    4. Test Adapter device-reminder v0.x
      guergen @Xenon last edited by guergen
      @Xenon Läuft soweit, abschaltung auch nach "0" Minuten gehtAllerdings sendet er mir, trotz (wohlweisslich) nicht angehaktem Telegram-Messenger eine Telegram Message:
      Waschmaschine Telegram true---> Ralf [wird auch gesendet wie "bestellt"]
      Wasserkocher Telegram true---> (leer) [wird dennoch gesendet]
      {"deviceName":"Waschmaschine","deviceType":"Waschmaschine","currentConsumption":"sonoff.0.Waschmaschine.ENERGY_Power","switchPower":"sonoff.0.Waschmaschine.POWER","pathStatus":"Waschmaschine.Zustand","pathLiveConsumption":"Waschmaschine.Verbrauch aktuell","timeTotal":"Waschmaschine.Laufzeit","messageDP":"Waschmaschine.messageDP","startMessageText":"","endMessageText":"Waschmaschine ist fertig","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"startValue":30,"endValue":15,"startCount":5,"endCount":65,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"startMessage":false,"endMessage":true,"timeoutInMS":300000,"timer":true,"timeout":null,"telegramUser":"Ralf","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsappID":["1"],"whatsapp":true},"sonoff.0.Wasserkocher.ENERGY_Power":{"deviceName":"Wasserkocher","deviceType":"Wasserkocher","currentConsumption":"sonoff.0.Wasserkocher.ENERGY_Power","switchPower":"sonoff.0.Wasserkocher.POWER","pathStatus":"Wasserkocher.Zustand","pathLiveConsumption":"Wasserkocher.Verbrauch aktuell","timeTotal":"Wasserkocher.Laufzeit","messageDP":"Wasserkocher.messageDP","startMessageText":"","endMessageText":"Wasserkocher ist fertig","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"startValue":10,"endValue":5,"startCount":2,"endCount":2,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"startMessage":false,"endMessage":true,"timeoutInMS":0,"timeout":null,"telegramUser":"","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsappID":["1"],"whatsapp":true}}
      Xenon 1 Reply Last reply Reply Quote 0
        @Xenon Fällt mir grade auf: Vorher hatte der DP Zustand ein "ausgeschaltet", jetzt steht da immer nach beenden ein "undefined", macht mir nichts, ist nur so ins Auge geflogen
          michihorn last edited by
          Danke für den Adapter, was trage ich denn bei WhatsApp ein?
          Michael
          • da_Woody
            da_Woody @michihorn last edited by
              michihorn @da_Woody last edited by
              @da_Woody Merci
              • da_Woody
                @michihorn bittsche
                • Xenon
                  Xenon Forum Testing Developer @guergen last edited by
                  @guergen sagte in Test Adapter device-reminder v0.x:
                  Das mit dem undefined ist mir auch aufgefallen, da muss ich nochmal nach schauen. Da stimmt was nicht
                  • Xenon
                    Das ist mein letzter Versuch mit dem automatischen ermitteln. Wenn das jetzt wieder Ärger macht, lasse ich die User auch von Hand anlegen
                      @Xenon Das sollte doch dann Telegram "false" sein, oder irre ich mich? Aussuchen kann ich den User ja!
                      • Xenon
                        ja sollte es, wenn aber kein Name drin steht kann auch an niemanden was gesendet werden. Schau ich mir gleich mal an
                        • htrecksler
                          htrecksler Forum Testing last edited by htrecksler
                          gibt es eigentlich eine Möglichkeit auf die Fertigmeldung Einfluss zu nehmen? Parameter hab ich in den Einstellungen nicht gefunden. Oder anders, woran macht der Adapter fest das die Waschmaschine fertig ist?
                          Hintergrund. Unsere Waschmaschine startet lt. Adapter zwar planmäßig (Meldung kommt), wird aber niemals fertig, weil Sie so intelligent ist, das sie immer mal wieder eine kleine Trommelumdrehung macht bis jemand zur Waschmaschine läuft und sie ausschaltet. Dann merkt der Adapter auch das sie fertig ist. (Aber dann hab ich es auch selber gemerkt).
