    4. Test Adapter device-reminder v0.x
    • Xenon
      Xenon Forum Testing Developer @guergen last edited by
      @guergen sagte in Test Adapter device-reminder v0.x:
      @Xenon In der Version 0.3.0 & 0.3.1 auf Git geht das Abschalten nach "0" Minuten nicht mehr:
      2020-11-08 07:50:34.000 - debug: device-reminder.0 (9437) RETURN {"deviceName":"Wasserkocher","deviceType":"Wasserkocher","currentConsumption":"sonoff.0.Wasserkocher.ENERGY_Power","switchPower":"sonoff.0.Wasserkocher.POWER","pathStatus":"Wasserkocher.Zustand","pathLiveConsumption":"Wasserkocher.Verbrauch aktuell","timeTotal":"Wasserkocher.Laufzeit","messageDP":"Wasserkocher.messageDP","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"resultStandby":null,"startValue":10,"endValue":5,"startCount":2,"endCount":2,"timeoutMsg":null,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"arrStandby":[],"startMessageText":"","startMessage":false,"endMessageText":"Wasserkocher ist fertig","endMessage":true,"timer":false,"timeout":null,"telegramUser":"Ralf","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsapp":false}
      Wenn ich "1" als timeout eintrage geht das Gerät aus und sieht es wie folgt aus:
      2020-11-08 08:10:01.936 - debug: device-reminder.0 (2276) RETURN {"deviceName":"Wasserkocher","deviceType":"Wasserkocher","currentConsumption":"sonoff.0.Wasserkocher.ENERGY_Power","switchPower":"sonoff.0.Wasserkocher.POWER","pathStatus":"Wasserkocher.Zustand","pathLiveConsumption":"Wasserkocher.Verbrauch aktuell","timeTotal":"Wasserkocher.Laufzeit","messageDP":"Wasserkocher.messageDP","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"resultStandby":null,"startValue":10,"endValue":5,"startCount":2,"endCount":2,"timeoutMsg":null,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"arrStandby":[],"startMessageText":"","startMessage":false,"endMessageText":"Wasserkocher ist fertig","endMessage":true,"timeoutInMS":60000,"timer":true,"timeout":null,"telegramUser":"Ralf","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsapp":false}
      Zum Telegram-Problem: Wähle ich einen User aus, bekommt derjenige die Meldung, trage ich keinen ein, bekommen beide User die Nachricht.
      für das auto Off gibts jetzt nen Patch, Telegram muss ich mir in Ruhe anschauen. Du bist auch der einzige der von dem Problem berichtet, muss aber ja nix heißen 😛
      Version 0.3.2 ist draußen
        guergen @Xenon last edited by
        @Xenon Die neue Version probiere ich gleich aus....
        Von 0.2.x nach 0.3.x habe ich den alten Adapter komplett gelöscht, muss ich beim Update innerhalb 0.3.x auch alles löschen?
        Xenon 1 Reply Last reply Reply Quote 0
        • Xenon
          nein, nur unter v 0.2, weil ich da was grundlegendes an der struktur geändert habe
            @Xenon OK
            • Xenon
              @Xenon OK
              wie gesagt das mit telegram schau ich mir in Ruhe an. Sollten bei der 0.3.2 Fehler auftreten, einfach melden 😉
                guergen @Xenon last edited by guergen
                @Xenon Nix mit "auto OFF" bei "0"....
                • JB_Sullivan
                  JB_Sullivan last edited by
                  Guten Morgen - habe diesen Adapter durch Zufall gefunden und mal installiert. Allerdings werden bei mir keine Objekte angelegt. Die Instanz ist vorhanden und auch Grün.
                  Jedoch gibt es keinen Ordner unter den Objekten. Kommen die erst wenn auch Verbrauch über die Steckdose geht?
                    guergen @JB_Sullivan last edited by guergen
                    @JB_Sullivan Anleitung gelesen?
                    Die Objekte musst Du schon selbst im Adapter anlegen....
                    Woher soll der denn wissen, welche Geräte Du überwachen willst?
