    2. English
    3. Scripting / Logic
    4. JavaScript
    5. how to stop instance of an adapter ?
      koburg last edited by
      how do I stop an instance of an adapter like Synology.0.stop don't seem to work
      please make a small script example if you like to help me.
      i want to stop the instance when a variable is true.
        paul53 @koburg last edited by paul53
        @koburg
        See example for function extendObject()
          koburg @paul53 last edited by
          great so script if a variable get true something like this ?
          if (getState("0_userdata.0.allan.New_object").val == true) {
            extendObject('adapter.system.synology.0', {common: {enabled: false}});
          what else would I need ?
            @koburg
            Better with trigger:
            on({id: "0_userdata.0.allan.New_object", val: true}, function() {
              @paul53 sorry but I can not get it working if the variable is true it is not disable/pause the instance nothing happen.
              1.0k