                          Ein Offset oder so ähnlich wäre nicht schlecht. Hat das Problem kein anderer? Beim Trockner müsste das doch genauso sein. Knitterschutz?
                          EDIT:
                          Ich hab vorhin mal auf Debug umgestellt. Jetzt zeigt er ja alle 2 Minuten die Live Werte an. Der dümpelt jetzt schon seit 20 Minuten bei 0,11 mal 0,12 dann wieder 0,11...
                          Aber die Fertigmeldung steht noch aus.
                          Oder liegt das daran das ich während des Waschvorgangs auf Debug gestellt habe?
                          • Xenon
                            Xenon Forum Testing Developer @htrecksler last edited by Xenon
                            @htrecksler sagte in Test Adapter device-reminder v0.x:
                            hilfreich wären Verbrauchswerte. Die Werte haben wir über Monate hinweg an zahlreichen Geräten ermittelt, es gibt keine Möglichkeit diese händisch einzugeben. Hast du einen Verlauf ? Grafana oder ähnliches?
                            Er zeigt alle 2 Minuten die live Werte an? Wie oft kommen deine Werte denn rein?
                            Das Prinzip ist folgendes:
                            bsp: 20 4 5 60
                            der Wert 20 muss 5x IN FOLGE überschritten werden um als gestartet erkannt zu werden
                            Danach werden 60 Werte gespeichert und immer der Mittelwert gebildet, unterschreitet er 4 Watt wird fertig erkannt
                            Kommen aber nur alle 2 Minuten Werte rein, dauert es natürlich ewig, bis der Mittelwert den Vorgabewert unterschreitet
                            htrecksler 3 Replies Last reply Reply Quote 0
                            • htrecksler
                              htrecksler Forum Testing @Xenon last edited by
                              @Xenon ja, Grafana
                              Ab 16:06 ist er in den "Knitterschutzmodus" gegangen
                              • Xenon
                                @Xenon ja, Grafana
                                falls du Discord hast, können wir uns das ja mal zusammen anschauen
                                • htrecksler
                                  @Xenon sagte in Test Adapter device-reminder v0.x:
                                  Homematic Steckdose, die meldet sicher alle 2 Minuten
                                  • Xenon
                                    Die Zeit kann man doch mit Sicherheit reduzieren. Wenn du nur alle 2 Minuten einen Wert bekommst, kannst du damit ohnehin keine ordentliche Auswertung machen. Die Werte sind viel zu ungenau
                                    • htrecksler
                                      das wird der Grund sein
                                      htrecksler 1 Reply Last reply Reply Quote 0
                                      • htrecksler
                                        htrecksler Forum Testing @htrecksler last edited by htrecksler
                                        @htrecksler ich hab mal etwas in den Einstellungen des Gerätes in der CCU2 gedreht.
                                        Jetzt sollte er hoffentlich öfter senden.
                                        Obwohl, ich hoffe das geht nicht zu Lasten des DC. Schaun wir mal.
                                        Jetzt muss ich nur warten bis meine Frau die 2. Maschine auflegt. 🙂
                                        Stay tuned...
                                        Edit:
                                        läuft wieder, das Teil... Und jetzt sendet er auch öffter
                                        • htrecksler
                                          und jetzt hat er auch zeitnah die Fertigmeldung gegeben.
                                          Alles OK,
                                          @Xenon
                                          Danke für den Support.👍
                                          • Xenon
                                            Xenon Forum Testing Developer last edited by Xenon
                                            Update auf Version 0.3.1
                                            • (xenon-s) standby Ermittlung, auch wenn die Steckdose nicht abgeschaltet werden soll
                                            • (xenon-s) Es ist nun möglich, Nachrichten aus einem externen Datenpunkt zu holen und als Start / Endnachricht zu versenden <- ich glaube, dass ist der interessanteste Punkt für die meisten 😉
                                            • (xenon-s) Gerät "Mikrowelle" hinzugefügt
                                            31.7k
                                            79.9k
                                            adapter device-reminder geräteüberwachung test
                                            34
                                            458
                                            73358
