    4. Ring Doorbell Bild versenden
    • lobomau
      lobomau @denjo last edited by
      @denjo ich schau auch mal zuHause ob lokal auch da was liegt.
        denjo @lobomau last edited by
        @lobomau so hier hast es nochmal
          <variables>
            <variable type="timeout" id="timeout2">timeout2</variable>
          </variables>
          <block type="procedures_defnoreturn" id="bs.Be:C=O@{PrDLiP=Xn" x="513" y="13">
            <field name="NAME">Foto senden</field>
            <statement name="STACK">
              <block type="timeouts_settimeout" id="%UC_laZ!*JVjI18h,~{L">
                <field name="DELAY">4</field>
                  <block type="telegram" id="veeUb`#.MPas7B,0rrzu">
                    <field name="LOG"></field>
                    <value name="MESSAGE">
                      <shadow type="text" id="E3!Jfy+ElH)$3p]I8$Q5">
                        <field name="TEXT">/opt/iobroker/node_modules/iobroker.ring/snapshot/snapshot.jpg</field>
          <block type="on_ext" id="*GQ/}isVM,5_TzN(D)T~" x="-37" y="213">
            <value name="OID0">
              <shadow type="field_oid" id="[bvNQ@mpJA{-Y$d|f7,t">
              <block type="field_oid" id="G.9freetPImvZnW#=zGN">
                <field name="oid">ring.0.doorbell_49207736.created_at</field>
              <block type="controls_if" id="+ByAo0I.3ZY#djo*7!Lo">
                  <block type="logic_compare" id="]*dZx-?J9!@DGiBZ.mfL">
                    <field name="OP">EQ</field>
                      <block type="get_value" id="GWGh=IWH~ZS{=f9Q!0Jb">
                        <field name="OID">ring.0.doorbell_49207736.kind</field>
                      <block type="text" id="e`y;fRb={q%~mH1p)hj~">
                        <field name="TEXT">ding</field>
                  <block type="telegram" id="T7wRo@dViH$OP]W0Gub9">
                      <shadow type="text" id="JYo)[:~I6r$?jk;qGm7*">
                        <field name="TEXT">Klingel Haustür</field>
                      <block type="procedures_callnoreturn" id="D=gs+cc9A5:goIMGq-)D">
                        <mutation name="Foto senden"></mutation>
                          <block type="procedures_callnoreturn" id="ae-2iv6/Itl@9d,YJPP,">
                            <mutation name="Video senden"></mutation>
          <block type="procedures_defnoreturn" id="|t(vFv/:#{A7JbYhp*J~" x="513" y="288">
            <field name="NAME">Video senden</field>
              <block type="timeouts_settimeout" id="a}q5YHzY{$[!b)6i@1fx">
                <field name="DELAY">20</field>
                  <block type="telegram" id="bD7wuyQzmMC,yDO$}~Wo">
                      <shadow type="text" id="QB2/Ay@*Uvd_It+{X/f~">
                        <field name="TEXT">/opt/iobroker/node_modules/iobroker.ring/snapshot/livestream.mp4</field>
          @lobomau welche Version hast du von dem ring Adapter?
          lobomau 1 Reply Last reply Reply Quote 0
          • lobomau
            lobomau @denjo last edited by lobomau
            @denjo Version 1.1.3.
            Mein Ordner speichert kein snapshot.jpg ab.
            Das Bild aber bei mir unter der URL abgespeichert:
            https://ioBrokerCT:8082/ring.0/doorbell_XX3746YY/snapshot.jpg
              @lobomau lade dir den Adapter über github.com Version 1.1.5
                @lobomau https://github.com/schmupu/ioBroker.ring
                lobomau E 3 Replies Last reply Reply Quote 0
                • lobomau
                  @denjo update läuft...
                  • lobomau
                    @denjo hmm... nun ist der Ordner komplett leer. Wird nichts geschrieben. Und der andere snapshot unter https://ioBrokerCT:8082/ring.0/doorbell_XX3746YY/snapshot.jpg ist alt, da scheint noch die Sonne.
                    Version 1.1.5 beta
                    • lobomau
                      lobomau @lobomau last edited by
                      @lobomau Wahrscheinlich hab ich irgendein Rechte Problem und kann da nicht schreiben 😞
                      • 2
                        2hot4you @denjo last edited by
                        @denjo sagte in Ring Doorbell Bild versenden:
                        @Ralla66 habs hin bekommen voll easy geil. kann es gerne erklären falls jemand möchte
                        welche Doorbell hast Du und funktioniert es auch ohne Abo ?
                          denjo @2hot4you last edited by
                          @2hot4you ich habe die pro und kein Abo
                            denjo @denjo last edited by
                            kann mir jemand sagen was diese fehlermeldung zu sagen hat???
