    4. Apple Homekit Siri
    Apple Homekit Siri
      Griesemer last edited by
      @Griesemer:
      also ich bekomme weder die 0.1.4 noch die 0.1.5 stabil. Der Homekit Adapter veraschiedet sich regelmäßig nach wenigen Sekunden.
      Hier ein Beispiel. Vielleicht hilft es ja beim debuggen.
      ! host-ioBroker 2016-08-08 17:32:51.204 info instance system.adapter.homekit.0 terminated with code 0 (OK)
      ! TypeError: 2016-08-08 17:32:51.057 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! TypeError: 2016-08-08 17:32:51.057 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
      ! TypeError: 2016-08-08 17:32:51.057 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      ! TypeError: 2016-08-08 17:32:51.057 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      ! TypeError: 2016-08-08 17:32:51.057 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
      ! TypeError: 2016-08-08 17:32:51.057 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      ! TypeError: 2016-08-08 17:32:51.057 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
      ! TypeError: 2016-08-08 17:32:51.057 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
      ! TypeError: 2016-08-08 17:32:51.057 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:280:67)
      ! TypeError: 2016-08-08 17:32:51.057 error at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit/main.js:511:41)
      ! TypeError: 2016-08-08 17:32:51.057 error Cannot read property 'CurrentRelativeHumidity' of undefined
      ! uncaught 2016-08-08 17:32:51.051 error exception: Cannot read property 'CurrentRelativeHumidity' of undefined
      ! homekit-0 2016-08-08 17:32:50.872 info hap-nodejs starting…
      ! homekit-0 2016-08-08 17:32:44.580 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.homekit
      ! host-ioBroker 2016-08-08 17:32:39.796 info instance system.adapter.homekit.0 started with pid 7457 `
      Kommando zurück! Das hat mir ja keine Ruhe gelassen und nachdem ich die Instanz des Adapters gelöscht und neu installiert hatte, läuft es ohne Fehler im Log. Jetzt werde ich mich mal vorantasten. Wäre schön, wenn weitere Devices in den Adapter integriert würden; auf GitHub habe ich allerdings gesehen, dass offensichtlich schon länger nicht mehr an dem Adapter gearbeitet wird. Wäre wirklich schade.
        Franzel61 last edited by
        Hallo ,
        Viel der Sensoren kann man - solange sie Schalter/Steckdosen/Temperaturegeber oder Heizungsregeler sind in der List nachpflegen … jedoch vermisse ich die Steuerung der Rolladen ... wenn jemand dafür eine Lösung hat bin ich zufrieden ... sehr zufrieden tolles Project
          Bobohne last edited by
          Hallo zusammen!
          Gibt es denn schon eine Möglichkeit die Instanz auf Windows laufen zu lassen?
          Michael
            JW86 last edited by
            Hallo Zusammen,
            ich arbeite gerade an einem neuen Homekit Adapter da der bisherige mir zu wenig Features bietet (u.a. fehlt mir auch die Rolladensteuerung).
            Sobald ich was zum testen habe, werde ich es hier posten.
            Zum Thema Windows:
            Mit folgender Anleitung konnte ich HAP-NodeJS (der eigentliche Homekit Connector) unter Windows zum Laufen bekommen:
            https://github.com/nfarina/homebridge/w … on-Windows
            Man muss natürlich nicht alle Schritte durchführen die dort beschrieben sind, da man ja nicht HomeBridge installieren will. Aber ein Großteil der Schritte ist notwendig.
            Jens
              chka last edited by
              super, leider bekomme ich den aktuellen nicht mit iOS gebunden
                JW86 last edited by
                Hast du irgendeine Fehlermeldung? Oder findet das i-Gerät die Bridge einfach nicht?
                  chka last edited by
                  Das passwort ist richtig aber danach geht die kopplung schief.
                  Den fehler haben hier mehrer wenn du die letzen seiten durchblätterst.
                    wep4you2 last edited by
                    Also erst mal danke für diesen tollen Adapter.
                    Nachdem ich einige Tage serumprobiert habe, hab ich den Adapter heute auf einem Banana Pro erfolgreich zum Laufen gebracht,
                    nachdem ich alles neu installiert habe, also Nodejs und Biobroker komplett von 0 weg installiert. Kann sowohl von der HomeKit App aus dem iOS 10 heraus als auch aus der EVE App erfolgreich auf meine Geräte zugreifen, verliert zwar zeitweise die Verbindung aber verbindet sich auch wieder.
