    4. Tr-064 adapter kann icht installiert werden
    UNSOLVED Tr-064 adapter kann icht installiert werden
      crunchip Forum Testing Most Active @Goldenbaum last edited by
      @Goldenbaum da sehe ich nichts zum installieren, dir fehlt lediglich die Instanz und diese wird automatisch installiert, wenn man normal über den Admin installiert. Stutzig macht mich deine 4.0.9 Version.
      Übrigens ist es übersichtlicher auf Listenansicht
      G Thomas Braun 2 Replies Last reply Reply Quote 0
        Goldenbaum @Thomas Braun last edited by
        @Thomas-Braun Hier ist der komplette log.
        $ ./iobroker upgrade tr-064
        Update tr-064 from @4.0.1 to @4.0.9
        NPM version: 6.14.4
        npm install iobroker.tr-064@4.0.9 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node']npm ERR! stack:npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'',npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'access',npm ERR! path:npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node' }
        npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR!
        If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-11-06T08_39_31_366Z-debug.log
        ERROR: host.ioBrokerCT Cannot install iobroker.tr-064@4.0.9: 243
        ERROR: process exited with code 25
          Goldenbaum @crunchip last edited by
          @crunchip Wenn ich den Adapter löschen möchte kommt folgende Meldung.
          host.ioBrokerCT 2020-11-06 09:42:47.090 info iobroker exit 0
          host.ioBrokerCT 2020-11-06 09:42:46.075 error iobroker You might have to delete it yourself!
          host.ioBrokerCT 2020-11-06 09:42:46.074 error iobroker Error deleting adapter tr-064 from disk: Error: host.ioBrokerCT: Cannot uninstall iobroker.tr-064: 243
          host.ioBrokerCT 2020-11-06 09:42:46.011 info iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-11-06T08_42_45_999Z-debug.log
          host.ioBrokerCT 2020-11-06 09:42:46.010 info iobroker
          host.ioBrokerCT 2020-11-06 09:42:45.986 info iobroker npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/no
          host.ioBrokerCT 2020-11-06 09:42:45.978 info iobroker npm ERR! errno -13
          host.ioBrokerCT 2020-11-06 09:42:45.977 info iobroker npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node
          host.ioBrokerCT 2020-11-06 09:42:45.967 info iobroker
          host.ioBrokerCT 2020-11-06 09:42:45.965 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: U
          host.ioBrokerCT 2020-11-06 09:42:41.949 info iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/nodenpm WARN checkPermissions Missing write access to /opt/iobroker/node_modu
          host.ioBrokerCT 2020-11-06 09:42:15.451 info iobroker npm uninstall iobroker.tr-064 --error --prefix "/opt/iobroker" (System call)
            @Goldenbaum setze dein log in
            code_text
            du installierst auch nicht sondern versuchst ein upgrade!!!
            du musst auf die drei Punkte und dann unten links aufs plus, oder wie bereits geschrieben, auf listenansicht gehen
              Thomas Braun Most Active @Goldenbaum last edited by Thomas Braun
              @Goldenbaum
              Pi auf einer SD-Karte?
              Auf der Kommandozeile arbeiten.
              Ausgabe von
              dmesg
              angeben. In CodeTags, bitte.
                @Thomas-Braun sagte in Tr-064 adapter kann icht installiert werden:
                @Goldenbaum Auf der Kommando
                Pi auf einer SD-Karte? Habe es auf einem NAS laufen
                  @crunchip sagte in Tr-064 adapter kann icht installiert werden:
                  code_text
                  wie mache ich das?
                    crunchip Forum Testing Most Active @Goldenbaum last edited by crunchip
                    @Goldenbaum hier dein log einfügen, anstatt code text
                      host.ioBrokerCT	2020-11-06 10:03:28.933	info	Restart adapter system.adapter.tr-064.0 because enabled
                      host.ioBrokerCT	2020-11-06 10:03:28.932	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      tr-064.0	2020-11-06 10:03:28.373	warn	(11930) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      tr-064.0	2020-11-06 10:03:28.371	error	(11930) ~
                      tr-064.0	2020-11-06 10:03:28.371	error	(11930) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      tr-064.0	2020-11-06 10:03:28.370	error	(11930) ~~ Fatal error. Can not connect to your FritzBox.