                    • JB_Sullivan
                      JB_Sullivan @guergen last edited by JB_Sullivan
                      Witzig Witzig - das ist mir auch klar.
                      So, jetzt ist ein Objekt angelegt worden, aber der Inhalt ist leer und es wurde die folgende Warn Meldung ausgegeben.
                      device-reminder.0	2020-11-08 10:07:23.958	warn	(8656) value status: 2
                      G Xenon 3 Replies Last reply Reply Quote 0
                        @JB_Sullivan Nachdem Du speichern gedrückt hast, sollten die GEräte als DP angelegt werden, zur Not einmal neu laden drücken in der Objekt-Anzeige.
                        Hast Du denn einen Alexa-Device angelegt? Dann klick doch mal auf den schwarzen Pfeil und wähle sie aus!
                        Warnmeldung ist schon "gemeldet" worden.... ist erst seit 0.3.2 so
                          @JB_Sullivan Leer ist das immer dann wenn Du keine Meldung haben möchtest!
                          • Xenon
                            das ist nur ne debug meldung die ich vergessen hab, hab ich entfernt aber du warst zu schnell 😄
                              @Xenon 😉
                              • Xenon
                                Xenon Forum Testing Developer @JB_Sullivan last edited by Xenon
                                @JB_Sullivan sagte in Test Adapter device-reminder v0.x:
                                aktuell ist es noch so, dass du zuerst alles auf der config seite anlegen musst und danach Speichern und Schliessen anklicken musst. Dadurch werden deine angelegten devices, alexas und co auf der Startseite in einer Tabelle erstellt. In dieser kannst du dann alles konfigurieren und musst anschließend nochmals auf Speichern und Schliessen.
                                Wenn alles in Ordnung ist erscheint im Log eine Meldung, die die anzeigt, dass alle Geräte erstellt wurden:
                                device-reminder.0	2020-11-08 10:25:27.457	info	(10706) Gerät "Geschirrspüler" wurde erfolgreich angelegt
                                device-reminder.0	2020-11-08 10:25:27.224	info	(10706) Gerät "Trockner" wurde erfolgreich angelegt
                                device-reminder.0	2020-11-08 10:25:27.072	info	(10706) Gerät "Computer" wurde erfolgreich angelegt
                                device-reminder.0	2020-11-08 10:25:26.883	info	(10706) Gerät "Waschmaschine" wurde erfolgreich angelegt
                                Ich bin da aber dran, dass man das mit einem Klick erledigen kann. Ist aber etwas aufwendiger und dauert noch ein wenig
                                Aber cool das du testest
                                • Xenon
                                  Xenon Forum Testing Developer last edited by Xenon
                                  device-reminder.0	2020-11-08 10:25:16.362	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:25:12.404	warn	(31013) value status: 0
                                  device-reminder.0	2020-11-08 10:25:09.247	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:25:07.512	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:25:06.440	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:25:02.388	warn	(31013) value status: 0
                                  device-reminder.0	2020-11-08 10:24:59.247	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:24:57.649	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:24:56.589	warn	(31013) value status: 1
                                  device-reminder.0	2020-11-08 10:24:52.738	warn	(31013) value status: 0
                                  device-reminder.0	2020-11-08 10:24:49.268	warn	(31013) value status: 1
                                  Das kam daher, dass ich anscheinend die falsche main.js gepusht hatte. Jetzt ist die richtige drauf. Nervig, wenn man auf mehreren Systemen gleichzeitig entwickelt 🙄
                                    @Xenon OK, ist drin... Log ist wieder ruhig.
                                    Aber abschalten macht er bei "0" leider immer noch nicht!
                                    • Xenon
                                      bei mir funktioniert es. Hast du Discord ?
                                        @Xenon ja
                                        • Xenon
                                          @Xenon ja
                                          hätte kurz Zeit mal drüber zu schauen, bin im Channel: 2 user only
                                            @Xenon ... habe ich, lese da mit, ob ich wirklich weiss, was discord kann.....??? Probieren
                                            adapter device-reminder geräteüberwachung test
                                            34
                                            458
                                            74966