                    Mich würde jetzt interessieren wie ich nun mehr Devices ins HomeKit einbinden kann. Von Homematic hab ich noch einen Zwischenstecker, der wird zwar als Gerät angezeigt, aber der stürzt ab und reisst die anderen Devices im gleichen Raum mit, und meine optischen Fenster/Türkontakte zeigt er nicht an.
                    Weiters würde ich gern auch die Netatmo und Netatmo Welcome einbinden, geht das mit Config oder ist das erst zu programmieren?
                    • wendy2702
                      wendy2702 last edited by
                      ich versuche gerade den Homekit Adapter auf meinem Debian Wheezy zu installieren. Leider schlägt das immer fehl:
                      ! $ ./iobroker add homekit
                      ! npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
                      ! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                      ! compilation terminated.
                      ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                      ! gyp
                      ! ERR! build error
                      ! gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                      ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
                      ! gyp ERR! System Linux 3.16-0.bpo.2-amd64
                      ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
                      ! gyp ERR! node -v v4.5.0
                      ! gyp ERR! node-gyp -v v3.4.0
                      ! gyp ERR! not ok
                      ! npm
                      ! ERR! Linux 3.16-0.bpo.2-amd64
                      ! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
                      ! npm ERR! npm v2.15.9
                      ! npm ERR! code ELIFECYCLE
                      ! npm ERR! mdns@2.2.11 install: node-gyp rebuild
                      ! npm ERR! Exit status 1
                      ! npm ERR!
                      ! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
                      ! npm ERR! This is most likely a problem with the mdns package,
                      ! npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                      ! npm ERR! node-gyp rebuild
                      ! npm ERR! You can get information on how to open an issue for this project with:
                      ! npm ERR! npm bugs mdns
                      ! npm ERR! Or if that isn't available, you can get their info via:
                      ! npm ERR!
                      ! npm ERR! npm owner ls mdns
                      ! npm ERR! There is likely additional logging output above.
                      ! npm ERR! Please include the following file with any support request:
                      ! npm ERR! /npm-debug.log
                      ! ERROR: host.openmediavault Cannot install iobroker.homekit: 1
                      ! ERROR: process exited with code 25
                      Node Version ist 4.5.0 –> ist das schon zu alt?
                      Vielleicht sonst noch jemand eine Idee was fehlen könnte?
                      EDIT:hat sich erledigt: fehlendes Paket installiert:
                      ! sudo apt-get install libavahi-compat-libdnssd-dev
                      Danke und Gruß
                        chka last edited by
                        den Fehler habe ich auch
                          Stefnas last edited by
                          @chka:
                          den Fehler habe ich auch `
                          bei mir hat folgendes geholfen:
                          apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
                          ich habe meinen homekit adapter aktuell laufen, nur leider findet mein handy auf einnmal die bridge nicht mehr. am vormittag zuhause noch gefunden und am nachmittag nicht mehr, seitdem ist nichts zu machen…neustart und neuinstallation blieb erfolglos...jemand eine idee?
                            JW86 last edited by
                            @Stefnas:
                            @chka:
                            den Fehler habe ich auch ich habe meinen homekit adapter aktuell laufen, nur leider findet mein handy auf einnmal die bridge nicht mehr. am vormittag zuhause noch gefunden und am nachmittag nicht mehr, seitdem ist nichts zu machen…neustart und neuinstallation blieb erfolglos...jemand eine idee?
                            Ändere mal den "Username". Wichtig ist das du wieder etwas in Form einer MAC Adresse angibst (XX:XX:XX:XX:XX:XX in HEX).
                            Anschließend wird die Bridge aber wieder als neues Gerät erkannt und du musst das Pairing wieder durchführen.
                              @JW86:
                              Anschließend wird die Bridge aber wieder als neues Gerät erkannt und du musst das Pairing wieder durchführen. `
                              Danke. Prüfe ich heute Abend und gebe bescheid…
                                @JW86:
                                Danke hat funktioniert. Siri funktioniert nun ohne Probleme mit meinen Homematicthermostaten, außer das Wandthermostat lässt sich nicht abfragen, ändern…aber das coolste überhaupt ist das sogar der Botcac Connected Staubsauger erkannt wird und sogar steuerbar ist...sensationell, ist das Zufall oder gewollt?