                            writeFile	2020-11-14 21:43:58.109	warn	will not write this file (doorbell_49207736/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
                            ring.0	2020-11-14 21:43:58.087	warn	(1734) writeFile will not write this file (doorbell_49207736/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
                              MyMeyer @denjo last edited by
                              @denjo Hi was ist mit der zweistufigen Überprüfung bei RING. Ich kann diese Online NICHT abschalten .
                                MyMeyer @MyMeyer last edited by
                                @MyMeyer sagte in Ring Doorbell Bild versenden:
                                @denjo Hat Sich erledigt. Ich habe alles gefunden. 🙂 Thanks...
                                  @denjo Schon ein Lösung dazu gefunden ?
                                  Error: Error setSanpshot()): Error: Could not create Snapshot for 45172445 in getSnapshot(). Error: Snapshot for Haustür failed to refresh after 70 attempts. This is normal behavior since th
                                  ring.0 2020-11-18 08:17:38.885 warn (28878) writeFile will not write this file (doorbell_45172445/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
                                    andyb @MCU last edited by andyb
                                    Kann mir jemand helfen.....ich bekomme keinen Snap und kein Video.
                                    Augenscheinlich tut alles, aber es werden keine Dateien erzeugt, Verzeichnis bleibt leer. Berechtigungen sind vergeben.
                                    host.iob2	2020-11-21 08:59:47.530	warn	writeFile will not write this file (doorbell_32387933/snapshot.jpg) in future versions: ring.0 is not an object of type "meta"
                                    ring.0	2020-11-21 08:59:47.498	warn	(16269) writeFile will not write this file (doorbell_32387933/snapshot.jpg) in future versions: ring.0 is not an object of type "meta"
                                    ring.0	2020-11-21 08:59:47.486	info	(16269) Done creating snapshot
                                    host.iob2	2020-11-21 08:59:39.481	warn	writeFile will not write this file (doorbell_32387933/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
                                    ring.0	2020-11-21 08:59:39.342	warn	(16269) writeFile will not write this file (doorbell_32387933/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
                                    ring.0	2020-11-21 08:59:39.300	info	(16269) Done creating livestream
                                    ring.0	2020-11-21 08:59:28.442	info	(16269) Starting creating livestream with recording time 10 sec.
                                    ring.0	2020-11-21 08:59:11.497	info	(16269) Starting creating snapshot
                                    ring.0	2020-11-21 08:59:11.403	info	(16269) Ding Dong for Id 32387933 (on_demand, ringing)
                                    ring.0	2020-11-21 08:59:11.389	info	(16269) Ding Dong for Id 32387933 (on_demand, ringing)
                                    ring.0	2020-11-21 08:59:01.077	info	(16269) Starting Ring Device for Id 32387933
                                    ring.0	2020-11-21 08:58:59.323	info	(16269) Starting Adapter ring.0 in version 1.1.5-beta
                                    ring.0	2020-11-21 08:58:59.260	info	(16269) starting. Version 1.1.5-beta in /opt/iobroker/node_modules/iobroker.ring, node: v10.22.1, js-controller: 3.1.6
                                    host.iob2	2020-11-21 08:58:52.779	info	instance system.adapter.ring.0 started with pid 16269
                                    C E 2 Replies Last reply Reply Quote 0
                                      ChrisXY @andyb last edited by
                                      Komisch ich bekomme livestreams gespeichert aber kein snapshot .. wenn ich es manuell auslöse hab ich folgendes im LOG:
                                      (7660) Error: Error setSanpshot()): Error: Could not create Snapshot for 49417401 in getSnapshot(). Error: Motion detection is disabled for Haustür, which prevents snapshots from this camera. This c
                                      Will ungern motion aktivieren das zieht ja nur akku .. möchte einfach ein Foto haben wenn es klingelt
                                        erniecs @andyb last edited by
                                        @andyb
                                        genau so ist es bei mir auch, wenn ich die Datei aus dem Verzeichnis raus lösche, dann speichert er 3-4 mal die Bilder, danach aktualisiert er die Datei wieder nicht mehr.
                                          erniecs @denjo last edited by
                                          Wo finde ich da die Version 1.1.5 ? Im Änderungsprotokoll steht 1.1.5 aber zum Download gibts nur 1.1.3
                                          bin etwas verwirrt
                                            mandragora last edited by mandragora
                                            Hallo und erstmals vielen Dank fürs sharen vom Blockly
                                            Ich hab noch eine kleine Frage und ein Problem damit
                                            Es werden bei mir die beiden Files angelegt.
                                            Wenn nun jemand klingelt werden neue Files erzeugt und ich bekomm die Nachrichten auch nach Telegram.
                                            Allerdings kein Bild und Video sonder nur die Pfade
                                            Was mach ich hier falsch bzw. was könnte ich hier übersehen haben ?
                                            Wäre fein wenn mir jemand auf die Sprünge helfen könnte.
                                            Vielen Dank schon mal für eure Hilfe.
                                            lg
                                            mandragora
                                            ring adapter
                                            21
                                            86
                                            12591
