848 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.activity_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.849 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.activity_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.853 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.state_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.854 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_POWER_SOCKET_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.state_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.886 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.name_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.925 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.batteryState_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.926 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.rfLinkLevel_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.927 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.rfLinkLevel_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.928 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.serial_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.929 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.modelType_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.929 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.SERVICE_COMMON_93db38b5-2D7cd8-2D47ac-2Db06d-2D23a0056066d5.rfLinkState_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.930 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.state_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.930 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.state_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.931 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.activity_mowing_i" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.932 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.activity_control_i" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.933 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.activity_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.933 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.activity_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.934 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.lastErrorCode_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.935 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.lastErrorCode_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.935 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_MOWER_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.operatingHours_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.942 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.name_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.943 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.batteryLevel_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.943 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.batteryLevel_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.944 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.batteryState_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.944 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.batteryState_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.945 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.rfLinkLevel_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.946 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.rfLinkLevel_timestamp" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.947 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.serial_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.948 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.modelType_value" has no existing object, this might lead to an error in future versions
                                      2021-02-21 07:26:14.949 - warn: smartgarden.0 (8855) State "smartgarden.0.LOCATION_966ac981-2Daa10-2D4ceb-2D94bc-2D2d28131dd52d.DEVICE_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.SERVICE_COMMON_96eaa31f-2Da9e6-2D4b5b-2Db44a-2D754b03bdde23.rfLinkState_value" has no existing object, this might lead to an error in future versions
                                      Hab vor zwei Tagen de JS-Controller geupdatet auf Version 3.2.16, kann es damit zusammenhängen?
                                      HappyUser20
                                        AndersAnderson last edited by
                                        ich habe heute diesen Adapter gefunden und war natürlich direkt neugierig. Spiele erst seit Dezember mit ioBroker rum.
                                        Hier habe ich aber glaube ich direkt ein Problem mit der Erstellung des Application Key. Ich habe den Sileno Smart life mit Gateway und das Gateway läuft auch. Verbindung zur Handy App funktioniert.
                                        Dann habe ich mich bei Husqvarna angemeldet und einen Application Key generiert und mit "Gardena Smart System API" und "Authentication API" connected. Den Key habe ich dann im Adapter eingefügt, aber es findet keine Verbindung statt. Wie findet das Adapter denn mein Gateway?
                                        Sorry für den fehlenden Sachverstand...
                                        • jpgorganizer
                                          jpgorganizer @Happyuser20 last edited by
                                          @happyuser20 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                          genau daran liegt es
                                          Muss ich mir bei Gelegenheit mal anschauen.
                                          • jpgorganizer
                                            jpgorganizer @AndersAnderson last edited by
                                            @andersanderson sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                            na dann schlage ich vor, dass du das Passwort überprüfst und evtl. auch ein LOG postest, denn so ist es Rätselraten woran es liegt
                                            gar nicht - der Adapter kommuniziert nicht direkt mit deinem Gateway, sondern mit dem Webservice von Gardena, der dann mit deinem Gateway kommuniziert
                                            VG jpgorganizer
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            285919