                                  Solear last edited by
                                  Kann jetzt bitte noch einmal jemand genau sagen, was momentan mit diesem Adapter machbar ist?
                                  Ich verstehe noch nicht genau, wie der funktioniert.
                                  Brauche ich ein Hardware-Home-fähiges Teil?
                                  Oder nur die Steuersoftware-App wie die von elagto?
                                  Ist es egal welche?
                                  Kann ich mit Siri dann Glühbirnen über Homematic Strommessstecker schalten? Darum geht es mir letztlich.
                                    @Solear:
                                    Ist es egal welche?
                                    Kann ich mit Siri dann Glühbirnen über Homematic Strommessstecker schalten? Darum geht es mir letztlich. `
                                    • Brauche ich ein Hardware-Home-fähiges Teil?
                                    Nein habe ich ebenfalls nicht.
                                    • Oder nur die Steuersoftware-App wie die von elagto
                                    Nein, kannst auch direkt die von Apple nehmen "Home".
                                    • Ist es egal welche?
                                    Denke schon, bei mir funktioniert "Home" von Apple und die von "Elgato".
                                    Bei mir werden zur Zeit alle Homematic Thermostate (Homematic 105155 Funk-Heizkörperthermostat für Smart Home / Hausautomation) und ein Zwischenstecker (Homematic 130248 Funk-Schaltaktor 1fach mit Leistungsmessung, Zwischenstecker für Smart Home / Hausautomation) erkannt und ich kann diese darüber steuern ob noch mehr Geräte funktionieren kann ich Dir nicht sagen da mir keine weiteren vorliegen. Zufällig habe ich gesehen das mein Neato Botvac Connected Staubsauger ebenfalls darüber ansteuerbar ist…
                                      Vielen Dank, Stefnas!
                                      Das hat soweit geklappt. Homekit ist installiert und aktiviert.
                                      Ich hatte schon schon, dass auf dem iPhone kein Homekit Server gefunden worden ist. Das konnte ich erst beheben als ich die Macadresse in den Homekit-Adaptereinstellungen etwas verändert habe.
                                      Es werden auch viele Geräte erkannt, u.a die Strommessschalter und UP-Dimmer. Aber, es steht dann immer "Kommunikation nicht möglich".
                                      Im Log steht nichts, da läuft öfter aber homekit vorbei mit Statusaktualisierungen (also das klappt, aber zwischen iPhone und Homekit-Adapter scheint was nicht zu klappen).
                                      Was könnte das sein?
                                      In den Adaptereinstellungen Homekit, was besagt die Mac-Adresse?
                                      Mein iobroker läuft in einer VM unter Ubuntu auf VMWare Workstation/Windows 8.1
                                        @Solear:
                                        Was könnte das sein? `
                                        Das Problem kann ich bei mir nachvollziehen, allerdings nur dann wenn die Apple Home App offen ist. Ich habe deshalb folgendes gemacht:
                                        • Installation Homekit Adapter
                                        • Einrichtung Homekit Adapter
                                        • Verbinden mit Apple Home und einrichten der einzelnen Geräte (Name + Raumzuordnung), Fehlermeldungen hierbei habe ich einfach ignoriert und weitergemacht
                                        • Nach der kompletten Einrichtung habe ich die Apple Home App geschlossen und ioBroker neugestartet
                                        Danach funktioniert das alles bei mir stabil, die Verbindung bricht immer dann ab wenn ich die Apple Home App öffne, dann ist es so das mal eine Verbindung besteht und mal nicht, dann kann ich im ioBroker aber auch beobachten das die Instanz mal grün und mal rot ist. Ich lasse deshalb die Home App einfach zu und alles geht wie es soll, außer meinem Wandthermostat, dieses mag nicht so wie ich, hat da jemand eine Idee?
                                          charlyphyro last edited by
                                          Bekomme eine Fehlermeldung vllt kann mir einer helfen!
                                          Hängt es an einem hm-module?
