    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Разные ошибки
    Разные ошибки
      spectrekr last edited by
      Драйвер Rickshaw Charts не обновляется ни в какую. Статус обновления 0, а в админке так и весит что надо обновить. Через консоль тоже самое.
      ! iobroker 2016-09-07 10:07:43.218 info exit 0
      ! iobroker 2016-09-07 10:07:43.209 info Adapter "rickshaw" updated
      ! iobroker 2016-09-07 10:07:43.117 info upload [0] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/edit.html edit.html text/html
      ! iobroker 2016-09-07 10:07:43.052 info upload [1] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/index.html index.html text/html
      ! iobroker 2016-09-07 10:07:42.993 info upload [2] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/lib/css/rickshaw.min.css lib/css/rickshaw.min.css text/css
      ! iobroker 2016-09-07 10:07:42.913 info upload [3] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/lib/js/d3.v3.js lib/js/d3.v3.js application/javascript
      ! iobroker 2016-09-07 10:07:42.904 info upload [0] rickshaw.admin /opt/iobroker/node_modules/iobroker.rickshaw/admin/index.html index.html text/html
      ! iobroker 2016-09-07 10:07:42.820 info upload [4] rickshaw /opt/iobroker/node_modules/iobroker.rickshaw/www/lib/js/rickshaw.min.js lib/js/rickshaw.min.js application/javascript
      ! iobroker 2016-09-07 10:07:42.813 info upload [1] rickshaw.admin /opt/iobroker/node_modules/iobroker.rickshaw/admin/rickshaw.png rickshaw.png image/png
      ! iobroker 2016-09-07 10:07:42.787 info got /opt/iobroker/node_modules/iobroker.rickshaw/www
      ! iobroker 2016-09-07 10:07:42.783 info got /opt/iobroker/node_modules/iobroker.rickshaw/admin
      ! iobroker 2016-09-07 10:07:41.892 info npm install –production --prefix "/opt/iobroker/node_modules/iobroker.rickshaw" (System call)
      ! iobroker 2016-09-07 10:07:23.312 info npm install iobroker.rickshaw --production --prefix "/opt/iobroker" (System call)
      ! iobroker 2016-09-07 10:07:22.761 info upgrade rickshaw
        Haus last edited by
        @spectrekr:
        ! iobroker 2016-09-07 10:07:22.761 info upgrade rickshaw `
        Bluefox исправь io-package.json
        "common": {
                "name":         "rickshaw",
                "version":      "0.4.2",
          dimon last edited by
          После последних обновлений перестал работать админский интерфейс - белый экран. Причем vis работает.
          Что можно сделать?
            Haus last edited by
            @dimon:
            Что можно сделать? `
            http://forum.iobroker.net/viewtopic.php … 120#p34162
              ford7 last edited by
              Откатился, вроде задышал брокер, но в логе сыпется каждые 2-3 минуты
              host-zvmubn	2016-09-07 21:10:42.120	info	Restart adapter system.adapter.admin.0 because enabled
              host-zvmubn	2016-09-07 21:10:42.119	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
              host-zvmubn	2016-09-07 21:10:42.075	info	Restart adapter system.adapter.web.0 because enabled
              host-zvmubn	2016-09-07 21:10:42.075	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
              host-zvmubn	2016-09-07 21:10:41.438	info	instance system.adapter.web.0 started with pid 10658
              host-zvmubn	2016-09-07 21:10:40.896	info	instance system.adapter.admin.0 started with pid 10656
              host-zvmubn	2016-09-07 21:10:38.908	info	Restart adapter system.adapter.sayit.0 because enabled
              host-zvmubn	2016-09-07 21:10:38.908	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
              host-zvmubn	2016-09-07 21:10:38.597	info	instance system.adapter.sayit.0 started with pid 10650
              host-zvmubn	2016-09-07 21:10:33.284	info	Update repository "fast-online" under "http://download.iobroker.net/sources-dist.json"
              host-zvmubn	2016-09-07 21:10:26.785	info	Restart adapter system.adapter.socketio.0 because enabled
              host-zvmubn	2016-09-07 21:10:26.784	error	instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
              host-zvmubn	2016-09-07 21:10:26.602	info	Restart adapter system.adapter.s7.0 because enabled
              host-zvmubn	2016-09-07 21:10:26.602	error	instance system.adapter.s7.0 terminated with code 7 (Adapter already running)
              host-zvmubn	2016-09-07 21:10:26.038	info	Restart adapter system.adapter.sql.0 because enabled
              host-zvmubn	2016-09-07 21:10:26.037	error	instance system.adapter.sql.0 terminated with code 7 (Adapter already running)
              host-zvmubn	2016-09-07 21:10:25.874	info	instance system.adapter.s7.0 started with pid 10635
              host-zvmubn	2016-09-07 21:10:25.848	info	instance system.adapter.socketio.0 started with pid 10633
              host-zvmubn	2016-09-07 21:10:25.219	info	instance system.adapter.sql.0 started with pid 10631
              • Bluefox
                Bluefox last edited by
                @ford7:
                Перезапустить надо комп.
                  andrey99986 last edited by
                  после попытки обновить admin через админку, он пропал.