                      tr-064.0	2020-11-06 10:03:28.368	error	(11930) Error: getaddrinfo ENOTFOUND fritz.box fritz.box:49000 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz.box","host":"fritz.box","port":"49000"}
                      tr-064.0	2020-11-06 10:03:28.140	info	(11930) starting. Version 4.0.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.21.0, js-controller: 3.1.6
                      host.ioBrokerCT	2020-11-06 10:03:25.222	info	instance system.adapter.tr-064.0 started with pid 11930
                        Goldenbaum @Goldenbaum last edited by
                        @Goldenbaum Das ist aktuell mein Problem
                          Neu gestartet habe ich die Fritzbox aber schon oft, das Passwort und Benutzername ist definitiv richtig
                            @Goldenbaum ok, also Installation hast du nun hinbekommen,
                            der Fehler ist ein anderes Problem.
                            • Einstellungen incl. Benutzer/Passwort (ohne Sonderzeichen) hast du in der Fritzbox gesetzt?
                              20936852-33ce-4765-900f-1cea970a0517-image.png 240cda75-5337-4cd3-92da-f833bbc01ce0-image.png
                            • Nach Neustart/Änderung der Fritzbox Einstellungen kann es bis zu 10 min dauern, bis die Kommunikation funktioniert
                            • Danach noch mal in die Instanz gehen, IP/Benutzer/Passwort erneut überschreiben und anschließend speichern, danach sollte es funktionieren
                              Thomas Braun Most Active @crunchip last edited by
                              Letzte stable-Version. Was lässt dich da stutzen?
                                @crunchip Habe ich alles soweit durchgeührt, wobei alles schon so eingestellt war.
                                host.ioBrokerCT	2020-11-06 10:36:42.677	info	Restart adapter system.adapter.tr-064.0 because enabled
                                host.ioBrokerCT	2020-11-06 10:36:42.677	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                tr-064.0	2020-11-06 10:36:42.121	warn	(17404) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                                tr-064.0	2020-11-06 10:36:42.119	error	(17404) ~
                                tr-064.0	2020-11-06 10:36:42.119	error	(17404) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                                tr-064.0	2020-11-06 10:36:42.118	error	(17404) ~~ Fatal error. Can not connect to your FritzBox.
                                tr-064.0	2020-11-06 10:36:42.116	error	(17404) Error: getaddrinfo ENOTFOUND fritz.box fritz.box:49000 - {"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"fritz.box","host":"fritz.box","port":"49000"}
                                haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                                • haselchen
                                  haselchen Most Active @Goldenbaum last edited by
                                  @Goldenbaum
                                  Gibt mal in den Einstellungen des Adapters die IP Deiner Box ein.
                                  Und lösche fritz.box raus.
                                    @Goldenbaum
                                    Kannst du die Box pingen?
                                    ping fritz.box
                                    ping IP_DER_BOX
                                      Goldenbaum @haselchen last edited by
                                      @haselchen Genau das war mein Problem.....
                                        @Thomas-Braun danke für die vielen nützlichen tipps, danke. läuft jetzt
                                        • haselchen
                                          haselchen Most Active @Goldenbaum last edited by haselchen
                                          @Goldenbaum
                                          Ist das gut oder schlecht, Problem gelöst oder nicht? 🤔
                                          Edit: okay, läuft jetzt. Sehr gut 👍
                                          Manchmal sind es die einfachen Dinge 😉
                                            Goldenbaum @haselchen last edited by Goldenbaum
                                            @haselchen Ja es läuft jetzt ...```
                                            das Problem des updaten habe ich zwar immer noch, aber evtl. löst sich das problem mit der zeit von selbst...
                                            NPM version: 6.14.4npm install iobroker.tr-064@4.0.9 --loglevel error --prefix "/opt/iobroker" (System call)
                                            npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/nodenpm ERR! errno -13npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node']npm ERR! stack:npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node'',npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'access',npm ERR! path:npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/@types/node' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
                                            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-11-06T10_01_06_289Z-debug.log
                                            tr-064 error
                                            1719