                                          Viele Grüße Charly
                                          inMem 2016-10-26 18:22:34.901 debug message * system.adapter.homekit.0.alive val=false, ack=true, ts=1477498954899, q=0, from=system.adapter.homekit.0, lc=1477498954899
                                          TypeError: 2016-10-26 18:22:34.898 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                          TypeError: 2016-10-26 18:22:34.898 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                          TypeError: 2016-10-26 18:22:34.898 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                                          TypeError: 2016-10-26 18:22:34.898 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                          TypeError: 2016-10-26 18:22:34.898 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                          TypeError: 2016-10-26 18:22:34.898 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                                          TypeError: 2016-10-26 18:22:34.898 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                                          TypeError: 2016-10-26 18:22:34.898 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                                          TypeError: 2016-10-26 18:22:34.898 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                                          TypeError: 2016-10-26 18:22:34.898 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:324:26)
                                          TypeError: 2016-10-26 18:22:34.898 error Cannot read property 'PARENT_TYPE' of undefined
                                          Gesendet von iPad mit Tapatalk
                                            holgerwolf last edited by
                                            ist gibt ja jetzt einen Homekit2.0 (V0.1.6) Adapter. Wurde hier nirgendwo angekündigt oder habe ich was übersehen.
                                            Damit habe ich erstmal die Installationsprobleme von der Vorgänger Version weg.
                                            Nach dem Starten des Adapters kann ich diesen auch in der Apple Home App sehen und die Bridge konfigurieren. Darauf sehe ich kurz alle Geräte aus der Adapter-Liste aber dann schmiert der Adapter ab:
                                            host.lemaker	2016-11-04 11:09:57.577	info	Restart adapter system.adapter.homekit2.0 because enabled
                                            host.lemaker	2016-11-04 11:09:57.575	error	instance system.adapter.homekit2.0 terminated with code 0 (OK)
                                            inMem	2016-11-04 11:09:57.493	debug	message * system.adapter.homekit2.0.alive val=false, ack=true, ts=1478254197476, q=0, from=system.adapter.homekit2.0, lc=1478254197476
                                            TypeError:	2016-11-04 11:09:57.461	error	at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Socket. (/opt/iobroker/node_modules/iobroker.homekit2/main.js:200:60)
                                            TypeError:	2016-11-04 11:09:57.461	error	at /opt/iobroker/node_modules/iobroker.homekit2/main.js:18:13
                                            TypeError:	2016-11-04 11:09:57.461	error	at main (/opt/iobroker/node_modules/iobroker.homekit2/main.js:280:67)
                                            TypeError:	2016-11-04 11:09:57.461	error	at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit2/main.js:513:41)
                                            TypeError:	2016-11-04 11:09:57.461	error	Cannot read property 'CurrentRelativeHumidity' of undefined
                                            uncaught	2016-11-04 11:09:57.456	error	exception: Cannot read property 'CurrentRelativeHumidity' of undefined
                                            homekit2.0	2016-11-04 11:09:57.425	debug	> iobroker subscribe Humidity hm-rpc.0.HEQ0118211.1.HUMIDITY
                                            homekit2.0	2016-11-04 11:09:57.408	debug	< hap Type for Humidity = HM-WDS100-C6-O
                                            homekit2.0	2016-11-04 11:09:57.404	debug	Accessory: Switch Object: State
                                            homekit2.0	2016-11-04 11:09:57.328	info	hap-nodejs starting...
                                            homekit2.0	2016-11-04 11:09:57.318	debug	received all objects
                                            homekit2.0	2016-11-04 11:09:56.415	debug	received all states
                                            homekit2.0	2016-11-04 11:09:54.335	debug	requesting all objects
                                            homekit2.0	2016-11-04 11:09:54.328	debug	requesting all states
                                            homekit2.0	2016-11-04 11:09:54.307	info	starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.homekit2
                                            homekit2.0	2016-11-04 11:09:54.113	debug	statesDB connected
                                            homekit2.0	2016-11-04 11:09:54.050	debug	objectDB connected
                                            host.lemaker	2016-11-04 11:09:50.072	info	instance system.adapter.homekit2.0 started with pid 494
                                            Scheint wohl zu sein, dass er mit einem Wert 'CurrentRelativeHumidity' nicht klar kommt.
                                            Ich habe auch mal alle Geräte aus der Adapter-Liste entfernt. Bis auf einen einfachen Schalter. Es wird trotzdem versucht alle Geräte einzulesen und der Adapter bleibt mit der gleichen Meldung wie oben stehen.
                                            Holger
                                            250
                                            52385