                  В консоли:
                  root@debian:/home/iobroker# iobroker stop
                  Stopping iobroker controller daemon...
                  iobroker controller daemon stopped.
                  Exit code for "killall.sh": 0
                  root@debian:/home/iobroker# npm install iobroker.admin --production
                  iobroker.core@ /home/iobroker
                  └── (empty)
                  npm ERR! code 1
                  Дело в том что по умолчанию указал репозитарий с гита. Может в этом проблема ? Как лечить?
                  Драйвер не запускается, на порт 8081 ничего нет.
                    kID last edited by
                    @andrey99986:
                    после попытки обновить admin через админку, он пропал. `
                    вначале обновить js-controller
                    iobroker upgrade self
                    затем
                    iobroker del admin
                    iobroker add admin –enabled
                    Мне помогло
                      @kID:
                      @andrey99986:
                      затем
                      iobroker del admin
                      Мне помогло `
                      Дело было в канале связи - ограничение скорости до 64 кбит.
                      Пополнил баланс, команда на обновление после этого отработала нормально.
                      Возьмите на заметку.
                        Обнаружил ошибку в мультихост.
                        Ситуация: на основном сервере стоит драйвер, вторую версию драйвера устанавливаю на дочерний сервер. Ошибка заключается в том, что если с дочернего сервера удаляешь драйвер, то с основного сервера он тоже удаляется.
                          Настройка let's encrypt.
                          2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80
                          2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80
                          at Object.exports._errnoException (util.js:874:11)
                          at exports._exceptionWithHostPort (util.js:897:20)
                          at Server._listen2 (net.js:1221:19)
                          at listen (net.js:1270:10)
                          at Server.listen (net.js:1366:5)
                          at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21)
                          at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28)
                          at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25
                          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21)
                          at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                          at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                          at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                          at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                          at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                          at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14)
                          at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10)
                          at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                          at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8)
                          at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8)
                          at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10)
                          at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                          at emitTwo (events.js:87:13)
                          2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081
                          2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081
                          2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure.
                          2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081
                          2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception)
                          2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous>
                            Попробовал сделать экспорт всех скриптов, получил ошибку.
                            ! TypeError: 2017-02-15 12:23:57.693 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Object.States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:228:25)
                            ! TypeError: 2017-02-15 12:23:57.693 error at processMessage (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1282:26)
                            ! TypeError: 2017-02-15 12:23:57.693 error at Object.readObjectsAsZip (/opt/iobroker/node_modules/iobroker.js-controller/lib/zipFiles.js:249:13)
                            ! TypeError: 2017-02-15 12:23:57.693 error objects.getConfigKeys is not a function
                            ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function
                            • Bluefox
                              @spectrekr:
                              ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function `
                              Multihost?
                                @Bluefox:
                                @spectrekr:
                                ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function Multihost?
                                Да.
                                • Bluefox
                                  @spectrekr:
                                  @Bluefox:
                                  @spectrekr:
                                  Да. `
                                  Ошибка.. Поправлю в следующей версии.
                                  Спасибо.
                                  • Bluefox
                                    @spectrekr:
                                    ! 2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80 2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80 at Object.exports._errnoException (util.js:874:11) at exports._exceptionWithHostPort (util.js:897:20) at Server._listen2 (net.js:1221:19) at listen (net.js:1270:10) at Server.listen (net.js:1366:5) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21) at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28) at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14) at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14) at emitTwo (events.js:87:13) 2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081 2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure. 2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous> `
                                    Кто то висит на порту 80 и не даёт запустить web.
                                    Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать.
                                      @Bluefox:
                                      @spectrekr:
                                      Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать. `
                                      Странно, висеть больше не чему. Ну в любом случае обновился.
                                        Подскажите, node-red ругается на node.js- как поправить?
                                        node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
                                        node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
                                        node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
                                        node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
                                        node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
                                        node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
                                        node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
                                        node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
                                        web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
                                        web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
                                        web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
                                        node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
                                        node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
                                        node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
                                          Haus last edited by
                                          @ford7:
                                          ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
                                          Сменить nodejs нужна версия v4.x и выше.
                                          • I
                                            Izzm last edited by
                                            Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
                                            Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
                                            js-controller 0.16.2
                                            Admin 1.7.0
                                            JS 3.2.6
                                            1.0k
                                            192
                                            55990
